Text To Speech -- Chinese
I modified a script and get my application working.
But I need the text-to-speech to use the Chinese engine,
to say the numbers in Chinese. I installed the SAPI language pak,
but how do I let VG to select the engine to use?
If you can find a Chinese TTS engine then just install it on your machine and select in SAPI config to make this your default engine. VG uses whatever TTS engine is selected as the default TTS engine.
To just say the numbers though you may re-record the sound files in VG's \system\voice\ subdirectory and then the "Say Numbers" module will use the sound files recorded by you when trying to say numbers/dates etc.
