Ivg Software Hanging
On 2 occassions over the last 10 days IVG has hung whilst playing a script. By this I mean it does not return to "waiting for a call" and incomping callers after this event recieve a ringing tone which eventually rings out (no engaged).
What could be causing this instability?
Which version of VG are you using?
Could you please send us a copy of VoiceGuide's Debug Printout which
captures the problem, this will allow us to see what is going wrong.
You can save the trace to a file - please select that option. Then when problem occurs please send us the last few calls captured in that trace file - and we can then see what is going wrong on your system.
(When running the script click on VoiceGuide's View menu and select 'Event
Trace Log' option - any log information will then appear in this window. You
must open the trace window before making the call.)
