Outbound Calling
I have a script that works with inbound calls. I am trying to use it for outbound calling. When I load it in the telephone numbers dialer, put in a number, and hit dial, it says finished , queued:1 rejected:0 but nothing happens. What is the proper procedure to get it to call out?
Could you please post a copy of VoiceGuide's Debug Printout which captures what happens on system just after you queue the call, this will allow us to see what is going wrong.
It's not dialing as "Allow dialout on this line" option is turned off.
See the "View" -> "Line Device Config" menu to turn it back on.
