Using The Run Program Function
Is there a way to use the RUN PROGRAM function of
version 2.9 to operate the 4.4 ( and above ) versions ?
I.E. If I check the box for " Close COM port "
via version 2.9 and then try to access the 4.4 version
within the SAME call and line !???
Is this possible ? If so, HOW ?
