samnjengah Report post Posted 09/01/2004 05:14 AM I need to setup dialogic d300pci E1 card to work similar to a cisco AS5300. I have the 5300 working perfectly and here is the E1 controller configuration controller E1 2 framing NO-CRC4 clock source line secondary 2 ds0-group 1 timeslots 1-15,17-31 type r2-digital r2-semi-compelled cas-custom 1 country argentina ! I am new to Dialogic and would like to know what files I have to edit and what the values that I have to have to achieve the same configuration as the 5300. Regards Sam Share this post Link to post
samnjengah Report post Posted 09/01/2004 05:26 AM I hope this too will help AS5300#sh contr e1 2 E1 2 is up. Applique type is Channelized E1 - balanced No alarms detected. alarm-trigger is not set Version info of slot 0: HW: 1, PLD Rev: 11 Framer Version: 0x8 Manufacture Cookie Info: EEPROM Type 0x0001, EEPROM Version 0x01, Board ID 0x4B, Board Hardware Version 3.1, Item Number 800-3881-02, Board Revision B0, Serial Number 25809149, PLD/ISP Version 0.1, Manufacture Date 4-Jul-2001. Framing is NO-CRC4, Line Code is HDB3, Clock Source is Line Secondary. Share this post Link to post
SupportTeam Report post Posted 09/01/2004 08:43 AM Are you using VoiceGuide for ISDN? This forum is for support of VoiceGuide installations only. Share this post Link to post
