omarello Report post Posted 09/27/2004 09:07 AM Hello all, I was wondering how i could use voice guide within a digital PBX using my voice fax modem??? I know that a modem requires an analoge signal, but it says that voice guide can connect using digital?? how is this possible.. if it is not, what hardware do i need to connect to a digital PBX, and how can I use that with vg. thank you for your time. Omarello. Share this post Link to post
SupportTeam Report post Posted 09/27/2004 11:56 AM Plugging a digital PBX extension into an analog voice modem will not work. Share this post Link to post
omarello Report post Posted 09/27/2004 12:00 PM how can i overcome this problem??? i read about those DPI modems, or the digital to analog to converters?? do these work. Share this post Link to post
SupportTeam Report post Posted 09/27/2004 08:22 PM A 'digital to analog to converter' should do the trick here. You should ask your PBX supplier as to what you should be using with your PBX. Share this post Link to post
