Guest A Mehta Report post Posted 09/22/2004 11:56 PM We have a licensed VoiceGuide Pro 4 dialer. I want to dial out from 5:00 pm - till 3:00 am and not stop by 11:59 pm. How can I do it? Share this post Link to post
SupportTeam Report post Posted 09/25/2004 04:43 AM Which version of VoiceGuide are you using? The current release version should allow you to do this - all that you need to do is specify 5PM as your start time and 3AM as your end time. Share this post Link to post
am@microworld Report post Posted 09/27/2004 05:38 PM I am using the latest one 5.2.3018. I tried setting the start time as 5:00 pm and the end time as 3:00 am but it did not work. Is there any other way of doing it?? Share this post Link to post
SupportTeam Report post Posted 09/27/2004 08:29 PM Please update your VoiceGuide installation with the attached .exe and try again. VgMulti_5.2.3035.zip Share this post Link to post
Guest Bunty Report post Posted 10/08/2004 06:44 PM Question 1 We want to dial from 6:00pm to 6:00am next morning We want to know if we can setup a start time on a particular date and and end time on a particular date How do we do that Question 2 I want to put 5000 calls in the que on Friday evening and want the dialers to diall all calls but stop on Monday morning at 3:00 am How can i accomplish this Share this post Link to post
SupportTeam Report post Posted 10/08/2004 08:24 PM You can set the start time for a particular day/time, but not the stop time. Only 'call between these hours' can then be used to regulate when the calls are made. At this stage if you want to stop calling at a certain time you can just write a short VBScript which would delete entries from the OutDialQue.mbd database where all of the queued calls are stored, and run that when you wnat the calls to stop... Share this post Link to post
