Guest Pat Report post Posted 04/17/2003 10:54 PM Is there a way to use the RUN PROGRAM function of version 2.9 to operate the 4.4 ( and above ) versions ? I.E. If I check the box for " Close COM port " via version 2.9 and then try to access the 4.4 version within the SAME call and line !??? Is this possible ? If so, HOW ? Thanks Share this post Link to post
SupportTeam Report post Posted 04/18/2003 04:21 AM You can't get v4.x to take over a call that has been answered by v2.x already... Share this post Link to post
