Guest Gabe Report post Posted 09/08/2004 12:39 PM Hi, I've just set up VoiceGuide and have it connecting to a remote MySQL database. If I query a numeric field and enter the RV in the 'Text to Speak' field everything works fine. However, if I query a field containing text I get the below 'type mismatch' error. I've tried putting the RV in double quotes and single quotes with no luck. By the way, text to speech works fine if I just type in the text, but not from the RV. Thanks for your help! 232232.06 0 [Access Query] DB Query 232232.06 0 db ODBC mode used 232253.52 0 rv replace start: [SELECT pr_description FROM property WHERE pr_property_id='$RV[Get Product Code]'] 232253.52 0 rv ns [PathSysVoice]{}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[ScriptsPath]{C:\Program Files\VoiceGuide\Scripts\Customer Enquiry\}[ScriptPath]{C:\Program Files\VoiceGuide\Scripts\Customer Enquiry}[$RV_STARTTIME]{9/7/2004 11:22:19 PM}[$RV_DEVICEID]{0}[$RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[$RV_CIDNUMBER]{}[Select Query]{1}[Get Product Code]{5}[Get Product Code_PathTaken]{success} 232253.52 0 rv replace end: [SELECT pr_description FROM property WHERE pr_property_id='5'] 232253.52 0 db About to execute a Retrieve type operation [SELECT pr_description FROM property WHERE pr_property_id='5'] 232253.59 0 db [Access Query] row count=1 232253.59 0 rv add [Access Query_RowCount]{1} 232253.59 0 db get RecordsetGetRowsMax 232253.61 0 db get 999 records. (row count=1) 232253.61 0 db update RVs 232253.61 0 ERROR 5.2.3018 RunModule:0:13:Type mismatch:VoiceGuide 232253.61 0 rv add [Hangup Time]{9/7/2004 11:22:53 PM} 232253.61 0 Hanging up call... [RunModule Error] Share this post Link to post
Guest jusedawg Report post Posted 09/08/2004 10:03 PM If pr_property_id is numeric in the database, then the quotes around the ID will cause your type mismatch. Share this post Link to post
Guest Gabe Report post Posted 09/09/2004 02:36 AM Hi, thanks for your response. I've tried it both ways and the results are the same. This problem seems almost identical to this post. Like this user, I am also using MySQL with the ODBC driver from the MySQL website. Any other ideas? I've tried everything I can think of... Share this post Link to post
Guest jusedawg Report post Posted 09/09/2004 04:58 AM What version of the database are you using? What version of the ODBC driver are you using? If you could post the code it might be easier to debug the situation. From dealing with mySQL on other projects, it has done some little quarky things like this. Share this post Link to post
Guest Gabe Report post Posted 09/09/2004 07:25 PM MySQL Version: 4.0.20 ODBC Driver Version: 3.51.9 I'll post the code as soon as I can, as I'm not in front the right computer at the moment. A couple other notes, the field type of pr_description is varchar. I tried casting it as a char ( CAST(pr_description AS CHAR) ) with no luck. I'm going to try other column types and see what works and what doesn't. So far: decimal: works varchar: type mismatch Thanks for your help... Share this post Link to post
Guest Gabe Report post Posted 09/11/2004 03:34 PM Ok, here is some more information and one correction from my previous post - varchar does work, text doesn't. See below: MySQL Version: 4.0.20 ODBC Driver Version: 3.51.9 The MySQL column types I've tested so far: TEXT - ERROR 5.2.3018 RunModule:0:13:Type mismatch:VoiceGuide MEDIUMTEXT - ERROR 5.2.3018 RunModule:0:13:Type mismatch:VoiceGuide DECIMAL - works VARCHAR - works ENUM - works CHAR - works MEDIUMINT - works Following are my VGS, vgm.txt, and tw.txt files. Thanks for any help or insight into this problem. VGS: Version=5.0 DefaultModuleDisplayHeight= StartModule=GetListingID RunAtHangup= StartWithoutAnswer=0 CtmAsiName= [GetListingID] Type=Get Numbers DispSize=69 Txt=Get the listing id PlayFile1=C:\_ Files\VG_sound_files\enter_listing_id.wav Replay=0,0 GetNbrLen_Min=0 GetNbrLen_Max=0 Confirm=OFF VbScript= VbsHoldPlay= on {Success} goto [MySQLQuery] Position=226,55 [ReadDescription] Type=Play DispSize=69 Txt=Play a sound file, then await a response... Replay=2,5 strTtsText=The following is the description of the listing ID that you requested $RV[MySQLQuery_1_1]. Press one to enter another listing ID. Press 2 to end this call. on {1} goto [GetListingID] on {2} goto [HangupCall] Position=250,363 [HangupCall] Type=Hangup the Call DispSize=69 Txt=Hangup the call. Position=251,505 [MySQLQuery] Type=Database Query DispSize=69 Txt=Query the database DbDatabase=MichiganEhomes DbUser= DbConnectString=ODBC;DSN=MichiganEhomes;UID=MYUID;PWD=MYPASS;SRVR=t:machine:p66; DbSql=SELECT pr_description FROM property WHERE pr_property_id=$RV[GetListingID] on {success} goto [ReadDescription] Position=241,212 vgm.txt: (error at 111250.44) 111200.38 0 ApiMode=[TAPI] 111200.39 0 Tapi device 8 is: H323 Line 111200.41 0 Tapi device 7 is: IPCONF LINE 111200.41 0 Tapi device 6 is: LPT1T 111200.41 0 Tapi device 5 is: WAN Miniport (L2TP) 111200.41 0 Tapi device 4 is: WAN Miniport (ATW) 2 111200.41 0 Tapi device 3 is: WAN Miniport (ATW) 1 111200.41 0 Tapi device 2 is: RAS VPN Line 0 111200.41 0 Tapi device 1 is: RAS PPPoE Line0000 111200.41 0 Tapi device 0 is: Conexant HSF V92 56K RTAD Speakerphone PCI Modem 111200.42 0 init vgmulti ver 5.2.3018 111200.45 0 Inband Signaling Config file not specified 111200.45 0 Loading VMB data begin 111200.45 0 Loading VMB data - about to delete old entries 111200.47 0 Loading VMB data - sorting/ordering 111200.47 0 Loading VMB data end 111200.53 0 init clear settings on 1 devices. 111200.53 0 Initialising... 111200.53 0 init attach vgs on 1 devices. 111200.53 0 Script Load C:\_ Files\VG_scripts\get_description.vgs 111200.53 0 init lineopen on 1 devices. 111200.53 0 Calling .lineOpen on device 1 111201.09 0 lineOpen(0)=> 111201.09 0 Calling .GetLineHandle on LineId 0 111201.09 0 hLine=66239 111201.09 0 Calling .GetProviderInfo on LineId 0 111201.09 0 tapi ProviderInfo: Windows Telephony Service Provider for Universal Modem Driver 111201.09 0 set provider type: PROVTYPE_MODEM 111201.09 0 Calling lineSetNumRings on lLineHandle 66239 111201.09 0 Waiting for a call... 111212.55 0 callstate OFFERING 66188 0 4 111212.55 0 ring 1 111218.58 0 ring 2 111218.58 0 Answer the call at 9/11/2004 11:12:18 AM 111218.58 0 lineAnswer(66188) => 66171 111218.58 0 callstate ACCEPTED 66188 0 0 111218.64 0 tapi Reply (LineEvReply) ok 66171 0 111218.64 0 callstate CONNECTED 66188 0 0 111218.64 0 callstate CONNECTED 66188,0,0 111218.64 0 WorkingModeTAPI@Connected= 111218.64 0 WorkingModeScript@Connected= 111218.64 0 Inband detection not enabled 111218.64 0 StartLoadedVgs at 9/11/2004 11:12:18 AM 111218.64 0 AddRVns [ScriptsPath]{C:\_ Files\VG_scripts\} 111218.64 0 AddRVns [ScriptPath]{C:\_ Files\VG_scripts} 111218.64 0 rv add [$RV_STARTTIME]{9/11/2004 11:12:18 AM} 111218.66 0 rv add [$RV_DEVICEID]{0} 111218.66 0 rv add [$RV_CIDNAME]{} 111218.66 0 AddRVns [PathApp]{C:\Program Files\VoiceGuide\} 111218.66 0 rv add [$RV_CIDNUMBER]{} 111218.66 0 timer clear 111218.66 0 [GetListingID] Number Input 111218.66 0 [GetListingID] Playing (C:\_ Files\VG_sound_files\enter_listing_id.wav) 111218.66 0 play set playid=790265 111218.69 0 PlaySoundStart ok [C:\_ Files\VG_sound_files\enter_listing_id.wav] 111218.70 0 timer clear 111218.70 0 wa(4109,79026500) 111221.86 0 dtmf 5 (66188,53,2) 111221.86 0 ScriptEventCode 53 iLineState=1300 111221.86 0 LsGetNbrsPlayWelcMsg 5 111222.44 0 PlaySoundStop err=0 111222.44 0 [GetListingID] Number Input 5 111222.44 0 path {5} not found 111222.44 0 timer set 6 EV_TIMEOUT_ENTERDATA 111228.89 0 timer fired EV_TIMEOUT_ENTERDATA 111228.89 0 ScriptEventCode 9006 iLineState=1301 111228.89 0 LsGetNbrsRxDigits EV_TIMEOUT_ENTERDATA 111228.89 0 timer clear 111228.89 0 rv add [GetListingID]{5} 111228.89 0 path {5} not found 111228.89 0 AddRVns [GetListingID_PathTaken]{success} 111228.89 0 timer clear 111228.89 0 [MySQLQuery] DB Query 111228.89 0 db ODBC mode used 111250.34 0 rv replace start: [SELECT pr_description FROM property WHERE pr_property_id=$RV[GetListingID]] 111250.34 0 rv ns [PathSysVoice]{}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[ScriptsPath]{C:\_ Files\VG_scripts\}[ScriptPath]{C:\_ Files\VG_scripts}[$RV_STARTTIME]{9/11/2004 11:12:18 AM}[$RV_DEVICEID]{0}[$RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[$RV_CIDNUMBER]{}[GetListingID]{5}[GetListingID_PathTaken]{success} 111250.34 0 rv replace end: [SELECT pr_description FROM property WHERE pr_property_id=5] 111250.34 0 db About to execute a Retrieve type operation [SELECT pr_description FROM property WHERE pr_property_id=5] 111250.42 0 db [MySQLQuery] row count=1 111250.42 0 rv add [MySQLQuery_RowCount]{1} 111250.42 0 db get RecordsetGetRowsMax 111250.44 0 db get 999 records. (row count=1) 111250.44 0 db update RVs 111250.44 0 ERROR 5.2.3018 RunModule:0:13:Type mismatch:VoiceGuide 111250.44 0 rv add [Hangup Time]{9/11/2004 11:12:50 AM} 111250.44 0 Hanging up call... [RunModule Error] 111250.44 0 RecSoundStop ok 111250.44 0 PlaySoundStop err=0 111250.44 0 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP 111250.44 0 fnHangupCall end 111250.66 0 callstate DISCONNECTED 66188 1 0 111250.66 0 ScriptEventCode 9250 iLineState=900 111250.66 0 LsAwaitingCalls EV_REMOTEPARTY_DISCONNECT 111250.66 0 rv add [Hangup Time]{9/11/2004 11:12:50 AM} 111250.66 0 Hanging up call... 111250.66 0 RecSoundStop ok 111250.66 0 PlaySoundStop err=0 111250.66 0 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP 111250.66 0 fnHangupCall end 111250.66 0 callstate IDLE 66188 0 0 111250.66 0 WorkingMode@Idle= 111250.66 0 timer clear 111250.66 0 timer set 1 EV_TIMEOUT_TIMETOREINITLINE 111250.66 0 tapi Reply (LineEvReply) ok 66137 0 111250.67 0 tapi Reply (LineEvReply) ok 66154 0 111251.72 0 timer fired EV_TIMEOUT_TIMETOREINITLINE 111251.72 0 ScriptEventCode 9008 iLineState=900 111251.72 0 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE 111251.72 0 ReinitTelephony due to IDLE 111251.72 0 tapic lineDeallocateCall(MainCall:66188) 0 111251.97 0 lineOpen(0)=> 111251.97 0 Waiting for a call... 111251.97 0 LineHandle=66120 111251.97 0 timer set 3 EV_TIMEOUT_ATERIDLE_ALLOWOUT 111252.34 0 dial start any summary:|0:rdy=0| 111253.34 0 dial start any summary:|0:rdy=0| 111254.34 0 dial start any summary:|0:rdy=0| 111255.30 0 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT 111255.30 0 ScriptEventCode 9013 iLineState=900 111256.33 0 Unloading Main Window tw.txt: 111200.328 ocxfn LogLevels 10,C:\Program Files\VoiceGuide\log\,tw.txt,,(null) 111200.328 ------------------------------------------------------------------------------ 111200.328 TAPIWrap OCX v1.84.0, May 20 2004 14:56:28 [For Pure Tapi] 111200.328 Started at 0911 111200.328 111200.328 ------------------------------------------------------------------------------ 111200.343 linec lineInitialize(0x94a668, 0x2d00000, 0x2d099e0, TapiWrap, 0x94a66c) => 0x0 111200.343 tapic lineNegotiateAPIVersion(0x800003ff, 0, 0x10003, 0x20001, 0x1916b8, 0x12c6e0) 111200.343 tapic lineGetDevCaps(0x800003ff, 0, 0x10004, 0, 0x19e8b0) call 111200.343 tapic lineGetDevCaps(0x800003ff, 0, 0x10004, 0, 0x19e8b0) => NO_ERROR (0) 111200.343 tapic lineGetIcon(0, 0, 0x1916c0) 111200.343 tapic lineNegotiateAPIVersion(0x800003ff, 1, 0x10003, 0x20001, 0x1a19e0, 0x12c6e0) 111200.343 tapic lineGetDevCaps(0x800003ff, 1, 0x10003, 0, 0x1aebd8) call 111200.343 tapic lineGetDevCaps(0x800003ff, 1, 0x10003, 0, 0x1aebd8) => NO_ERROR (0) 111200.343 tapic lineGetIcon(1, 0, 0x1a19e8) 111200.343 tapic lineNegotiateAPIVersion(0x800003ff, 2, 0x10003, 0x20001, 0x1aebe8, 0x12c6e0) 111200.343 tapic lineGetDevCaps(0x800003ff, 2, 0x10003, 0, 0x1bbde0) call 111200.343 tapic lineGetDevCaps(0x800003ff, 2, 0x10003, 0, 0x1bbde0) => NO_ERROR (0) 111200.343 tapic lineGetIcon(2, 0, 0x1aebf0) 111200.359 tapic lineNegotiateAPIVersion(0x800003ff, 3, 0x10003, 0x20001, 0x1bbdf0, 0x12c6e0) 111200.359 tapic lineGetDevCaps(0x800003ff, 3, 0x10003, 0, 0x1c8fe8) call 111200.359 tapic lineGetDevCaps(0x800003ff, 3, 0x10003, 0, 0x1c8fe8) => NO_ERROR (0) 111200.359 tapic lineGetIcon(3, 0, 0x1bbdf8) 111200.359 tapic lineNegotiateAPIVersion(0x800003ff, 4, 0x10003, 0x20001, 0x1c8ff8, 0x12c6e0) 111200.359 tapic lineGetDevCaps(0x800003ff, 4, 0x10003, 0, 0x1d61f0) call 111200.359 tapic lineGetDevCaps(0x800003ff, 4, 0x10003, 0, 0x1d61f0) => NO_ERROR (0) 111200.359 tapic lineGetIcon(4, 0, 0x1c9000) 111200.359 tapic lineNegotiateAPIVersion(0x800003ff, 5, 0x10003, 0x20001, 0x1d6200, 0x12c6e0) 111200.359 tapic lineGetDevCaps(0x800003ff, 5, 0x10004, 0, 0x1e33f8) call 111200.359 tapic lineGetDevCaps(0x800003ff, 5, 0x10004, 0, 0x1e33f8) => NO_ERROR (0) 111200.359 tapic lineGetIcon(5, 0, 0x1d6208) 111200.359 tapic lineNegotiateAPIVersion(0x800003ff, 6, 0x10003, 0x20001, 0x1e3408, 0x12c6e0) 111200.359 tapic lineGetDevCaps(0x800003ff, 6, 0x10004, 0, 0x1f0600) call 111200.359 tapic lineGetDevCaps(0x800003ff, 6, 0x10004, 0, 0x1f0600) => NO_ERROR (0) 111200.359 tapic lineGetIcon(6, 0, 0x1e3410) 111200.359 tapic lineNegotiateAPIVersion(0x800003ff, 7, 0x10003, 0x20001, 0x1f0610, 0x12c6e0) 111200.359 tapic lineGetDevCaps(0x800003ff, 7, 0x10004, 0, 0x1fd808) call 111200.359 tapic lineGetDevCaps(0x800003ff, 7, 0x10004, 0, 0x1fd808) => NO_ERROR (0) 111200.359 tapic lineGetIcon(7, 0, 0x1f0618) 111200.359 fn TAPI_ERR:LINEERR_OPERATIONUNAVAIL 111200.359 tapic lineNegotiateAPIVersion(0x800003ff, 8, 0x10003, 0x20001, 0x1fd818, 0x12c6e0) 111200.359 tapic lineGetDevCaps(0x800003ff, 8, 0x10004, 0, 0x20aa10) call 111200.359 tapic lineGetDevCaps(0x800003ff, 8, 0x10004, 0, 0x20aa10) => NO_ERROR (0) 111200.359 tapic lineGetIcon(8, 0, 0x1fd820) 111200.390 ocxfn GetLineCount() 111200.390 ocxfn GetLineName(sLineId=8) 111200.390 tapic lineGetDevCaps(0x800003ff, 8, 0x10004, 0, 0x210638) call 111200.390 tapic lineGetDevCaps(0x800003ff, 8, 0x10004, 0, 0x210638) => NO_ERROR (0) 111200.390 ocxfn GetLineName(sLineId=7) 111200.390 tapic lineGetDevCaps(0x800003ff, 7, 0x10004, 0, 0x211770) call 111200.406 tapic lineGetDevCaps(0x800003ff, 7, 0x10004, 0, 0x211770) => NO_ERROR (0) 111200.406 ocxfn GetLineName(sLineId=6) 111200.406 tapic lineGetDevCaps(0x800003ff, 6, 0x10004, 0, 0x211770) call 111200.406 tapic lineGetDevCaps(0x800003ff, 6, 0x10004, 0, 0x211770) => NO_ERROR (0) 111200.406 ocxfn GetLineName(sLineId=5) 111200.406 tapic lineGetDevCaps(0x800003ff, 5, 0x10004, 0, 0x211770) call 111200.406 tapic lineGetDevCaps(0x800003ff, 5, 0x10004, 0, 0x211770) => NO_ERROR (0) 111200.406 ocxfn GetLineName(sLineId=4) 111200.406 tapic lineGetDevCaps(0x800003ff, 4, 0x10003, 0, 0x211770) call 111200.406 tapic lineGetDevCaps(0x800003ff, 4, 0x10003, 0, 0x211770) => NO_ERROR (0) 111200.406 ocxfn GetLineName(sLineId=3) 111200.406 tapic lineGetDevCaps(0x800003ff, 3, 0x10003, 0, 0x211770) call 111200.406 tapic lineGetDevCaps(0x800003ff, 3, 0x10003, 0, 0x211770) => NO_ERROR (0) 111200.406 ocxfn GetLineName(sLineId=2) 111200.406 tapic lineGetDevCaps(0x800003ff, 2, 0x10003, 0, 0x211770) call 111200.406 tapic lineGetDevCaps(0x800003ff, 2, 0x10003, 0, 0x211770) => NO_ERROR (0) 111200.406 ocxfn GetLineName(sLineId=1) 111200.406 tapic lineGetDevCaps(0x800003ff, 1, 0x10003, 0, 0x211770) call 111200.406 tapic lineGetDevCaps(0x800003ff, 1, 0x10003, 0, 0x211770) => NO_ERROR (0) 111200.406 ocxfn GetLineName(sLineId=0) 111200.406 tapic lineGetDevCaps(0x800003ff, 0, 0x10004, 0, 0x211770) call 111200.406 tapic lineGetDevCaps(0x800003ff, 0, 0x10004, 0, 0x211770) => NO_ERROR (0) 111200.531 ocxfn LineOpen(sLineId=0) 111200.531 tapic lineNegotiateAPIVersion(0x800003ff, 0, 0x10003, 0x20001, 0x1916b8, 0x12dfec) 111200.531 tapic lineGetDevCaps(0x800003ff, 0, 0x10004, 0, 0x241590) call 111200.546 tapic lineGetDevCaps(0x800003ff, 0, 0x10004, 0, 0x241590) => NO_ERROR (0) 111200.546 tapic lineGetIcon(0, 0, 0x1916c0) 111200.546 tapic lineGetDevCaps(0x800003ff, 0, 0x10004, 0, 0x241590) call 111200.546 tapic lineGetDevCaps(0x800003ff, 0, 0x10004, 0, 0x241590) => NO_ERROR (0) 111200.546 tapic lineOpen(0x800003ff, 0, 0x1916b4, 0x10004, 0, 0x1916a8, 0x4, LINEMEDIAMODE_INTERACTIVEVOICE | LINEMEDIAMODE_AUTOMATEDVOICE, 0) 111200.812 tapic lineGetID(0x102bf, 0, 0, 0x1, 0x7fd0008, wave/in) LINECALLSELECT_LINE hLineInfo 111201.078 tapic lineGetID(0x102bf, 0, 0, 0x1, 0x7fd0008, wave/in) => 0x0 111201.078 tapic lineGetID => 1 111201.078 tapic lineGetID(0x102bf, 0, 0, 0x1, 0x7fd0008, wave/out) LINECALLSELECT_LINE hLineInfo 111201.078 tapic lineGetID(0x102bf, 0, 0, 0x1, 0x7fd0008, wave/out) => 0x0 111201.078 tapic lineGetID => 1 111201.078 ocxfn GetLineName(sLineId=0) 111201.078 tapic lineGetDevCaps(0x800003ff, 0, 0x10004, 0, 0x243378) call 111201.078 tapic lineGetDevCaps(0x800003ff, 0, 0x10004, 0, 0x243378) => NO_ERROR (0) 111201.093 wavec waveInGetDevCaps(0x1, 0x12e050, 0x30) => 0 111201.093 wavec waveOutGetDevCaps(0x1, 0x12e01c, 0x34) => 0 111201.093 wave IN:[Modem #1 Line Record v80.0 format=0x0, channels=0x1] OUT:[Modem #1 Line Playback v80.0 format=0x0, channels=0x1, support=0x0] 111201.093 ocxfn LineOpen(0, 0, 0, , ) 111201.093 tapic lineGetID(0x102bf, 0, 0, 0x1, 0x7fd0008, wave/in) LINECALLSELECT_LINE hLineInfo 111201.093 tapic lineGetID(0x102bf, 0, 0, 0x1, 0x7fd0008, wave/in) => 0x0 111201.093 tapic lineGetID => 1 111201.093 tapic lineGetID(0x102bf, 0, 0, 0x1, 0x7fd0008, wave/out) LINECALLSELECT_LINE hLineInfo 111201.093 tapic lineGetID(0x102bf, 0, 0, 0x1, 0x7fd0008, wave/out) => 0x0 111201.093 tapic lineGetID => 1 111201.093 ocxfn GetLineName(sLineId=0) 111201.093 tapic lineGetDevCaps(0x800003ff, 0, 0x10004, 0, 0x243378) call 111201.093 tapic lineGetDevCaps(0x800003ff, 0, 0x10004, 0, 0x243378) => NO_ERROR (0) 111201.093 wavec waveInGetDevCaps(0x1, 0x12dfb4, 0x30) => 0 111201.093 wavec waveOutGetDevCaps(0x1, 0x12df80, 0x34) => 0 111201.093 wave IN:[Modem #1 Line Record v80.0 format=0x0, channels=0x1] OUT:[Modem #1 Line Playback v80.0 format=0x0, channels=0x1, support=0x0] 111201.093 ocxfn GetProviderInfo(sLineId=0) 111201.093 tapic lineGetDevCaps(0x800003ff, 0, 0x10004, 0, 0x243448) call 111201.093 tapic lineGetDevCaps(0x800003ff, 0, 0x10004, 0, 0x243448) => NO_ERROR (0) 111201.093 fn GetProviderInfo => UnimodemV 111201.093 ocxfn SilenceDetectSet(sLineId=0, sTimeLen=0, sVolumeLevel=0) 111212.546 tapie LINE_CALLSTATE(0, 0x1028c, 0x2, 0x0, 0x4) 111212.546 tapic lineMonitorDigits(0x1028c, 0x2) => 0x0 111212.546 tapic lineMonitorMedia(0x1028c, 0xfc) => -2147483601 111212.546 fn TAPI_ERR:LINEERR_INVALMEDIAMODE 111212.546 tapic lineGetCallInfo(0x1028c, 0x246ed8) 111212.546 eng No CallerId info available at this time 111212.546 tapie LINE_LINEDEVSTATE(0, 0x102bf, 0x2, 0x1, 0x1) 111218.562 tapie LINE_LINEDEVSTATE(0, 0x102bf, 0x2, 0x1, 0x2) 111218.578 tapie LINE_CALLSTATE(0, 0x1028c, 0x4, 0x0, 0x0) 111218.640 tapie LINE_REPLY(0, 0x0, 0x1027b, 0x0) 111218.640 tapie LINE_CALLSTATE(0, 0x1028c, 0x100, 0x0, 0x0) 111218.640 tapic lineGetID(0x102bf, 0, 0, 0x1, 0x248368, wave/in) LINECALLSELECT_LINE hLineInfo 111218.640 tapic lineGetID(0x102bf, 0, 0, 0x1, 0x248368, wave/in) => 0x0 111218.640 tapic lineGetID => 1 111218.640 tapic lineGetID(0x102bf, 0, 0, 0x1, 0x248368, wave/out) LINECALLSELECT_LINE hLineInfo 111218.640 tapic lineGetID(0x102bf, 0, 0, 0x1, 0x248368, wave/out) => 0x0 111218.640 tapic lineGetID => 1 111218.640 info This device does not support Volume control, dwSupport=0x0 111218.656 ocxfn PlayMultiDelimited(sLineId=0, strFile1=C:\_ Files\VG_sound_files\enter_listing_id.wav, lPlayId=0xc0ef9, lOptions=0x0, strOptions=) 111218.656 tr 5 ResetWavOutAndContinuePlay start 111218.656 play FileMmioOpenAndAscend start C:\_ Files\VG_sound_files\enter_listing_id.wav 111218.656 play FileMmioOpenAndAscend end 111218.656 fn play wav format: wFormatTag=0x1, nChannels=1, nSamplesPerSec=8000, nAvgBytesPerSec=16000, nBlockAlign=2, wBitsPerSample=16, cbSize=0 111218.656 wavec waveOutOpen(0x0, 0x1, 0x1916d0, 0x0, 0x0, 0x1) => 0 (MMSYSERR_OK) - format query 111218.687 wavec waveOutOpen(0x191704, 0x1, 0x1916d0, 0x1e016c, 0x1916a8, 0x10002) => 0 (MMSYSERR_OK) ... hli->hWaveOut=0x248c58 111218.687 wavec waveOutReset(0x248c58) => 0(MMSYSERR_OK) fn:PlaySoundStart 111218.687 tapic lineMonitorDigits(0x1028c, 0x2) => 0x0 111218.687 tapic lineMonitorMedia(0x1028c, 0x7c) => -2147483601 111218.687 fn TAPI_ERR:LINEERR_INVALMEDIAMODE 111218.687 play FileMmioOpenAndAscend start C:\_ Files\VG_sound_files\enter_listing_id.wav 111218.687 play FileMmioOpenAndAscend end 111218.687 play LoadCurrFileToPlay start 111218.687 play FileMmioOpenAndAscend start C:\_ Files\VG_sound_files\enter_listing_id.wav 111218.687 play FileMmioOpenAndAscend end 111218.687 iPlayListIdxCurr 0 wav format: wFormatTag=0x1, nChannels=1, nSamplesPerSec=8000, nAvgBytesPerSec=16000, nBlockAlign=2, wBitsPerSample=16, cbSize=0 111218.687 wavec waveOutWrite HeapAllocs bytes: DataToPlay=65756, WaveHdr=32, UserData=12 111218.687 wavehdr: lpData=0x7fb0ff8, dwBufferLength=65756, dwBytesRecorded=0, dwUser=0x2481e8, dwFlags=0x0, dwLoops=0x0, lpNext=0x0, reserved=0x0 111218.687 wavec waveOutPrepareHeader(0x248c58, 0x24b108, 0x20) => 0 111218.687 wavec waveOutWrite(0x248c58, 0x24b108, 0x20) => 0 111218.687 play LoadCurrFileToPlay end 111218.687 tr fn ResetWavOutAndContinuePlay LoadCurrFileToPlay returned 111218.687 tr fn PostMessage WM_FIRE_PLAY_WDOG_SET_EVENT (linked buffers) params: 0 79026500 111218.703 fn OnFirePlayPlayWdogSetEvent start 111218.703 ocxev PlayWdogSet(dwLineId=0, dwPlayId=0x4b5d944, LenMsecs=4109) 111221.859 tapie LINE_MONITORDIGITS(0, 0x1028c, 0x35) 111221.859 ocxfn PlayStop(sLineId=0) 111221.859 fn PlaySoundStop start 111221.859 tr fn PlaySoundStop calling PostMessage WM_FIRE_PLAY_WDOG_CLEAR_EVENT 111221.859 wavec waveOutReset(0x248c58) call, caller: PlaySoundStop 111221.859 wavec waveOutReset(0x248c58) => 0 (MMSYSERR_OK), caller: PlaySoundStop 111221.859 wavec waveOutClose(0x248c58) call, caller: PlaySoundStop 111222.437 wavec waveOutClose(0x248c58) => 0 (MMSYSERR_OK), caller: PlaySoundStop 111222.437 fn OnFirePlayPlayWdogClearEvent start 111222.437 ocxev PlayWdogClear(dwLineId=0, dwPlayId=0x4b5d944) 111222.437 wavee WOM_DONE(0x248c58, 0x24b108) (callback window message) 111222.437 wavee WOM_DONE(0x248c58, 0x3bd, 0x1916a8, 0x24b108, 0x0) psch 111222.437 fn psch hwo(0x248c58) != hli->hWaveOut(0x0) 111222.437 fn psch lpUserData=0x2481e8 : dwPlayId=790265, hli=0x1916a8, iFileIdx=0x0 111222.437 fn psch hli=0x1916a8 : dwPlayId=790265, iPlayListIdxCurr=0xfffffffe 111222.437 fn psch not clearing watchdog 111222.437 wavec waveOutUnprepareHeader(0x248c58, 0x24b108, 0x20) call unimodem 111222.437 wavec waveOutUnprepareHeader(0x248c58, 0x24b108, 0x20) => 5 (MMSYSERR_INVALHANDLE) unimodem 111250.437 ocxfn RecStop(sLineId:0) 111250.437 wavec waveInReset(0x0) => 5 111250.437 linec lineMonitorTones(0x1028c, 0x0, 1) => 0x8000003c (disabling monitoring for silence/tones) 111250.437 ocxfn PlayStop(sLineId=0) 111250.437 fn PlaySoundStop start 111250.437 fn PlaySoundStop line not playing a sound file. 0x0 111250.437 ocxfn LineDrop(sLineId=0, sOpt=0) 111250.437 tapic lineDrop(0x1028c, , 0) call in ocxfn_LineDrop 111250.437 tapic lineDrop(0x1028c, , 0) => async:66137 (66137) 111250.656 tapie LINE_CALLSTATE(0, 0x1028c, 0x4000, 0x1, 0x0) 111250.656 ocxfn RecStop(sLineId:0) 111250.656 wavec waveInReset(0x0) => 5 111250.656 linec lineMonitorTones(0x1028c, 0x0, 1) => 0x8000003c (disabling monitoring for silence/tones) 111250.656 ocxfn PlayStop(sLineId=0) 111250.656 fn PlaySoundStop start 111250.656 fn PlaySoundStop line not playing a sound file. 0x0 111250.656 ocxfn LineDrop(sLineId=0, sOpt=0) 111250.656 tapic lineDrop(0x1028c, , 0) call in ocxfn_LineDrop 111250.656 tapic lineDrop(0x1028c, , 0) => async:66154 (66154) 111250.656 tapie LINE_CALLSTATE(0, 0x1028c, 0x1, 0x0, 0x0) 111250.656 tapie LINE_REPLY(0, 0x0, 0x10259, 0x0) 111250.656 tapie LINE_REPLY(0, 0x0, 0x1026a, 0x0) 111251.718 ocxfn LineClose(sLineId:0) 111251.718 tapic lineNegotiateAPIVersion(0x800003ff, 0, 0x10003, 0x20001, 0x1916b8, 0x12f110) 111251.718 tapic lineGetDevCaps(0x800003ff, 0, 0x10004, 0, 0x7fb1890) call 111251.718 tapic lineGetDevCaps(0x800003ff, 0, 0x10004, 0, 0x7fb1890) => NO_ERROR (0) 111251.718 tapic lineGetIcon(0, 0, 0x1916c0) 111251.718 ocxfn LineOpen(0, 0, 0, , ) 111251.718 tapic lineNegotiateAPIVersion(0x800003ff, 0, 0x10003, 0x20001, 0x1916b8, 0x12e450) 111251.718 tapic lineGetDevCaps(0x800003ff, 0, 0x10004, 0, 0x7fb1890) call 111251.718 tapic lineGetDevCaps(0x800003ff, 0, 0x10004, 0, 0x7fb1890) => NO_ERROR (0) 111251.718 tapic lineGetIcon(0, 0, 0x1916c0) 111251.718 tapic lineGetDevCaps(0x800003ff, 0, 0x10004, 0, 0x7fb1890) call 111251.718 tapic lineGetDevCaps(0x800003ff, 0, 0x10004, 0, 0x7fb1890) => NO_ERROR (0) 111251.718 tapic lineOpen(0x800003ff, 0, 0x1916b4, 0x10004, 0, 0x1916a8, 0x4, LINEMEDIAMODE_INTERACTIVEVOICE | LINEMEDIAMODE_AUTOMATEDVOICE, 0) 111251.968 tapic lineGetID(0x10248, 0, 0, 0x1, 0x2490f8, wave/in) LINECALLSELECT_LINE hLineInfo 111251.968 tapic lineGetID(0x10248, 0, 0, 0x1, 0x2490f8, wave/in) => 0x0 111251.968 tapic lineGetID => 1 111251.968 tapic lineGetID(0x10248, 0, 0, 0x1, 0x2490f8, wave/out) LINECALLSELECT_LINE hLineInfo 111251.968 tapic lineGetID(0x10248, 0, 0, 0x1, 0x2490f8, wave/out) => 0x0 111251.968 tapic lineGetID => 1 111251.968 ocxfn GetLineName(sLineId=0) 111251.968 tapic lineGetDevCaps(0x800003ff, 0, 0x10004, 0, 0x7fb1890) call 111251.968 tapic lineGetDevCaps(0x800003ff, 0, 0x10004, 0, 0x7fb1890) => NO_ERROR (0) 111251.968 wavec waveInGetDevCaps(0x1, 0x12e4b8, 0x30) => 0 111251.968 wavec waveOutGetDevCaps(0x1, 0x12e484, 0x34) => 0 111251.968 wave IN:[Modem #1 Line Record v80.0 format=0x0, channels=0x1] OUT:[Modem #1 Line Playback v80.0 format=0x0, channels=0x1, support=0x0] 111251.968 ocxfn SilenceDetectSet(sLineId=0, sTimeLen=30, sVolumeLevel=10) 111256.218 tapic lineNegotiateAPIVersion(0x800003ff, 0, 0x10003, 0x20001, 0x1916b8, 0x12ee30) 111256.218 tapic lineGetDevCaps(0x800003ff, 0, 0x10004, 0, 0x7fb1890) call 111256.218 tapic lineGetDevCaps(0x800003ff, 0, 0x10004, 0, 0x7fb1890) => NO_ERROR (0) 111256.218 tapic lineGetIcon(0, 0, 0x1916c0) 111256.234 linec lineShutdown(0x800003ff) => 0x0 Share this post Link to post
SupportTeam Report post Posted 09/12/2004 04:43 AM Please update your VG v5.2.3 install with the .exe attached below and run the test against a TEXT or MEDIUMTEXT type field, then post the relevant section of the MMDDvgm.txt log file - this should give us info on exactly where the error is occurring. VgMulti_5.2.3030.zip Share this post Link to post
Guest Gabe Report post Posted 09/12/2004 06:42 AM I've replaced the VGMulti.exe file and the following is from the MMDDvgm.txt file after testing on a TEXT column: 023231.16 0 AddRVns [GetListingID_PathTaken]{success} 023231.16 0 timer clear 023231.16 0 [MySQLQuery] DB Query 023231.16 0 db ODBC mode used 023252.73 0 rv replace start: [SELECT pr_description FROM property WHERE pr_property_id=$RV[GetListingID]] 023252.73 0 rv ns [PathSysVoice]{}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[ScriptsPath]{C:\_ Files\VG_scripts\}[ScriptPath]{C:\_ Files\VG_scripts}[$RV_STARTTIME]{9/12/2004 2:32:17 AM}[$RV_DEVICEID]{0}[$RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[$RV_CIDNUMBER]{}[GetListingID]{5}[GetListingID_PathTaken]{success} 023252.73 0 rv replace end: [SELECT pr_description FROM property WHERE pr_property_id=5] 023252.75 0 db About to execute a Retrieve type operation [SELECT pr_description FROM property WHERE pr_property_id=5] 023252.86 0 db [MySQLQuery] row count=1 023252.86 0 rv add [MySQLQuery_RowCount]{1} 023252.86 0 db get RecordsetGetRowsMax 023252.86 0 db get 999 records. (row count=1) 023252.86 0 db update RVs 1 023252.86 0 db update RVs 2 cols=0 rows=0 023252.88 0 ERROR 5.2.3030 RunModule 5450 13:Type mismatch (VoiceGuide) 023252.88 0 rv add [Hangup Time]{9/12/2004 2:32:52 AM} 023252.89 0 Hanging up call... [RunModule Error] 023252.89 0 RecSoundStop ok 023252.89 0 PlaySoundStop err=0 023252.89 0 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP 023252.89 0 fnHangupCall end Share this post Link to post
SupportTeam Report post Posted 09/12/2004 07:26 AM OK, we now can see where the error is occurring but cannot yet tell why - can you please update with this .exe and run the query again. The script will now not hang up after query but you probably will not see anything returned in RV - the entries in MMDDvgm.txt trace should give us more info now - please post the trace again after running your test. VgMulti_5.2.3032.zip Share this post Link to post
Guest Gabe Report post Posted 09/12/2004 03:25 PM Ok, below are the results: 110753.39 0 db [MySQLQuery] row count=1 110753.39 0 rv add [MySQLQuery_RowCount]{1} 110753.39 0 db get RecordsetGetRowsMax 110753.39 0 db get 999 records. (row count=1) 110753.39 0 db update RVs start 110753.39 0 db update RVs cols=1 rows=1 110753.42 0 db test CStr(vRetData(0, 0))=Error 40035 110753.42 0 db about to close dbDbqDatabase 110753.42 0 db going down path [True] 110753.42 0 timer clear 110753.42 0 [ReadDescription] Playing Share this post Link to post
SupportTeam Report post Posted 09/13/2004 12:09 AM Looks like the ODBC Driver itself is returning this error so there is nothing that can be done by VoiceGuide to fix this. The only solution is to change the database to use VARCHAR fields instead of TEXT or MEDIUMTEXT. Share this post Link to post
Guest jmiller808 Report post Posted 11/18/2005 05:00 PM i am actually getting the same type mismatch error using sql server. i found what was causing it for me. it looks like voice guide has a problem with columns defined as varchar(8000). Share this post Link to post
Guest Derek Report post Posted 01/23/2006 07:01 PM I'm getting this same problem. Is the problem here the ODBC driver or a problem in Voiceguide? What's the workarround? 110753.39 0 db [MySQLQuery] row count=1 110753.39 0 rv add [MySQLQuery_RowCount]{1} 110753.39 0 db get RecordsetGetRowsMax 110753.39 0 db get 999 records. (row count=1) 110753.39 0 db update RVs start 110753.39 0 db update RVs cols=1 rows=1 110753.42 0 db test CStr(vRetData(0, 0))=Error 40035 110753.42 0 db about to close dbDbqDatabase 110753.42 0 db going down path [True] 110753.42 0 timer clear 110753.42 0 [ReadDescription] Playing Share this post Link to post
SupportTeam Report post Posted 01/24/2006 01:03 AM Have you tried changing around the DB field defintions as per prior posts in this thread? Share this post Link to post
Guest Derek Report post Posted 01/24/2006 05:39 PM No not yet. This is easier said than done in this case. If this is the only workaround I'll try it. Is it known why this happens? Is it the odbc driver or Voiceguide? Thanks. Share this post Link to post
SupportTeam Report post Posted 01/24/2006 08:55 PM Apparently it's the ODBC driver - but it could be the way MDAC (which VG uses) interacts with the ODBC driver... Either way, right now the solution for such problems seems to be to alter the DB table definition. Share this post Link to post
