Dialogic 4pci And Xp
We are upgrading our machines and operating systems.
I have gone through all the install procedures for installation of the modem, uploading
Dialogic 5.1.1
Waver drivers
TAPI drivers
But I get a LINEERR_RESOURCEUNAVAIL error against all 4 channels when I try to run a script.
Any ideas.
Also, XP does not recognise the modem, I was about to use the example provided for win2000/nt but was not sure.
Can anyone help.
Vatsal
Have you ran the VoiceGuide Configuration Wizard? Did that allow you to select the 4 Dialogic line devices with no problems?
Yes,
The configured displayed the 4 analog lines that were available, which I duely selected etc.
As a secondary check, I tried the horoscope sample program that came with the dialogic driver download, and got
"Failed to open dxxxB1"
"Please make sure your drivers are properly installed"
Yet I am convinced I installed the drivers correctly, as I followed the same procedure as the first machine I confirgured, although it was a Win2000 operating system.
I am completely at a loss as to what to do next.
Vatsal
I managed to find the fault, the drivers had not been installed properly.
Simply went into device manager reinstalled the drivers
As easy as pie, when you know how
Vatsal
