Uk's Pri Isdn
looking to use Voiceguide with BT or Telewest's ISDN30 service which uses DASS2. From reading the support forum I believe it does work with this ?
Also, does the system support DDI's ? If I have 10 DDI's overlaid on each of my PRI ISDN 30 lines that gives me 300 DDI's I believe ? I want to run different scripts across different DDI's, not necessarily across each channel.
Jai
DASS2 is a supported ISDN protocol. You should have no problems using it.
"VoiceGuide for ISDN" which you would be using does support DDIs - using the $RV[DNIS] Result Variable.
You just ask the phone company for however many DDIs (indial telephone numbers) you'd like to terminate on this E1.
Yes, you can do this. You’d switch to different scripts based on value of the $RV[DNIS] Result Variable.
