Lines Just Ring No Answer
I have 2 Dialogic PCI cards that have been working fine over the last 2 months. When I place a call to the IVR, the line just rings and rollover to the next line in the hunt group. I can see in VG that the script is running. The lines just ring and then rollover to the next line. It seems that the dialogic card is not picking up the call. I uninstalled the wave driver and reinstalled.
Here is the trace file:
041806.17 10 linedevstate 2048 0 0
041806.17 10 callstate OFFERING 65860 0 4
041806.17 10 Answer the call at 7/15/2004 4:18:06 AM
041806.20 10 lineAnswer(65860) => 65843
041806.20 10 Lev_CallerID [9013127610,]
041806.22 10 Lev_CallerID [9013127610,]
041806.22 10 callinfo CALLEDID
041806.22 10 callinfo ORIGIN
041806.22 10 ring 0
041806.75 10 callstate CONNECTED 65860,1,0
041806.75 10 WorkingModeTAPI@Connected=
041806.75 10 WorkingModeScript@Connected=
041806.78 10 Inband detection not enabled
041806.78 10 StartLoadedVgs at 7/15/2004 4:18:06 AM
041806.78 10 rv add [$RV_STARTTIME]{7/15/2004 4:18:06 AM}
041806.78 10 rv add [$RV_DEVICEID]{10}
041806.78 10 rv add [$RV_CIDNAME]{}
041806.78 10 AddRVns [PathApp]{C:\Program Files\VoiceGuide\}
041806.80 10 rv add [$RV_CIDNUMBER]{9013127610}
041806.80 10 tapi Reply (LineEvReply) ok 65843 0
041806.80 10 callinfo MONITORMODES
041806.80 10 TimeoutClear
041806.80 10 [Welcome] Playing
041806.80 10 [Welcome] Playing (C:\wave files\Marsha\welcome.wav)
041806.83 10 PlaySoundStart ok [C:\wave files\Marsha\welcome.wav]
041806.83 10 TimeoutClear
041806.83 10 RunModule PLAY end
041806.83 10 wa(7982,90650000)
041806.83 10 callinfo MONITORMODES
041814.83 10 wb(90650000)
041814.89 10 Play End line[10] (id=906500)
041814.89 10 ScriptEventCode 8001 iLineState=1100
041814.89 10 LsPlayMsg EV_PLAY_FINISHED
041814.89 10 TimeoutSet 10 EV_TIMEOUT_HANGUP
041814.89 10 TimeoutSet 0 EV_TIMEOUT_GOTOMODULE
041814.89 10 ScriptEventCode 9002 iLineState=1101
041814.91 10 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE
041814.91 10 TimeoutClear
041814.91 10 [Main Menu] Playing
041814.91 10 [Main Menu] Playing (C:\wave files\Marsha\main2.wav)
041814.92 10 PlaySoundStart ok [C:\wave files\Marsha\main2.wav]
041814.92 10 TimeoutClear
041814.92 10 RunModule PLAY end
041814.92 10 wa(11988,91460900)
041814.94 10 callinfo MONITORMODES
041824.11 11 linedevstate 2048 0 0
041824.11 11 callstate OFFERING 65809 0 4
041824.11 11 Answer the call at 7/15/2004 4:18:24 AM
041824.16 11 lineAnswer(65809) => 65792
041824.16 11 Lev_CallerID [9013127610,]
041824.16 11 callinfo CALLEDID
041824.17 11 callinfo ORIGIN
041824.17 11 ring 0
041824.70 11 callstate CONNECTED 65809,1,0
041824.70 11 WorkingModeTAPI@Connected=
041824.70 11 WorkingModeScript@Connected=
041824.75 11 Inband detection not enabled
041824.75 11 StartLoadedVgs at 7/15/2004 4:18:24 AM
041824.75 11 rv add [$RV_STARTTIME]{7/15/2004 4:18:24 AM}
041824.75 11 rv add [$RV_DEVICEID]{11}
041824.75 11 rv add [$RV_CIDNAME]{}
041824.75 11 AddRVns [PathApp]{C:\Program Files\VoiceGuide\}
041824.75 11 rv add [$RV_CIDNUMBER]{9013127610}
041824.76 11 tapi Reply (LineEvReply) ok 65792 0
041824.76 11 callinfo MONITORMODES
041824.76 11 TimeoutClear
041824.76 11 [Welcome] Playing
041824.76 11 [Welcome] Playing (C:\wave files\Marsha\welcome.wav)
041824.80 11 PlaySoundStart ok [C:\wave files\Marsha\welcome.wav]
041824.80 11 TimeoutClear
041824.80 11 RunModule PLAY end
041824.80 11 wa(7982,92446800)
041824.80 11 callinfo MONITORMODES
041827.00 10 Play End line[10] (id=914609)
041827.00 10 ScriptEventCode 8001 iLineState=1100
041827.00 10 LsPlayMsg EV_PLAY_FINISHED
041827.00 10 TimeoutSet 15 EV_TIMEOUT_REPLAYMSG
041832.84 11 wb(92446800)
041832.91 11 Play End line[11] (id=924468)
041832.91 11 ScriptEventCode 8001 iLineState=1100
041832.91 11 LsPlayMsg EV_PLAY_FINISHED
041832.91 11 TimeoutSet 10 EV_TIMEOUT_HANGUP
041832.92 11 TimeoutSet 0 EV_TIMEOUT_GOTOMODULE
041832.92 11 ScriptEventCode 9002 iLineState=1101
041832.92 11 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE
041832.92 11 TimeoutClear
041832.92 11 [Main Menu] Playing
041832.92 11 [Main Menu] Playing (C:\wave files\Marsha\main2.wav)
041832.94 11 PlaySoundStart ok [C:\wave files\Marsha\main2.wav]
041832.94 11 TimeoutClear
041832.94 11 RunModule PLAY end
041832.95 11 wa(11988,93264000)
041832.95 11 callinfo MONITORMODES
041836.44 0 btn Hangup on line 10
041836.44 10 ScriptEventCode 9001 iLineState=1101
041836.44 10 LsPlayMsgFinished EV_TIMEOUT_HANGUP
041836.45 10 rv add [Hangup Time]{7/15/2004 4:18:36 AM}
041836.45 10 Hanging up call...
041836.45 10 RecSoundStop ok
041836.45 10 PlaySoundStop err=0
041836.45 10 TimeoutSet 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
041836.45 10 fnHangupCall end
041836.50 10 linedevstate 2048 0 0
041836.50 10 callstate IDLE 65860 0 0
041836.50 10 WorkingMode@Idle=
041836.50 10 TimeoutClear
041836.51 10 TimeoutSet 1 EV_TIMEOUT_TIMETOREINITLINE
041836.51 10 tapi Reply (LineEvReply) ok 65791 0
041837.51 10 Timer fired EV_TIMEOUT_TIMETOREINITLINE
041837.51 10 ScriptEventCode 9008 iLineState=900
041837.51 10 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
041837.51 10 ReinitTelephony due to IDLE
041837.51 10 tapic lineDeallocateCall(MainCall:65860) 0
041837.69 10 lineOpen(10)=>
041837.69 10 Waiting for a call...
041837.69 10 LineHandle=65774
041837.70 10 TimeoutSet 3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
041839.91 0 btn Hangup on line 11
041839.92 11 ScriptEventCode 9001 iLineState=1100
041839.92 11 LsPlayMsg EV_TIMEOUT_HANGUP
041839.92 11 rv add [Hangup Time]{7/15/2004 4:18:39 AM}
041839.92 11 Hanging up call...
041839.92 11 RecSoundStop ok
041839.98 11 PlaySoundStop err=0
041839.98 11 TimeoutSet 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
041839.98 11 fnHangupCall end
041840.03 11 linedevstate 2048 0 0
041840.03 11 callstate IDLE 65809 0 0
041840.03 11 WorkingMode@Idle=
041840.03 11 TimeoutClear
041840.03 11 TimeoutSet 1 EV_TIMEOUT_TIMETOREINITLINE
041840.05 11 tapi Reply (LineEvReply) ok 65740 0
041840.98 10 Timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
041840.98 10 ScriptEventCode 9013 iLineState=900
041841.09 11 Timer fired EV_TIMEOUT_TIMETOREINITLINE
041841.09 11 ScriptEventCode 9008 iLineState=900
041841.09 11 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
041841.09 11 ReinitTelephony due to IDLE
041841.09 11 tapic lineDeallocateCall(MainCall:65809) 0
041841.25 11 lineOpen(11)=>
041841.26 11 Waiting for a call...
041841.26 11 LineHandle=65723
041841.26 11 TimeoutSet 3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
041844.55 11 Timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
041844.55 11 ScriptEventCode 9013 iLineState=900
From what this tells me VG is detecting the call and running the script but nothing happens on the line but unanswered ring. After 4 rings it moves on to the next line in the hunt group, and so on and so on. thru all 8 lines.
Trace shows that VoiceGuide answers the call and plays a sound file.
The Dialogic card responds like it has answered the call OK.
If the call has not in fact been answered then maybe there is something wrong with the card's line interface circuitry - but it is a bit strange that all the ports' line interfaces have failed...
I'd try plugging the lines into normal phones and see if picking up the ringing handset answers the call OK.
The roll-over during the same call, or do you have to make another call?
