Datediff Evaluation
I have tried everything I can think of to get DateDiff to work. Here is the excerpt from the .vgl log. I am trying to calculate an age (in years) based on caller's input and the current day.
{DateDiff("yyyy",01/01/1976, 09/09/2004)}[Eval Age]{0}[Age]{0}
I have been to the Microsoft scripting web page that explains how to use this function, but it just doesn't seem to be working because I always get an age of zero...
Please post your script here and indicate in which module the DateDiff function is called, we can then have a look at it.
It took some some trial and error, but I did figure it out. You need to encpsulate the date within quotes.
DateDiff("yyyy", "01/01/1976", "09/09/2004")
But I ended up not even using this method because the result isn't accurate to the day, just the year. It's really only evaluating 2004-1976 = 28. For this application, I needed to be accurate to the day.
My real goal is to determine whether the caller is at least 21. So I used:
DateAdd("yyyy", 21, "01/01/1976") <= "$RV_MM/$RV_DD/$RV_YEAR"
It seems to work much better this way.
Thanks for your help!
