amolinero Report post Posted 07/05/2004 09:03 AM Hi! I suppose this is a dummy question...anyway, i need define a brand new variable to store a number, how can i do it? Thanks! Share this post Link to post
Guest Mark Bellavance Report post Posted 07/05/2004 07:13 PM Hey amolinero, I'm not support just another user like you but I believe the easiest way would be to use the f(x). Your question is kinda open ended. Do you mean in a database you would like to store the info, was the information taken from a user with the numbers module or are you just taking a number like .6 to use as a number within the script? If its the later just insert the f(x) box, in the expression to evaluate: section enter the number or $RV (VAlue) and in the "assign result to the following result variable:" box enter what you want the variable (xxx) to be. If this is unclear check out the help files. http://www.voiceguide.com/vghelp/html/modEvalExpr.htm Hope this helped Share this post Link to post
