Guest Steve Report post Posted 08/02/2004 01:47 AM Hi, I've been trying to follow the transfer of variables from VB scripts into other modules but don't seen to be having any luck. The script will read dtmf tiones from an sql server stored procedure, but for now, I'm just trying to pass a test string. I am running the evaluation version of the application - but the specs don't appear to indicate that this is excluded from this version. The first VBScript module just consists of: Quote dim vg set vg = CreateObject("VoiceGuide.CommandLink") vg.Run_ResultReturn $RV_LINEID, "[NewDTMF]{12121212}" set vg = Nothing And on success, this modules goes to a 'play sound file' module where the 'sound file to play' field contains: $RV[NewDTMF] However, when run from the dialer, it will call but no tones are sent. Further, from the event log: Quote .. .. 024018.33 8 Live person answered, starting C:\Program Files\VoiceGuide\Scripts\qqqq.vgs 024018.36 2 tr NewVgsVgm_Goto C:\Program Files\VoiceGuide\Scripts\qqqq.vgs,,,,,0 024018.38 8 rv add [scriptEnd_Time]{02/08/2004 02:40:18} 024018.41 8 rv add [scriptEnd_Goto_Script]{C:\Program Files\VoiceGuide\Scripts\qqqq.vgs} 024018.44 8 rv add [scriptEnd_Goto_Module]{} 024018.47 8 rv add [scriptStart_Time]{02/08/2004 02:40:18} 024018.50 8 rv add [scriptStart_CalledFrom_Module]{Play 2} 024018.52 0 LoadedVgs_Find C:\Program Files\VoiceGuide\Scripts\qqqq.vgs at idx=2 024018.55 8 AddRVns [scriptsPath]{C:\Program Files\VoiceGuide\Scripts\} 024018.58 8 AddRVns [scriptPath]{C:\Program Files\VoiceGuide\Scripts} 024018.61 8 cl NewVgsVgm_RunModule module not found: 024018.98 8 timer clear 024019.02 8 [Play 2] Playing 024019.06 8 rv replace start: [$RV[NewDTMF]] 024019.11 8 rv ns none[OutDial_RetriesLeft]{2}[OutDial_Result]{Contacted_Human}[scriptEnd_Time]{02/08/2004 02:40:18}[scriptEnd_Goto_Script]{C:\Program Files\VoiceGuide\Scripts\qqqq.vgs}[scriptEnd_Goto_Module]{}[scriptStart_Time]{02/08/2004 02:40:18}[scriptStart_CalledFrom_Module]{Play 2}[scriptsPath]{C:\Program Files\VoiceGuide\Scripts\}[scriptPath]{C:\Program Files\VoiceGuide\Scripts} 024019.17 8 rv replace end: [] 024019.20 8 [Play 2] Playing () 024019.23 8 ScriptEventCode 8001 iLineState=1100 024019.27 8 LsPlayMsg EV_PLAY_FINISHED 024019.30 8 timer set 5 EV_TIMEOUT_REPLAYMSG 024019.33 8 RunModule PLAY end .. .. Where the lines: Quote 024019.17 8 rv replace end: [] 024019.20 8 [Play 2] Playing () again show the variable isn't being transferred. Does anyone know what I'm doing wrong? Steve Share this post Link to post
SupportTeam Report post Posted 08/02/2004 03:41 AM Trace shows that the script is set to begin at module [Play 2] - so it is not even running the VB Script module from within which you are setting the RV. In Script Designer go to "Edit"->"Script Properties" menu and select the module from which you'd like the script to start. (Which version of VG are you running?) Share this post Link to post
Guest lorer Report post Posted 08/03/2004 10:46 AM I use VBscripts frequently throughout my 200+ module VG-script. The way I pass variables out of a VBscript module to be used in subseq. modules is as follows: I define my own function in each VBscript, and this doesn't change: function WriteResultFile(strResult) const ForReading=1, ForWriting=2, ForAppending=8 Dim filename, fso, ts, outdata, outdata2, outdata3 filename = "VGRUNRESULT_$RV_DEVICEID.TXT" set fso = CreateObject("Scripting.FileSystemObject") set ts = fso.OpenTextFile(filename, ForWriting, True) ts.WriteLine(strResult) ts.Close WriteResultFile = 0 end function Then towards the end of the main script I issue a call to this function with the set of variables as the param: strResultVariables="[LookUpPwd_1_1]{" & v_cust_id & "}[addnewtel]{1}[getNewCustMaxKontor_2_1]{0}[kk_son4]{" & cc_num_d & "}" 'msgbox strResultVariables iRet = WriteResultFile(strResultVariables) hope this helps. == LEVENT == Share this post Link to post
Guest Steve Report post Posted 08/03/2004 12:23 PM Thanks folks, working now. Share this post Link to post
SupportTeam Report post Posted 08/05/2004 07:50 AM Just a note: Levent returns results using the "Result File" which is then read in by VoiceGuide. This reading in of result file may take up to about half a second to complete. The Run_ResultReturn COM function returns data to VoiceGuide instantaneously. Share this post Link to post
Guest fsoudbakhsh Report post Posted 09/12/2004 06:38 AM can some one help me to poke following prometers <user>: <vendor>: <partner>: <password>: <hostAddress>: via VG script into the bellow VB script and run it? This VB script is located out of the VG script. I am not sure how to use DDE, Run Program, or VB script module to poke the above date into the VB script. And I don’t have any VB programming experience. Any help would be appreciated. Thanks Private Sub Command1_Click() Dim client As Object Dim strParm As String Dim Ctx1 As Long Dim Response As String ' gray out the send button so two transaction can't go ' out at the same time Command1.Enabled = False ' create the PNCOMClient component Set client = CreateObject("PFProCOMControl.PFProCOMControl.1") strParm = ParmList.Text strLength = Len(strParm) Ctx1 = client.CreateContext(HostAddress.Text, HostPort.Text, Timeout.Text, "", 0, "", "") Response = client.SubmitTransaction(Ctx1, ParmList.Text, Len(ParmList.Text)) TranOutput.AddItem Response client.DestroyContext (Ctx1) TranOutput.AddItem " " ' Free the save button for another transaction Command1.Enabled = True End Sub Share this post Link to post
SupportTeam Report post Posted 09/12/2004 07:06 AM Just run the VBScript from within a "Run VBScript" module, and then just use teh relevant Result Variables within the script... Share this post Link to post
Guest fsoudbakhsh Report post Posted 09/12/2004 03:08 PM Here is the log file when I run the previous VB script in VG file. also please see the error picture attached file that VG is displaying when VG module is runes. Any suggestion I clear this error? 080257.45 6 callstate CONNECTED 65999,1,0 080257.47 6 WorkingModeTAPI@Connected= 080257.47 6 WorkingModeScript@Connected= 080257.50 6 Inband detection not enabled 080257.50 6 StartLoadedVgs at 9/12/2004 8:02:57 AM 080257.50 6 AddRVns [scriptsPath]{C:\Program Files\ivg\Scripts\PBPScript\test\} 080257.50 6 AddRVns [scriptPath]{C:\Program Files\ivg\Scripts\PBPScript\test} 080257.50 6 rv add [$RV_STARTTIME]{9/12/2004 8:02:57 AM} 080257.52 6 rv add [$RV_DEVICEID]{6} 080257.52 6 rv add [$RV_CIDNAME]{} 080257.52 6 AddRVns [PathApp]{C:\Program Files\VoiceGuide\} 080257.52 6 rv add [$RV_CIDNUMBER]{} 080257.52 6 tapi Reply (LineEvReply) ok 66000 0 080257.52 6 timer clear 080257.52 6 [Run VB Script 1] Running VB Script... 080257.53 6 eng copy of script ran: vbs_6_1.vbs 080257.56 6 Run Script waiting... (shellid=2156, process=152) 080257.56 6 timer set 1 EV_TIMEOUT_CHECKONSTATE 080257.56 6 callinfo MONITORMODES 080258.55 6 timer fired EV_TIMEOUT_CHECKONSTATE 080258.55 6 ScriptEventCode 9007 iLineState=1501 080258.55 6 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE 080258.55 6 task still running (shellid=2156, process=152) 080258.56 6 timer set 1 EV_TIMEOUT_CHECKONSTATE 080259.66 6 timer fired EV_TIMEOUT_CHECKONSTATE 080259.66 6 ScriptEventCode 9007 iLineState=1501 080259.66 6 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE 080259.66 6 task still running (shellid=2156, process=152) 080259.67 6 timer set 1 EV_TIMEOUT_CHECKONSTATE 080300.77 6 timer fired EV_TIMEOUT_CHECKONSTATE 080300.77 6 ScriptEventCode 9007 iLineState=1501 080300.77 6 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE 080300.77 6 task still running (shellid=2156, process=152) 080300.78 6 timer set 1 EV_TIMEOUT_CHECKONSTATE 080301.88 6 timer fired EV_TIMEOUT_CHECKONSTATE 080301.88 6 ScriptEventCode 9007 iLineState=1501 080301.88 6 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE 080301.88 6 task still running (shellid=2156, process=152) 080301.89 6 timer set 1 EV_TIMEOUT_CHECKONSTATE 080302.98 6 timer fired EV_TIMEOUT_CHECKONSTATE 080302.98 6 ScriptEventCode 9007 iLineState=1501 080302.98 6 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE 080302.98 6 task still running (shellid=2156, process=152) 080303.00 6 timer set 1 EV_TIMEOUT_CHECKONSTATE 080304.09 6 timer fired EV_TIMEOUT_CHECKONSTATE 080304.09 6 ScriptEventCode 9007 iLineState=1501 080304.09 6 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE 080304.11 6 task still running (shellid=2156, process=152) 080304.11 6 timer set 1 EV_TIMEOUT_CHECKONSTATE 080305.03 0 btn Hangup on line 6 Share this post Link to post
SupportTeam Report post Posted 09/12/2004 11:56 PM Looks like the error is right at the beginning of your VBScript - did you have a look at the line number mentioned in the error message and see what could be causing this error? You may want to ask a programmer who knows VBScript to take a look at it for you - they should be able to tell you where the error is. If you are stuck please post the VoiceGuide script which produces this error and we can take a quick look at it for you. Share this post Link to post
Guest fsoudbakhsh Report post Posted 09/13/2004 03:46 AM I am stuck. thank you for helping me on this problem. Please find my VG script attached. I have not enter the Result Variables into the VB script yet, because I don't know whether I have to input the result variable into the "params.txt" or into the VB script. Your advice on this part would be appreciated too. DepositCashInDisposalCard.vgs Share this post Link to post
SupportTeam Report post Posted 09/13/2004 03:50 AM The trace shows that the VBScript problem occurred in module [Run VB Script 1], yet the attached script does not even have a module with that name... Share this post Link to post
Guest fsoudbakhsh Report post Posted 09/14/2004 01:46 AM (edited) sorry, I have attached the worng file. Here is the file I use to transct the C/CNum to veisign. the script is works well out of the VG script. but when I use it inside of the VG script it give me above error. since I have no exparince with VB programing, I don't have any idea how to resulve the error. I realy faced wall, you are the only hope I have to fix this problem. Edited 09/21/2004 08:32 PM by fsoudbakhsh Share this post Link to post
SupportTeam Report post Posted 09/14/2004 04:53 AM Looking at "TransactToVerisign" module I can see that you do not know how to program in VBScript. I'd recommend speaking to a programmer to get this all sorted out for you. Share this post Link to post
Guest fsoudbakhsh Report post Posted 09/21/2004 04:45 PM I have attached my CCTransactions scripts in my privouse posts. would you please remove my script from this fourm? Thanks Share this post Link to post
