Call Transfert
When VG try to transfert a call, it hang up the line. I modify at 250ms the time of hook flash but it hang up again.
help me
Are you using a Dialogic card?
What length hookflash does your PBX expect?
Could you please post a copy of VoiceGuide's Debug Printout which captures the problem, this will allow us to see what is going wrong.
Perhaps your modem is not sending the correct hookflash length? It's hard to tell with voice modems what is their hookflash length - that is why it's usually better to use Dialogic cards when implementing systems which do hookflash call transfers.
What length hookflash does your PBX expect? Usually its a fair bit lower then 500ms.
