Pctel Hsp56 Mr Data/fax
I have a PCTel HSP56 MR Data/Fax,
in your forum somebody say we can use Voice Guide with that modem,
but I can´t.
It says that modem uses PCtel AMR interface (on-board) ?
I receive the message that my modem is not a voice modem,
I had install the wave and tapi drivers.
Thanks a lot.
If you cannot get the modem to work then the simplest and usually the quickest approach is to try another modem - or better yet just purchase a Dialogic card.
We want to buy Voice Guide, but first we want to try with a modem.
I try it with Toshiba V.90. But appears the same message.
Thanks a lot.
