Guest Juga Guru Report post Posted 04/19/2003 07:37 PM We would like to develop a store value card upload program for internal use. Interested Party pls leave email/Phone for contact. Harware: Celeron 1.2G, 40G Harddisk, 256MB Memory, Robotics Sportster Voice Modem Software: Windows XP/2000, Traditional Chinese version Deliverable includes source code. Pls suggest which version of Voice Guide to buy, delivery schedule and budget!! Urgent. Specification are as following: 1. read all parameters input from the cfg.ini ( see below cfg.ini ) from the default directory 2. process all *.xls from the Data_dir, 3. For each .xls file, use worksheet Sheet_name 4. start from Start_Row 5. if cell(Column A, Start_Row) not null 6. Get dial tone from Voice Modem 7. if not Skip_DTMF_1 then Send DTMF_1 in band followed by Pause_Time_1 endif 8. Send DTMF_2 in band in band followed by Pause_Time_2 9. Send DTMF_3 in band followed by Pause_Time_3 10. Send DTMF_4 in band followed by Pause_Time_4 11. Send DTMF_5 in band followed by Pause_Time_5 12. Send Column A + "#" in band followed by Pause_Time_6 13. Send Column A + "#" in band followed by Pause_Time_7 14. Send DTMF_8 in band followed by Pause_Time_8 15. Send Column B + "#" in band followed by Pause_Time_9 16. update Column C with "Done", Column D with current date time(format=text, mask=yyyy-mm-dd-hh-mm-ss), save work sheet 17. go to next row in Excel file 18. if not cell(Column b, next Row) null 19. if cell(Column A, next Row) is null Send DTMF_10 in band followed by Pause_Time_10 goto 15 else Hang up line go to 6. endif else Hang up line endif 20. Hang up line 21. endif cfg.ini Data_dir Sheet_Name Start_Row Skip_DTMF_1 DTMF_1 ;1st stage dial # Pause_Time_1 DTMF_2 ;2nd stage dial # Pause_Time_2 DTMF_3 ;Card service selection Pause_Time_3 DTMF_4 ;Card Language Selection Pause_Time_4 DTMF_5 ;Card Function Pause_Time_5 Pause_Time_6 ;Telephone # Pause_Time_7 ;Telephone # confirm DTMF_8 ;Store Value Selection Pause_Time_8 Pause_Time_9 ;Card Pin DTMF_10 ;Continue Store Value Pause_Time_10 Excel File Format Column A: Telephone Number (TEXT) Column B: Card Pin (TEXT) Column C: Status (TEXT) Column D: Update Date Time (TEXT) Must work with Voice Card also. Share this post Link to post
SupportTeam Report post Posted 04/20/2003 07:00 AM You will require VoiceGuide Pro + Dialer. From what I can see here one of the approaches could be to just create a dial string up to about 'DTMF_5' using DTMF tones and comma characters for pauses. Then use that dial string as the telephone number to be called when adding an entry to the DialListNew.txt file (see the 'Auto Dialing' chapter in the VoiceGuide Help file), with 'strAnnouce' set to "none", and the script points to a VGS script which reads data from Excel and plays out the digits... You may prefer to use a Dialogic card, as for these cards you can set the length of the pause (",") character - and then when creating the dial string you can easily calculate how many pause characters would be needed between each successive sequence of DTMF tones. An example of a VB Script which reads Excel files is also included in VG Help file (Run VB Script module section): Example 6: The VB Script below retrieves information from an Excel spreadsheet. Dim xlApp 'Excel.Application Dim xlBook 'Excel.Workbook dim xlSht Dim filename, value1, value2, value3, value4 filename = "c:\Warehouse.xls" Set xlApp = CreateObject("Excel.Application") set xlBook = xlApp.WorkBooks.Open(filename) set xlSht = xlApp.activesheet value1 = xlSht.Cells(2, 1) value2 = xlSht.Cells(2, 2) msgbox "Values are: " & value1 & ", " & value2 xlBook.Close False xlApp.Quit Set xlBook = Nothing Set xlApp = Nothing Share this post Link to post
