Iterate Trough Records From Db
How to read each record from database separately (Oracle)?
I.e. I get 10 records as a result of query, next I'd like to read (TTS) each record at one time (long sentences).
Now I read from database, the result is stored in $RV[q1] next I define a counter, which is updated after a loop. A huge scrips mostly with IF conditions tests counter and uses appropriate value (i.e. $RV[q1_1_1] and so on).
Such a method results in huge number of created files in data directory. Moreover it's not flexible because I've got a fixed number of IFs and id I would have more records than IF the script wouldn't work correctly.
Do you know a smarter solution?
Thanks and all the best
Dominik
You can check how many rows were retrieved by using the "_RowCount" Result Variable - and then you can just loop through to the value of that RV.
Each spoken TTS will create a temporary sound files in \data\ directory - these files do not just take up more and more disk space - they are overwritten by TTS on next call and also are deleted by a periodic cleaning process.
Thanks,
I know about _RowCount
but what about conditions? I don't know max row count and therefore I cannot determine max number of IFs.
Dominik
Can you code your IF statements to use a counter variable, and therefore have one loop which goes though all of the retrieved records? Please post the script showing what you are trying to do.
