Id Change
I am using 4.8.45 I want to upgrade to latest and greatest. My old unique ID is based on my hard drive. Will the unique ID be the same for the new version if NOTHING in the system has changed? I only ask because a minimal delay is imperative when upgrading.
ID will be more likely based on Network Card with the newer version of VG... you just got to try it and see...
I am sorry; I guess I didn't make my self clear. There is NO "try it and see". I can not be down except for the brief time I need to upgrade program and enter new, already at hand serial number.
I guess what I am asking is, if there is only the original hard drive and a voice modem (no other cards) will the unique number for the new version of voice guide be the same as old unique number?
If it is the same unique number, I can order the upgrade before I attempt to install it. And later I can install the new network card, and not be down but briefly.
Issuing a new registration code for v5.2 based on the same hard disk ID as reported by v4.8 should work...
To unregister VoiceGuide please rename the file USERINFO.INI in VoiceGuide's directory, then restart VoiceGuide and see what that Unique ID is.
