Datatype
My data type for holding the Credit Card number in the Access Database is Text data type, because I can not find any other data type that can hold 16 digit number.
Would you please let me know why my inquiry result for GetCC is converting to scientific number. below is part my log file.
Files\VoiceGuide\system\}[scriptsPath]{C:\Program Files\ivg\Scripts\PBPScript\MCAC\starting scrip\DepositCashInRefilllCard\}[scriptPath]{C:\Program Files\ivg\Scripts\PBPScript\MCAC\starting scrip\DepositCashInRefilllCard}[$RV_STARTTIME]{9/13/2004 11:17:09 PM}[$RV_DEVICEID]{6}[$RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[$RV_CIDNUMBER]{}[retrysetCC1_Input]{0}[retrysetCC1]{0}[retrycount]{0}[GetCNu
]{116940}[GetCNum_PathTaken]{success}[lookForCNum_RowCount]{1}[lookForCNum_1_1]{
16940}[lookforCNumResult_Input]{116940}[lookforCNumResult]{116940}[retrysetPW_In
ut]{0}[retrysetPW]{0}[retrycount]{0}[GetPW]{4072}[GetPW_PathTaken]{success}[look
orPW_RowCount]{1}[lookForPW_1_1]{4072}[lookforPWResult_Input]{4072}[lookforPWRes
lt]{4072}[lookForCCNum_RowCount]{4}[lookForCCNum_1_1]{5424180168228010}[lookForC
Num_1_2]{5424180168228010}[lookForCCNum_1_3]{5424180168228010}[lookForCCNum_1_4]
5424180168228010}[GetCC_Input]{5424180168228010}[GetCC]{5.42418016822801E+15}[lo
kForExp_RowCount]{4}[lookForExp_1_1]{505}[lookForExp_1_2]{505}[lookForExp_1_3]{5
5}[lookForExp_1_4]{505}[GetExp_Input]{505}[GetExp]{505}[setGetExp_Input]{"505"}[setGetExp]{505}[GetExp]{505}[checkExpLen_Input]{len("505") = 4}[checkExpLen]{False}[retryincExp_Input]{0+1}[retryincExp]{1}[retrycount]{1}[Ge
Exp2]{0505}[GetExp2_PathTaken]{success}[setGetExp2_Input]{"0505"}[setGetExp2]{0505}[GetExp]{0505}[checkExpLen_2_Input]{len("0505") = 4}[checkExpLen_2]{True}[check Exp_111]{}[uPDATEExp2_RowCount]{1}[GetAmt]{500}[GetAmt_PathTaken]{success}[check
mtLen_Input]{500>100}[checkAmtLen]{True}[checkAmtSize1_Input]{500 <= 2000}[checkAmtSize1]{True}[ConfirmOrder]{1}
I assume that module "GetCC" is an Evaluate Expression module?
Try using quotes around the input RV - that will force the RV to be evaluated as a string.
