Number Capture
How do i capture the phone number on which the call has been made. I have 4 different lines whicg are being used for inbound calling. How do i capture as to which phone number was called?
If each telephone number comes in on its own separate line then you just run a different script on each line.
If the call to each number can arrive on any of the 4 lines then the PBX (or the phone company) needs to send through the info as inband signaling. You can set this up with most PBX but not with many phone companies.
For determining number dialed by caller you really need to use digital ISDN (T1 or E1) lines.
