Script Loading Using Cid
I want to know If it's possible to have a script that IF it is THIS phone number on CID, then use a different script for that call, and IF NOT, run the current script.
thanks.
Anthony.
If I understand you correctly, yeah thats easy. Just use the evaluate expression.
put the $RV_CIDNUMBER in the box and in the paths, enter the phone numbers which you would like to go to the diffrent script module. {5082322221}goto whatever..
check out the help file under F(x) it has an example of what you are looking for.
http://www.voiceguide.com/vghelp/html/modEvalExpr.htm
