Removal Of Tapi From Configuration
I have setup VG to use both my voice modem and my D/4PCIU. I have decided to remove the voice modem from the VG configuration. I can't find the instruction in the help section. When I tried to use the "Add/Remove/Configure" in the Config Wizard, It asked if I want to remove the voice modem from my system instead.
Please advise the procedure for removing the voice modem from the VG application only.
In the Configuration Wizard just select the lines you want VG to use, and do not select the lines you do not want VG to use.
