Guest xuduo18 Report post Posted 08/24/2004 12:38 AM I am using enterprise 8 line dialer. It hung suddenly with '?' showing on the line status. It is the lastest version. below is the log. it shows the transition. this happened around 6:00pm and i saw it after 7:00 and I had to exit the program and restart it. Could you figure it out? Thanks! 175751.03 7 Waiting for a call... 175751.03 7 fnHangupCall end 175751.08 7 linedevstate 2048 0 0 175751.09 7 callstate IDLE 65753 0 0 175751.09 7 WorkingMode@Idle= 175751.11 7 timer clear 175751.11 7 LineState(iLineId).iVgsIdx = 0 175751.11 7 timer set 1 EV_TIMEOUT_TIMETOREINITLINE 175751.13 7 tapi Reply (LineEvReply) ok 66014 0 175751.48 0 dial start any summary:|5:hc>0|6:hc>0|7:hc>0|8:hc>0|9:rdy=0|10:hc>0|11:idx=0|12:idx=0| 175752.34 7 timer fired EV_TIMEOUT_TIMETOREINITLINE 175752.34 7 ScriptEventCode 9008 iLineState=900 175752.34 7 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE 175752.36 7 ReinitTelephony due to IDLE 175752.36 7 tapic lineDeallocateCall(MainCall:65753) 0 175752.81 7 lineOpen(7)=> 175752.81 7 Waiting for a call... 175752.83 7 LineHandle=65860 175752.83 7 timer set 3 EV_TIMEOUT_ATERIDLE_ALLOWOUT 175753.16 0 dial start any summary:|5:hc>0|6:hc>0|7:rdy=0|8:hc>0|9:rdy=0|10:hc>0|11:idx=0|12:idx=0| 175753.78 5 wb(80021800) 175753.92 5 play end current play (playid=800218) 175753.94 5 ScriptEventCode 8001 iLineState=1100 175753.94 5 LsPlayMsg EV_PLAY_FINISHED 175753.94 5 timer set 3 EV_TIMEOUT_REPLAYMSG 175754.30 9 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT 175754.31 9 ScriptEventCode 9013 iLineState=900 175754.47 0 dial start any summary:|5:hc>0|6:hc>0|7:rdy=0|8:hc>0|9:rdy=0|10:hc>0|11:idx=0|12:idx=0| 175755.66 9 dial [73418,9054576385,408170005,930,2000,MoTuWeThFrSaSu,,dxxxB2C1,,2,NONE,C:\Program Files\VoiceGuide\Scripts\toronto_2004.vgs,NONE,none,60,2,120,,none] 175755.72 0 dial callque update id=73418 next call time 0408231957 175755.78 0 dial callque DB update returned 175755.80 9 dial found entry: tel[9054576385] ann[NONE] vgs[C:\Program Files\VoiceGuide\Scripts\toronto_2004.vgs] am[NONE] 175755.83 9 Dialing: 9054576385 175755.83 9 MakeCall => 66149 175755.83 9 timer set 60 EV_TIMEOUT_MAKECALL_NORESPONSE 175755.83 9 TapiCbTrigSet 66149 7002 175756.16 0 dial start any summary:|5:hc>0|6:hc>0|7:rdy=0|8:hc>0|9:dial=0|10:hc>0|11:idx=0|12:idx=0| 175756.69 9 tapi Reply (LineEvReply) ok 66149 0 175756.69 9 TapiCbTrigClear 175756.72 9 linedevstate 2048 0 0 175756.73 9 callstate DIALTONE 66445 0 0 175756.75 9 callstate DIALING 66445 0 0 175756.75 9 callstate PROCEEDING 66445 0 0 175756.77 9 callinfo CALLEDID 175756.78 9 callinfo REASON 175756.81 9 Lev_CallerID [0000,,9054576385] 175756.81 9 rv add [DNIS]{9054576385} 175756.83 9 callinfo ORIGIN 175756.84 7 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT 175756.84 7 ScriptEventCode 9013 iLineState=900 175757.33 7 dial [68313,xxxxxxxxx,408142235,930,2000,MoTuWeThFrSaSu,,dxxxB1C3,,2,NONE,C:\Program Files\VoiceGuide\Scripts\toronto.vgs,NONE,none,60,1,1440,,none] 175757.36 0 dial callque update id=68313 next call time 0408241757 175757.36 0 dial callque DB update returned 175757.38 7 dial found entry: tel[xxxxxxxxx] ann[NONE] vgs[C:\Program Files\VoiceGuide\Scripts\toronto.vgs] am[NONE] 175757.39 7 Dialing: xxxxxxxxxxx 175757.39 7 MakeCall => 66199 175757.41 7 timer set 60 EV_TIMEOUT_MAKECALL_NORESPONSE 175757.41 7 TapiCbTrigSet 66199 7002 175757.86 0 dial start any summary:|5:hc>0|6:hc>0|7:dial=0|8:hc>0|9:hc>0|10:hc>0|11:idx=0|12:idx=0| 175757.97 5 timer fired EV_TIMEOUT_REPLAYMSG 175757.97 5 ScriptEventCode 9005 iLineState=1101 175757.97 5 LsPlayMsgFinished EV_TIMEOUT_REPLAYMSG 175757.98 5 [please_select] Playing (C:\script_audio\11k\select123_11.wav) 175757.98 5 play set playid=819671 175758.11 5 PlaySoundStart ok [C:\script_audio\11k\select123_11.wav] 175758.11 5 timer clear 175758.13 5 wa(14958,81967100) 175758.14 5 callinfo MONITORMODES 175758.25 7 tapi Reply (LineEvReply) ok 66199 0 175758.25 7 TapiCbTrigClear 175758.27 7 linedevstate 2048 0 0 175758.27 7 callstate DIALTONE 66451 0 0 175758.28 7 callstate DIALING 66451 0 0 175758.30 7 callstate PROCEEDING 66451 0 0 175758.30 7 callinfo CALLEDID 175758.31 7 callinfo REASON 175758.34 7 Lev_CallerID [0000,,xxxxxxxxxxxx] 175758.36 7 rv add [DNIS]{xxxxxxxxxxxxx} 175758.36 7 callinfo ORIGIN 175759.02 8 wb(80565600) 175759.16 8 play end current play (playid=805656) 175759.16 8 ScriptEventCode 8001 iLineState=1100 175759.16 8 LsPlayMsg EV_PLAY_FINISHED 175759.17 8 timer set 10 EV_TIMEOUT_HANGUP 175759.17 8 timer set 0 EV_TIMEOUT_GOTOMODULE 175759.17 8 ScriptEventCode 9002 iLineState=1101 175759.19 8 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE 175759.19 8 timer clear 175759.19 8 [introduction4] Playing 175759.20 8 [introduction4] Playing (C:\script_audio\11k\introduction4_11.wav) 175759.20 8 play set playid=820890 175759.31 8 PlaySoundStart ok [C:\script_audio\11k\introduction4_11.wav] 175759.31 8 timer clear 175759.33 8 RunModule PLAY end 175759.34 8 wa(12514,82089000) 175759.34 8 callinfo MONITORMODES 175801.73 10 wb(80815600) 175801.77 10 play end current play (playid=808156) 175801.77 10 ScriptEventCode 8001 iLineState=1100 175801.78 10 LsPlayMsg EV_PLAY_FINISHED 175801.78 10 timer set 10 EV_TIMEOUT_HANGUP 175801.78 10 timer set 5 EV_TIMEOUT_GOTOMODULE 175806.47 6 wb(80712500) 175806.72 6 play end current play (playid=807125) 175806.73 6 ScriptEventCode 8001 iLineState=1100 175806.73 6 LsPlayMsg EV_PLAY_FINISHED 175806.73 6 timer set 10 EV_TIMEOUT_HANGUP 175806.73 6 timer set 0 EV_TIMEOUT_GOTOMODULE 175806.75 6 ScriptEventCode 9002 iLineState=1101 175806.75 6 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE 175806.77 6 timer clear 175806.77 6 [introduction2] Playing 175806.77 6 [introduction2] Playing (C:\script_audio\11k\introduction2_11.wav) 175806.78 6 play set playid=828468 175806.89 6 PlaySoundStart ok [C:\script_audio\11k\introduction2_11.wav] 175806.89 6 timer clear 175806.89 6 RunModule PLAY end 175806.91 6 wa(5774,82846800) 175806.92 6 callinfo MONITORMODES 175808.13 10 timer fired EV_TIMEOUT_GOTOMODULE 175808.13 10 ScriptEventCode 9002 iLineState=1101 175808.13 10 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE 175808.14 10 timer clear 175808.14 10 [thank you] Playing 175808.14 10 [thank you] Playing (C:\script_audio\11k\thankuandhaveaniceday_11.wav) 175808.16 10 play set playid=829843 175808.25 10 PlaySoundStart ok [C:\script_audio\11k\thankuandhaveaniceday_11.wav] 175808.27 10 timer clear 175808.27 10 RunModule PLAY end 175808.28 10 wa(2714,82984300) 175808.30 10 callinfo MONITORMODES 175809.41 5 callstate DISCONNECTED 66506 0 0 175809.42 5 ScriptEventCode 9250 iLineState=1100 175809.42 5 LsPlayMsg EV_REMOTEPARTY_DISCONNECT 175809.42 5 rv add [Hangup Time]{8/23/2004 5:58:09 PM} 175809.44 5 Hanging up call... 175809.45 5 RecSoundStop ok 175809.64 5 PlaySoundStop err=0 175809.69 5 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP 175809.75 5 fnHangupCall end 175809.81 5 linedevstate 2048 0 0 175809.83 5 callstate IDLE 66506 0 0 175809.83 5 WorkingMode@Idle= 175809.83 5 timer clear 175809.84 5 timer set 1 EV_TIMEOUT_TIMETOREINITLINE 175809.86 5 tapi Reply (LineEvReply) ok 65881 0 175810.98 5 timer fired EV_TIMEOUT_TIMETOREINITLINE 175810.98 5 ScriptEventCode 9008 iLineState=900 175810.98 5 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE 175811.00 5 ReinitTelephony due to IDLE 175811.02 5 tapic lineDeallocateCall(MainCall:66506) 0 175811.11 10 wb(82984300) 175811.19 10 play end current play (playid=829843) 175811.20 10 ScriptEventCode 8001 iLineState=1100 175811.22 10 LsPlayMsg EV_PLAY_FINISHED 175811.22 10 timer set 10 EV_TIMEOUT_HANGUP 175811.22 10 timer set 0 EV_TIMEOUT_GOTOMODULE 175811.23 10 ScriptEventCode 9002 iLineState=1101 175811.23 10 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE 175811.23 10 timer clear 175811.25 10 rv add [Hangup Time]{8/23/2004 5:58:11 PM} 175811.25 10 Hanging up call... [Hangup Module] 175813.25 10 RecSoundStop ok 175813.27 10 PlaySoundStop err=0 175813.27 10 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP 175819.16 10 fnHangupCall end 175819.16 8 wb(82089000) 175819.19 6 wb(82846800) 175819.33 8 play end current play (playid=820890) 175819.34 8 ScriptEventCode 8001 iLineState=1100 175819.34 8 LsPlayMsg EV_PLAY_FINISHED 175819.34 8 timer set 10 EV_TIMEOUT_HANGUP 175819.36 8 timer set 0 EV_TIMEOUT_GOTOMODULE 175819.36 8 ScriptEventCode 9002 iLineState=1101 175819.36 8 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE 175819.39 6 play end current play (playid=828468) 175819.39 6 ScriptEventCode 8001 iLineState=1100 175819.39 6 LsPlayMsg EV_PLAY_FINISHED 175819.41 6 timer set 10 EV_TIMEOUT_HANGUP 175819.41 6 timer set 0 EV_TIMEOUT_GOTOMODULE 175819.41 6 ScriptEventCode 9002 iLineState=1101 175819.42 6 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE 175819.94 6 timer clear 175819.94 6 [introduction3] Playing 175819.95 6 [introduction3] Playing (C:\script_audio\11k\introduction3_11.wav) 175819.95 6 play set playid=841640 175821.11 6 PlaySoundStart ok [C:\script_audio\11k\introduction3_11.wav] 175821.13 6 timer clear 175821.13 6 RunModule PLAY end 175821.14 6 wa(14903,84164000) 175821.48 8 timer clear 175821.50 8 [introduction5] Playing 175821.50 8 [introduction5] Playing (C:\script_audio\11k\introduction5_11.wav) 175821.50 8 play set playid=843187 175821.75 8 PlaySoundStart ok [C:\script_audio\11k\introduction5_11.wav] 175821.75 8 timer clear 175821.75 8 RunModule PLAY end 175821.77 8 wa(37285,84318700) 175821.80 5 lineOpen(5)=>LINEERR_UNINITIALIZED 175821.81 5 Waiting for a call... (?) 175821.81 0 OnError_Unavailable: disabled - no action taken 175824.20 10 timer fired EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP 175824.20 10 ScriptEventCode 9101 iLineState=900 175824.20 10 Hanging up call...(2) 175824.23 10 RecSoundStop ok 175824.27 10 PlaySoundStop err=0 175824.28 10 fnHangupCall end 175824.28 10 LsAwaitingCalls EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP 175836.06 6 wb(84164000) 175836.20 6 play end current play (playid=841640) 175836.25 6 ScriptEventCode 8001 iLineState=1100 175836.25 6 LsPlayMsg EV_PLAY_FINISHED 175836.25 6 timer set 10 EV_TIMEOUT_HANGUP 175836.27 6 timer set 0 EV_TIMEOUT_GOTOMODULE 175836.27 6 ScriptEventCode 9002 iLineState=1101 175836.27 6 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE 175836.64 6 timer clear 175836.69 6 [introduction4] Playing 175836.70 6 [introduction4] Playing (C:\script_audio\11k\introduction4_11.wav) 175836.72 6 play set playid=858406 175836.83 6 PlaySoundStart ok [C:\script_audio\11k\introduction4_11.wav] 175836.84 6 timer clear 175836.84 6 RunModule PLAY end 175836.86 6 wa(12514,85840600) 175849.39 6 wb(85840600) 175849.56 6 play end current play (playid=858406) 175849.56 6 ScriptEventCode 8001 iLineState=1100 175849.58 6 LsPlayMsg EV_PLAY_FINISHED 175849.63 6 timer set 10 EV_TIMEOUT_HANGUP 175849.66 6 timer set 0 EV_TIMEOUT_GOTOMODULE 175849.69 6 ScriptEventCode 9002 iLineState=1101 175849.70 6 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE 175849.72 6 timer clear 175849.72 6 [introduction5] Playing 175849.73 6 [introduction5] Playing (C:\script_audio\11k\introduction5_11.wav) 175849.73 6 play set playid=871421 175849.84 6 PlaySoundStart ok [C:\script_audio\11k\introduction5_11.wav] 175849.86 6 timer clear 175849.86 6 RunModule PLAY end 175849.88 6 wa(37285,87142100) 175859.11 8 wb(84318700) 175859.25 8 play end current play (playid=843187) 175859.25 8 ScriptEventCode 8001 iLineState=1100 175859.25 8 LsPlayMsg EV_PLAY_FINISHED 175859.27 8 timer set 10 EV_TIMEOUT_HANGUP 175859.27 8 timer set 0 EV_TIMEOUT_GOTOMODULE 175859.27 8 ScriptEventCode 9002 iLineState=1101 175859.28 8 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE 175859.28 8 timer clear 175859.28 8 [please_select] Playing 175859.30 8 [please_select] Playing (C:\script_audio\11k\select123_11.wav) 175859.30 8 play set playid=880984 175859.41 8 PlaySoundStart ok [C:\script_audio\11k\select123_11.wav] 175859.42 8 timer clear 175859.42 8 RunModule PLAY end 175859.44 8 wa(14958,88098400) 175914.53 8 wb(88098400) 175914.56 8 play end current play (playid=880984) 175914.56 8 ScriptEventCode 8001 iLineState=1100 175914.56 8 LsPlayMsg EV_PLAY_FINISHED 175914.58 8 timer set 3 EV_TIMEOUT_REPLAYMSG 175918.30 8 timer fired EV_TIMEOUT_REPLAYMSG 175918.30 8 ScriptEventCode 9005 iLineState=1101 175918.30 8 LsPlayMsgFinished EV_TIMEOUT_REPLAYMSG 175918.31 8 [please_select] Playing (C:\script_audio\11k\select123_11.wav) 175918.31 8 play set playid=900000 175918.44 8 PlaySoundStart ok [C:\script_audio\11k\select123_11.wav] 175918.44 8 timer clear 175918.45 8 wa(14958,90000000) 175923.53 9 timer fired EV_TIMEOUT_MAKECALL_NORESPONSE 175923.53 9 ScriptEventCode 9020 iLineState=5200 175923.53 9 LsWaitAfterDialingOut EV_TIMEOUT_MAKECALL_NORESPONSE 175923.55 0 dial callque update id=73418 next call time 0408231959 175923.55 0 dial callque DB update returned 175923.55 9 rv add [Hangup Time]{8/23/2004 5:59:23 PM} 175923.56 9 Hanging up call... [EV_TIMEOUT_MAKECALL_NORESPONSE] 175923.58 9 RecSoundStop ok 175923.67 9 PlaySoundStop err=0 175923.72 9 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP 175923.75 9 Waiting for a call... 175923.75 9 fnHangupCall end 175925.31 7 timer fired EV_TIMEOUT_MAKECALL_NORESPONSE 175925.31 7 ScriptEventCode 9020 iLineState=5200 175925.31 7 LsWaitAfterDialingOut EV_TIMEOUT_MAKECALL_NORESPONSE 175925.33 0 dial callque update id=68313 next call time 0408241759 175925.33 0 dial callque DB update returned 175925.33 7 rv add [Hangup Time]{8/23/2004 5:59:25 PM} 175925.34 7 Hanging up call... [EV_TIMEOUT_MAKECALL_NORESPONSE] 175925.36 7 RecSoundStop ok 175925.38 7 PlaySoundStop err=0 175925.39 7 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP 175925.41 7 Waiting for a call... 175925.41 7 fnHangupCall end 175926.41 9 timer fired EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP 175926.41 9 ScriptEventCode 9101 iLineState=900 175926.41 9 Hanging up call...(2) 175926.44 9 RecSoundStop ok 175926.45 9 PlaySoundStop err=0 175926.47 9 Waiting for a call... 175926.47 9 fnHangupCall end 175926.48 9 LsAwaitingCalls EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP 175927.17 6 wb(87142100) 175927.33 6 play end current play (playid=871421) 175927.34 6 ScriptEventCode 8001 iLineState=1100 175927.34 6 LsPlayMsg EV_PLAY_FINISHED 175927.34 6 timer set 10 EV_TIMEOUT_HANGUP 175927.36 6 timer set 0 EV_TIMEOUT_GOTOMODULE 175927.36 6 ScriptEventCode 9002 iLineState=1101 175927.36 6 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE 175927.38 6 timer clear 175927.38 6 [please_select] Playing 175927.38 6 [please_select] Playing (C:\script_audio\11k\select123_11.wav) 175927.39 6 play set playid=909078 175927.50 6 PlaySoundStart ok [C:\script_audio\11k\select123_11.wav] 175927.50 6 timer clear 175927.52 6 RunModule PLAY end 175927.53 6 wa(14958,90907800) 175928.31 7 timer fired EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP 175928.31 7 ScriptEventCode 9101 iLineState=900 175928.31 7 Hanging up call...(2) 175928.34 7 RecSoundStop ok 175928.36 7 PlaySoundStop err=0 175928.38 7 Waiting for a call... 175928.39 7 fnHangupCall end 175928.39 7 LsAwaitingCalls EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP 175933.45 8 wb(90000000) 175933.58 8 play end current play (playid=900000) 175933.64 8 ScriptEventCode 8001 iLineState=1100 175933.67 8 LsPlayMsg EV_PLAY_FINISHED 175933.70 8 timer set 10 EV_TIMEOUT_HANGUP 175933.73 8 timer set 5 EV_TIMEOUT_GOTOMODULE 175939.92 8 timer fired EV_TIMEOUT_GOTOMODULE 175939.92 8 ScriptEventCode 9002 iLineState=1101 175939.92 8 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE 175939.94 8 timer clear 175939.94 8 [thank you] Playing 175939.94 8 [thank you] Playing (C:\script_audio\11k\thankuandhaveaniceday_11.wav) 175939.95 8 play set playid=921640 175940.06 8 PlaySoundStart ok [C:\script_audio\11k\thankuandhaveaniceday_11.wav] 175940.06 8 timer clear 175940.08 8 RunModule PLAY end 175940.09 8 wa(2714,92164000) 175942.56 6 wb(90907800) 175942.66 6 play end current play (playid=909078) 175942.69 6 ScriptEventCode 8001 iLineState=1100 175942.72 6 LsPlayMsg EV_PLAY_FINISHED 175942.73 6 timer set 3 EV_TIMEOUT_REPLAYMSG 175942.84 8 wb(92164000) 175942.98 8 play end current play (playid=921640) 175942.98 8 ScriptEventCode 8001 iLineState=1100 175942.98 8 LsPlayMsg EV_PLAY_FINISHED 175943.00 8 timer set 10 EV_TIMEOUT_HANGUP 175943.00 8 timer set 0 EV_TIMEOUT_GOTOMODULE 175943.00 8 ScriptEventCode 9002 iLineState=1101 175943.02 8 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE 175943.02 8 timer clear 175943.02 8 rv add [Hangup Time]{8/23/2004 5:59:43 PM} 175943.03 8 Hanging up call... [Hangup Module] 175943.05 8 RecSoundStop ok 175943.06 8 PlaySoundStop err=0 175943.08 8 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP 175943.11 8 fnHangupCall end 175945.48 8 timer fired EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP 175945.48 8 ScriptEventCode 9101 iLineState=900 175945.48 8 Hanging up call...(2) 175945.50 8 RecSoundStop ok 175945.53 8 PlaySoundStop err=0 175945.55 8 fnHangupCall end 175945.55 8 LsAwaitingCalls EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP 175946.47 6 timer fired EV_TIMEOUT_REPLAYMSG 175946.47 6 ScriptEventCode 9005 iLineState=1101 175946.47 6 LsPlayMsgFinished EV_TIMEOUT_REPLAYMSG 175946.47 6 [please_select] Playing (C:\script_audio\11k\select123_11.wav) 175946.48 6 play set playid=928171 175946.64 6 PlaySoundStart ok [C:\script_audio\11k\select123_11.wav] 175946.66 6 timer clear 175946.73 6 wa(14958,92817100) 180001.77 6 wb(92817100) 180001.80 6 play end current play (playid=928171) 180001.80 6 ScriptEventCode 8001 iLineState=1100 180001.80 6 LsPlayMsg EV_PLAY_FINISHED 180001.80 6 timer set 10 EV_TIMEOUT_HANGUP 180001.81 6 timer set 5 EV_TIMEOUT_GOTOMODULE 180008.17 6 timer fired EV_TIMEOUT_GOTOMODULE 180008.17 6 ScriptEventCode 9002 iLineState=1101 180008.17 6 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE 180008.19 6 timer clear 180008.19 6 [thank you] Playing 180008.19 6 [thank you] Playing (C:\script_audio\11k\thankuandhaveaniceday_11.wav) 180008.20 6 play set playid=949890 180008.31 6 PlaySoundStart ok [C:\script_audio\11k\thankuandhaveaniceday_11.wav] 180008.31 6 timer clear 180008.31 6 RunModule PLAY end 180008.33 6 wa(2714,94989000) 180011.06 6 wb(94989000) 180011.20 6 play end current play (playid=949890) 180011.22 6 ScriptEventCode 8001 iLineState=1100 180011.22 6 LsPlayMsg EV_PLAY_FINISHED 180011.22 6 timer set 10 EV_TIMEOUT_HANGUP 180011.23 6 timer set 0 EV_TIMEOUT_GOTOMODULE 180011.23 6 ScriptEventCode 9002 iLineState=1101 180011.23 6 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE 180011.25 6 timer clear 180011.25 6 rv add [Hangup Time]{8/23/2004 6:00:11 PM} 180011.25 6 Hanging up call... [Hangup Module] 180011.28 6 RecSoundStop ok 180011.30 6 PlaySoundStop err=0 180011.30 6 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP 180011.34 6 fnHangupCall end 180013.72 6 timer fired EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP 180013.72 6 ScriptEventCode 9101 iLineState=900 180013.73 6 Hanging up call...(2) 180013.75 6 RecSoundStop ok 180013.78 6 PlaySoundStop err=0 180013.80 6 fnHangupCall end 180013.80 6 LsAwaitingCalls EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP 180240.95 0 sys cleanup Start 180240.95 0 sys cleanup End 183241.88 0 sys cleanup Start 183241.89 0 sys cleanup End 190242.81 0 sys cleanup Start 190242.81 0 sys cleanup End 191238.70 0 btn Exit (8 lines) 191238.70 5 line state =900 191238.70 6 line state =900 191238.98 7 line state =900 191239.00 8 line state =900 191239.05 9 line state =900 191239.06 10 line state =900 191239.08 11 line state =0 191239.09 12 line state =0 191239.09 5 Exiting... 191239.11 6 Exiting... 191239.11 7 Exiting... 191239.13 8 Exiting... 191239.14 9 Exiting... 191239.16 10 Exiting... 191239.16 11 Exiting... 191239.17 12 Exiting... 191239.22 0 calling TapiWrap.Shutdown 191240.61 0 Unloading Main Window 191254.08 0 ApiMode=[TAPI] 191254.13 0 Tapi device 12 is: Analog Line 8(dxxxB2C4) 191254.14 0 Tapi device 11 is: Analog Line 7(dxxxB2C3) 191254.16 0 Tapi device 10 is: Analog Line 6(dxxxB2C2) 191254.19 0 Tapi device 9 is: Analog Line 5(dxxxB2C1) 191254.20 0 Tapi device 8 is: Analog Line 4(dxxxB1C4) 191254.22 0 Tapi device 7 is: Analog Line 3(dxxxB1C3) 191254.23 0 Tapi device 6 is: Analog Line 2(dxxxB1C2) 191254.25 0 Tapi device 5 is: Analog Line 1(dxxxB1C1) 191254.27 0 Tapi device 4 is: H323 Line 191254.28 0 Tapi device 3 is: IPCONF LINE 191254.31 0 Tapi device 2 is: LPT1T 191254.33 0 Tapi device 1 is: WAN Miniport (L2TP) 191254.34 0 Tapi device 0 is: RAS VPN Line 0 191254.52 0 init vgmulti ver 5.2.3018 191254.61 0 Inband Signaling Config file not specified 191254.81 0 Loading VMB data begin 191254.95 0 Loading VMB data - about to delete old entries 191255.00 0 Loading VMB data - sorting/ordering 191255.00 0 Loading VMB data end 191255.14 0 init clear settings on 8 devices. 191255.14 5 Initialising... 191255.16 6 Initialising... 191255.16 7 Initialising... 191255.17 8 Initialising... 191255.17 9 Initialising... 191255.19 10 Initialising... 191255.19 11 Initialising... 191255.20 12 Initialising... 191255.20 0 init attach vgs on 8 devices. 191255.22 0 Script Load C:\Program Files\VoiceGuide\Scripts\hangup.vgs 191255.25 0 init lineopen on 8 devices. 191255.25 0 Calling .lineOpen on device 1 191256.20 5 lineOpen(5)=> 191256.22 0 Calling .GetLineHandle on LineId 5 191256.22 5 hLine=66508 191256.23 0 Calling .GetProviderInfo on LineId 5 191256.30 5 tapi ProviderInfo: D41MT.TSP: Dialogic D41 Service Provider 191256.30 5 set provider type: PROVTYPE_DIALOGIC 191256.31 0 Calling lineSetNumRings on lLineHandle 66508 191256.31 5 Waiting for a call... 191256.34 5 dlgc bus switching not supported 191256.36 0 Calling .lineOpen on device 2 191256.69 6 lineOpen(6)=> 191256.69 0 Calling .GetLineHandle on LineId 6 191256.70 6 hLine=66474 191256.70 0 Calling .GetProviderInfo on LineId 6 191256.78 6 tapi ProviderInfo: D41MT.TSP: Dialogic D41 Service Provider 191256.81 6 set provider type: PROVTYPE_DIALOGIC 191256.84 0 Calling lineSetNumRings on lLineHandle 66474 191256.88 6 Waiting for a call... 191256.91 6 dlgc bus switching not supported 191256.92 0 Calling .lineOpen on device 3 191257.25 7 lineOpen(7)=> 191257.25 0 Calling .GetLineHandle on LineId 7 191257.27 7 hLine=66440 191257.27 0 Calling .GetProviderInfo on LineId 7 191257.30 7 tapi ProviderInfo: D41MT.TSP: Dialogic D41 Service Provider 191257.30 7 set provider type: PROVTYPE_DIALOGIC 191257.31 0 Calling lineSetNumRings on lLineHandle 66440 191257.31 7 Waiting for a call... 191257.36 7 dlgc bus switching not supported 191257.38 0 Calling .lineOpen on device 4 191257.69 8 lineOpen(8)=> 191257.69 0 Calling .GetLineHandle on LineId 8 191257.70 8 hLine=66406 191257.70 0 Calling .GetProviderInfo on LineId 8 191257.80 8 tapi ProviderInfo: D41MT.TSP: Dialogic D41 Service Provider 191257.86 8 set provider type: PROVTYPE_DIALOGIC 191257.88 0 Calling lineSetNumRings on lLineHandle 66406 191257.89 8 Waiting for a call... 191257.91 8 dlgc bus switching not supported 191257.92 0 Calling .lineOpen on device 5 191258.23 9 lineOpen(9)=> 191258.23 0 Calling .GetLineHandle on LineId 9 191258.23 9 hLine=66372 191258.25 0 Calling .GetProviderInfo on LineId 9 191258.28 9 tapi ProviderInfo: D41MT.TSP: Dialogic D41 Service Provider 191258.28 9 set provider type: PROVTYPE_DIALOGIC 191258.30 0 Calling lineSetNumRings on lLineHandle 66372 191258.30 9 Waiting for a call... 191258.33 9 dlgc bus switching not supported 191258.34 0 Calling .lineOpen on device 6 191258.66 10 lineOpen(10)=> 191258.66 0 Calling .GetLineHandle on LineId 10 191258.67 10 hLine=66338 191258.67 0 Calling .GetProviderInfo on LineId 10 191258.70 10 tapi ProviderInfo: D41MT.TSP: Dialogic D41 Service Provider 191258.70 10 set provider type: PROVTYPE_DIALOGIC 191258.72 0 Calling lineSetNumRings on lLineHandle 66338 191258.72 10 Waiting for a call... 191258.88 10 dlgc bus switching not supported 191258.88 0 Calling .lineOpen on device 7 191259.17 11 lineOpen(11)=> 191259.17 0 Calling .GetLineHandle on LineId 11 191259.17 11 hLine=66304 191259.19 0 Calling .GetProviderInfo on LineId 11 191259.22 11 tapi ProviderInfo: D41MT.TSP: Dialogic D41 Service Provider 191259.22 11 set provider type: PROVTYPE_DIALOGIC 191259.22 0 Calling lineSetNumRings on lLineHandle 66304 191259.23 11 Waiting for a call... 191259.27 11 dlgc bus switching not supported 191259.27 0 Calling .lineOpen on device 8 191259.59 12 lineOpen(12)=> 191259.59 0 Calling .GetLineHandle on LineId 12 191259.59 12 hLine=66286 191259.61 0 Calling .GetProviderInfo on LineId 12 191259.64 12 tapi ProviderInfo: D41MT.TSP: Dialogic D41 Service Provider 191259.64 12 set provider type: PROVTYPE_DIALOGIC 191259.64 0 Calling lineSetNumRings on lLineHandle 66286 191259.66 12 Waiting for a call... 191259.69 12 dlgc bus switching not supported 191300.22 5 dial [67761,xxxxxxxxxxx,408142235,930,2000,MoTuWeThFrSaSu,,dxxxB1C1,,2,NONE,C:\Program Files\VoiceGuide\Scripts\toronto.vgs,NONE,none,60,1,1440,,none] 191300.23 0 dial callque update id=67761 next call time 0408241912 191300.23 0 dial callque DB update returned 191300.25 5 dial found entry: tel[xxxxxxxx] ann[NONE] vgs[C:\Program Files\VoiceGuide\Scripts\toronto.vgs] am[NONE] 191300.27 5 Dialing: xxxxxxxx 191300.27 5 MakeCall => 66252 191300.28 5 timer set 60 EV_TIMEOUT_MAKECALL_NORESPONSE 191300.28 5 TapiCbTrigSet 66252 7002 191300.48 0 dial bulk mode enter 191300.50 6 dial [49679,xxxxxxxx,408012131,930,2000,MoTuWeThFrSaSu,,dxxxB1C2,,2,NONE,C:\Program Files\VoiceGuide\Scripts\toronto.vgs,NONE,none,60,1,1440,,none] 191300.50 0 dial callque update id=49679 next call time 0408241912 191300.52 0 dial callque DB update returned 191300.52 6 dial found entry: tel[xxxxxxxx] ann[NONE] vgs[C:\Program Files\VoiceGuide\Scripts\toronto.vgs] am[NONE] 191300.53 6 Dialing: xxxxxxxx 191300.53 6 MakeCall => 66201 191300.55 6 timer set 60 EV_TIMEOUT_MAKECALL_NORESPONSE 191300.56 6 TapiCbTrigSet 66201 7002 191300.78 7 dial [68315,xxxxxxxx,408142235,930,2000,MoTuWeThFrSaSu,,dxxxB1C3,,2,NONE,C:\Program Files\VoiceGuide\Scripts\toronto.vgs,NONE,none,60,1,1440,,none] 191300.84 0 dial callque update id=68315 next call time 0408241912 191300.88 0 dial callque DB update returned 191300.88 7 dial found entry: tel[xxxxxxxx] ann[NONE] vgs[C:\Program Files\VoiceGuide\Scripts\toronto.vgs] am[NONE] 191300.91 7 Dialing: xxxxxxxx 191300.92 7 MakeCall => 66150 191300.92 7 timer set 60 EV_TIMEOUT_MAKECALL_NORESPONSE 191300.92 7 TapiCbTrigSet 66150 7002 191301.11 8 dial [69180,xxxxxxxx,408142235,930,2000,MoTuWeThFrSaSu,,dxxxB1C4,,2,NONE,C:\Program Files\VoiceGuide\Scripts\toronto.vgs,NONE,none,60,1,1440,,none] 191301.11 0 dial callque update id=69180 next call time 0408241913 191301.13 0 dial callque DB update returned 191301.16 8 dial found entry: tel[xxxxxxxx] ann[NONE] vgs[C:\Program Files\VoiceGuide\Scripts\toronto.vgs] am[NONE] 191301.19 8 Dialing: xxxxxxxx 191301.19 8 MakeCall => 66099 191301.20 8 timer set 60 EV_TIMEOUT_MAKECALL_NORESPONSE 191301.20 8 TapiCbTrigSet 66099 7002 191301.22 5 tapi Reply (LineEvReply) ok 66252 0 191301.22 5 TapiCbTrigClear 191301.23 5 linedevstate 2048 0 0 191301.23 5 callstate DIALTONE 66218 0 0 Share this post Link to post
SupportTeam Report post Posted 08/24/2004 01:17 AM Looks like something has happened to the Dialogic TSP here... I take it that VG was still responding to commands here - but it was just unable to make any calls as the Dialogic TSP was telling it that the lines were unavailable? ie: you were able to exit VG using the "Exit" command button - and did not have to stop the software using the Task Manager.. A few questions: What Dialogic card(s) and version of Dialogic drivers are you using? Which version of Windows/Service Pack are you running? What is the CPU & Memory? What other software is running on this machine? For haw many days was VG running before this happened and how many calls did it take/make ? How heavily utilized is this system in general? Share this post Link to post
Guest Guest Report post Posted 08/25/2004 04:14 PM A few questions: What Dialogic card(s) and version of Dialogic drivers are you using? two d4pci Which version of Windows/Service Pack are you running? win2000 server ,fully updated What is the CPU & Memory? p4 2.2G, 256M+512M What other software is running on this machine? sql server 2000,tigntvnc(for remote login),advanced SMTP server,norton antivirus For haw many days was VG running before this happened and how many calls did it take/make ? i ran this program at 9:00am. six lines dailing out concurrently. How heavily utilized is this system in general? it keeps dialing out without sttop. Share this post Link to post
SupportTeam Report post Posted 08/25/2004 09:23 PM I don't suppose that you'd still have on your disk the MMDDtw.txt log file from that day? Please see in VG's \log\ subdirectory - "MMDD" stands for Month and Day. If you still have that file could you please .ZIP it up and post it here - this will give us more info on the communications between VG and Dialogic TSP. It does look like the Dialogic TSP just stopped working here - but that file should give us more info on exactly what happened. Share this post Link to post
Guest xuduo18 Report post Posted 09/09/2004 11:27 PM Hi, i have been too busy to send you the debug file. almost everyday voiceguide hangs for a couple of times. sometimes a coulpe of lines, sometimes more than a couple. today it hung again on about 4 lines (i did not count exactly). Here is the debug file. I think the hang time should fall into this time period. Please delete the file after you check it in. Thank you! (This problem is forcing to check the line status every couple of hours during the day, which is no good.) Looking forward to you reply! debug.rar Share this post Link to post
SupportTeam Report post Posted 09/21/2004 05:20 AM Sorry for late reply. We've now had a look at the trace (attached trace from 9th Sept). Trace starts at 6pm and shows system dialing on all lines. Something does go wrong at about 6:40pm and the system is restarted soon afterwards. The system then commences dialing out on all lines again. As before when the problem occurs it is caused by the Dialogic TSP ceasing to send any information to VoiceGuide... We've had one instance where a user had a similar problem and installing WindowsXP on the server instead of Win2000 fixed this problem for them - we don't know why, but the problem just fixed itself. so the first thing I'd try is to change to WinXP. Another thing I'd try is to get rid of Norton antivirus - Antivirus software has been in the past implicated in strange system behavior... I'd suggest trying the two things above. If you still have problems please email us and we'll send you the new version of "VoiceGuide for Dialogic" which does not use the Dialogic TSP at all - but controls the Dialogic cards directly. Share this post Link to post
Guest Guest_xuduo18 Report post Posted 10/06/2004 01:51 AM Sir, I installed win xp without any antivirus. The problem still exist and it is even worse. I still need to restart voiceguide several times per day. attached is a recent instance. Please send me the other version of voiceguide if it is able to solve the problem. Thanks! voiceguidelog.rar Share this post Link to post
