Help In Answer Script.
We are trying to do one script where the first 15 second we can run a voice message but not send the answer signal to the telco.
Is for make a preview advertising free of charge for the users, the script will work for 0900 numbers.
somebody can help us? how to do it. and after this 15 seconds start another voice message and the aplications.
regards
Beth.
This is only possible if you are running an ISDN line.
Is that what you are currently using?
What ISDN protocol are you running on the line?
We are using a R2-MD signal, and out card is a dialogic D300/JCT .
We will apreciate so much any help.
regards
Beth
