Program Wont Insert Data
I have a problem I hope you can help with.
I get an error on a trace log which says;
ERROR 5.1.3305 DBExecute:3134,Syntax error in INSERT INTO statement.
The SQL statement I am using is;
INSERT INTO mastertable (workordernumber , employeenumber , repairrequestedby, roomnumber , firstrepairnum , firstrepairdescription) VALUES($RV[receipt] , $RV[enteremployeeidnumber] , '$RV[Access Query 4_1_1]', $RV[askroomnumber] ,$RV[askrepaircode], '$RV[Access Query 3_1_1]')
This statement works fine in an older version of VG.
Thanks,
Jim
Please post the entire VoiceGuide script (along with the database used) and/or update to v5.2.3 of VG and then post a copy of VoiceGuide's Debug Printout which captures the problem.
ok here is what you requested
084433.29 0 callstate OFFERING 4342784 0 4
084433.29 0 ring 1
084437.30 0 ring 2
084437.30 0 Answer the call at 8/6/2004 8:44:37 AM
084437.30 0 lineAnswer(4342784) => 3
084437.30 0 tapi Reply (LineEvReply) ok 3 0
084437.30 0 callstate ACCEPTED 4342784 0 0
084437.63 0 callstate CONNECTED 4342784,0,0
084437.63 0 WorkingModeTAPI@Connected=
084437.63 0 WorkingModeScript@Connected=
084437.63 0 Inband detection not enabled
084437.63 0 StartLoadedVgs at 8/6/2004 8:44:37 AM
084437.63 0 [hello intro] Playing
084437.63 0 [hello intro] Playing (hello_intro_bi.wav)
084437.63 0 PlaySoundStart ok [C:\Roomtalk\voiceguide\Scripts\roomtalk script\hello_intro_bi.wav]
084437.63 0 RunModule PLAY end
084442.08 0 dtmf 1 (4342784,49,2)
084442.08 0 LsPlayMsg 1
084442.13 0 PlaySoundStop ok
084442.13 0 [Run VB Script 1] Running VB Script...
084442.13 0 RVreplace start (strlen>100)
084442.13 0 Run Script waiting... (shellid=-408113, process=256)
084443.18 0 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
084443.18 0 task completed (shellid=-408113, process=256)
084443.18 0 Found result file: C:\Roomtalk\voiceguide\Scripts\roomtalk script\VGRUNRESULT_0.TXT
084443.18 0 Run Results >>>[workorder] {0207190620} , [room] {422} , [repair] {504} , [repaircode] [Tub Drain} , [repaircodetwo] {Tub/Bath tile} , [employee] {102}<<<
084443.18 0 [enteremployeeidnumber] Number Input
084443.23 0 [enteremployeeidnumber] Playing (C:\roomtalk\voiceguide\Scripts\roomtalkscript\employee_code.wav)
084443.23 0 PlaySoundStart ok [C:\Roomtalk\voiceguide\Scripts\roomtalk script\employee_code.wav]
084447.02 0 dtmf 1 (4342784,49,2)
084447.02 0 LsGetNbrsPlayWelcMsg 1
084447.19 0 PlaySoundStop ok
084447.19 0 [enteremployeeidnumber] Number Input 1
084447.24 0 path {1} not found
084447.41 0 dtmf 0 (4342784,48,2)
084447.41 0 LsGetNbrsRxDigits 0
084447.41 0 [enteremployeeidnumber] Number Input 10
084447.41 0 path {10} not found
084447.74 0 dtmf 2 (4342784,50,2)
084447.74 0 LsGetNbrsRxDigits 2
084447.74 0 [enteremployeeidnumber] Number Input 102
084447.74 0 path {102} not found
084447.74 0 [Access Query 6] DB Query
084447.74 0 Jet mode used (To use ODBC mode specify ODBC Connect string)
084447.74 0 RVreplace start: [sELECT employeenumber FROM employeetable WHERE employeenumber = $RV[enteremployeeidnumber]]
084447.74 0 RVreplace end: [sELECT employeenumber FROM employeetable WHERE employeenumber = 102]
084447.79 0 About to execute Retrieve Operation [sELECT employeenumber FROM employeetable WHERE employeenumber = 102]
084447.79 0 [Access Query 6] row count=1
084447.85 0 [Access Query 4] DB Query
084447.85 0 Jet mode used (To use ODBC mode specify ODBC Connect string)
084447.85 0 RVreplace start: [sELECT (employeename) FROM employeetable WHERE employeenumber = $RV[enteremployeeidnumber]]
084447.85 0 RVreplace end: [sELECT (employeename) FROM employeetable WHERE employeenumber = 102]
084447.85 0 About to execute Retrieve Operation [sELECT (employeename) FROM employeetable WHERE employeenumber = 102]
084447.85 0 [Access Query 4] row count=1
084447.85 0 [askroomnumber] Number Input
084447.85 0 [askroomnumber] Playing (C:\roomtalk\voiceguide\Scripts\roomtalkscript\Ask_room_number.wav)
084447.90 0 PlaySoundStart ok [C:\Roomtalk\voiceguide\Scripts\roomtalk script\Ask_room_number.wav]
084450.48 0 dtmf 4 (4342784,52,2)
084450.48 0 LsGetNbrsPlayWelcMsg 4
084450.54 0 PlaySoundStop ok
084450.54 0 [askroomnumber] Number Input 4
084450.54 0 path {4} not found
084450.87 0 dtmf 2 (4342784,50,2)
084450.87 0 LsGetNbrsRxDigits 2
084450.87 0 [askroomnumber] Number Input 42
084450.87 0 path {42} not found
084451.09 0 dtmf 2 (4342784,50,2)
084451.09 0 LsGetNbrsRxDigits 2
084451.09 0 [askroomnumber] Number Input 422
084451.09 0 path {422} not found
084457.68 0 LsGetNbrsRxDigits EV_TIMEOUT_ENTERDATA
084457.68 0 path {422} not found
084457.68 0 [Access Query 5] DB Query
084457.68 0 Jet mode used (To use ODBC mode specify ODBC Connect string)
084457.68 0 RVreplace start: [sELECT roomnumber FROM roomnumberstable WHERE roomnumber = $RV[askroomnumber]]
084457.68 0 RVreplace end: [sELECT roomnumber FROM roomnumberstable WHERE roomnumber = 422]
084457.68 0 About to execute Retrieve Operation [sELECT roomnumber FROM roomnumberstable WHERE roomnumber = 422]
084457.68 0 [Access Query 5] row count=1
084457.68 0 [askrepaircode] Number Input
084457.68 0 [askrepaircode] Playing (C:\roomtalk\voiceguide\Scripts\roomtalkscript\enter_repair_code_num.wav)
084457.73 0 PlaySoundStart ok [C:\Roomtalk\voiceguide\Scripts\roomtalk script\enter_repair_code_num.wav]
084500.97 0 dtmf 1 (4342784,49,2)
084500.97 0 LsGetNbrsPlayWelcMsg 1
084500.97 0 PlaySoundStop ok
084500.97 0 [askrepaircode] Number Input 1
084500.97 0 path {1} not found
084502.73 0 dtmf 0 (4342784,48,2)
084502.73 0 LsGetNbrsRxDigits 0
084502.73 0 [askrepaircode] Number Input 10
084502.73 0 path {10} not found
084503.34 0 dtmf 1 (4342784,49,2)
084503.34 0 LsGetNbrsRxDigits 1
084503.34 0 [askrepaircode] Number Input 101
084503.34 0 path {101} not found
084503.34 0 [Access Query 2] DB Query
084503.34 0 Jet mode used (To use ODBC mode specify ODBC Connect string)
084503.39 0 RVreplace start: [sELECT repaircodenumber FROM repaircodetable WHERE repaircodenumber = $RV[askrepaircode]]
084503.39 0 RVreplace end: [sELECT repaircodenumber FROM repaircodetable WHERE repaircodenumber = 101]
084503.39 0 About to execute Retrieve Operation [sELECT repaircodenumber FROM repaircodetable WHERE repaircodenumber = 101]
084503.39 0 [Access Query 2] row count=1
084503.39 0 [Access Query 3] DB Query
084503.39 0 Jet mode used (To use ODBC mode specify ODBC Connect string)
084503.39 0 RVreplace start: [sELECT (repaircodedescription) FROM repaircodetable WHERE repaircodenumber = $RV[askrepaircode]]
084503.39 0 RVreplace end: [sELECT (repaircodedescription) FROM repaircodetable WHERE repaircodenumber = 101]
084503.39 0 About to execute Retrieve Operation [sELECT (repaircodedescription) FROM repaircodetable WHERE repaircodenumber = 101]
084503.39 0 [Access Query 3] row count=1
084503.39 0 [printpath] Evaluate [($RV[askrepaircode]) = 100]
084503.39 0 RVreplace start: [($RV[askrepaircode]) = 100]
084503.45 0 RVreplace end: [(101) = 100]
084503.45 0 .Eval((101) = 100)
084503.45 0 Eval Expr result:[False]
084503.45 0 [repairtwo] Playing
084503.45 0 [repairtwo] Playing (C:\roomtalk\voiceguide\Scripts\roomtalkscript\enter_repair_code_number_two.wav)
084503.50 0 PlaySoundStart ok [C:\Roomtalk\voiceguide\Scripts\roomtalk script\enter_repair_code_number_two.wav]
084503.50 0 RunModule PLAY end
084507.89 0 dtmf 1 (4342784,49,2)
084507.89 0 LsPlayMsg 1
084507.89 0 PlaySoundStop ok
084507.89 0 [askrepairtwo] Number Input
084507.89 0 [askrepairtwo] Playing (C:\roomtalk\voiceguide\Scripts\roomtalkscript\enter_repair_code_num.wav)
084508.00 0 PlaySoundStart ok [C:\Roomtalk\voiceguide\Scripts\roomtalk script\enter_repair_code_num.wav]
084510.92 0 dtmf 5 (4342784,53,2)
084510.92 0 LsGetNbrsPlayWelcMsg 5
084510.92 0 PlaySoundStop ok
084510.92 0 [askrepairtwo] Number Input 5
084510.92 0 path {5} not found
084511.63 0 dtmf 0 (4342784,48,2)
084511.63 0 LsGetNbrsRxDigits 0
084511.63 0 [askrepairtwo] Number Input 50
084511.63 0 path {50} not found
084511.85 0 dtmf 0 (4342784,48,2)
084511.85 0 LsGetNbrsRxDigits 0
084511.85 0 [askrepairtwo] Number Input 500
084511.85 0 path {500} not found
084511.85 0 [Access Query 9] DB Query
084511.85 0 Jet mode used (To use ODBC mode specify ODBC Connect string)
084511.90 0 RVreplace start: [sELECT repaircodenumber FROM repaircodetable WHERE repaircodenumber = $RV[askrepairtwo]]
084511.90 0 RVreplace end: [sELECT repaircodenumber FROM repaircodetable WHERE repaircodenumber = 500]
084511.90 0 About to execute Retrieve Operation [sELECT repaircodenumber FROM repaircodetable WHERE repaircodenumber = 500]
084511.90 0 [Access Query 9] row count=1
084511.90 0 [Access Query 7] DB Query
084511.90 0 Jet mode used (To use ODBC mode specify ODBC Connect string)
084511.90 0 RVreplace start: [sELECT (repaircodedescription) FROM repaircodetable WHERE repaircodenumber = $RV[askrepairtwo]]
084511.90 0 RVreplace end: [sELECT (repaircodedescription) FROM repaircodetable WHERE repaircodenumber = 500]
084511.90 0 About to execute Retrieve Operation [sELECT (repaircodedescription) FROM repaircodetable WHERE repaircodenumber = 500]
084511.90 0 [Access Query 7] row count=1
084511.90 0 [Access Query 1] DB Query
084511.90 0 RVreplace start (strlen>100)
084511.90 0 About to execute Action Query
084512.01 0 ERROR 5.1.3305 DB Execute: 3134,Syntax error in INSERT INTO statement.
084512.01 0 Hanging up call... [srlib 282]
084512.01 0 RecSoundStop ok
084512.01 0 PlaySoundStop ok
084512.01 0 fnHangupCall end
084512.95 0 callstate IDLE 4342784 0 0
084512.95 0 WorkingMode@Idle=
084512.95 0 tapi Reply (LineEvReply) ok 4 0
084513.99 0 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
084513.99 0 ReinitTelephony due to IDLE start
084513.99 0 tapic lineDeallocateCall(MainCall:4342784) 0
084514.38 0 lineOpen(0) => 0
084514.38 0 Waiting for a call...
084514.38 0 lineOpen(0)LineHandle=4341992
090510.16 0 sys cleanup Start
090510.16 0 sys cleanup End
OK. Which version of VoiceGuide are you using right now? (plz see the "About VG" selection from the Help menu)
the version is 5.1.3302.
In case you tell me to upgrade, i need to know if upgrading will affect the license
on the version I have now?
Thanks,
jim
Please update to v5.2.3 and post trace from that version. (backup any scripts you need first!)
You will be able to use the license key from v5.1 (or v5.0) with v5.2
I dont believe I have the license key ( code nymbers) anymore . Where can I find them at on the program?
Thanks,
Jim
They are in the USERINFO.INI file - just backup that file before uninstalling Voiceguide and after installing new version just copy that file into VG's directory.
You can see from the trace that $RV[receipt] which is used in the SQL statement has not been defined earlier in the script- so it is replaced by a blank - which then causes the syntax error when trying to execute the SQL command.
Suggest checking the script to see why $RV[receipt] is not getting defined - or maybe yo should be using another RV?
145613.32  0 rv    replace start: [iNSERT INTO mastertable (workordernumber , employeenumber , repairrequestedby, roomnumber , firstrepairnum , firstrepairdescription) VALUES($RV[receipt] , $RV[enteremployeeidnumber] , '$RV[Access Query 4_1_1]', $RV[askroomnumber] ,$RV[askrepaircode], '$RV[Access Query 3_1_1]')]
145613.32  0 rv    ns [PathSysVoice]{}[PathApp]{C:\ROOMTALK\VOICEGUIDE\}[PathDataVm]{C:\ROOMTALK\VOICEGUIDE\data\}[PathVgSys]{C:\ROOMTALK\VOICEGUIDE\system\}[scriptsPath]{C:\Roomtalk\voiceguide\Scripts\roomtalk script\}[scriptPath]{C:\Roomtalk\voiceguide\Scripts\roomtalk script}[$RV_STARTTIME]{8/13/2004 2:55:35 PM}[$RV_DEVICEID]{0}[$RV_CIDNAME]{}[PathApp]{C:\ROOMTALK\VOICEGUIDE\}[$RV_CIDNUMBER]{}[hello intro]{1}[workorder]{0207190620}[room]{422}[repair]{504}[repaircode]{Tub/Bath tile}[employee]{102}[enteremployeeidnumber]{102}[enteremployeeidnumber_PathTaken
{success}[Access Query 6_RowCount]{1}[Access Query 6_1_1]{102}[Access Query 4_RowCount]{1}[Access Query 4_1_1]{Jim Benson}[askroomnumber]{422}[askroomnumber_PathTaken]{success}[Access Query 5_RowCount]{1}[Access Query 5_1_1]{422}[askrepaircode]{102}[askrepaircode_PathTaken]{success}[Access Query 2_RowCount]{1}[Access Query 2_1_1]{102}[Access Query 3_RowCount]{1}[Access Query 3_1_1]{Door Lock}[printpath_Input]{(102) = 100}[printpath]{False}[repairtwo]{2}
145613.32  0 db    About to execute a Modify type operation [iNSERT INTO mastertable (workordernumber , employeenumber , repairrequestedby, roomnumber , firstrepairnum , firstrepairdescription) VALUES( , 102 , 'Jim Benson', 422 ,102, 'Door Lock')]
