Using D/41epci As Faxcard
Hello all;
I am trying to change firmware of my card to use it as a fax card. I searched internet but I couldn't find anything. Does anyone know how to do this or an URL where I can find info?
Thanks for any help.................
I tried to use Dialogic's StandAlone Fax program to test if I can send Fax with D/41epci but it gives an error..... (I can use that program on D/4PCI-U and it works fine)
fx_open function returns 2 ( ENOENT ) when I try to open one channel on dialogic card.
description of ENOENT is :
No such file or directory; invalid device name; file or path not found. The specified file or directory does not exist or cannot be found. This message can occur whenever a specified file does not exist or a component of a path does not specify an existing directory.
So I think I should change its firmware or change settings. Can you help me about it or am I doing something wrong?
Thanks for your help.
