Hanging Up Call...(2)
Every now and again one line will freeze and I have to shut down VoiceGuide to restart that line. Here is the log when this happens - line 7 is the problem -
124222.98 7 ScriptEventCode 9013 iLineState=900
124223.14 7 dial [22200,9xxxxxxxxxx,0,800,2330,,,1,,c:\Program Files\VoiceGuide\Scripts\expressbaggage\ogs1.vgs,C:\Program Files\VoiceGuide\Scripts\expressbaggage\ogs1_am.vgs,[MyCallId]{22200},30,1,60, , ]
124223.16 0 dial callque update id=22200 next call time 0409111342
124223.17 0 dial callque DB update returned
124223.19 7 dial found entry: tel[9xxxxxxxxxx] ann[] vgs[c:\Program Files\VoiceGuide\Scripts\expressbaggage\ogs1.vgs] am[C:\Program Files\VoiceGuide\Scripts\expressbaggage\ogs1_am.vgs]
124223.23 7 Dialing: 9xxxxxxxxxx
124223.27 7 MakeCall => 66221
124223.28 7 TimeoutSet 30 EV_TIMEOUT_MAKECALL_NORESPONSE
124223.30 7 TapiCbTrigSet 66221 7002
124223.44 6 Timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
124223.44 6 ScriptEventCode 9013 iLineState=900
124224.11 7 tapi Reply (LineEvReply) ok 66221 0
124224.13 7 TapiCbTrigClear
124224.14 7 linedevstate 2048 0 0
124224.17 7 callstate DIALTONE 65853 0 0
124224.20 7 callstate DIALING 65853 0 0
124224.23 7 callstate PROCEEDING 65853 0 0
124224.27 7 callinfo CALLEDID
124224.30 7 callinfo REASON
124224.39 7 Lev_CallerID [0000,]
124224.42 7 callinfo ORIGIN
124233.11 7 callstate CONNECTED 65853,1,0
124233.13 7 WorkingModeTAPI@Connected=
124233.14 7 WorkingModeScript@Connected=
124233.17 7 rv add [MyCallId]{22200}
124233.19 7 rv add [OutDial_RetriesLeft]{1}
124233.22 7 rv add [$RV_STARTTIME]{11/09/2004 12:42:33}
124233.23 7 rv add [$RV_DEVICEID]{7}
124233.25 7 rv add [$RV_CIDNAME]{}
124233.27 7 AddRVns [PathApp]{C:\Program Files\VoiceGuide\}
124233.28 7 rv add [$RV_CALLEDNUMBER]{9xxxxxxxxxx}
124233.30 0 dial callque delete id=22200
124233.34 7 AddRVns [OutDial_Result]{Contacted_Human}
124233.36 7 Live person answered, starting c:\Program Files\VoiceGuide\Scripts\expressbaggage\ogs1.vgs
124233.38 2 tr NewVgsVgm_Goto c:\Program Files\VoiceGuide\Scripts\expressbaggage\ogs1.vgs,,,,,0
124233.42 7 rv add [scriptEnd_Time]{11/09/2004 12:42:33}
124233.44 7 rv add [scriptEnd_Goto_Script]{c:\Program Files\VoiceGuide\Scripts\expressbaggage\ogs1.vgs}
124233.48 7 rv add [scriptEnd_Goto_Module]{}
124233.50 7 rv add [scriptStart_Time]{11/09/2004 12:42:33}
124233.55 0 Script Load c:\Program Files\VoiceGuide\Scripts\expressbaggage\ogs1.vgs
124233.59 7 Loaded c:\Program Files\VoiceGuide\Scripts\expressbaggage\ogs1.vgs into:3
124233.61 7 AddRVns [scriptsPath]{c:\Program Files\VoiceGuide\Scripts\expressbaggage\}
124233.63 7 cl NewVgsVgm_RunModule module not found:
124233.64 2 tr NewVgsVgm_Goto 1
124233.66 2 tr NewVgsVgm_Goto 2
124233.67 7 TimeoutClear
124233.69 7 [GetCallInfo] DB Query
124233.70 7 db ODBC mode used
124233.75 7 RVreplace start: [sELECT AirlineName, PaxName, ETA, FirstText, SecText, Internal_Comments, Internal_Comments1, DelDate, ID FROM AutomatedCalls WHERE ID = $RV[MyCallID]]
124233.77 7 RVns [MyCallId]{22200}[OutDial_RetriesLeft]{1}[OutDial_Result]{Contacted_Human}[scrip
End_Time]{11/09/2004 12:42:33}[scriptEnd_Goto_Script]{c:\Program Files\VoiceGuide\Scripts\expressbaggage\ogs1.vgs}[scriptEnd_Goto_Module]{}[scriptStart_Time]{11/09/2004 12:42:33}[scriptsPath]{c:\Program Files\VoiceGuide\Scripts\expressbaggage\}
124233.78 7 db About to execute a Retrieve type operation [sELECT AirlineName, PaxName, ETA, FirstText, SecText, Internal_Comments, Internal_Comments1, DelDate, ID FROM AutomatedCalls WHERE ID = 22200]
124233.81 7 db [GetCallInfo] row count=1
124233.83 7 rv add [GetCallInfo_RowCount]{1}
124233.84 7 db get RecordsetGetRowsMax
124233.86 7 db get 999 records. (row count=1)
124233.88 7 db update RVs
124233.89 7 db about to close dbDbqDatabase
124233.92 7 db going down path [True]
124233.94 7 TimeoutClear
124233.97 7 [OGM1] Playing
124233.98 7 RVreplace start: [This is an automated message on behalf of $RV[GetCallInfo_1_1] with regard to the luggage of passenger, $RV[GetCallInfo_2_1]. Press ONE for more information. Press NINE to finish this call. Press ZERO to hear this message again.]
124234.00 7 RVns [MyCallId]{22200}[OutDial_RetriesLeft]{1}[OutDial_Result]{Contacted_Human}[scrip
End_Time]{11/09/2004 12:42:33}[scriptEnd_Goto_Script]{c:\Program Files\VoiceGuide\Scripts\expressbaggage\ogs1.vgs}[scriptEnd_Goto_Module]{}[scriptStart_Time]{11/09/2004 12:42:33}[scriptsPath]{c:\Program Files\VoiceGuide\Scripts\expressbaggage\}[GetCallInfo_RowCount]{1}[GetCallInfo_1_1]{Air Canada}[GetCallInfo_2_1]{BOURNE}[GetCallInfo_3_1]{11/09/2004 13:15:00}[GetCallInfo_4_1]{True}[GetCallInfo_5_1]{False}[GetCallInfo_6_1]{10/9/2004 13:45}[GetCallInfo_7_1]{11/9/2004 12:29}[GetCallInfo_8_1]{September, 11}[GetCallInfo_9_1]{22200}
124234.02 7 tts generate start[This is an automated message on behalf of Air Canada with regard to the luggage of passenger, BOURNE. Press ONE for more information. Press NINE to finish this call. Press ZERO to hear this message again.]
124234.14 7 tts generate wait
124234.16 7 RunModule PLAY end
124234.17 2 tr NewVgsVgm_Goto end
124238.73 7 tts generate finish
124238.75 7 [OGM1] Playing (C:\Program Files\VoiceGuide\data\tts7.wav)
124239.11 7 PlaySoundStart ok [C:\Program Files\VoiceGuide\data\tts7.wav]
124239.13 7 TimeoutClear
124239.22 7 wa(14134,14332800)
124239.31 7 callinfo MONITORMODES
124253.41 7 Play End line[7] (id=143328)
124253.42 7 ScriptEventCode 8001 iLineState=1100
124253.44 7 LsPlayMsg EV_PLAY_FINISHED
124253.45 7 TimeoutSet 10 EV_TIMEOUT_HANGUP
124253.50 7 TimeoutSet 15 EV_TIMEOUT_GOTOMODULE
124255.94 7 dtmf 0 (65853,48,2)
124255.95 7 ScriptEventCode 48 iLineState=1101
124255.97 7 LsPlayMsgFinished 0
124255.98 7 rv add [OGM1]{0}
124256.02 7 TimeoutClear
124256.03 7 [OGM1] Playing
124256.05 7 RVreplace start: [This is an automated message on behalf of $RV[GetCallInfo_1_1] with regard to the luggage of passenger, $RV[GetCallInfo_2_1]. Press ONE for more information. Press NINE to finish this call. Press ZERO to hear this message again.]
124256.06 7 RVns [MyCallId]{22200}[OutDial_RetriesLeft]{1}[OutDial_Result]{Contacted_Human}[scrip
End_Time]{11/09/2004 12:42:33}[scriptEnd_Goto_Script]{c:\Program Files\VoiceGuide\Scripts\expressbaggage\ogs1.vgs}[scriptEnd_Goto_Module]{}[scriptStart_Time]{11/09/2004 12:42:33}[scriptsPath]{c:\Program Files\VoiceGuide\Scripts\expressbaggage\}[GetCallInfo_RowCount]{1}[GetCallInfo_1_1]{Air Canada}[GetCallInfo_2_1]{BOURNE}[GetCallInfo_3_1]{11/09/2004 13:15:00}[GetCallInfo_4_1]{True}[GetCallInfo_5_1]{False}[GetCallInfo_6_1]{10/9/2004 13:45}[GetCallInfo_7_1]{11/9/2004 12:29}[GetCallInfo_8_1]{September, 11}[GetCallInfo_9_1]{22200}[OGM1]{0}
124256.08 7 tts generate start[This is an automated message on behalf of Air Canada with regard to the luggage of passenger, BOURNE. Press ONE for more information. Press NINE to finish this call. Press ZERO to hear this message again.]
124256.17 7 tts generate wait
124256.20 7 RunModule PLAY end
124256.89 7 tts generate finish
124256.91 7 [OGM1] Playing (C:\Program Files\VoiceGuide\data\tts7.wav)
124257.33 7 PlaySoundStart ok [C:\Program Files\VoiceGuide\data\tts7.wav]
124257.34 7 TimeoutClear
124257.39 7 wa(14134,16150000)
124257.42 7 callinfo MONITORMODES
124311.70 7 wb(16150000)
124311.84 7 Play End line[7] (id=161500)
124311.86 7 ScriptEventCode 8001 iLineState=1100
124311.92 7 LsPlayMsg EV_PLAY_FINISHED
124311.95 7 TimeoutSet 10 EV_TIMEOUT_HANGUP
124311.97 7 TimeoutSet 15 EV_TIMEOUT_GOTOMODULE
124314.53 7 dtmf 1 (65853,49,2)
124314.61 7 ScriptEventCode 49 iLineState=1101
124314.66 7 LsPlayMsgFinished 1
124314.67 7 rv add [OGM1]{1}
124314.81 7 TimeoutClear
124314.83 7 [Check for ETA] Evaluate ["$RV[GetCallInfo_3_1]"=""]
124314.89 7 RVreplace start: ["$RV[GetCallInfo_3_1]"=""]
124314.91 7 RVns [MyCallId]{22200}[OutDial_RetriesLeft]{1}[OutDial_Result]{Contacted_Human}[scrip
End_Time]{11/09/2004 12:42:33}[scriptEnd_Goto_Script]{c:\Program Files\VoiceGuide\Scripts\expressbaggage\ogs1.vgs}[scriptEnd_Goto_Module]{}[scriptStart_Time]{11/09/2004 12:42:33}[scriptsPath]{c:\Program Files\VoiceGuide\Scripts\expressbaggage\}[GetCallInfo_RowCount]{1}[GetCallInfo_1_1]{Air Canada}[GetCallInfo_2_1]{BOURNE}[GetCallInfo_3_1]{11/09/2004 13:15:00}[GetCallInfo_4_1]{True}[GetCallInfo_5_1]{False}[GetCallInfo_6_1]{10/9/2004 13:45}[GetCallInfo_7_1]{11/9/2004 12:29}[GetCallInfo_8_1]{September, 11}[GetCallInfo_9_1]{22200}[OGM1]{0}[OGM1]{1}
124314.98 7 RVreplace end: ["11/09/2004 13:15:00"=""]
124315.05 7 .Eval(Cstr("11/09/2004 13:15:00"=""))
124315.06 7 rv add [Check for ETA_Input]{"11/09/2004 13:15:00"=""}
124315.09 7 rv add [Check for ETA]{False}
124315.11 7 Eval Expr result:[False]
124315.13 7 TimeoutClear
124315.20 7 [ETAHours] Running VB Script...
124315.25 7 RVreplace start: [Dim ETAHourParam
Dim ETAValue
Dim ETAHour
ETAValue = "$RV[GetCallInfo_3_1]"
ETAHourParam="h"
ETAHour=DatePart(ETAHourParam,ETAValue)
vg.Run_ResultReturn $RV_LINEID, "[ETAHours]{" & ETAHour & "}"
set vg = Nothing
124315.27 7 RVns [MyCallId]{22200}[OutDial_RetriesLeft]{1}[OutDial_Result]{Contacted_Human}[scrip
End_Time]{11/09/2004 12:42:33}[scriptEnd_Goto_Script]{c:\Program Files\VoiceGuide\Scripts\expressbaggage\ogs1.vgs}[scriptEnd_Goto_Module]{}[scriptStart_Time]{11/09/2004 12:42:33}[scriptsPath]{c:\Program Files\VoiceGuide\Scripts\expressbaggage\}[GetCallInfo_RowCount]{1}[GetCallInfo_1_1]{Air Canada}[GetCallInfo_2_1]{BOURNE}[GetCallInfo_3_1]{11/09/2004 13:15:00}[GetCallInfo_4_1]{True}[GetCallInfo_5_1]{False}[GetCallInfo_6_1]{10/9/2004 13:45}[GetCallInfo_7_1]{11/9/2004 12:29}[GetCallInfo_8_1]{September, 11}[GetCallInfo_9_1]{22200}[OGM1]{0}[OGM1]{1}[Check for ETA_Input]{"11/09/2004 13:15:00"=""}[Check for ETA]{False}
124321.63 7 Run Script waiting... (shellid=5900, process=1900)
124321.64 7 TimeoutSet 1 EV_TIMEOUT_CHECKONSTATE
124322.55 7 cl Run_ResultReturn >>[ETAHours]{13}<<
124322.56 7 AddRVns [ETAHours]{13}
124322.58 7 TimeoutClear
124322.59 7 [ETAMinutes] Running VB Script...
124322.61 7 RVreplace start: [Dim ETAMinuteParam
Dim ETAValue
Dim ETAMinute
ETAMinuteParam="n"
ETAMinute=DatePart(ETAMinuteParam,ETAValue)
vg.Run_ResultReturn $RV_LINEID, "[ETAMinutes]{" & ETAMinute & "}"
set vg = Nothing
124322.64 7 RVns [MyCallId]{22200}[OutDial_RetriesLeft]{1}[OutDial_Result]{Contacted_Human}[scrip
End_Time]{11/09/2004 12:42:33}[scriptEnd_Goto_Script]{c:\Program Files\VoiceGuide\Scripts\expressbaggage\ogs1.vgs}[scriptEnd_Goto_Module]{}[scriptStart_Time]{11/09/2004 12:42:33}[scriptsPath]{c:\Program Files\VoiceGuide\Scripts\expressbaggage\}[GetCallInfo_RowCount]{1}[GetCallInfo_1_1]{Air Canada}[GetCallInfo_2_1]{BOURNE}[GetCallInfo_3_1]{11/09/2004 13:15:00}[GetCallInfo_4_1]{True}[GetCallInfo_5_1]{False}[GetCallInfo_6_1]{10/9/2004 13:45}[GetCallInfo_7_1]{11/9/2004 12:29}[GetCallInfo_8_1]{September, 11}[GetCallInfo_9_1]{22200}[OGM1]{0}[OGM1]{1}[Check for ETA_Input]{"11/09/2004 13:15:00"=""}[Check for ETA]{False}[ETAHours]{13}
124322.94 7 Run Script waiting... (shellid=4804, process=1972)
124322.95 7 TimeoutSet 1 EV_TIMEOUT_CHECKONSTATE
124323.25 7 cl Run_ResultReturn >>[ETAMinutes]{15}<<
124323.27 7 AddRVns [ETAMinutes]{15}
124323.30 7 TimeoutClear
124323.31 7 [OGM3] Playing
124323.33 7 RVreplace start: [<?xml version="1.0" encoding="ISO-8859-1"?> <speak version="1.0" xml:lang="en-US">We will be delivering your luggage before, <p><say-as type="date">$RV[ETAHours] </say-as></p>, hundred hours and, <p><say-as type="date">$RV[ETAMinutes] </say-as></p>, minutes, on, $RV[GetCallInfo_8_1], to the address that $RV[GetCallInfo_1_1] has given us. Thank you for your patience.</speak>]
124323.34 7 RVns [MyCallId]{22200}[OutDial_RetriesLeft]{1}[OutDial_Result]{Contacted_Human}[scrip
End_Time]{11/09/2004 12:42:33}[scriptEnd_Goto_Script]{c:\Program Files\VoiceGuide\Scripts\expressbaggage\ogs1.vgs}[scriptEnd_Goto_Module]{}[scriptStart_Time]{11/09/2004 12:42:33}[scriptsPath]{c:\Program Files\VoiceGuide\Scripts\expressbaggage\}[GetCallInfo_RowCount]{1}[GetCallInfo_1_1]{Air Canada}[GetCallInfo_2_1]{BOURNE}[GetCallInfo_3_1]{11/09/2004 13:15:00}[GetCallInfo_4_1]{True}[GetCallInfo_5_1]{False}[GetCallInfo_6_1]{10/9/2004 13:45}[GetCallInfo_7_1]{11/9/2004 12:29}[GetCallInfo_8_1]{September, 11}[GetCallInfo_9_1]{22200}[OGM1]{0}[OGM1]{1}[Check for ETA_Input]{"11/09/2004 13:15:00"=""}[Check for ETA]{False}[ETAHours]{13}[ETAMinutes]{15}
124323.36 7 tts generate start[<?xml version="1.0" encoding="ISO-8859-1"?> <speak version="1.0" xml:lang="en-US">We will be delivering your luggage before, <p><say-as type="date">13 </say-as></p>, hundred hours and, <p><say-as type="date">15 </say-as></p>, minutes, on, September, 11, to the address that Air Canada has given us. Thank you for your patience.</speak>]
124323.45 7 tts generate wait
124323.47 7 RunModule PLAY end
124325.13 7 tts generate finish
124325.14 7 [OGM3] Playing (C:\Program Files\VoiceGuide\data\tts7.wav)
124325.47 7 PlaySoundStart ok [C:\Program Files\VoiceGuide\data\tts7.wav]
124325.50 7 TimeoutClear
124325.59 7 wa(14435,18971800)
124325.64 7 callinfo MONITORMODES
124340.06 7 Play End line[7] (id=189718)
124340.08 7 ScriptEventCode 8001 iLineState=1100
124340.09 7 LsPlayMsg EV_PLAY_FINISHED
124340.11 7 TimeoutSet 10 EV_TIMEOUT_HANGUP
124340.13 7 TimeoutSet 0 EV_TIMEOUT_GOTOMODULE
124340.16 7 ScriptEventCode 9002 iLineState=1101
124340.17 7 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE
124340.19 7 TimeoutClear
124340.20 7 [Get Date and Time Stamp_2] Evaluate [Cstr($RV_DATE) & "/" & Cstr($RV_MONTH) & "/" & Cstr($RV_YEAR) & " " & Cstr($RV_HOUR) & ":" & Cstr($RV_MINUTE)]
124340.22 7 RVreplace start: [Cstr($RV_DATE) & "/" & Cstr($RV_MONTH) & "/" & Cstr($RV_YEAR) & " " & Cstr($RV_HOUR) & ":" & Cstr($RV_MINUTE)]
124340.23 7 RVns [MyCallId]{22200}[OutDial_RetriesLeft]{1}[OutDial_Result]{Contacted_Human}[scrip
124340.25 7 RVreplace end: [Cstr(11) & "/" & Cstr(9) & "/" & Cstr(2004) & " " & Cstr(12) & ":" & Cstr(43)]
124340.28 7 .Eval(Cstr(11) & "/" & Cstr(9) & "/" & Cstr(2004) & " " & Cstr(12) & ":" & Cstr(43))
124340.30 7 rv add [Get Date and Time Stamp_2_Input]{Cstr(11) & "/" & Cstr(9) & "/" & Cstr(2004) & " " & Cstr(12) & ":" & Cstr(43)}
124340.31 7 rv add [Get Date and Time Stamp_2]{11/9/2004 12:43}
124340.36 7 rv add [DateTimeStamp]{11/9/2004 12:43}
124340.38 7 Eval Expr result:[11/9/2004 12:43] stored in $RV[DateTimeStamp]
124340.39 7 path {11/9/2004 12:43} not found
124340.47 7 TimeoutClear
124340.48 7 [update Db2] DB Query
124340.55 7 db ODBC mode used
124340.59 7 RVreplace start: [uPDATE AutomatedCalls SET OutDial_Result='$RV[OutDial_Result]', SecText=true, Internal_Comments1='$RV[DateTimeStamp]' WHERE ID = $RV[MyCallID]]
124340.61 7 RVns [MyCallId]{22200}[OutDial_RetriesLeft]{1}[OutDial_Result]{Contacted_Human}[scrip
End_Time]{11/09/2004 12:42:33}[scriptEnd_Goto_Script]{c:\Program Files\VoiceGuide\Scripts\expressbaggage\ogs1.vgs}[scriptEnd_Goto_Module]{}[scriptStart_Time]{11/09/2004 12:42:33}[scriptsPath]{c:\Program Files\VoiceGuide\Scripts\expressbaggage\}[GetCallInfo_RowCount]{1}[GetCallInfo_1_1]{Air Canada}[GetCallInfo_2_1]{BOURNE}[GetCallInfo_3_1]{11/09/2004 13:15:00}[GetCallInfo_4_1]{True}[GetCallInfo_5_1]{False}[GetCallInfo_6_1]{10/9/2004 13:45}[GetCallInfo_7_1]{11/9/2004 12:29}[GetCallInfo_8_1]{September, 11}[GetCallInfo_9_1]{22200}[OGM1]{0}[OGM1]{1}[Check for ETA_Input]{"11/09/2004 13:15:00"=""}[Check for ETA]{False}[ETAHours]{13}[ETAMinutes]{15}[Get Date and Time Stamp_2_Input]{Cstr(11) & "/" & Cstr(9) & "/" & Cstr(2004) & " " & Cstr(12) & ":" & Cstr(43)}[Get Date and Time Stamp_2]{11/9/2004 12:43}[DateTimeStamp]{11/9/2004 12:43}
124340.64 7 db About to execute a Modify type operation [uPDATE AutomatedCalls SET OutDial_Result='Contacted_Human', SecText=true, Internal_Comments1='11/9/2004 12:43' WHERE ID = 22200]
124340.67 7 db Modify operation returned OK
124340.69 7 rv add [update Db2_RowCount]{1}
124340.72 7 TimeoutClear
124340.73 7 [OGM3a] Playing
124340.77 7 tts generate start[if you would like to hear this message again, press zero, otherwise, press nine to finish this call.]
124340.84 7 tts generate wait
124340.86 7 RunModule PLAY end
124341.50 7 tts generate finish
124341.52 7 [OGM3a] Playing (C:\Program Files\VoiceGuide\data\tts7.wav)
124341.80 7 PlaySoundStart ok [C:\Program Files\VoiceGuide\data\tts7.wav]
124341.81 7 TimeoutClear
124341.86 7 wa(6838,20609300)
124341.88 7 callinfo MONITORMODES
124347.72 7 dtmf 0 (65853,48,2)
124347.73 7 ScriptEventCode 48 iLineState=1100
124347.75 7 LsPlayMsg 0
124347.89 7 PlaySoundStop err=0
124347.91 7 rv add [OGM3a]{0}
124348.03 7 TimeoutClear
124348.05 7 [OGM3] Playing
124348.06 7 RVreplace start: [<?xml version="1.0" encoding="ISO-8859-1"?> <speak version="1.0" xml:lang="en-US">We will be delivering your luggage before, <p><say-as type="date">$RV[ETAHours] </say-as></p>, hundred hours and, <p><say-as type="date">$RV[ETAMinutes] </say-as></p>, minutes, on, $RV[GetCallInfo_8_1], to the address that $RV[GetCallInfo_1_1] has given us. Thank you for your patience.</speak>]
124348.08 7 RVns [MyCallId]{22200}[OutDial_RetriesLeft]{1}[OutDial_Result]{Contacted_Human}[scrip
End_Time]{11/09/2004 12:42:33}[scriptEnd_Goto_Script]{c:\Program Files\VoiceGuide\Scripts\expressbaggage\ogs1.vgs}[scriptEnd_Goto_Module]{}[scriptStart_Time]{11/09/2004 12:42:33}[scriptsPath]{c:\Program Files\VoiceGuide\Scripts\expressbaggage\}[GetCallInfo_RowCount]{1}[GetCallInfo_1_1]{Air Canada}[GetCallInfo_2_1]{BOURNE}[GetCallInfo_3_1]{11/09/2004 13:15:00}[GetCallInfo_4_1]{True}[GetCallInfo_5_1]{False}[GetCallInfo_6_1]{10/9/2004 13:45}[GetCallInfo_7_1]{11/9/2004 12:29}[GetCallInfo_8_1]{September, 11}[GetCallInfo_9_1]{22200}[OGM1]{0}[OGM1]{1}[Check for ETA_Input]{"11/09/2004 13:15:00"=""}[Check for ETA]{False}[ETAHours]{13}[ETAMinutes]{15}[Get Date and Time Stamp_2_Input]{Cstr(11) & "/" & Cstr(9) & "/" & Cstr(2004) & " " & Cstr(12) & ":" & Cstr(43)}[Get Date and Time Stamp_2]{11/9/2004 12:43}[DateTimeStamp]{11/9/2004 12:43}[update Db2_RowCount]{1}[OGM3a]{0}
124348.11 7 tts generate start[<?xml version="1.0" encoding="ISO-8859-1"?> <speak version="1.0" xml:lang="en-US">We will be delivering your luggage before, <p><say-as type="date">13 </say-as></p>, hundred hours and, <p><say-as type="date">15 </say-as></p>, minutes, on, September, 11, to the address that Air Canada has given us. Thank you for your patience.</speak>]
124348.22 7 tts generate wait
124348.23 7 RunModule PLAY end
124348.98 7 tts generate finish
124349.00 7 [OGM3] Playing (C:\Program Files\VoiceGuide\data\tts7.wav)
124349.27 7 PlaySoundStart ok [C:\Program Files\VoiceGuide\data\tts7.wav]
124349.28 7 TimeoutClear
124349.36 7 wa(14435,21359300)
124349.39 7 callinfo MONITORMODES
124403.84 7 wb(21359300)
124403.92 7 Play End line[7] (id=213593)
124403.94 7 ScriptEventCode 8001 iLineState=1100
124403.95 7 LsPlayMsg EV_PLAY_FINISHED
124403.97 7 TimeoutSet 10 EV_TIMEOUT_HANGUP
124404.00 7 TimeoutSet 0 EV_TIMEOUT_GOTOMODULE
124404.02 7 ScriptEventCode 9002 iLineState=1101
124404.03 7 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE
124404.11 7 TimeoutClear
124404.13 7 [Get Date and Time Stamp_2] Evaluate [Cstr($RV_DATE) & "/" & Cstr($RV_MONTH) & "/" & Cstr($RV_YEAR) & " " & Cstr($RV_HOUR) & ":" & Cstr($RV_MINUTE)]
124404.16 7 RVreplace start: [Cstr($RV_DATE) & "/" & Cstr($RV_MONTH) & "/" & Cstr($RV_YEAR) & " " & Cstr($RV_HOUR) & ":" & Cstr($RV_MINUTE)]
124404.17 7 RVns [MyCallId]{22200}[OutDial_RetriesLeft]{1}[OutDial_Result]{Contacted_Human}[scrip
124404.22 7 RVreplace end: [Cstr(11) & "/" & Cstr(9) & "/" & Cstr(2004) & " " & Cstr(12) & ":" & Cstr(44)]
124404.23 7 .Eval(Cstr(11) & "/" & Cstr(9) & "/" & Cstr(2004) & " " & Cstr(12) & ":" & Cstr(44))
124404.28 7 rv add [Get Date and Time Stamp_2_Input]{Cstr(11) & "/" & Cstr(9) & "/" & Cstr(2004) & " " & Cstr(12) & ":" & Cstr(44)}
124404.30 7 rv add [Get Date and Time Stamp_2]{11/9/2004 12:44}
124404.31 7 rv add [DateTimeStamp]{11/9/2004 12:44}
124404.33 7 Eval Expr result:[11/9/2004 12:44] stored in $RV[DateTimeStamp]
124404.34 7 path {11/9/2004 12:44} not found
124404.36 7 TimeoutClear
124404.38 7 [update Db2] DB Query
124404.41 7 db ODBC mode used
124404.42 7 RVreplace start: [uPDATE AutomatedCalls SET OutDial_Result='$RV[OutDial_Result]', SecText=true, Internal_Comments1='$RV[DateTimeStamp]' WHERE ID = $RV[MyCallID]]
124404.44 7 RVns [MyCallId]{22200}[OutDial_RetriesLeft]{1}[OutDial_Result]{Contacted_Human}[scrip
End_Time]{11/09/2004 12:42:33}[scriptEnd_Goto_Script]{c:\Program Files\VoiceGuide\Scripts\expressbaggage\ogs1.vgs}[scriptEnd_Goto_Module]{}[scriptStart_Time]{11/09/2004 12:42:33}[scriptsPath]{c:\Program Files\VoiceGuide\Scripts\expressbaggage\}[GetCallInfo_RowCount]{1}[GetCallInfo_1_1]{Air Canada}[GetCallInfo_2_1]{BOURNE}[GetCallInfo_3_1]{11/09/2004 13:15:00}[GetCallInfo_4_1]{True}[GetCallInfo_5_1]{False}[GetCallInfo_6_1]{10/9/2004 13:45}[GetCallInfo_7_1]{11/9/2004 12:29}[GetCallInfo_8_1]{September, 11}[GetCallInfo_9_1]{22200}[OGM1]{0}[OGM1]{1}[Check for ETA_Input]{"11/09/2004 13:15:00"=""}[Check for ETA]{False}[ETAHours]{13}[ETAMinutes]{15}[Get Date and Time Stamp_2_Input]{Cstr(11) & "/" & Cstr(9) & "/" & Cstr(2004) & " " & Cstr(12) & ":" & Cstr(43)}[Get Date and Time Stamp_2]{11/9/2004 12:43}[DateTimeStamp]{11/9/2004 12:43}[update Db2_RowCount]{1}[OGM3a]{0}[Get Date and Time Stamp_2_Input]{Cstr(11) & "/" & Cstr(9) & "/" & Cstr(2004) & " " & Cstr(12) & ":" & Cstr(44)}[Get Date and Time Stamp_2]{11/9/2004 12:44}[DateTimeStamp]{11/9/2004 12:44}
124404.47 7 db About to execute a Modify type operation [uPDATE AutomatedCalls SET OutDial_Result='Contacted_Human', SecText=true, Internal_Comments1='11/9/2004 12:44' WHERE ID = 22200]
124404.50 7 db Modify operation returned OK
124404.52 7 rv add [update Db2_RowCount]{1}
124404.55 7 TimeoutClear
124404.56 7 [OGM3a] Playing
124404.58 7 tts generate start[if you would like to hear this message again, press zero, otherwise, press nine to finish this call.]
124404.67 7 tts generate wait
124404.72 7 RunModule PLAY end
124405.08 7 dtmf 9 (65853,57,2)
124405.09 7 ScriptEventCode 57 iLineState=1100
124405.11 7 LsPlayMsg 9
124405.17 7 PlaySoundStop err=0
124405.19 7 rv add [OGM3a]{9}
124405.20 7 TimeoutClear
124405.22 7 rv add [Hangup Time]{11/09/2004 12:44:05}
124405.23 7 Hanging up call... [Hangup Module]
124405.30 7 RecSoundStop ok
124405.34 7 PlaySoundStop err=0
124405.36 7 TimeoutSet 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
124405.47 7 fnHangupCall end
124405.52 7 linedevstate 2048 0 0
124405.55 7 callstate IDLE 65853 0 0
124405.56 7 WorkingMode@Idle=
124405.59 7 TimeoutClear
124405.77 7 TimeoutSet 1 EV_TIMEOUT_TIMETOREINITLINE
124405.80 7 tapi Reply (LineEvReply) ok 66100 0
124405.94 7 tts generate finish
124405.95 7 [OGM3a] Playing (C:\Program Files\VoiceGuide\data\tts7.wav)
124406.30 7 PlaySoundStart ok [C:\Program Files\VoiceGuide\data\tts7.wav]
124406.31 7 TimeoutClear
124406.36 7 wa(6838,23054600)
124414.52 7 wb(23054600)
124414.83 7 Play End line[7] (id=230546)
124414.86 7 ScriptEventCode 8001 iLineState=900
124414.89 7 LsAwaitingCalls EV_PLAY_FINISHED
124624.44 0 Script Load c:\Program Files\VoiceGuide\Scripts\expressbaggage\ogs1.vgs
124624.69 0 Loaded Script Id 4: c:\Program Files\VoiceGuide\Scripts\expressbaggage\ogs1.vgs
124626.92 6 dial [22212,9xxxxxxxxxx,0,800,2330,,,1,,c:\Program Files\VoiceGuide\Scripts\expressbaggage\ogs1.vgs,C:\Program Files\VoiceGuide\Scripts\expressbaggage\ogs1_am.vgs,[MyCallId]{22212},30,1,60, , ]
124627.23 0 dial callque update id=22212 next call time 0409111346
124627.27 0 dial callque DB update returned
124627.34 6 dial found entry: tel[9xxxxxxxxxx] ann[] vgs[c:\Program Files\VoiceGuide\Scripts\expressbaggage\ogs1.vgs] am[C:\Program Files\VoiceGuide\Scripts\expressbaggage\ogs1_am.vgs]
124627.61 6 Dialing: 9xxxxxxxxxx
124627.63 6 MakeCall => 65997
124627.64 6 TimeoutSet 30 EV_TIMEOUT_MAKECALL_NORESPONSE
124627.66 6 TapiCbTrigSet 65997 7002
124628.39 6 tapi Reply (LineEvReply) ok 65997 0
124628.41 6 TapiCbTrigClear
124628.44 6 linedevstate 2048 0 0
124628.45 6 callstate DIALTONE 66085 0 0
124628.48 6 callstate DIALING 66085 0 0
124628.52 6 callstate PROCEEDING 66085 0 0
124628.55 6 callinfo CALLEDID
124628.56 6 callinfo REASON
124628.70 6 Lev_CallerID [0000,]
124628.72 6 callinfo ORIGIN
124650.31 6 callstate DISCONNECTED 66085,16,0
124650.33 6 ScriptEventCode 9250 iLineState=5200
124650.34 6 LsWaitAfterDialingOut EV_REMOTEPARTY_DISCONNECT
124650.38 0 dial callque delete id=22212
124650.44 6 AddRVns [OutDial_Result]{Contacted_AM}
124650.45 6 AM - wait for end of welcome message...
124650.48 6 dial awaiting end of answering machine message (lvl:30 for 10)
124650.70 6 RecSoundStart file[C:\Program Files\VoiceGuide\data\RecAm_6.wav] ok
124650.72 6 TimeoutSet 120 EV_TIMEOUT_HANGUP
124653.89 6 ScriptEventCode 9300 iLineState=1152
124653.91 6 LsDialoutRecAnswerMachineWelcMsg EV_SILENCE_DETECTED
124654.03 6 RecSoundStop ok
124654.09 6 TimeoutSet 1 EV_REC_FINISHED
124654.23 6 ScriptEventCode 8003 iLineState=1152
124654.25 6 LsDialoutRecAnswerMachineWelcMsg EV_REC_FINISHED
124654.27 6 RVreplace start: [$RV[AmWelcMsg_RecLen100ms]]
124654.31 6 RVns [MyCallId]{22212}[OutDial_RetriesLeft]{1}
124654.33 6 RVreplace end: []
124654.36 6 am msglen=0, minrequired=10
124654.41 6 Run Answer Machine script [C:\Program Files\VoiceGuide\Scripts\expressbaggage\ogs1_am.vgs]
124654.42 2 tr NewVgsVgm_Goto C:\Program Files\VoiceGuide\Scripts\expressbaggage\ogs1_am.vgs,,,,,0
124654.45 6 rv add [scriptEnd_Time]{11/09/2004 12:46:54}
124654.47 6 rv add [scriptEnd_Goto_Script]{C:\Program Files\VoiceGuide\Scripts\expressbaggage\ogs1_am.vgs}
124654.52 6 rv add [scriptEnd_Goto_Module]{}
124654.53 6 rv add [scriptStart_Time]{11/09/2004 12:46:54}
124654.55 6 rv add [scriptStart_CalledFrom_Module]{Hangup the Call 1}
124654.56 0 LoadedVgs_Find C:\Program Files\VoiceGuide\Scripts\expressbaggage\ogs1_am.vgs at idx=2
124654.58 6 AddRVns [scriptsPath]{C:\Program Files\VoiceGuide\Scripts\expressbaggage\}
124654.59 6 cl NewVgsVgm_RunModule module not found:
124654.61 2 tr NewVgsVgm_Goto 1
124654.63 2 tr NewVgsVgm_Goto 2
124654.64 6 TimeoutClear
124654.66 6 [GetCallInfo] DB Query
124654.67 6 db ODBC mode used
124654.72 6 RVreplace start: [sELECT AirlineName, PaxName, ETA, FirstText, SecText, Internal_Comments, Internal_Comments1, DelDate, ID FROM AutomatedCalls WHERE ID = $RV[MyCallID]]
124654.78 6 RVns [MyCallId]{22212}[OutDial_RetriesLeft]{1}[scriptEnd_Time]{11/09/2004 12:46:54}[scriptEnd_Goto_Script]{C:\Program Files\VoiceGuide\Scripts\expressbaggage\ogs1_am.vgs}[scriptEnd_Goto_Module]{}[scriptStart_Time]{11/09/2004 12:46:54}[scriptStart_CalledFrom_Module]{Hangup the Call 1}[scriptsPath]{C:\Program Files\VoiceGuide\Scripts\expressbaggage\}
124654.80 6 db About to execute a Retrieve type operation [sELECT AirlineName, PaxName, ETA, FirstText, SecText, Internal_Comments, Internal_Comments1, DelDate, ID FROM AutomatedCalls WHERE ID = 22212]
124654.86 6 db [GetCallInfo] row count=1
124654.88 6 rv add [GetCallInfo_RowCount]{1}
124654.91 6 db get RecordsetGetRowsMax
124654.92 6 db get 999 records. (row count=1)
124654.94 6 db update RVs
124654.95 6 db about to close dbDbqDatabase
124654.98 6 db going down path [True]
124655.00 6 TimeoutClear
124655.02 6 [OGM1] Playing
124655.03 6 RVreplace start: [This is an automated message on behalf of $RV[GetCallInfo_1_1] with regard to the luggage of passenger, $RV[GetCallInfo_2_1].]
124655.11 6 RVns [MyCallId]{22212}[OutDial_RetriesLeft]{1}[scriptEnd_Time]{11/09/2004 12:46:54}[scriptEnd_Goto_Script]{C:\Program Files\VoiceGuide\Scripts\expressbaggage\ogs1_am.vgs}[scriptEnd_Goto_Module]{}[scriptStart_Time]{11/09/2004 12:46:54}[scriptStart_CalledFrom_Module]{Hangup the Call 1}[scriptsPath]{C:\Program Files\VoiceGuide\Scripts\expressbaggage\}[GetCallInfo_RowCount]{1}[GetCallInfo_1_1]{British Airways T4}[GetCallInfo_2_1]{REID}[GetCallInfo_3_1]{11/09/2004 13:00:00}[GetCallInfo_4_1]{False}[GetCallInfo_5_1]{False}[GetCallInfo_6_1]{}[Get
allInfo_7_1]{}[GetCallInfo_8_1]{September, 11}[GetCallInfo_9_1]{22212}
124655.16 6 tts generate start[This is an automated message on behalf of British Airways T4 with regard to the luggage of passenger, REID.]
124655.33 6 tts generate wait
124655.41 6 RunModule PLAY end
124655.42 2 tr NewVgsVgm_Goto end
124656.09 6 tts generate finish
124656.11 6 [OGM1] Playing (C:\Program Files\VoiceGuide\data\tts6.wav)
124656.58 6 PlaySoundStart ok [C:\Program Files\VoiceGuide\data\tts6.wav]
124656.59 6 TimeoutClear
124656.64 6 wa(7680,40068700)
124704.42 6 wb(40068700)
124704.52 6 Play End line[6] (id=400687)
124704.56 6 ScriptEventCode 8001 iLineState=1100
124704.61 6 LsPlayMsg EV_PLAY_FINISHED
124704.63 6 TimeoutSet 10 EV_TIMEOUT_HANGUP
124704.67 6 TimeoutSet 0 EV_TIMEOUT_GOTOMODULE
124704.69 6 ScriptEventCode 9002 iLineState=1101
124704.73 6 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE
124704.77 6 TimeoutClear
124704.78 6 [Check for ETA] Evaluate ["$RV[GetCallInfo_3_1]"=""]
124704.80 6 RVreplace start: ["$RV[GetCallInfo_3_1]"=""]
124704.81 6 RVns [MyCallId]{22212}[OutDial_RetriesLeft]{1}[scriptEnd_Time]{11/09/2004 12:46:54}[scriptEnd_Goto_Script]{C:\Program Files\VoiceGuide\Scripts\expressbaggage\ogs1_am.vgs}[scriptEnd_Goto_Module]{}[scriptStart_Time]{11/09/2004 12:46:54}[scriptStart_CalledFrom_Module]{Hangup the Call 1}[scriptsPath]{C:\Program Files\VoiceGuide\Scripts\expressbaggage\}[GetCallInfo_RowCount]{1}[GetCallInfo_1_1]{British Airways T4}[GetCallInfo_2_1]{REID}[GetCallInfo_3_1]{11/09/2004 13:00:00}[GetCallInfo_4_1]{False}[GetCallInfo_5_1]{False}[GetCallInfo_6_1]{}[Get
124704.83 6 RVreplace end: ["11/09/2004 13:00:00"=""]
124704.84 6 .Eval(Cstr("11/09/2004 13:00:00"=""))
124704.86 6 rv add [Check for ETA_Input]{"11/09/2004 13:00:00"=""}
124704.88 6 rv add [Check for ETA]{False}
124704.89 6 Eval Expr result:[False]
124704.92 6 TimeoutClear
124704.94 6 [ETAHours] Running VB Script...
124704.95 6 RVreplace start: [Dim ETAHourParam
Dim ETAValue
Dim ETAHour
ETAHourParam="h"
set vg = Nothing
124704.97 6 RVns [MyCallId]{22212}[OutDial_RetriesLeft]{1}[scriptEnd_Time]{11/09/2004 12:46:54}[scriptEnd_Goto_Script]{C:\Program Files\VoiceGuide\Scripts\expressbaggage\ogs1_am.vgs}[scriptEnd_Goto_Module]{}[scriptStart_Time]{11/09/2004 12:46:54}[scriptStart_CalledFrom_Module]{Hangup the Call 1}[scriptsPath]{C:\Program Files\VoiceGuide\Scripts\expressbaggage\}[GetCallInfo_RowCount]{1}[GetCallInfo_1_1]{British Airways T4}[GetCallInfo_2_1]{REID}[GetCallInfo_3_1]{11/09/2004 13:00:00}[GetCallInfo_4_1]{False}[GetCallInfo_5_1]{False}[GetCallInfo_6_1]{}[Get
allInfo_7_1]{}[GetCallInfo_8_1]{September, 11}[GetCallInfo_9_1]{22212}[Check for ETA_Input]{"11/09/2004 13:00:00"=""}[Check for ETA]{False}
124705.67 6 Run Script waiting... (shellid=2612, process=1612)
124705.72 6 TimeoutSet 1 EV_TIMEOUT_CHECKONSTATE
124705.98 6 cl Run_ResultReturn >>[ETAHours]{13}<<
124706.00 6 AddRVns [ETAHours]{13}
124706.03 6 TimeoutClear
124706.05 6 [ETAMinutes] Running VB Script...
124706.06 6 RVreplace start: [Dim ETAMinuteParam
Dim ETAValue
Dim ETAMinute
ETAMinuteParam="n"
set vg = Nothing
124706.08 6 RVns [MyCallId]{22212}[OutDial_RetriesLeft]{1}[scriptEnd_Time]{11/09/2004 12:46:54}[scriptEnd_Goto_Script]{C:\Program Files\VoiceGuide\Scripts\expressbaggage\ogs1_am.vgs}[scriptEnd_Goto_Module]{}[scriptStart_Time]{11/09/2004 12:46:54}[scriptStart_CalledFrom_Module]{Hangup the Call 1}[scriptsPath]{C:\Program Files\VoiceGuide\Scripts\expressbaggage\}[GetCallInfo_RowCount]{1}[GetCallInfo_1_1]{British Airways T4}[GetCallInfo_2_1]{REID}[GetCallInfo_3_1]{11/09/2004 13:00:00}[GetCallInfo_4_1]{False}[GetCallInfo_5_1]{False}[GetCallInfo_6_1]{}[Get
allInfo_7_1]{}[GetCallInfo_8_1]{September, 11}[GetCallInfo_9_1]{22212}[Check for ETA_Input]{"11/09/2004 13:00:00"=""}[Check for ETA]{False}[ETAHours]{13}
124706.36 6 Run Script waiting... (shellid=4696, process=2024)
124706.38 6 TimeoutSet 1 EV_TIMEOUT_CHECKONSTATE
124706.72 6 cl Run_ResultReturn >>[ETAMinutes]{0}<<
124706.73 6 AddRVns [ETAMinutes]{0}
124706.75 6 TimeoutClear
124706.77 6 [OGM3] Playing
124706.78 6 RVreplace start: [<?xml version="1.0" encoding="ISO-8859-1"?> <speak version="1.0" xml:lang="en-US">We will be delivering your luggage before, <p><say-as type="date">$RV[ETAHours] </say-as></p>, hundred hours and, <p><say-as type="date">$RV[ETAMinutes] </say-as></p>, minutes, on, $RV[GetCallInfo_8_1], to the address that $RV[GetCallInfo_1_1] has given us. Thank you for your patience.</speak>]
124706.83 6 RVns [MyCallId]{22212}[OutDial_RetriesLeft]{1}[scriptEnd_Time]{11/09/2004 12:46:54}[scriptEnd_Goto_Script]{C:\Program Files\VoiceGuide\Scripts\expressbaggage\ogs1_am.vgs}[scriptEnd_Goto_Module]{}[scriptStart_Time]{11/09/2004 12:46:54}[scriptStart_CalledFrom_Module]{Hangup the Call 1}[scriptsPath]{C:\Program Files\VoiceGuide\Scripts\expressbaggage\}[GetCallInfo_RowCount]{1}[GetCallInfo_1_1]{British Airways T4}[GetCallInfo_2_1]{REID}[GetCallInfo_3_1]{11/09/2004 13:00:00}[GetCallInfo_4_1]{False}[GetCallInfo_5_1]{False}[GetCallInfo_6_1]{}[Get
allInfo_7_1]{}[GetCallInfo_8_1]{September, 11}[GetCallInfo_9_1]{22212}[Check for ETA_Input]{"11/09/2004 13:00:00"=""}[Check for ETA]{False}[ETAHours]{13}[ETAMinutes]{0}
124706.86 6 tts generate start[<?xml version="1.0" encoding="ISO-8859-1"?> <speak version="1.0" xml:lang="en-US">We will be delivering your luggage before, <p><say-as type="date">13 </say-as></p>, hundred hours and, <p><say-as type="date">0 </say-as></p>, minutes, on, September, 11, to the address that British Airways T4 has given us. Thank you for your patience.</speak>]
124707.08 6 tts generate wait
124707.09 6 RunModule PLAY end
124707.92 6 tts generate finish
124707.94 6 [OGM3] Playing (C:\Program Files\VoiceGuide\data\tts6.wav)
124708.33 6 PlaySoundStart ok [C:\Program Files\VoiceGuide\data\tts6.wav]
124708.34 6 TimeoutClear
124708.39 6 wa(15016,41251500)
124723.55 6 Play End line[6] (id=412515)
124723.56 6 ScriptEventCode 8001 iLineState=1100
124723.58 6 LsPlayMsg EV_PLAY_FINISHED
124723.61 6 TimeoutSet 10 EV_TIMEOUT_HANGUP
124723.63 6 TimeoutSet 0 EV_TIMEOUT_GOTOMODULE
124723.66 6 ScriptEventCode 9002 iLineState=1101
124723.67 6 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE
124723.77 6 TimeoutClear
124723.78 6 [Get Date and Time Stamp_2] Evaluate [Cstr($RV_DATE) & "/" & Cstr($RV_MONTH) & "/" & Cstr($RV_YEAR) & " " & Cstr($RV_HOUR) & ":" & Cstr($RV_MINUTE) & " Answerphone message left."]
124723.80 6 RVreplace start: [Cstr($RV_DATE) & "/" & Cstr($RV_MONTH) & "/" & Cstr($RV_YEAR) & " " & Cstr($RV_HOUR) & ":" & Cstr($RV_MINUTE) & " Answerphone message left."]
124723.81 6 RVns [MyCallId]{22212}[OutDial_RetriesLeft]{1}[scriptEnd_Time]{11/09/2004 12:46:54}[scriptEnd_Goto_Script]{C:\Program Files\VoiceGuide\Scripts\expressbaggage\ogs1_am.vgs}[scriptEnd_Goto_Module]{}[scriptStart_Time]{11/09/2004 12:46:54}[scriptStart_CalledFrom_Module]{Hangup the Call 1}[scriptsPath]{C:\Program Files\VoiceGuide\Scripts\expressbaggage\}[GetCallInfo_RowCount]{1}[GetCallInfo_1_1]{British Airways T4}[GetCallInfo_2_1]{REID}[GetCallInfo_3_1]{11/09/2004 13:00:00}[GetCallInfo_4_1]{False}[GetCallInfo_5_1]{False}[GetCallInfo_6_1]{}[Get
124723.83 6 .Eval(Cstr(11) & "/" & Cstr(9) & "/" & Cstr(2004) & " " & Cstr(12) & ":" & Cstr(47) & " Answerphone message left.")
124723.84 6 rv add [Get Date and Time Stamp_2_Input]{Cstr(11) & "/" & Cstr(9) & "/" & Cstr(2004) & " " & Cstr(12) & ":" & Cstr(47) & " Answerphone message left."}
124723.86 6 rv add [Get Date and Time Stamp_2]{11/9/2004 12:47 Answerphone message left.}
124723.88 6 rv add [DateTimeStamp]{11/9/2004 12:47 Answerphone message left.}
124723.91 6 Eval Expr result:[11/9/2004 12:47 Answerphone message left.] stored in $RV[DateTimeStamp]
124723.92 6 path {11/9/2004 12:47 Answerphone message left.} not found
124723.94 6 TimeoutClear
124723.95 6 [update Db2] DB Query
124724.03 6 db ODBC mode used
124724.09 6 RVreplace start: [uPDATE AutomatedCalls SET SecText=true, Internal_Comments1='$RV[DateTimeStamp]' WHERE ID = $RV[MyCallID]]
124724.11 6 RVns [MyCallId]{22212}[OutDial_RetriesLeft]{1}[scriptEnd_Time]{11/09/2004 12:46:54}[scriptEnd_Goto_Script]{C:\Program Files\VoiceGuide\Scripts\expressbaggage\ogs1_am.vgs}[scriptEnd_Goto_Module]{}[scriptStart_Time]{11/09/2004 12:46:54}[scriptStart_CalledFrom_Module]{Hangup the Call 1}[scriptsPath]{C:\Program Files\VoiceGuide\Scripts\expressbaggage\}[GetCallInfo_RowCount]{1}[GetCallInfo_1_1]{British Airways T4}[GetCallInfo_2_1]{REID}[GetCallInfo_3_1]{11/09/2004 13:00:00}[GetCallInfo_4_1]{False}[GetCallInfo_5_1]{False}[GetCallInfo_6_1]{}[Get
allInfo_7_1]{}[GetCallInfo_8_1]{September, 11}[GetCallInfo_9_1]{22212}[Check for ETA_Input]{"11/09/2004 13:00:00"=""}[Check for ETA]{False}[ETAHours]{13}[ETAMinutes]{0}[Get Date and Time Stamp_2_Input]{Cstr(11) & "/" & Cstr(9) & "/" & Cstr(2004) & " " & Cstr(12) & ":" & Cstr(47) & " Answerphone message left."}[Get Date and Time Stamp_2]{11/9/2004 12:47 Answerphone message left.}[DateTimeStamp]{11/9/2004 12:47 Answerphone message left.}
124724.13 6 db About to execute a Modify type operation [uPDATE AutomatedCalls SET SecText=true, Internal_Comments1='11/9/2004 12:47 Answerphone message left.' WHERE ID = 22212]
124724.16 6 db Modify operation returned OK
124724.17 6 rv add [update Db2_RowCount]{1}
124724.20 6 TimeoutClear
124724.22 6 rv add [Hangup Time]{11/09/2004 12:47:24}
124724.23 6 Hanging up call... [Hangup Module]
124724.33 6 RecSoundStop ok
124724.47 6 PlaySoundStop err=0
124724.48 6 TimeoutSet 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
124724.59 6 fnHangupCall end
124724.64 6 linedevstate 2048 0 0
124724.67 6 callstate IDLE 66085 0 0
124724.69 6 WorkingMode@Idle=
124724.70 6 TimeoutClear
124725.03 6 TimeoutSet 1 EV_TIMEOUT_TIMETOREINITLINE
124725.06 6 tapi Reply (LineEvReply) ok 66506 0
124726.06 6 Timer fired EV_TIMEOUT_TIMETOREINITLINE
124726.08 6 ScriptEventCode 9008 iLineState=900
124726.09 6 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
124726.14 6 ReinitTelephony due to IDLE
124726.42 6 tapic lineDeallocateCall(MainCall:66085) 0
124728.81 6 lineOpen(6)=>
124728.86 6 Waiting for a call...
124729.02 6 LineHandle=66434
124729.06 6 TimeoutSet 2 EV_TIMEOUT_ATERIDLE_ALLOWOUT
124731.27 6 Timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
124731.30 6 ScriptEventCode 9013 iLineState=900
124732.20 6 dial [22211,901992424126,0,800,2330,,,1,,c:\Program Files\VoiceGuide\Scripts\expressbaggage\ogs1.vgs,C:\Program Files\VoiceGuide\Scripts\expressbaggage\ogs1_am.vgs,[MyCallId]{22211},30,0,60, , ]
124732.30 0 dial callque update id=22211 next call time 0409111347
124732.31 0 dial callque DB update returned
124732.36 6 dial found entry: tel[901992424126] ann[] vgs[c:\Program Files\VoiceGuide\Scripts\expressbaggage\ogs1.vgs] am[C:\Program Files\VoiceGuide\Scripts\expressbaggage\ogs1_am.vgs]
124732.59 6 Dialing: 901992424126
124732.61 6 MakeCall => 65956
124732.69 6 TimeoutSet 30 EV_TIMEOUT_MAKECALL_NORESPONSE
124732.70 6 TapiCbTrigSet 65956 7002
124734.31 6 tapi Reply (LineEvReply) ok 65956 0
124734.33 6 TapiCbTrigClear
124734.39 6 linedevstate 2048 0 0
124734.44 6 callstate DIALTONE 65616 0 0
124734.50 6 callstate DIALING 65616 0 0
124734.64 6 callstate PROCEEDING 65616 0 0
124734.73 6 callinfo CALLEDID
124734.78 6 callinfo REASON
124735.05 6 Lev_CallerID [0000,]
124735.13 6 callinfo ORIGIN
124740.30 0 btn Hangup on line 7
124740.33 7 rv add [Hangup Time]{11/09/2004 12:47:40}
124740.34 7 Hanging up call...
124740.39 7 RecSoundStop ok
124740.44 7 PlaySoundStop err=0
124740.45 7 TimeoutSet 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
124740.56 7 fnHangupCall end
124740.59 7 tapi Reply (LineEvReply) err 66048 LINEERR_INVALCALLSTATE [8000001C]
124742.66 7 Timer fired EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
124742.67 7 ScriptEventCode 9101 iLineState=900
124742.69 7 Hanging up call...(2)
124742.73 7 RecSoundStop ok
124742.80 7 PlaySoundStop err=0
124742.84 7 fnHangupCall end
124742.86 7 LsAwaitingCalls EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
124742.92 7 tapi Reply (LineEvReply) err 65948 LINEERR_INVALCALLSTATE [8000001C]
124746.88 6 callstate DISCONNECTED 65616,16,0
124746.89 6 ScriptEventCode 9250 iLineState=5200
124746.91 6 LsWaitAfterDialingOut EV_REMOTEPARTY_DISCONNECT
124746.92 0 dial callque delete id=22211
124746.95 6 AddRVns [OutDial_Result]{Contacted_AM}
124746.97 6 AM - wait for end of welcome message...
124746.98 6 dial awaiting end of answering machine message (lvl:30 for 10)
124747.30 6 RecSoundStart file[C:\Program Files\VoiceGuide\data\RecAm_6.wav] ok
124747.31 6 TimeoutSet 120 EV_TIMEOUT_HANGUP
124749.38 0 btn Hangup on line 7
124749.39 7 rv add [Hangup Time]{11/09/2004 12:47:49}
124749.41 7 Hanging up call...
124749.45 7 RecSoundStop ok
124749.52 7 PlaySoundStop err=0
124749.53 7 TimeoutSet 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
124749.58 7 fnHangupCall end
124749.61 7 tapi Reply (LineEvReply) err 65857 LINEERR_INVALCALLSTATE [8000001C]
124751.75 7 Timer fired EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
124751.77 7 ScriptEventCode 9101 iLineState=900
124751.78 7 Hanging up call...(2)
124751.83 7 RecSoundStop ok
124751.89 7 PlaySoundStop err=0
124751.98 7 fnHangupCall end
124752.00 7 LsAwaitingCalls EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
124752.14 7 tapi Reply (LineEvReply) err 66296 LINEERR_INVALCALLSTATE [8000001C]
Any ideas as to what is causing this issue?
This looks like the "tts generate finishes after hangup" bug that was resolved some time ago.
Which version of VG are you using?
If you are using anything before 5.2.3018 then please install the latest version (available from our WWW) and then update it with the .exe attached below.
VgMulti_5.2.3035.zip
Looks like you tested it for over a month first before coming back with a positive feedback, right? ;)
