Guest Dominik Report post Posted 09/15/2004 10:07 AM Hi, Is it possible to empty or unset or delete a DB query variable? Scenario: 1. I query database with DB module (module name is rs) 2. a result count is i.e. 4, $RV[rs_RowCount] 3. $RV[rs_x_1] to $RV[rs_x_4] are set 4. I query DB again with the same module 5. this time the result count is let's say 3, $RV[rs_RowCount] 6. $RV[rs_x_1] to $RV[rs_x_3] are set with new values, but $RV[rs_x_4] still stores the old I need a clean or brand new rs each time DB is queried. Best regards Dominik Share this post Link to post
Guest Dominik Report post Posted 09/15/2004 10:25 AM Will set vg = CreateObject("VoiceGuide.CommandLink") vg.RvSet $RV_LINEID, "rs", "" set vg = Nothing empty all the results as well ? ($RV[rs_1_1] and so on?) Dominik Share this post Link to post
SupportTeam Report post Posted 09/15/2004 10:41 AM RVs are never 'deleted' - once set they exist for the length of the call, but may be overwritten with new values. To see how many rows the latest Database query returns you can use $RV[ModuleTitle_RowCount] Share this post Link to post
Guest Dominik Report post Posted 09/15/2004 10:47 AM Thanks, but I'd like to force deleting them. Is it possible? Dominik Share this post Link to post
SupportTeam Report post Posted 09/15/2004 08:56 PM You can just set them to be a blank... Share this post Link to post
Guest Dominik Report post Posted 10/06/2004 09:15 AM Sek blank, OK. What about query result variable? How can I set it blank? Dominik Share this post Link to post
SupportTeam Report post Posted 10/06/2004 10:21 AM If you want to clear the query result variable hen you can just set them to be a blank in the same way... (using the Eval Expr module or using multiple RvSet COM function calls) But why do need to set them to a blank? To see how many rows the latest Database query returns you can use $RV[ModuleTitle_RowCount] .. Share this post Link to post
