3com Nbx
Trying to use Voiceguide with a 3Com NBX with WAV/TAPI drivers, I'm certain they are working because I can run other WAV/TAPI application (Crystal Voice).
I can associate a script with the TAPI line but it never answers.
Using the latest version of Voice Guide and the 3Com drivers.
Thanks,
Samuel Castro
Is "3Com NBX" a Voice modem?
Could you please post a copy of VoiceGuide's Debug Printout which captures the incoming call, this will allow us to see what is going wrong.
Which version of Windows are you using?
What is Crystal Voice?
Thanks,
Samuel Castro
Samuel, Did you ever resolve this issue. I am running into the same?
Tony Balasubramanian
