trouble Report post Posted 09/14/2004 11:43 PM Hi, We are using VG with a new 4 port dialogic card and all seems to be working except when we do an announced transfer and the extn is busy. It seems the system does not recognize that the extn is busy and the caller is just left on hold. What we want is when the extn is busy is for the call to be retrieved so we can forward to voicemail or another extn We are using a Panasonic KX816 PABX with a flash time of 10ms on the dialogic board. All other functions seem to work fine. Any ideas....event log for a transfer to a busy extn included below Thanks Dave Y 120021.78 8 linedevstate 2048 0 0 120021.79 8 callstate OFFERING 66392 0 4 120021.79 8 No old processes from last call (could not obtain handle) 1276, 1588 120021.79 8 Answer the call at 14/09/2004 12:00:21 PM 120021.79 8 lineAnswer(66392) => 65606 120021.80 8 callinfo CALLEDID 120021.80 8 callinfo ORIGIN 120021.80 8 ring 0 120022.33 8 callstate CONNECTED 66392 1 0 120022.34 8 callstate CONNECTED 66392,1,0 120022.34 8 WorkingModeTAPI@Connected= 120022.34 8 WorkingModeScript@Connected= 120022.35 8 Inband detection not enabled 120022.35 8 StartLoadedVgs at 14/09/2004 12:00:22 PM 120022.35 8 AddRVns [scriptsPath]{C:\Program Files\VoiceGuide\Prowess\} 120022.36 8 AddRVns [scriptPath]{C:\Program Files\VoiceGuide\Prowess} 120022.36 8 rv add [$RV_STARTTIME]{14/09/2004 12:00:22 PM} 120022.36 8 rv add [$RV_DEVICEID]{8} 120022.36 8 rv add [$RV_CIDNAME]{} 120022.37 8 AddRVns [PathApp]{C:\Program Files\VoiceGuide\} 120022.37 8 rv add [$RV_CIDNUMBER]{} 120022.37 8 tapi Reply (LineEvReply) ok 65606 0 120022.39 8 callinfo MONITORMODES 120022.43 8 timer clear 120022.43 8 [Welcome] Number Input 120022.43 8 [Welcome] Playing (Kaz Recordings\Welcome.wav) 120022.44 8 play set playid=469604 120022.46 8 PlaySoundStart ok [C:\Program Files\VoiceGuide\Prowess\Kaz Recordings\Welcome.wav] 120022.46 8 timer clear 120022.47 8 wa(17454,46960400) 120022.47 8 callinfo MONITORMODES 120025.86 8 dtmf 2 (66392,50,2) 120025.86 8 ScriptEventCode 50 iLineState=1300 120025.87 8 LsGetNbrsPlayWelcMsg 2 120025.92 8 PlaySoundStop err=0 120025.92 8 [Welcome] Number Input 2 120025.93 8 rv add [Welcome]{2} 120025.93 8 timer clear 120025.94 8 timer set 0.4 EV_TIMEOUT_READYTOBEGINTRANSFER 120026.33 8 timer fired EV_TIMEOUT_READYTOBEGINTRANSFER 120026.33 8 ScriptEventCode 9012 iLineState=1900 120026.33 8 LsXferStart EV_TIMEOUT_READYTOBEGINTRANSFER 120026.34 8 timer set 15 EV_TIMEOUT_ANNOUNCED_TRANSFER_ATTEMPT_TOOK_TOO_LONG 120026.34 8 [PP Support] Announced Transfer to 210 (Generate) 120026.35 8 tapic lineGenerateDigits(66392,!,0) => 0 120026.61 8 generate LINEGENERATETERM_DONE 120026.61 8 timer set 1 EV_TAPI_GENERATE 120027.55 8 timer fired EV_TAPI_GENERATE 120027.55 8 ScriptEventCode 9602 iLineState=1900 120027.55 8 LsXferStart EV_TAPI_GENERATE 120027.56 8 timer set 1 EV_HOOKFLASHFINISHED 120028.56 8 timer fired EV_HOOKFLASHFINISHED 120028.56 8 ScriptEventCode 9200 iLineState=1905 120028.56 8 LsXferPlayVts EV_HOOKFLASHFINISHED 120028.57 8 tapic lineGenerateDigits(66392,210,0) => 0 120028.98 8 generate LINEGENERATETERM_DONE 120028.98 8 timer set 1 EV_TAPI_GENERATE 120029.89 8 timer fired EV_TAPI_GENERATE 120029.89 8 ScriptEventCode 9602 iLineState=1905 120029.89 8 LsXferPlayVts EV_TAPI_GENERATE 120029.89 8 [PP Support] Playing (Kaz Recordings\PropPro Announce.wav) 120029.90 8 play set playid=477065 120029.91 8 PlaySoundStart ok [C:\Program Files\VoiceGuide\Prowess\Kaz Recordings\PropPro Announce.wav] 120029.91 8 timer clear 120029.93 8 wa(7127,47706500) 120029.93 8 callinfo MONITORMODES 120037.07 8 wb(47706500) 120037.11 8 play end current play (playid=477065) 120037.13 8 ScriptEventCode 8001 iLineState=1906 120037.13 8 LsXferPlayAnn EV_PLAY_FINISHED 120037.13 8 LsXferPlayAnn EV_TIMEOUT_REPLAYMSG 120037.14 8 [PP Support] Playing (Kaz Recordings\PropPro Announce.wav) 120037.14 8 play set playid=484295 120037.14 8 PlaySoundStart ok [C:\Program Files\VoiceGuide\Prowess\Kaz Recordings\PropPro Announce.wav] 120037.16 8 timer clear 120037.16 8 wa(7127,48429500) 120037.16 8 callinfo MONITORMODES 120040.27 8 callstate DISCONNECTED 66392 0 0 120040.28 8 ScriptEventCode 9250 iLineState=1906 120040.28 8 LsXferPlayAnn EV_REMOTEPARTY_DISCONNECT 120040.28 8 timer set 1 EV_PLAY_FINISHED 120040.34 8 PlaySoundStop err=0 120041.27 8 timer fired EV_PLAY_FINISHED 120041.27 8 ScriptEventCode 8001 iLineState=1906 120041.27 8 LsXferPlayAnn EV_PLAY_FINISHED 120041.28 8 tapic lineGenerateDigits(66392,!,0) => LINEERR_INVALCALLSTATE [8000001C] 120041.28 8 rv add [Hangup Time]{14/09/2004 12:00:41 PM} 120041.28 8 Hanging up call... [lineGenerateDigits ret=-2147483620] 120041.29 8 RecSoundStop ok 120041.29 8 PlaySoundStop err=0 120041.30 8 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP 120041.30 8 fnHangupCall end 120041.34 8 linedevstate 2048 0 0 120041.35 8 callstate IDLE 66392 0 0 120041.35 8 WorkingMode@Idle= 120041.35 8 timer clear 120041.36 8 timer set 1 EV_TIMEOUT_TIMETOREINITLINE 120041.36 8 tapi Reply (LineEvReply) ok 66460 0 120042.31 8 timer fired EV_TIMEOUT_TIMETOREINITLINE 120042.31 8 ScriptEventCode 9008 iLineState=900 120042.31 8 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE 120042.32 8 ReinitTelephony due to IDLE 120042.33 8 tapic lineDeallocateCall(MainCall:66392) 0 120042.39 8 lineOpen(8)=> 120042.40 8 Waiting for a call... 120042.40 8 LineHandle=66477 120042.40 8 timer set 3 EV_TIMEOUT_ATERIDLE_ALLOWOUT 120043.32 0 dial start any summary:|5:idx=0|6:idx=0|7:idx=0|8:rdy=0| 120044.37 0 dial start any summary:|5:idx=0|6:idx=0|7:idx=0|8:rdy=0| 120045.41 0 dial start any summary:|5:idx=0|6:idx=0|7:idx=0|8:rdy=0| 120045.42 8 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT 120045.42 8 ScriptEventCode 9013 iLineState=900 Share this post Link to post
