Guest Brad Report post Posted 09/01/2004 01:49 PM Can I have a different voicemail greeting based on if the call is long distance or a local call? Reason being is our small setup (I run a contracting business through the internet, and the wife runs a daycare in home). All of her customers are local, and none of mine are. We'd like to only use one phone line to accomplish this if possible. Please let me know if your software does this. Thanks, Brad Share this post Link to post
SupportTeam Report post Posted 09/02/2004 08:33 PM You could use CallerID to determine this. Just have calls from your own area code go to one voicemail box and other calls go to another voicemail box. Use the Evaluate Expression module to extract and check the value of the area code within the Caller ID. Share this post Link to post
