Strange Behavior - Crashing And Cutting Off Caller
Hello,
We have been using voiceguide for a few months now and have had two recurring problems I have been unable to conquer. We are using voiceguide 5.2.1006 on a windows 2000 machine with a Dialogic 4 ISA card. The first is callers being cut off ONLY while recording a message in voicemail. When callers are cut off, it is not during a period of silence, it is mid sentence, either a few seconds into the message, or sometimes after a few sentences. There is no discernable pattern I have noticed, though it happens about 4 times a week. This does not happen only on cell phone calls, or weak signals; it happens on calls of every signal strength, to speakers who speak quickly normally, and slowly. The program does NOT crash when this happens. I have attached a log file which seems to indicate a disconnect, but the caller did not actually disconnect. The second problem is random crashing. Again, there is no pattern that I have observed which causes this to happen, rather it just happens intermittently (once every few days). The machine runs nothing besides an installation of win2k, the dialogic drivers, voiceguide, norton antivirus, and foobar2000 for call hold music (these problems occurred before foobar was installed.) In response, I am considering two measures - first upgrading to windows xp, as other customers seem to have had better success with your program in XP, and second just replacing the old computer. Do you think this is more likely a hardware or a software problem, and what course of action do you suggest?
Thank you,
Seth Goldman
104719.47 5 Waiting for a call...
104719.48 5 LineHandle=65650
104719.52 5 TimeoutSet 3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
104720.04 6 Timer fired EV_TIMEOUT_TIMETOREINITLINE
104720.05 6 ScriptEventCode 9008 iLineState=900
104720.07 6 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
104720.09 6 ReinitTelephony due to IDLE
104720.11 6 tapic lineDeallocateCall(MainCall:65734) 0
104720.75 6 lineOpen(6)=>
104720.77 6 Waiting for a call...
104720.79 6 LineHandle=65871
104720.83 6 TimeoutSet 3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
104723.35 5 Timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
104723.37 5 ScriptEventCode 9013 iLineState=900
104723.89 6 Timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
104723.91 6 ScriptEventCode 9013 iLineState=900
104909.25 0 sys cleanup Start
104909.27 0 sys cleanup End
105656.92 5 linedevstate 2048 0 0
105656.98 5 callstate OFFERING 65683 0 4
105657.00 5 No old processes from last call (could not obtain handle) 864, 1780
105657.02 5 Answer the call at 8/11/2004 10:56:57 AM
105657.04 5 lineAnswer(65683) => 65752
105657.11 5 callinfo CALLEDID
105657.15 5 callinfo ORIGIN
105657.18 5 ring 0
105657.78 5 callstate CONNECTED 65683,1,0
105657.79 5 WorkingModeTAPI@Connected=
105657.81 5 WorkingModeScript@Connected=
105657.83 5 Inband detection not enabled
105657.85 5 StartLoadedVgs at 8/11/2004 10:56:57 AM
105657.87 5 rv add [$RV_STARTTIME]{8/11/2004 10:56:57 AM}
105657.88 5 rv add [$RV_DEVICEID]{5}
105657.90 5 rv add [$RV_CIDNAME]{}
105657.92 5 AddRVns [PathApp]{C:\Program Files\VoiceGuide\}
105657.94 5 rv add [$RV_CIDNUMBER]{}
105657.97 5 tapi Reply (LineEvReply) ok 65752 0
105658.01 5 callinfo MONITORMODES
105658.03 5 TimeoutClear
105658.04 5 [Office Hours Check] Evaluate [((($RV_DAY >= 1) and ($RV_DAY <= 4)) and (($RV_HOUR >= 9) and ($RV_HOUR < 17))) or ((($RV_DAY = 5) or ($RV_DAY = 7)) and (($RV_HOUR >= 9) and ($RV_HOUR < 13))) or $RV_LINEID = 8]
105658.06 5 RVreplace start: [((($RV_DAY >= 1) and ($RV_DAY <= 4)) and (($RV_HOUR >= 9) and ($RV_HOUR < 17))) or ((($RV_DAY = 5) or ($RV_DAY = 7)) and (($RV_HOUR >= 9) and ($RV_HOUR < 13))) or $RV_LINEID = 8]
105658.08 5 RVns [PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[$RV_STARTTIME]{8/11/2004 10:56:57 AM}[$RV_DEVICEID]{5}[$RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[$RV_CIDNUMBER]{}
105658.10 5 .Eval((((3 >= 1) and (3 <= 4)) and ((10 >= 9) and (10 < 17))) or (((3 = 5) or (3 = 7)) and ((10 >= 9) and (10 < 13))) or 5 = 8)
105658.12 5 rv add [Office Hours Check_Input]{(((3 >= 1) and (3 <= 4)) and ((10 >= 9) and (10 < 17))) or (((3 = 5) or (3 = 7)) and ((10 >= 9) and (10 < 13))) or 5 = 8}
105658.13 5 rv add [Office Hours Check]{True}
105658.15 5 Eval Expr result:[True]
105658.17 5 TimeoutClear
105658.19 5 [Attend] Number Input
105658.21 5 [Attend] Playing (Attend.wav)
105658.63 5 PlaySoundStart ok [C:\Program Files\VoiceGuide\Scripts\Voicemail\Attend.wav]
105658.64 5 TimeoutClear
105658.70 5 wa(37412,57625500)
105658.73 5 callinfo MONITORMODES
105718.51 5 dtmf 1 (65683,49,2)
105718.53 5 ScriptEventCode 49 iLineState=1300
105718.54 5 LsGetNbrsPlayWelcMsg 1
105718.71 5 PlaySoundStop err=0
105718.73 5 [Attend] Number Input 1
105718.75 5 rv add [Attend]{1}
105718.97 5 TimeoutClear
105718.99 5 [Office] Number Input
105719.01 5 [Office] Playing (Staff.wav)
105719.36 5 PlaySoundStart ok [C:\Program Files\VoiceGuide\Scripts\Voicemail\Staff.wav]
105719.38 5 TimeoutClear
105719.43 5 wa(35048,59706500)
105719.47 5 callinfo MONITORMODES
105729.88 5 dtmf 1 (65683,49,2)
105729.90 5 ScriptEventCode 49 iLineState=1300
105729.92 5 LsGetNbrsPlayWelcMsg 1
105730.10 5 PlaySoundStop err=0
105730.12 5 [Office] Number Input 1
105730.14 5 rv add [Office]{1}
105730.31 5 TimeoutClear
105730.33 5 [WhoIs] Playing
105730.35 5 [WhoIs] Playing (Caller.wav)
105730.70 5 PlaySoundStart ok [C:\Program Files\VoiceGuide\Scripts\Voicemail\Caller.wav]
105730.72 5 TimeoutClear
105730.74 5 RunModule PLAY end
105730.79 5 wa(3176,60840100)
105730.82 5 callinfo MONITORMODES
105734.05 5 wb(60840100)
105734.16 5 Play End line[5] (id=608401)
105734.18 5 ScriptEventCode 8001 iLineState=1100
105734.20 5 LsPlayMsg EV_PLAY_FINISHED
105734.21 5 TimeoutSet 10 EV_TIMEOUT_HANGUP
105734.23 5 TimeoutSet 0 EV_TIMEOUT_GOTOMODULE
105734.25 5 ScriptEventCode 9002 iLineState=1101
105734.27 5 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE
105734.34 5 TimeoutClear
105734.34 5 [Caller] Recording
105734.70 5 PlaySoundStart ok [C:\Program Files\VoiceGuide\system\voice\beep1.wav]
105734.71 5 TimeoutClear
105734.77 5 wa(179,61239700)
105734.80 5 callinfo MONITORMODES
105735.05 5 wb(61239700)
105735.16 5 Play End line[5] (id=612397)
105735.18 5 ScriptEventCode 8001 iLineState=1200
105735.19 5 LsRecPlayBeep EV_PLAY_FINISHED
105735.21 5 RVreplace start: [$RV_LINEID.wav]
105735.23 5 RVns [PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[$RV_STARTTIME]{8/11/2004 10:56:57 AM}[$RV_DEVICEID]{5}[$RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[$RV_CIDNUMBER]{}[Office Hours Check_Input]{(((3 >= 1) and (3 <= 4)) and ((10 >= 9) and (10 < 17))) or (((3 = 5) or (3 = 7)) and ((10 >= 9) and (10 < 13))) or 5 = 8}[Office Hours Check]{True}[Attend]{1}[Office]{1}
105735.25 5 RVreplace end: [5.wav]
105735.26 5 rv add [Caller]{C:\Program Files\VoiceGuide\Scripts\Voicemail\5.wav}
105735.59 5 RecSoundStart file[C:\Program Files\VoiceGuide\Scripts\Voicemail\5.wav] ok
105735.60 5 RecFile[C:\Program Files\VoiceGuide\Scripts\Voicemail\5.wav]
105735.62 5 TimeoutSet 4 EV_TIMEOUT_GOTOMODULE
105739.66 5 Timer fired EV_TIMEOUT_GOTOMODULE
105739.68 5 ScriptEventCode 9002 iLineState=1201
105739.69 5 LsRecRecording EV_TIMEOUT_GOTOMODULE
105739.81 5 RecSoundStop ok
105739.83 5 rec length RV: Caller_RecLen100ms = 43
105739.85 5 rv add [Caller_RecLen100ms]{43}
105739.87 5 rv add [Caller_EndRecCause]{timeout}
105740.12 5 ScriptEventCode 8003 iLineState=5900
105740.19 5 TimeoutClear
105740.21 5 [CallDirect] Evaluate [$RV[Office]]
105740.23 5 RVreplace start: [$RV[Office]]
105740.24 5 RVns [PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[$RV_STARTTIME]{8/11/2004 10:56:57 AM}[$RV_DEVICEID]{5}[$RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[$RV_CIDNUMBER]{}[Office Hours Check_Input]{(((3 >= 1) and (3 <= 4)) and ((10 >= 9) and (10 < 17))) or (((3 = 5) or (3 = 7)) and ((10 >= 9) and (10 < 13))) or 5 = 8}[Office Hours Check]{True}[Attend]{1}[Office]{1}[Caller]{C:\Program Files\VoiceGuide\Scripts\Voicemail\5.wav}[Caller_RecLen100ms]{43}[Caller_EndRecCause]{timeout}
105740.26 5 RVreplace end: [1]
105740.28 5 .Eval(1)
105740.30 5 AddRVns [CallDirect_Input]{1}
105740.32 5 AddRVns [CallDirect]{1}
105740.34 5 Eval Expr result:[1]
105740.35 5 TimeoutClear
105740.38 5 TimeoutSet 0.4 EV_TIMEOUT_READYTOBEGINTRANSFER
105740.79 5 Timer fired EV_TIMEOUT_READYTOBEGINTRANSFER
105740.80 5 ScriptEventCode 9012 iLineState=1900
105740.82 5 LsXferStart EV_TIMEOUT_READYTOBEGINTRANSFER
105740.84 5 TimeoutSet 20 EV_TIMEOUT_ANNOUNCED_TRANSFER_ATTEMPT_TOOK_TOO_LONG
105740.86 5 [Miriam] Announced Transfer to 111 (Generate)
105740.89 5 tapic lineGenerateDigits(65683,!,0) => 0
105741.61 5 generate LINEGENERATETERM_DONE
105741.63 5 TimeoutSet 1 EV_TAPI_GENERATE
105742.55 5 Timer fired EV_TAPI_GENERATE
105742.57 5 ScriptEventCode 9602 iLineState=1900
105742.59 5 LsXferStart EV_TAPI_GENERATE
105742.60 5 TimeoutSet 1 EV_HOOKFLASHFINISHED
105743.62 5 Timer fired EV_HOOKFLASHFINISHED
105743.64 5 ScriptEventCode 9200 iLineState=1905
105743.65 5 LsXferPlayVts EV_HOOKFLASHFINISHED
105743.69 5 tapic lineGenerateDigits(65683,111,0) => 0
105744.16 5 generate LINEGENERATETERM_DONE
105744.18 5 TimeoutSet 1 EV_TAPI_GENERATE
105745.11 5 Timer fired EV_TAPI_GENERATE
105745.12 5 ScriptEventCode 9602 iLineState=1905
105745.14 5 LsXferPlayVts EV_TAPI_GENERATE
105745.16 5 RVreplace start: [Announce.wav, $RV[Caller]]
105745.18 5 RVns [PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[$RV_STARTTIME]{8/11/2004 10:56:57 AM}[$RV_DEVICEID]{5}[$RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[$RV_CIDNUMBER]{}[Office Hours Check_Input]{(((3 >= 1) and (3 <= 4)) and ((10 >= 9) and (10 < 17))) or (((3 = 5) or (3 = 7)) and ((10 >= 9) and (10 < 13))) or 5 = 8}[Office Hours Check]{True}[Attend]{1}[Office]{1}[Caller]{C:\Program Files\VoiceGuide\Scripts\Voicemail\5.wav}[Caller_RecLen100ms]{43}[Caller_EndRecCause]{timeout}[CallDirect_Inpu
]{1}[CallDirect]{1}
105745.20 5 RVreplace end: [Announce.wav, C:\Program Files\VoiceGuide\Scripts\Voicemail\5.wav]
105745.21 5 [Miriam] Playing (Announce.wav, C:\Program Files\VoiceGuide\Scripts\Voicemail\5.wav)
105745.86 5 PlaySoundStart ok [C:\Program Files\VoiceGuide\Scripts\Voicemail\Announce.wav,C:\Program Files\VoiceGuide\Scripts\Voicemail\5.wav]
105745.88 5 TimeoutClear
105745.93 5 wa(6108,62326201)
105745.97 5 callinfo MONITORMODES
105752.14 5 wb(62326201)
105752.24 5 Play End line[5] (id=623262)
105752.26 5 ScriptEventCode 8001 iLineState=1906
105752.28 5 LsXferPlayAnn EV_PLAY_FINISHED
105752.30 5 LsXferPlayAnn EV_TIMEOUT_REPLAYMSG
105752.31 5 RVreplace start: [Announce.wav, $RV[Caller]]
105752.33 5 RVns [PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[$RV_STARTTIME]{8/11/2004 10:56:57 AM}[$RV_DEVICEID]{5}[$RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[$RV_CIDNUMBER]{}[Office Hours Check_Input]{(((3 >= 1) and (3 <= 4)) and ((10 >= 9) and (10 < 17))) or (((3 = 5) or (3 = 7)) and ((10 >= 9) and (10 < 13))) or 5 = 8}[Office Hours Check]{True}[Attend]{1}[Office]{1}[Caller]{C:\Program Files\VoiceGuide\Scripts\Voicemail\5.wav}[Caller_RecLen100ms]{43}[Caller_EndRecCause]{timeout}[CallDirect_Inpu
]{1}[CallDirect]{1}
105752.35 5 RVreplace end: [Announce.wav, C:\Program Files\VoiceGuide\Scripts\Voicemail\5.wav]
105752.37 5 [Miriam] Playing (Announce.wav, C:\Program Files\VoiceGuide\Scripts\Voicemail\5.wav)
105752.92 5 PlaySoundStart ok [C:\Program Files\VoiceGuide\Scripts\Voicemail\Announce.wav,C:\Program Files\VoiceGuide\Scripts\Voicemail\5.wav]
105752.93 5 TimeoutClear
105752.99 5 wa(6108,63042301)
105753.02 5 callinfo MONITORMODES
105759.19 5 wb(63042301)
105759.30 5 Play End line[5] (id=630423)
105759.31 5 ScriptEventCode 8001 iLineState=1906
105759.33 5 LsXferPlayAnn EV_PLAY_FINISHED
105759.35 5 LsXferPlayAnn EV_TIMEOUT_REPLAYMSG
105759.37 5 RVreplace start: [Announce.wav, $RV[Caller]]
105759.38 5 RVns [PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[$RV_STARTTIME]{8/11/2004 10:56:57 AM}[$RV_DEVICEID]{5}[$RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[$RV_CIDNUMBER]{}[Office Hours Check_Input]{(((3 >= 1) and (3 <= 4)) and ((10 >= 9) and (10 < 17))) or (((3 = 5) or (3 = 7)) and ((10 >= 9) and (10 < 13))) or 5 = 8}[Office Hours Check]{True}[Attend]{1}[Office]{1}[Caller]{C:\Program Files\VoiceGuide\Scripts\Voicemail\5.wav}[Caller_RecLen100ms]{43}[Caller_EndRecCause]{timeout}[CallDirect_Inpu
]{1}[CallDirect]{1}
105759.40 5 RVreplace end: [Announce.wav, C:\Program Files\VoiceGuide\Scripts\Voicemail\5.wav]
105759.42 5 [Miriam] Playing (Announce.wav, C:\Program Files\VoiceGuide\Scripts\Voicemail\5.wav)
105759.99 5 PlaySoundStart ok [C:\Program Files\VoiceGuide\Scripts\Voicemail\Announce.wav,C:\Program Files\VoiceGuide\Scripts\Voicemail\5.wav]
105800.01 5 TimeoutClear
105800.07 5 wa(6108,63747301)
105800.10 5 callinfo MONITORMODES
105800.15 5 dtmf 1 (65683,49,2)
105800.16 5 ScriptEventCode 49 iLineState=1906
105800.18 5 LsXferPlayAnn 1
105800.20 5 rv add [Miriam]{1}
105800.22 5 TimeoutSet 1 EV_PLAY_FINISHED
105800.39 5 PlaySoundStop err=0
105801.46 5 Timer fired EV_PLAY_FINISHED
105801.47 5 ScriptEventCode 8001 iLineState=1906
105801.49 5 LsXferPlayAnn EV_PLAY_FINISHED
105801.52 5 ScriptEventCode 9602 iLineState=1906
105801.54 5 LsXferPlayAnn EV_TAPI_GENERATE
105801.54 5 PlayFinishCause=CallAccepted
105801.56 5 Success path not defined - hanging up (iXferType=1)
105801.59 5 TimeoutSet 1 EV_TIMEOUT_HANGUP
105802.61 5 Timer fired EV_TIMEOUT_HANGUP
105802.63 5 ScriptEventCode 9001 iLineState=1906
105802.64 5 LsXferPlayAnn EV_TIMEOUT_HANGUP
105802.66 5 rv add [Hangup Time]{8/11/2004 10:58:02 AM}
105802.68 5 Hanging up call...
105802.75 5 RecSoundStop ok
105802.82 5 PlaySoundStop err=0
105802.84 5 TimeoutSet 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
105802.98 5 fnHangupCall end
105803.02 5 linedevstate 2048 0 0
105803.05 5 callstate IDLE 65683 0 0
105803.07 5 WorkingMode@Idle=
105803.10 5 TimeoutClear
105803.16 5 TimeoutSet 1 EV_TIMEOUT_TIMETOREINITLINE
105803.19 5 tapi Reply (LineEvReply) ok 65854 0
105804.11 5 Timer fired EV_TIMEOUT_TIMETOREINITLINE
105804.13 5 ScriptEventCode 9008 iLineState=900
105804.14 5 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
105804.16 5 ReinitTelephony due to IDLE
105804.18 5 tapic lineDeallocateCall(MainCall:65683) 0
105804.89 5 lineOpen(5)=>
105804.91 5 Waiting for a call...
105804.93 5 LineHandle=66006
105804.97 5 TimeoutSet 3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
105808.00 5 Timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
105808.01 5 ScriptEventCode 9013 iLineState=900
That would be due to Dialogic card mistakenly detecting a disconnect tone during the person speaking. This fix this you'll need to specify the frequencies & cadence of the busy tone more tightly and increase the number or 'cadences' or times that the disconnect on/off tone pattern must be heard by the Dialogic card before it decides that it hears the disconnect tone.
The trace seems to show a successful announced transfer.
What is the error message displayed when the problem occurs?
Hello again, and thank you for your reply.
First, I seem to have pasted the wrong log into my last message, my apologies.
I reformatted, and installed winXP Pro on the same hardware. The random crashing hasn't happened yet (though this is only the second day of operation) os I'm hoping that problem is resolved. However, callers are getting cut off while leaving a message, just as before. I've attached two abbreviated voicemails and the log which matches the last of the two (logging was not enabled when the first was left). I tried using cooledit to identify a symptom, but it seems both callers were cut off while speaking. I've also included my dialogic/4 settings, both the PBXpert config settings and the TAPI .txt export. Any help would be greatly appreciated.
Thanks,
Seth Goldman
The hangup is around 100147.03. It says silence is the reason for hangup, but from the wavfile that was clearly not the case.
095955.52 6 linedevstate 2048 0 0
095955.59 6 callstate OFFERING 66441 0 4
095955.61 6 No old processes from last call (could not obtain handle) 2848, 1896
095955.63 6 Answer the call at 8/13/2004 9:59:55 AM
095955.65 6 lineAnswer(66441) => 66458
095955.73 6 callinfo CALLEDID
095955.77 6 callinfo ORIGIN
095955.81 6 ring 0
095956.35 6 callstate CONNECTED 66441 1 0
095956.37 6 callstate CONNECTED 66441,1,0
095956.39 6 WorkingModeTAPI@Connected=
095956.41 6 WorkingModeScript@Connected=
095956.43 6 Inband detection not enabled
095956.45 6 StartLoadedVgs at 8/13/2004 9:59:56 AM
095956.47 6 AddRVns [scriptsPath]{C:\Program Files\VoiceGuide\Scripts\Voicemail\}
095956.49 6 AddRVns [scriptPath]{C:\Program Files\VoiceGuide\Scripts\Voicemail}
095956.51 6 rv add [$RV_STARTTIME]{8/13/2004 9:59:56 AM}
095956.53 6 rv add [$RV_DEVICEID]{6}
095956.55 6 rv add [$RV_CIDNAME]{}
095956.57 6 AddRVns [PathApp]{C:\Program Files\VoiceGuide\}
095956.58 6 rv add [$RV_CIDNUMBER]{}
095956.62 6 tapi Reply (LineEvReply) ok 66458 0
095956.66 6 callinfo MONITORMODES
095956.73 6 timer clear
095956.75 6 [Office Hours Check] Evaluate [((($RV_DAY >= 1) and ($RV_DAY <= 4)) and (($RV_HOUR >= 9) and ($RV_HOUR < 17))) or ((($RV_DAY = 5) or ($RV_DAY = 7)) and (($RV_HOUR >= 9) and ($RV_HOUR < 13))) or $RV_LINEID = 8]
095956.77 6 rv replace start: [((($RV_DAY >= 1) and ($RV_DAY <= 4)) and (($RV_HOUR >= 9) and ($RV_HOUR < 17))) or ((($RV_DAY = 5) or ($RV_DAY = 7)) and (($RV_HOUR >= 9) and ($RV_HOUR < 13))) or $RV_LINEID = 8]
095956.79 6 rv ns [PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[scriptsPath]{C:\Program Files\VoiceGuide\Scripts\Voicemail\}[scriptPath]{C:\Program Files\VoiceGuide\Scripts\Voicemail}[$RV_STARTTIME]{8/13/2004 9:59:56 AM}[$RV_DEVICEID]{6}[$RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[$RV_CIDNUMBER]{}
095956.81 6 .Eval((((5 >= 1) and (5 <= 4)) and ((9 >= 9) and (9 < 17))) or (((5 = 5) or (5 = 7)) and ((9 >= 9) and (9 < 13))) or 6 = 8)
095956.82 6 rv add [Office Hours Check_Input]{(((5 >= 1) and (5 <= 4)) and ((9 >= 9) and (9 < 17))) or (((5 = 5) or (5 = 7)) and ((9 >= 9) and (9 < 13))) or 6 = 8}
095956.85 6 rv add [Office Hours Check]{True}
095956.86 6 Eval Expr result:[True]
095956.88 6 timer clear
095956.91 6 [Attend] Number Input
095956.92 6 [Attend] Playing (Attend.wav)
095956.94 6 play set playid=390281
095957.44 6 PlaySoundStart ok [Attend.wav]
095957.45 6 timer clear
095957.51 6 wa(37412,39028100)
095957.55 6 callinfo MONITORMODES
100015.83 6 dtmf 1 (66441,49,2)
100015.85 6 ScriptEventCode 49 iLineState=1300
100015.87 6 LsGetNbrsPlayWelcMsg 1
100016.05 6 PlaySoundStop err=0
100016.07 6 [Attend] Number Input 1
100016.09 6 rv add [Attend]{1}
100016.29 6 timer clear
100016.31 6 [Office] Number Input
100016.33 6 [Office] Playing (Staff.wav)
100016.35 6 play set playid=409689
100016.75 6 PlaySoundStart ok [staff.wav]
100016.77 6 timer clear
100016.83 6 wa(35048,40968900)
100016.87 6 callinfo MONITORMODES
100026.48 6 dtmf 1 (66441,49,2)
100026.50 6 ScriptEventCode 49 iLineState=1300
100026.52 6 LsGetNbrsPlayWelcMsg 1
100026.71 6 PlaySoundStop err=0
100026.72 6 [Office] Number Input 1
100026.74 6 rv add [Office]{1}
100026.95 6 timer clear
100026.96 6 [WhoIs] Playing
100026.98 6 [WhoIs] Playing (Caller.wav)
100027.00 6 play set playid=420344
100027.41 6 PlaySoundStart ok [Caller.wav]
100027.43 6 timer clear
100027.45 6 RunModule PLAY end
100027.52 6 wa(3176,42034400)
100027.55 6 callinfo MONITORMODES
100030.78 6 wb(42034400)
100030.90 6 play end current play (playid=420344)
100030.92 6 ScriptEventCode 8001 iLineState=1100
100030.94 6 LsPlayMsg EV_PLAY_FINISHED
100030.95 6 timer set 10 EV_TIMEOUT_HANGUP
100030.97 6 timer set 0 EV_TIMEOUT_GOTOMODULE
100030.99 6 ScriptEventCode 9002 iLineState=1101
100031.01 6 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE
100031.07 6 timer clear
100031.09 6 [Caller] Recording
100031.11 6 play set playid=424450
100031.52 6 PlaySoundStart ok [C:\Program Files\VoiceGuide\system\voice\beep1.wav]
100031.54 6 timer clear
100031.59 6 wa(179,42445000)
100031.63 6 callinfo MONITORMODES
100031.88 6 wb(42445000)
100032.00 6 play end current play (playid=424450)
100032.02 6 ScriptEventCode 8001 iLineState=1200
100032.04 6 LsRecPlayBeep EV_PLAY_FINISHED
100032.06 6 rv replace start: [$RV_LINEID.wav]
100032.08 6 rv ns [PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[scriptsPath]{C:\Program Files\VoiceGuide\Scripts\Voicemail\}[scriptPath]{C:\Program Files\VoiceGuide\Scripts\Voicemail}[$RV_STARTTIME]{8/13/2004 9:59:56 AM}[$RV_DEVICEID]{6}[$RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[$RV_CIDNUMBER]{}[Office Hours Check_Input]{(((5 >= 1) and (5 <= 4)) and ((9 >= 9) and (9 < 17))) or (((5 = 5) or (5 = 7)) and ((9 >= 9) and (9 < 13))) or 6 = 8}[Office Hours Check]{True}[Attend]{1}[Office]{1}
100032.10 6 rv replace end: [6.wav]
100032.12 6 rv add [Caller]{C:\Program Files\VoiceGuide\Scripts\Voicemail\6.wav}
100032.48 6 RecSoundStart file[C:\Program Files\VoiceGuide\Scripts\Voicemail\6.wav] ok
100032.51 6 RecFile[C:\Program Files\VoiceGuide\Scripts\Voicemail\6.wav]
100032.52 6 timer set 4 EV_TIMEOUT_GOTOMODULE
100036.58 6 timer fired EV_TIMEOUT_GOTOMODULE
100036.60 6 ScriptEventCode 9002 iLineState=1201
100036.62 6 LsRecRecording EV_TIMEOUT_GOTOMODULE
100036.74 6 RecSoundStop ok
100036.77 6 rec length RV: Caller_RecLen100ms = 44
100036.78 6 rv add [Caller_RecLen100ms]{44}
100036.81 6 rv add [Caller_EndRecCause]{timeout}
100037.05 6 ScriptEventCode 8003 iLineState=5900
100037.13 6 timer clear
100037.14 6 [CallDirect] Evaluate [$RV[Office]]
100037.16 6 rv replace start: [$RV[Office]]
100037.18 6 rv ns [PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[scriptsPath]{C:\Program Files\VoiceGuide\Scripts\Voicemail\}[scriptPath]{C:\Program Files\VoiceGuide\Scripts\Voicemail}[$RV_STARTTIME]{8/13/2004 9:59:56 AM}[$RV_DEVICEID]{6}[$RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[$RV_CIDNUMBER]{}[Office Hours Check_Input]{(((5 >= 1) and (5 <= 4)) and ((9 >= 9) and (9 < 17))) or (((5 = 5) or (5 = 7)) and ((9 >= 9) and (9 < 13))) or 6 = 8}[Office Hours Check]{True}[Attend]{1}[Office]{1}[Caller]{C:\Program Files\VoiceGuide\Scripts\Voicemail\6.wav}[Caller_RecLen100ms]{44}[Caller_EndRecCause]{timeout}
100037.20 6 rv replace end: [1]
100037.22 6 .Eval(1)
100037.24 6 AddRVns [CallDirect_Input]{1}
100037.26 6 AddRVns [CallDirect]{1}
100037.28 6 Eval Expr result:[1]
100037.30 6 timer clear
100037.32 6 timer set 0.4 EV_TIMEOUT_READYTOBEGINTRANSFER
100037.75 6 timer fired EV_TIMEOUT_READYTOBEGINTRANSFER
100037.77 6 ScriptEventCode 9012 iLineState=1900
100037.79 6 LsXferStart EV_TIMEOUT_READYTOBEGINTRANSFER
100037.81 6 timer set 20 EV_TIMEOUT_ANNOUNCED_TRANSFER_ATTEMPT_TOOK_TOO_LONG
100037.83 6 [Miriam] Announced Transfer to 111 (Generate)
100037.86 6 tapic lineGenerateDigits(66441,!,0) => 0
100038.58 6 generate LINEGENERATETERM_DONE
100038.60 6 timer set 1 EV_TAPI_GENERATE
100039.52 6 timer fired EV_TAPI_GENERATE
100039.54 6 ScriptEventCode 9602 iLineState=1900
100039.56 6 LsXferStart EV_TAPI_GENERATE
100039.58 6 timer set 1 EV_HOOKFLASHFINISHED
100040.61 6 timer fired EV_HOOKFLASHFINISHED
100040.63 6 ScriptEventCode 9200 iLineState=1905
100040.64 6 LsXferPlayVts EV_HOOKFLASHFINISHED
100040.68 6 tapic lineGenerateDigits(66441,111,0) => 0
100041.16 6 generate LINEGENERATETERM_DONE
100041.18 6 timer set 1 EV_TAPI_GENERATE
100042.12 6 timer fired EV_TAPI_GENERATE
100042.14 6 ScriptEventCode 9602 iLineState=1905
100042.16 6 LsXferPlayVts EV_TAPI_GENERATE
100042.18 6 rv replace start: [Announce.wav, $RV[Caller]]
100042.20 6 rv ns [PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[scriptsPath]{C:\Program Files\VoiceGuide\Scripts\Voicemail\}[scriptPath]{C:\Program Files\VoiceGuide\Scripts\Voicemail}[$RV_STARTTIME]{8/13/2004 9:59:56 AM}[$RV_DEVICEID]{6}[$RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[$RV_CIDNUMBER]{}[Office Hours Check_Input]{(((5 >= 1) and (5 <= 4)) and ((9 >= 9) and (9 < 17))) or (((5 = 5) or (5 = 7)) and ((9 >= 9) and (9 < 13))) or 6 = 8}[Office Hours Check]{True}[Attend]{1}[Office]{1}[Caller]{C:\Program Files\VoiceGuide\Scripts\Voicemail\6.wav}[Caller_RecLen100ms]{44}[Caller_EndRecCause]{timeout}[CallDirect_Inpu
]{1}[CallDirect]{1}
100042.21 6 rv replace end: [Announce.wav, C:\Program Files\VoiceGuide\Scripts\Voicemail\6.wav]
100042.23 6 [Miriam] Playing (Announce.wav, C:\Program Files\VoiceGuide\Scripts\Voicemail\6.wav)
100042.26 6 play set playid=435596
100042.99 6 PlaySoundStart ok [Announce.wav,C:\Program Files\VoiceGuide\Scripts\Voicemail\6.wav]
100043.01 6 timer clear
100043.07 6 wa(6132,43559601)
100043.11 6 callinfo MONITORMODES
100049.32 6 wb(43559601)
100049.43 6 play end current play (playid=435596)
100049.45 6 ScriptEventCode 8001 iLineState=1906
100049.47 6 LsXferPlayAnn EV_PLAY_FINISHED
100049.49 6 LsXferPlayAnn EV_TIMEOUT_REPLAYMSG
100049.51 6 rv replace start: [Announce.wav, $RV[Caller]]
100049.53 6 rv ns [PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[scriptsPath]{C:\Program Files\VoiceGuide\Scripts\Voicemail\}[scriptPath]{C:\Program Files\VoiceGuide\Scripts\Voicemail}[$RV_STARTTIME]{8/13/2004 9:59:56 AM}[$RV_DEVICEID]{6}[$RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[$RV_CIDNUMBER]{}[Office Hours Check_Input]{(((5 >= 1) and (5 <= 4)) and ((9 >= 9) and (9 < 17))) or (((5 = 5) or (5 = 7)) and ((9 >= 9) and (9 < 13))) or 6 = 8}[Office Hours Check]{True}[Attend]{1}[Office]{1}[Caller]{C:\Program Files\VoiceGuide\Scripts\Voicemail\6.wav}[Caller_RecLen100ms]{44}[Caller_EndRecCause]{timeout}[CallDirect_Inpu
]{1}[CallDirect]{1}
100049.55 6 rv replace end: [Announce.wav, C:\Program Files\VoiceGuide\Scripts\Voicemail\6.wav]
100049.57 6 [Miriam] Playing (Announce.wav, C:\Program Files\VoiceGuide\Scripts\Voicemail\6.wav)
100049.59 6 play set playid=442927
100050.21 6 PlaySoundStart ok [Announce.wav,C:\Program Files\VoiceGuide\Scripts\Voicemail\6.wav]
100050.23 6 timer clear
100050.29 6 wa(6132,44292701)
100050.32 6 callinfo MONITORMODES
100056.54 6 wb(44292701)
100056.65 6 play end current play (playid=442927)
100056.67 6 ScriptEventCode 8001 iLineState=1906
100056.69 6 LsXferPlayAnn EV_PLAY_FINISHED
100056.71 6 LsXferPlayAnn EV_TIMEOUT_REPLAYMSG
100056.73 6 rv replace start: [Announce.wav, $RV[Caller]]
100056.75 6 rv ns [PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[scriptsPath]{C:\Program Files\VoiceGuide\Scripts\Voicemail\}[scriptPath]{C:\Program Files\VoiceGuide\Scripts\Voicemail}[$RV_STARTTIME]{8/13/2004 9:59:56 AM}[$RV_DEVICEID]{6}[$RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[$RV_CIDNUMBER]{}[Office Hours Check_Input]{(((5 >= 1) and (5 <= 4)) and ((9 >= 9) and (9 < 17))) or (((5 = 5) or (5 = 7)) and ((9 >= 9) and (9 < 13))) or 6 = 8}[Office Hours Check]{True}[Attend]{1}[Office]{1}[Caller]{C:\Program Files\VoiceGuide\Scripts\Voicemail\6.wav}[Caller_RecLen100ms]{44}[Caller_EndRecCause]{timeout}[CallDirect_Inpu
]{1}[CallDirect]{1}
100056.77 6 rv replace end: [Announce.wav, C:\Program Files\VoiceGuide\Scripts\Voicemail\6.wav]
100056.79 6 [Miriam] Playing (Announce.wav, C:\Program Files\VoiceGuide\Scripts\Voicemail\6.wav)
100056.81 6 play set playid=450147
100057.44 6 PlaySoundStart ok [Announce.wav,C:\Program Files\VoiceGuide\Scripts\Voicemail\6.wav]
100057.46 6 timer clear
100057.52 6 wa(6132,45014701)
100057.56 6 callinfo MONITORMODES
100103.76 6 wb(45014701)
100103.88 6 play end current play (playid=450147)
100103.90 6 ScriptEventCode 8001 iLineState=1906
100103.92 6 LsXferPlayAnn EV_PLAY_FINISHED
100103.95 6 tapic lineGenerateDigits(66441,!,0) => 0
100104.67 6 generate LINEGENERATETERM_DONE
100104.68 6 timer set 1 EV_TAPI_GENERATE
100105.61 6 timer fired EV_TAPI_GENERATE
100105.63 6 ScriptEventCode 9602 iLineState=1906
100105.65 6 LsXferPlayAnn EV_TAPI_GENERATE
100105.67 6 eng PlayFinishCause=CallAcceptWaitTimedOut
100105.69 6 voicemail used: Scripted
100105.71 6 stack idx=1
100105.73 6 rv add [scriptStart_Time]{8/13/2004 10:01:05 AM}
100105.75 6 rv add [scriptStart_CalledFrom_Script]{C:\Program Files\VoiceGuide\Scripts\Voicemail\AutoAttendant reverse.vgs}
100105.77 6 rv add [scriptStart_CalledFrom_Module]{Miriam}
100105.79 0 LoadedVgs_Find C:\Program Files\VoiceGuide\system\vm\VmLm.vgs at idx=5
100105.80 6 AddRVns [scriptsPath]{C:\Program Files\VoiceGuide\system\vm\}
100105.83 6 AddRVns [scriptPath]{C:\Program Files\VoiceGuide\system\vm}
100105.84 6 rv add [PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}
100105.86 6 rv add [PathDataVm]{C:\Program Files\VoiceGuide\data\}
100105.88 6 rv add [PathVgSys]{C:\Program Files\VoiceGuide\system\}
100105.90 6 rv add [vmbId]{01}
100105.92 6 eng Going down Timeout path (iXferType=1)
100105.94 6 timer clear
100105.96 6 [VmLmStart] Running vb script:[VmLmHangup.vgs]
100147.69 0 LoadedVgs_Find C:\Program Files\VoiceGuide\system\vm\VmLmHangup.vgs at idx=6
100147.73 6 tapi Reply (LineEvReply) ok 65607 0
100147.75 6 timer clear
100147.77 6 [VmLmHangup_ForwardLastMsg] Running VB Script...
100147.79 6 rv replace start (strlen>500)
100147.81 6 rv ns [PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[scriptsPath]{C:\Program Files\VoiceGuide\Scripts\Voicemail\}[scriptPath]{C:\Program Files\VoiceGuide\Scripts\Voicemail}[$RV_STARTTIME]{8/13/2004 9:59:56 AM}[$RV_DEVICEID]{6}[$RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[$RV_CIDNUMBER]{}[Office Hours Check_Input]{(((5 >= 1) and (5 <= 4)) and ((9 >= 9) and (9 < 17))) or (((5 = 5) or (5 = 7)) and ((9 >= 9) and (9 < 13))) or 6 = 8}[Office Hours Check]{True}[Attend]{1}[Office]{1}[Caller]{C:\Program Files\VoiceGuide\Scripts\Voicemail\6.wav}[Caller_RecLen100ms]{44}[Caller_EndRecCause]{timeout}[CallDirect_Inpu
]{1}[CallDirect]{1}[scriptStart_Time]{8/13/2004 10:01:05 AM}[scriptStart_CalledFrom_Script]{C:\Program Files\VoiceGuide\Scripts\Voicemail\AutoAttendant reverse.vgs}[scriptStart_CalledFrom_Module]{Miriam}[scriptsPath]{C:\Program Files\VoiceGuide\system\vm\}[scriptPath]{C:\Program Files\VoiceGuide\system\vm}[PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[vmbId]{01}[Key_VmLmStopRecAndPlay]{1}[Key_VmLmDelRecRecAgain]{2}[Key_VmLm
aveAndPlayGreeting]{3}[Key_VmLmDeleteGoGroupPrevious]{4}[Key_VmLmDeleteAndPlayGr
eting]{5}[Key_VmLmDeleteGoGroupNext]{6}[Key_VmLmSaveGoVmLogin]{8}[Key_VmLmSaveVm
xit]{0}[Key_VmLmSaveGoLmRecMsgMenu]{#}[RecMessage]{}[VmbWelcMsg]{C:\Program Files\VoiceGuide\data\VmWelc\01.wav}[VmLmRecFilename]{01_0813100124_1_6__.wav}[MsgLenMax]{120}[Vmb_Name]
Miriam}[VmLmRec]{C:\Program Files\VoiceGuide\data\VmSave\01_0813100124_1_6__.wav}[VmLmRec_RecLen100ms]{181}[VmLmRec_EndRecCause]{sil
nce}[Hangup Time]{8/13/2004 10:01:47 AM}
100147.89 6 eng copy of script ran: vbs_6_3.vbs
100147.96 6 Run Script waiting... (shellid=2940, process=1896)
100147.99 6 timer set 1 EV_TIMEOUT_CHECKONSTATE
100148.35 0 cl Vm_VmbConfig_Get 01, MsgLenMin
100148.37 6 vm RecLen100ms=181, MinLength for VMB01=1
100148.39 6 cl Vm_Event 6, FORWARD, 01, C:\Program Files\VoiceGuide\data\VmSave\01_0813100124_1_6__.wav, ,
100148.42 6 vm frwrd vmb 01
100148.44 6 rv add [VoicemailMessage01]{C:\Program Files\VoiceGuide\data\VmSave\01_0813100124_1_6__.wav}
100148.46 6 AddRVns [VoicemailMessage]{C:\Program Files\VoiceGuide\data\VmSave\01_0813100124_1_6__.wav}
100148.48 6 vm frwrd vmb 01 end
100148.50 6 cl Vm_Event 6, MSG_NEW, 01, , ,
100148.53 0 DialListDB_AddCall '6311', 0, 0, 0, , 6,7,8, 1, , MSGLAMP, , , 2, 0, 0, ESCALATION:
100148.65 6 VBScript started [wscript "C:\Program Files\VoiceGuide\data\vbs_6_vm_msglamp_on_040813100148.vbs" //I //T:3600]
100148.67 6 vm msglamp_on ok
100148.71 6 cl Run_ResultReturn >>success<<
100148.73 6 rv add [VmLmHangup_ForwardLastMsg_ResultReturn]{success}
100148.76 6 path {success} not found
100148.79 6 cl module's runwait=1, WavPlayHasNowFinished=0
100148.83 6 rv add [Hangup Time]{8/13/2004 10:01:48 AM}
100148.85 6 Hanging up call... [Run_ResultReturn - no path match (same vgm)]
100148.88 6 HangupCall_Common Mode=AfterHangupRun
100148.92 6 ReinitTelephony due to IDLE
100148.97 6 tapic lineDeallocateCall(MainCall:66441) 0
100149.23 7 dial [46,6311,0,0,2359,,,6,7,8,,1,NONE,MSGLAMP,NONE,none,10,0,0,,none]
100149.26 0 dial callque update id=46 next call time 0408131003
100149.29 0 dial callque DB update returned
100149.31 7 dial found entry: tel[6311] ann[NONE] vgs[MSGLAMP] am[NONE]
100149.37 7 Dialing: 6311
100149.40 7 MakeCall => 65846
100149.42 7 timer set 10 EV_TIMEOUT_MAKECALL_NORESPONSE
100149.43 7 TapiCbTrigSet 65846 7002
100149.49 0 dial start any summary:|6:hc>0|7:dial=0|8:idx=0|9:idx=0|
100150.09 6 lineOpen(6)=>
100150.11 6 Waiting for a call...
100150.13 6 LineHandle=66188
100150.16 6 timer set 3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
100150.36 7 tapi Reply (LineEvReply) ok 65846 0
100150.38 7 TapiCbTrigClear
100150.41 7 linedevstate 2048 0 0
100150.45 7 callstate DIALTONE 66494 0 0
100150.48 7 callstate DIALING 66494 0 0
100150.52 7 callstate PROCEEDING 66494 0 0
100150.57 7 callinfo CALLEDID
100150.61 7 callinfo REASON
100150.73 7 Lev_CallerID [0000,,6311]
100150.75 7 rv add [DNIS]{6311}
100150.80 7 callinfo ORIGIN
100150.84 0 dial start any summary:|6:rdy=0|7:hc>0|8:idx=0|9:idx=0|
100151.89 0 dial start any summary:|6:rdy=0|7:hc>0|8:idx=0|9:idx=0|
100152.95 0 dial start any summary:|6:rdy=0|7:hc>0|8:idx=0|9:idx=0|
100153.52 6 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
100153.54 6 ScriptEventCode 9013 iLineState=900
100157.91 6 linedevstate 2048 0 0
100157.00 6 callstate OFFERING 66342 0 4
100158.02 6 No old processes from last call (could not obtain handle) 3716, 1896
100158.04 6 Answer the call at 8/13/2004 10:01:58 AM
100158.05 6 lineAnswer(66342) => 66069
100158.14 6 callinfo CALLEDID
100158.18 6 callinfo ORIGIN
100158.21 6 ring 0
100158.76 6 callstate CONNECTED 66342 1 0
100158.78 6 callstate CONNECTED 66342,1,0
100158.80 6 WorkingModeTAPI@Connected=
100158.82 6 WorkingModeScript@Connected=
100158.84 6 Inband detection not enabled
100158.86 6 StartLoadedVgs at 8/13/2004 10:01:58 AM
100158.88 6 AddRVns [scriptsPath]{C:\Program Files\VoiceGuide\Scripts\Voicemail\}
100158.89 6 AddRVns [scriptPath]{C:\Program Files\VoiceGuide\Scripts\Voicemail}
100158.92 6 rv add [$RV_STARTTIME]{8/13/2004 10:01:58 AM}
100158.94 6 rv add [$RV_DEVICEID]{6}
100158.96 6 rv add [$RV_CIDNAME]{}
100158.98 6 AddRVns [PathApp]{C:\Program Files\VoiceGuide\}
100158.00 6 rv add [$RV_CIDNUMBER]{}
100159.04 6 tapi Reply (LineEvReply) ok 66069 0
100159.08 6 callinfo MONITORMODES
100159.10 6 timer clear
100159.12 6 [Office Hours Check] Evaluate [((($RV_DAY >= 1) and ($RV_DAY <= 4)) and (($RV_HOUR >= 9) and ($RV_HOUR < 17))) or ((($RV_DAY = 5) or ($RV_DAY = 7)) and (($RV_HOUR >= 9) and ($RV_HOUR < 13))) or $RV_LINEID = 8]
100159.13 6 rv replace start: [((($RV_DAY >= 1) and ($RV_DAY <= 4)) and (($RV_HOUR >= 9) and ($RV_HOUR < 17))) or ((($RV_DAY = 5) or ($RV_DAY = 7)) and (($RV_HOUR >= 9) and ($RV_HOUR < 13))) or $RV_LINEID = 8]
100159.15 6 rv ns [PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[scriptsPath]{C:\Program Files\VoiceGuide\Scripts\Voicemail\}[scriptPath]{C:\Program Files\VoiceGuide\Scripts\Voicemail}[$RV_STARTTIME]{8/13/2004 10:01:58 AM}[$RV_DEVICEID]{6}[$RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[$RV_CIDNUMBER]{}
100159.17 6 .Eval((((5 >= 1) and (5 <= 4)) and ((10 >= 9) and (10 < 17))) or (((5 = 5) or (5 = 7)) and ((10 >= 9) and (10 < 13))) or 6 = 8)
100159.20 6 rv add [Office Hours Check_Input]{(((5 >= 1) and (5 <= 4)) and ((10 >= 9) and (10 < 17))) or (((5 = 5) or (5 = 7)) and ((10 >= 9) and (10 < 13))) or 6 = 8}
100159.21 6 rv add [Office Hours Check]{True}
100159.23 6 Eval Expr result:[True]
100159.26 6 timer clear
100159.28 6 [Attend] Number Input
100159.30 6 [Attend] Playing (Attend.wav)
100159.31 6 play set playid=512647
100159.79 6 PlaySoundStart ok [Attend.wav]
100159.81 6 timer clear
100159.86 6 wa(37412,51264700)
100159.91 6 callinfo MONITORMODES
100201.66 6 dtmf 1 (66342,49,2)
100201.68 6 ScriptEventCode 49 iLineState=1300
100201.70 6 LsGetNbrsPlayWelcMsg 1
100201.89 6 PlaySoundStop err=0
100201.91 6 [Attend] Number Input 1
100201.93 6 rv add [Attend]{1}
100202.17 6 timer clear
100202.19 6 [Office] Number Input
100202.21 6 [Office] Playing (Staff.wav)
100202.23 6 play set playid=515571
100202.64 6 PlaySoundStart ok [staff.wav]
100202.66 6 timer clear
100202.72 6 wa(35048,51557100)
100202.76 6 callinfo MONITORMODES
100202.78 7 timer fired EV_TIMEOUT_MAKECALL_NORESPONSE
100202.80 7 ScriptEventCode 9020 iLineState=5200
100202.82 7 LsWaitAfterDialingOut EV_TIMEOUT_MAKECALL_NORESPONSE
100202.84 0 dial callque delete id=46
100202.86 7 rv add [Hangup Time]{8/13/2004 10:02:02 AM}
100202.88 7 Hanging up call... [EV_TIMEOUT_MAKECALL_NORESPONSE]
100202.99 7 RecSoundStop ok
100203.07 7 PlaySoundStop err=0
100203.09 7 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
100203.17 7 Waiting for a call...
100203.19 7 fnHangupCall end
100203.28 7 linedevstate 2048 0 0
100203.31 7 callstate IDLE 66494 0 0
100203.34 7 WorkingMode@Idle=
100203.35 7 timer clear
100203.37 7 LineState(iLineId).iVgsIdx = 0
100203.39 7 timer set 1 EV_TIMEOUT_TIMETOREINITLINE
100203.44 7 tapi Reply (LineEvReply) ok 66513 0
100203.88 6 dtmf 4 (66342,52,2)
100203.90 6 ScriptEventCode 52 iLineState=1300
100203.93 6 LsGetNbrsPlayWelcMsg 4
100204.11 6 PlaySoundStop err=0
100204.13 6 [Office] Number Input 4
100204.14 6 rv add [Office]{4}
100204.38 6 timer clear
100204.40 6 [WhoIs] Playing
100204.43 6 [WhoIs] Playing (Caller.wav)
100204.43 6 play set playid=517774
100204.84 6 PlaySoundStart ok [Caller.wav]
100204.86 6 timer clear
100204.88 6 RunModule PLAY end
100204.93 6 wa(3176,51777400)
100204.98 6 callinfo MONITORMODES
100205.30 7 timer fired EV_TIMEOUT_TIMETOREINITLINE
100205.30 7 ScriptEventCode 9008 iLineState=900
100205.32 7 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
100205.35 7 ReinitTelephony due to IDLE
100205.38 7 tapic lineDeallocateCall(MainCall:66494) 0
100206.18 7 lineOpen(7)=>
100206.20 7 Waiting for a call...
100206.21 7 LineHandle=66154
100206.26 7 timer set 3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
100206.46 0 dial start any summary:|6:hc>0|7:rdy=0|8:idx=0|9:idx=0|
100207.51 0 dial start any summary:|6:hc>0|7:rdy=0|8:idx=0|9:idx=0|
100208.20 6 wb(51777400)
100208.32 6 play end current play (playid=517774)
100208.34 6 ScriptEventCode 8001 iLineState=1100
100208.36 6 LsPlayMsg EV_PLAY_FINISHED
100208.37 6 timer set 10 EV_TIMEOUT_HANGUP
100208.40 6 timer set 0 EV_TIMEOUT_GOTOMODULE
100208.42 6 ScriptEventCode 9002 iLineState=1101
100208.44 6 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE
100208.47 6 timer clear
100208.49 6 [Caller] Recording
100208.51 6 play set playid=521850
100208.91 6 PlaySoundStart ok [C:\Program Files\VoiceGuide\system\voice\beep1.wav]
100208.92 6 timer clear
100208.98 6 wa(179,52185000)
100209.02 6 callinfo MONITORMODES
100209.07 0 dial start any summary:|6:hc>0|7:rdy=0|8:idx=0|9:idx=0|
100209.27 6 wb(52185000)
100209.39 6 play end current play (playid=521850)
100209.41 6 ScriptEventCode 8001 iLineState=1200
100209.43 6 LsRecPlayBeep EV_PLAY_FINISHED
100209.45 6 rv replace start: [$RV_LINEID.wav]
100209.47 6 rv ns [PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[scriptsPath]{C:\Program Files\VoiceGuide\Scripts\Voicemail\}[scriptPath]{C:\Program Files\VoiceGuide\Scripts\Voicemail}[$RV_STARTTIME]{8/13/2004 10:01:58 AM}[$RV_DEVICEID]{6}[$RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[$RV_CIDNUMBER]{}[Office Hours Check_Input]{(((5 >= 1) and (5 <= 4)) and ((10 >= 9) and (10 < 17))) or (((5 = 5) or (5 = 7)) and ((10 >= 9) and (10 < 13))) or 6 = 8}[Office Hours Check]{True}[Attend]{1}[Office]{4}
100209.49 6 rv replace end: [6.wav]
100209.51 6 rv add [Caller]{C:\Program Files\VoiceGuide\Scripts\Voicemail\6.wav}
100209.89 6 RecSoundStart file[C:\Program Files\VoiceGuide\Scripts\Voicemail\6.wav] ok
100209.91 6 RecFile[C:\Program Files\VoiceGuide\Scripts\Voicemail\6.wav]
100209.92 6 timer set 4 EV_TIMEOUT_GOTOMODULE
100210.12 0 dial start any summary:|6:hc>0|7:rdy=0|8:idx=0|9:idx=0|
100210.95 7 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
100210.96 7 ScriptEventCode 9013 iLineState=900
100213.98 6 timer fired EV_TIMEOUT_GOTOMODULE
100213.00 6 ScriptEventCode 9002 iLineState=1201
100214.02 6 LsRecRecording EV_TIMEOUT_GOTOMODULE
100214.15 6 RecSoundStop ok
100214.16 6 rec length RV: Caller_RecLen100ms = 44
100214.19 6 rv add [Caller_RecLen100ms]{44}
100214.21 6 rv add [Caller_EndRecCause]{timeout}
100214.45 6 ScriptEventCode 8003 iLineState=5900
100214.53 6 timer clear
100214.55 6 [CallDirect] Evaluate [$RV[Office]]
100214.57 6 rv replace start: [$RV[Office]]
100214.59 6 rv ns [PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[scriptsPath]{C:\Program Files\VoiceGuide\Scripts\Voicemail\}[scriptPath]{C:\Program Files\VoiceGuide\Scripts\Voicemail}[$RV_STARTTIME]{8/13/2004 10:01:58 AM}[$RV_DEVICEID]{6}[$RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[$RV_CIDNUMBER]{}[Office Hours Check_Input]{(((5 >= 1) and (5 <= 4)) and ((10 >= 9) and (10 < 17))) or (((5 = 5) or (5 = 7)) and ((10 >= 9) and (10 < 13))) or 6 = 8}[Office Hours Check]{True}[Attend]{1}[Office]{4}[Caller]{C:\Program Files\VoiceGuide\Scripts\Voicemail\6.wav}[Caller_RecLen100ms]{44}[Caller_EndRecCause]{timeout}
100214.61 6 rv replace end: [4]
100214.63 6 .Eval(4)
100214.65 6 AddRVns [CallDirect_Input]{4}
100214.67 6 AddRVns [CallDirect]{4}
100214.69 6 Eval Expr result:[4]
100214.71 6 timer clear
100214.73 6 timer set 0.4 EV_TIMEOUT_READYTOBEGINTRANSFER
100215.15 6 timer fired EV_TIMEOUT_READYTOBEGINTRANSFER
100215.17 6 ScriptEventCode 9012 iLineState=1900
100215.19 6 LsXferStart EV_TIMEOUT_READYTOBEGINTRANSFER
100215.20 6 timer set 20 EV_TIMEOUT_ANNOUNCED_TRANSFER_ATTEMPT_TOOK_TOO_LONG
100215.22 6 [Rabbi] Announced Transfer to 151 (Generate)
100215.26 6 tapic lineGenerateDigits(66342,!,0) => 0
100215.98 6 generate LINEGENERATETERM_DONE
100216.00 6 timer set 1 EV_TAPI_GENERATE
100216.92 6 timer fired EV_TAPI_GENERATE
100216.94 6 ScriptEventCode 9602 iLineState=1900
100216.96 6 LsXferStart EV_TAPI_GENERATE
100216.98 6 timer set 1 EV_HOOKFLASHFINISHED
100218.00 6 timer fired EV_HOOKFLASHFINISHED
100218.02 6 ScriptEventCode 9200 iLineState=1905
100218.04 6 LsXferPlayVts EV_HOOKFLASHFINISHED
100218.09 6 tapic lineGenerateDigits(66342,151,0) => 0
100218.55 6 generate LINEGENERATETERM_DONE
100218.57 6 timer set 1 EV_TAPI_GENERATE
100219.51 6 timer fired EV_TAPI_GENERATE
100219.53 6 ScriptEventCode 9602 iLineState=1905
100219.55 6 LsXferPlayVts EV_TAPI_GENERATE
100219.57 6 rv replace start: [Announce.wav, $RV[Caller]]
100219.59 6 rv ns [PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[scriptsPath]{C:\Program Files\VoiceGuide\Scripts\Voicemail\}[scriptPath]{C:\Program Files\VoiceGuide\Scripts\Voicemail}[$RV_STARTTIME]{8/13/2004 10:01:58 AM}[$RV_DEVICEID]{6}[$RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[$RV_CIDNUMBER]{}[Office Hours Check_Input]{(((5 >= 1) and (5 <= 4)) and ((10 >= 9) and (10 < 17))) or (((5 = 5) or (5 = 7)) and ((10 >= 9) and (10 < 13))) or 6 = 8}[Office Hours Check]{True}[Attend]{1}[Office]{4}[Caller]{C:\Program Files\VoiceGuide\Scripts\Voicemail\6.wav}[Caller_RecLen100ms]{44}[Caller_EndRecCause]{timeout}[CallDirect_Inpu
]{4}[CallDirect]{4}
100219.61 6 rv replace end: [Announce.wav, C:\Program Files\VoiceGuide\Scripts\Voicemail\6.wav]
100219.63 6 [Rabbi] Playing (Announce.wav, C:\Program Files\VoiceGuide\Scripts\Voicemail\6.wav)
100219.64 6 play set playid=532986
100220.38 6 PlaySoundStart ok [Announce.wav,C:\Program Files\VoiceGuide\Scripts\Voicemail\6.wav]
100220.40 6 timer clear
100220.46 6 wa(6132,53298601)
100220.50 6 callinfo MONITORMODES
100226.70 6 wb(53298601)
100226.82 6 play end current play (playid=532986)
100226.84 6 ScriptEventCode 8001 iLineState=1906
100226.86 6 LsXferPlayAnn EV_PLAY_FINISHED
100226.87 6 LsXferPlayAnn EV_TIMEOUT_REPLAYMSG
100226.90 6 rv replace start: [Announce.wav, $RV[Caller]]
100226.92 6 rv ns [PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[scriptsPath]{C:\Program Files\VoiceGuide\Scripts\Voicemail\}[scriptPath]{C:\Program Files\VoiceGuide\Scripts\Voicemail}[$RV_STARTTIME]{8/13/2004 10:01:58 AM}[$RV_DEVICEID]{6}[$RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[$RV_CIDNUMBER]{}[Office Hours Check_Input]{(((5 >= 1) and (5 <= 4)) and ((10 >= 9) and (10 < 17))) or (((5 = 5) or (5 = 7)) and ((10 >= 9) and (10 < 13))) or 6 = 8}[Office Hours Check]{True}[Attend]{1}[Office]{4}[Caller]{C:\Program Files\VoiceGuide\Scripts\Voicemail\6.wav}[Caller_RecLen100ms]{44}[Caller_EndRecCause]{timeout}[CallDirect_Inpu
]{4}[CallDirect]{4}
100226.93 6 rv replace end: [Announce.wav, C:\Program Files\VoiceGuide\Scripts\Voicemail\6.wav]
100226.95 6 [Rabbi] Playing (Announce.wav, C:\Program Files\VoiceGuide\Scripts\Voicemail\6.wav)
100226.98 6 play set playid=540317
100227.60 6 PlaySoundStart ok [Announce.wav,C:\Program Files\VoiceGuide\Scripts\Voicemail\6.wav]
100227.62 6 timer clear
100227.68 6 wa(6132,54031701)
100227.72 6 callinfo MONITORMODES
100233.93 6 wb(54031701)
100234.04 6 play end current play (playid=540317)
100234.06 6 ScriptEventCode 8001 iLineState=1906
100234.08 6 LsXferPlayAnn EV_PLAY_FINISHED
100234.10 6 LsXferPlayAnn EV_TIMEOUT_REPLAYMSG
100234.12 6 rv replace start: [Announce.wav, $RV[Caller]]
100234.14 6 rv ns [PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[scriptsPath]{C:\Program Files\VoiceGuide\Scripts\Voicemail\}[scriptPath]{C:\Program Files\VoiceGuide\Scripts\Voicemail}[$RV_STARTTIME]{8/13/2004 10:01:58 AM}[$RV_DEVICEID]{6}[$RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[$RV_CIDNUMBER]{}[Office Hours Check_Input]{(((5 >= 1) and (5 <= 4)) and ((10 >= 9) and (10 < 17))) or (((5 = 5) or (5 = 7)) and ((10 >= 9) and (10 < 13))) or 6 = 8}[Office Hours Check]{True}[Attend]{1}[Office]{4}[Caller]{C:\Program Files\VoiceGuide\Scripts\Voicemail\6.wav}[Caller_RecLen100ms]{44}[Caller_EndRecCause]{timeout}[CallDirect_Inpu
]{4}[CallDirect]{4}
100234.16 6 rv replace end: [Announce.wav, C:\Program Files\VoiceGuide\Scripts\Voicemail\6.wav]
100234.18 6 [Rabbi] Playing (Announce.wav, C:\Program Files\VoiceGuide\Scripts\Voicemail\6.wav)
100234.20 6 play set playid=547537
100234.83 6 PlaySoundStart ok [Announce.wav,C:\Program Files\VoiceGuide\Scripts\Voicemail\6.wav]
100234.84 6 timer clear
100234.90 6 wa(6132,54753701)
100234.94 6 callinfo MONITORMODES
100238.46 6 dtmf 1 (66342,49,2)
100238.48 6 ScriptEventCode 49 iLineState=1906
100238.50 6 LsXferPlayAnn 1
100238.52 6 rv add [Rabbi]{1}
100238.54 6 timer set 1 EV_PLAY_FINISHED
100238.73 6 PlaySoundStop err=0
100239.82 6 timer fired EV_PLAY_FINISHED
100239.84 6 ScriptEventCode 8001 iLineState=1906
100239.86 6 LsXferPlayAnn EV_PLAY_FINISHED
100239.89 6 ScriptEventCode 9602 iLineState=1906
100239.91 6 LsXferPlayAnn EV_TAPI_GENERATE
100239.91 6 eng PlayFinishCause=CallAccepted
100239.93 6 eng Success path not defined - hanging up (iXferType=1)
100239.96 6 timer set 1 EV_TIMEOUT_HANGUP
100240.98 6 timer fired EV_TIMEOUT_HANGUP
100240.00 6 ScriptEventCode 9001 iLineState=1906
100241.02 6 LsXferPlayAnn EV_TIMEOUT_HANGUP
100241.04 6 rv add [Hangup Time]{8/13/2004 10:02:41 AM}
100241.06 6 Hanging up call...
100241.14 6 RecSoundStop ok
100241.21 6 PlaySoundStop err=0
100241.23 6 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
100241.39 6 fnHangupCall end
100241.44 6 linedevstate 2048 0 0
100241.48 6 callstate IDLE 66342 0 0
100241.50 6 WorkingMode@Idle=
100241.52 6 timer clear
100241.58 6 timer set 1 EV_TIMEOUT_TIMETOREINITLINE
100241.62 6 tapi Reply (LineEvReply) ok 65864 0
100242.54 6 timer fired EV_TIMEOUT_TIMETOREINITLINE
100242.55 6 ScriptEventCode 9008 iLineState=900
100242.57 6 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
100242.59 6 ReinitTelephony due to IDLE
100242.62 6 tapic lineDeallocateCall(MainCall:66342) 0
100243.39 6 lineOpen(6)=>
100243.41 6 Waiting for a call...
100243.43 6 LineHandle=66086
100243.47 6 timer set 3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
100243.88 0 dial start any summary:|6:rdy=0|7:idx=0|8:idx=0|9:idx=0|
100244.95 0 dial start any summary:|6:rdy=0|7:idx=0|8:idx=0|9:idx=0|
100246.02 0 dial start any summary:|6:rdy=0|7:idx=0|8:idx=0|9:idx=0|
100246.52 6 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
100246.55 6 ScriptEventCode 9013 iLineState=900
VMcut.zip
My dialogic PBXpert settings are attached to this post. Not - there is no formal disconnect tone sent by the PBX, a Toshiba DK-16. Only the busy signal or a loop current drop indicates hangup.
tw_16.prm
If the end of recording is made due to a false detection of Silence then you should change the VG.INI file's silence detection settings.
Please see the SilenceDetectLength and SilenceDetectLevel settings in VG.INI file.
I have adjusted the silence sensitivity from the previous value, 10, down to 3. I will post again if this does not fix the problem. Thank you for your suggestion.
I readjusted the silence detect level to 1, to maximum sensitivity, to make sure there were no false hangups. In testing, however, I was able to create a false hangup consistently when speakin softly, but not unrealistically so, into either a cellphone, or landline. The logs continue to indicate "silence", as before, as the reason for ending the call. The silence length is still set to three seconds. I've attached a few sample voicemails, one of which has a fairly loud sound less than three seconds before it hangs up. This does not seem to be simply a sensitivity problem. What do you think?
cutoffs.zip
If I am not able to resolve this false silence reporting, I'd like to disable silence monitoring only in the voicemail recording module (I'd still like to monitor while callers are elsewhere in the script), so I don't want to simply change SilenceDetectLevel to 0. If you have no other solution, can you send me a modified VM script which does not listen for silence?
Thank you
If you are using the Enterprise version of VoiceGuide then you can modify the voicemail scripts directly (see in VG's \system\vm\ subdirectory), turning off silence detection by setting the SilenceDetectLvl result variable to 0 - see: http://www.voiceguide.com/vghelp/html/modRecord.htm
Further looking at the trace we can see that it is the Dialogic card's silence detection that is at fault here - not VoiceGuide's own silence detection though.
You can disable VoiceGuide's reaction to Dialogic's silence detection by setting the following in the [PlayRecordConfig] section of VG.INI file:
SilenceDetectDialogic=off
and then restarting VoiceGuide.
Dialogic's silence detection settings are usually configurable using the .PRM file - please refer to Dialogic documentation for more info on this.
