Guest amis Report post Posted 09/07/2004 10:23 AM Dear Support Person! I was trying to use the Text to Speak method but no luck, every time i typed text into the text to speak box, i get a message said that i need to enter a file name, in the sound file.... well, i typed text into a notepad file and insert the file name in the sound file... but it didn’t work. Just that you know, i have AT&T TTS Netural Voice. so what should i do now? the other question i have is, if you know where i can get the Hebrew language Text to speech (text going from right to left)? Waiting for your answer. Thanks again, Amis. Share this post Link to post
SupportTeam Report post Posted 09/07/2004 11:42 AM Could you please post a copy of VoiceGuide's Debug Printout which captures the problem, this will allow us to see what is going wrong. (When running the script click on VoiceGuide's View menu and select 'Event Trace Log' option - any log information will then appear in this window. You must open the trace window before making the call.) Please also post the script that you are using. Share this post Link to post
