Guest Renato Report post Posted 07/12/2004 07:13 PM I know that I can record portuguese voice messages, but can the Voice Guide read some number, for example, in portuguese? If I ask Voice Guide to read the number '123', can I get a portuguese response? regards, Renato Medeiros Share this post Link to post
SupportTeam Report post Posted 07/12/2004 11:57 PM Just re-record the number sound files in Portuguese, see: http://www.voiceguide.com/vghelp/html/SoundFiles.htm or find a Portuguese Text-To-Speech engine and use it to say the numbers. Share this post Link to post
Guest problem persists Report post Posted 08/27/2004 03:50 PM I tried it. But I still have a problem: if I have the number 27, for example: 20.wav + 7.wav -> In this case, I can replace the sound in that files. But... If I have 200, 300...: 200 = two hundred = 2.wav + hundred.wav 300 = three hundred = 3.wav + hundred.wav In portuguese: 200 = duzentos 300 = trezentos There's no way to use the files 2 or 3 + hundred.wav to get the word "duzentos". I'm really intersted to buy the VoiceGuide, but I need to be sure it's going to work for me. Regards, Renato Medeiros Share this post Link to post
SupportTeam Report post Posted 08/27/2004 09:17 PM From: http://www.voiceguide.com/vghelp/html/modSayNumber.htm : Quote Need to change the way Say Number module speaks Amounts ? Users can edit the way in which the numbers are spoken, or even add their own Say Number functions by editing the file: lib_num2wav.vbs located in VoiceGuide's \system\vbs\ subdirectory. This is useful if it is required to say numbers/amounts in a language other then English. Please read the lib_num2wav.vbs file for more information. Share this post Link to post
