Guest Merzik Agaiby Report post Posted 07/05/2004 03:20 PM I have a dialogic card D/4PCI, its driver installed successfully but the voiceguide not detect it and not list it in the devices list. Share this post Link to post
SupportTeam Report post Posted 07/05/2004 10:00 PM Have you gone through all the steps as per: http://www.voiceguide.com/vghelp/html/Inst...allDialogic.htm Share this post Link to post
Guest Merzik Agaiby Report post Posted 07/06/2004 07:20 AM we do not install the TAPI driver succfully because we did not found Dialogic Generation 2 Service on the list of the TAPI provider and also when we click add we did not found it. note(we work on operating system windows XP) please replay as soon as possible. Share this post Link to post
SupportTeam Report post Posted 07/06/2004 08:42 AM Which version of Dialogic's System Release drivers are you using? Have you ensured that the "Global Call" option has been enabled when installing the SR drivers? When installing the Dialogic software select 'Custom Installation' option and ensure that the TAPI Drivers and the Global Call option is selected. Global Call needs to be installed in order for the TAPI Driver to be loaded. (as per instructions on: http://www.voiceguide.com/vghelp/html/Inst...llDialogic.htm) Share this post Link to post
Guest Merzik Agaiby Report post Posted 07/06/2004 01:20 PM We use Dialogic's System Release drivers 5.1.1 , we install it again and choose custom and select Global call. Now the Dialogic TAPI driver instilled successfully but the Voiveguide does not detect it? Note: the attach link does not work Share this post Link to post
Guest Merzik Agaiby Report post Posted 07/06/2004 02:05 PM Now the dialogic card detected in VoiceGuide but when select one port to start the script found its status "No wav driver found"? Share this post Link to post
SupportTeam Report post Posted 07/06/2004 09:23 PM Did you install the card's Wave drivers as per instructions on: http://www.voiceguide.com/vghelp/html/Inst...allDialogic.htm ? Share this post Link to post
