Ivg Programming
HI!! I need help on the following script..
My program just hung up on either one of these 2 section here.. everything were working fine until this stage where it do a (fx) in [Check Result] to check the result variable return by a VBS. At this stage the program hung up the phone automatically.
Please help!
Thanks..
[Check Result]
Type=Evaluate
DispSize=69
Txt=Evaluate the Result Variable specified, and select the path which matches the current value of the Result Variable
Expression=$RV[PINResult]
ExprNewRV=
ExprStoreRV=0
On {False} Goto [Get PIN]
On {1} Goto [select Website]
On {0} Goto [Get PIN]
On {True} Goto [Get PIN]
Position=322,189
[select Website]
Type=Evaluate
DispSize=69
Expression=$RV[website]
ExprNewRV=
ExprStoreRV=0
On {gp2003} Goto [Get GP]
On {wanahorse} Goto [wanaRecordMessage]
Position=501,196
Could you please send us a copy of VoiceGuide's Debug Printout which captures the call, this will allow us to see what is going wrong.
This is the error message i am getting from the program.
05601 5 tapie callstate OFFERING 4342304 0 4
05601 5 tapie ring 1
08471 5 tapie ring 2
08471 5 Answer the call
08475 5 lineAnswer(4342304) => 1
08483 5 tapi Reply 1 0
08483 5 tapie callstate ACCEPTED 4342304 0 0
09203 5 tapie callstate CONNECTED 4342304,0,0
09204 5 WorkingModeTAPI=
09204 5 WorkingModeScript=
09206 5 [introduction] Playing
09207 5 [introduction] Playing (D:\automedia\gp\intro.wav)
09838 5 PlaySoundStart ok [D:\automedia\gp\intro.wav]
09839 5 RunModule PLAY end
13501 5 Play End line[5] (id=609207)
13501 5 LsPlayMsg EV_PLAY_FINISHED
13503 5 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE
13504 5 [Get PIN] Number Input
13504 5 [Get PIN] Playing (D:\automedia\gp\getpin.wav)
13714 5 PlaySoundStart ok [D:\automedia\gp\getpin.wav]
13717 5 tapie monitordigits 42 2
13718 5 LsGetNbrsPlayWelcMsg
13725 5 PlaySoundStop ok
13727 5 [Get PIN] Number Input
13728 5 [Get PIN] Playing (D:\automedia\gp\getpin.wav)
13934 5 PlaySoundStart ok [D:\automedia\gp\getpin.wav]
16336 5 wb(61373100)
16397 5 Play End line[5] (id=613731)
16399 5 LsGetNbrsPlayWelcMsg EV_PLAY_FINISHED
18405 5 tapie monitordigits 49 2
18407 5 LsGetNbrsRxDigits [1]
18409 5 [Get PIN] Number Input 1
18716 5 tapie monitordigits 50 2
18718 5 LsGetNbrsRxDigits [2]
18720 5 [Get PIN] Number Input 12
19096 5 tapie monitordigits 51 2
19098 5 LsGetNbrsRxDigits [3]
19100 5 [Get PIN] Number Input 123
19477 5 tapie monitordigits 52 2
19479 5 LsGetNbrsRxDigits [4]
19481 5 [Get PIN] Number Input 1234
19797 5 tapie monitordigits 53 2
19799 5 LsGetNbrsRxDigits [5]
19801 5 [Get PIN] Number Input 12345
20188 5 tapie monitordigits 54 2
20190 5 LsGetNbrsRxDigits [6]
20192 5 [Get PIN] Number Input 123456
20609 5 tapie monitordigits 55 2
20610 5 LsGetNbrsRxDigits [7]
20613 5 [Get PIN] Number Input 1234567
20929 5 tapie monitordigits 56 2
20931 5 LsGetNbrsRxDigits [8]
20933 5 [Get PIN] Number Input 12345678
20937 5 [Verify PIN] Running VB Script...
21021 5 VBScript Run waiting...
43127 5 Found result file: VGRUNRESULT_5.TXT
43548 5 Run Results >>>[PINResult]{1}[website]{wanahorse}[lang]{fr}[filetype]{asf}<<<
43560 5 [Check Result] Evaluate $RV[PINResult]
43562 5 RVreplace start: [$RV[PINResult]]
43565 5 RVreplace end: [1]
43568 5 .Eval(1)
43570 5 Eval Expr result:[1]
43595 5 Bad Module Type [] Stopping Script
43597 5 HangupCall called from [Run module 3105]
43599 5 Hanging up call...
43601 5 PlaySoundStop ok
43605 5 fnHangupCall end
44026 5 tapie callstate IDLE 4342304 0 0
44028 5 WorkingMode@Idle=
44194 5 set EV_TIMEOUT_TIMETOREINITLINE 2
44195 5 tapi Reply 2 0
82714 5 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
82717 5 ReinitTelephony due to IDLE start
82721 5 tapic lineDeallocateCall(MainCall:4342304) 0
83614 5 lineOpen(5) => 0
83615 5 Waiting for a call...
83617 5 lineOpen(5)LineHandle=4341960
In the trace we can see:
There is somethig wrong with the script - can post your entire script here?
Hi!! thanks for the reply. :)
Ok the following are the code for the program but I will put up a dummie URL as I will need to protect our company client on this system. I will also mention wat sort of result it will return on each of the VBS section as follows:
Explaination
On this URL
http://URL1/pin.asp?pin=$RV[Get PIN]
it will return
[PINResult]{1}[website]{gp2003}[lang]{uk}[filetype]{rpm}
or
[PINResult]{0}
On this URL
http://URL1/getges.asp?id=$RV[Get GP]
it will return
[gp]{0}
or
[gp]{1}
On this URL
http://URL1/getgday.asp?day=$RV[Get GPDay]
it will return
[gpday]{0}
or
[gpday]{1}
Start Script
Version=4.5
DefaultModuleDisplayHeight=
StartModule=Play 14
RunAtHangup=
StartWithoutAnswer=0
CtmAsiName=
[introduction]
Type=Play
DispSize=69
Txt=Play a sound file, then await a response...
PlayFile1=D:\auto\intro.wav
Replay=0,0
strTtsText=
On {*} Goto [Get PIN]
On {Timeout 0} Goto [Get PIN]
Position=122,8
[Get PIN]
Type=Get Numbers
DispSize=69
Txt=Play a prompt asking the caller to enter a sequence of numbers, speak the sequence back to the caller and ask them to confirm it. Go down different paths depending on the numbers entered...
PlayFile1=D:\auto\getpin.wav
PlayFile4=D:\auto\invalid .wav
Replay=0,0
GetNbrLenEnforce=2
GetNbrLenMax=8
Confirm=OFF
On {Success} Goto [Verify PIN]
On {Fail} Goto [Get PIN]
On {Timeout 30} Goto [Get PIN]
Position=122,93
[Verify PIN]
Type=Run VB Script
DispSize=69
Txt=Run a VB Script.
VbsWait=1
VbScript=Dim Shell, IE, readWwwHtml, readWwwText\
Dim boolPINResult\
Set Shell = CreateObject("Wscript.Shell")\
Set IE = CreateObject("InternetExplorer.Application")\
With IE\
.RegisterAsDropTarget = False\
.Visible = False\
.Silent = True\
.Navigate("http://URL1/pin.asp?pin=$RV[Get PIN]")\
While .Busy\
WScript.Sleep 100\
'DoEvents\
Wend\
With .Document.Body\
readWwwHtml = .InnerHTML\
readWwwText = .InnerText\
End With\
End With\
IE.Quit\
Set IE = Nothing\
strResultVariables = GetStatus()\
iRet = WriteResultFile(strResultVariables)\
function GetStatus()\
GetStatus = readWwwText\
end function\
function WriteResultFile(strResult)\
const ForReading=1, ForWriting=2, ForAppending=8\
Dim filename, fso, ts, outdata, outdata2, outdata3 \
filename = "VGRUNRESULT_$RV_DEVICEID.TXT"\
set fso = CreateObject("Scripting.FileSystemObject")\
set ts = fso.OpenTextFile(filename, ForWriting, True)\
ts.WriteLine(strResult)\
ts.Close\
WriteResultFile = 0\
end function\
VbsHoldPlay=
On {Success} Goto [Check Result]
On {Fail} Goto [Verify PIN]
On {Timeout 10} Goto [Check Result]
Position=129,183
[Record Message]
Type=Play
DispSize=69
PlayFile1=D:\auto\recordmessage.wav
Replay=0,0
strTtsText=
On {Timeout 0} Goto [Get Audio]
Position=329,370
[Menu]
Type=Play
DispSize=69
PlayFile1=D:\auto\menu.wav
Replay=0,0
strTtsText=
On {1} Goto [Replay]
On {2} Goto [Delete]
On {*} Goto [Check Type]
On {Timeout 5} Goto [Menu]
Position=543,460
[Delete]
Type=Run Program
DispSize=69
Txt=Run the program, and read in the results file created. The results supplied can then be used in other parts of the script (see Result Variables).
ProgramToRun=D:\auto\del_file.bat $RV[website]_$RV[lang]_$RV[gp]$RV[Get GPDay]_$RV[Get PIN].wav
RunHoldPlay=
RunMode=0
RunWait=1
On {Fail} Goto [Record Message]
On {Success} Goto [Record Message]
On {Timeout 5} Goto [Record Message]
Position=507,368
[save RPM]
Type=Run Program
DispSize=69
ProgramToRun=D:\auto\move_rpm.bat $RV[website]_$RV[lang]_$RV[gp]$RV[Get GPDay]_$RV[Get PIN].wav
RunHoldPlay=
RunMode=1
RunWait=1
On {Success} Goto [Finish]
On {Fail} Goto [Finish]
On {Timeout 5} Goto [Finish]
Position=447,665
[Finish]
Type=Play
DispSize=69
PlayFile1=D:\auto\finish.wav
Replay=0,0
strTtsText=
On {Timeout 5} Goto [Hangup]
Position=475,762
[Check Result]
Type=Evaluate
DispSize=69
ExprNewRV=
ExprStoreRV=0
Position=322,189
[Get Audio]
Type=Record
DispSize=69
Txt=Record a sound file, and go down different paths depending on what digit was pressed to terminate recording...
RecFile=d:\auto\raw\$RV[website]_$RV[lang]_$RV[gp]$RV[Get GPDay]_$RV[Get PIN].wav
PlayTone=ON
On {#} Goto [Menu]
Position=331,471
[Replay]
Type=Play
DispSize=69
PlayFile1=d:\auto\raw\$RV[website]_$RV[lang]_$RV[gp]$RV[Get GPDay]_$RV[Get PIN].wav
Replay=0,0
strTtsText=
On {Timeout 0} Goto [Menu]
Position=726,473
[Hangup]
Type=Hangup the Call
DispSize=69
Txt=Hangup the call.
Position=661,762
[Check Type]
Type=Evaluate
DispSize=69
Expression="$RV[filetype]" = "asf"
ExprNewRV=
ExprStoreRV=0
On {True} Goto [save ASF]
On {False} Goto [save RPM]
Position=546,577
[save ASF]
Type=Run Program
DispSize=69
ProgramToRun=D:\auto\move_asf.bat $RV[website]_$RV[lang]_$RV[gp]$RV[Get GPDay]_$RV[Get PIN].wav
RunHoldPlay=
RunMode=1
RunWait=1
Position=656,665
[Get GP]
Type=Get Numbers
DispSize=69
PlayFile1=D:\auto\getgp.wav
Replay=0,0
GetNbrLenEnforce=2
GetNbrLenMax=2
Confirm=OFF
On {Success} Goto [Verify GPID]
On {Timeout 30} Goto [Get GP]
Position=130,302
[Verify GPID]
Type=Run VB Script
DispSize=69
VbsWait=1
Dim boolPINResult\
With IE\
.Visible = False\
.Silent = True\
.Navigate("http://URL1/getges.asp?id=$RV[Get GP]")\
While .Busy\
WScript.Sleep 100\
'DoEvents\
Wend\
End With\
End With\
IE.Quit\
Set IE = Nothing\
end function\
ts.Close\
end function\
VbsHoldPlay=
On {Success} Goto [Check GPID]
On {Fail} Goto [Verify GPID]
Position=128,399
[Get GPDay]
Type=Get Numbers
DispSize=69
PlayFile1=D:\automedia\gp\getgpday.wav
Replay=0,0
GetNbrLenEnforce=2
GetNbrLenMax=1
Confirm=OFF
On {Success} Goto [Verify GPDay]
On {Timeout 30} Goto [Get GPDay]
Position=111,597
[Verify GPDay]
Type=Run VB Script
DispSize=69
VbsWait=1
Dim boolPINResult\
With IE\
.Visible = False\
.Silent = True\
.Navigate("http://URL1/getgday.asp?day=$RV[Get GPDay]")\
While .Busy\
WScript.Sleep 100\
'DoEvents\
Wend\
End With\
End With\
IE.Quit\
Set IE = Nothing\
end function\
ts.Close\
end function\
VbsHoldPlay=
On {Success} Goto [Check GPDay]
On {Fail} Goto [Verify GPDay]
Position=132,697
[Check GPID]
Type=Evaluate
DispSize=69
Expression=$RV[gp] = "0"
ExprNewRV=
ExprStoreRV=0
On {True} Goto [Get GP]
On {False} Goto [Get GPDay]
Position=116,497
[Check GPDay]
Type=Evaluate
DispSize=69
Expression=$RV[gpday] = "0"
ExprNewRV=
ExprStoreRV=0
On {True} Goto [Get GPDay]
On {False} Goto [Record Message]
Position=134,797
[select Website]
Type=Evaluate
DispSize=69
ExprNewRV=
ExprStoreRV=0
Position=501,196
[wanaRecordMessage]
Type=Play
DispSize=69
PlayFile1=D:\auto\wanaMESSAGE4.WAV
Replay=0,0
strTtsText=
On {Timeout 2} Goto [wanaGetAudio]
Position=688,9
[wanaGetAudio]
Type=Record
DispSize=69
RecFile=d:\auto\raw\$RV[website]_$RV[lang]_$RV[Get PIN].wav
PlayTone=ON
On {#} Goto [wanaMenu]
Position=690,97
[wanaMenu]
Type=Play
DispSize=69
PlayFile1=D:\auto\wanaMESSAGE5.WAV
Replay=0,0
strTtsText=
On {1} Goto [wanaReplay]
On {2} Goto [wanaDelete]
On {*} Goto [wanaCheckType]
On {Timeout 5} Goto [wanaMenu]
Position=694,196
[wanaReplay]
Type=Play
DispSize=69
PlayFile1=d:\auto\raw\$RV[website]_$RV[lang]_$RV[Get PIN].wav
Replay=0,0
strTtsText=
On {Timeout 1} Goto [wanaMenu]
Position=696,292
[wanaDelete]
Type=Run Program
DispSize=69
ProgramToRun=D:\auto\del_file.bat $RV[website]_$RV[lang]_$RV[Get PIN].wav
RunHoldPlay=
RunMode=1
RunWait=1
On {Success} Goto [wanaRecordMessage]
On {Fail} Goto [wanaRecordMessage]
On {Timeout 5} Goto [wanaRecordMessage]
Position=866,297
[wanaCheckType]
Type=Evaluate
DispSize=69
ExprNewRV=
ExprStoreRV=0
On {True} Goto [wanaSaveASF]
On {False} Goto [wanaSaveRM]
Position=868,195
[wanaSaveRM]
Type=Run Program
DispSize=69
ProgramToRun=D:\auto\move_rpm.bat $RV[website]_$RV[lang]_$RV[Get PIN].wav
RunHoldPlay=
RunMode=1
RunWait=1
On {Success} Goto [wanaFinish]
On {Fail} Goto [wanaFinish]
On {Timeout 5} Goto [wanaFinish]
Position=1052,155
[wanaSaveASF]
Type=Run Program
DispSize=69
ProgramToRun=D:\auto\move_asf.bat $RV[website]_$RV[lang]_$RV[Get PIN].wav
RunHoldPlay=
RunMode=1
RunWait=1
Position=1052,238
[wanaFinish]
Type=Play
DispSize=69
PlayFile1=wanahorse\wanaMESSAGE6.WAV
Replay=0,0
strTtsText=
On {Timeout 1} Goto [wanaHangUp]
Position=1237,192
[wanaHangUp]
DispSize=69
Position=1239,278
Are you running it in registered or evaluation mode?
The evaluation version of VoiceGuide will only let you use scripts up to 20 modules in size - if a script is larger then that, then only the first 20 modules are read in (in your script the module [select Website] is the 21st module)...
There should have been a warning message displayed when you load the script about your script being too big to run in the evaluation version of VoiceGuide - but it looks like it was no longer displayed in current v4.9.0 download.
The update files attached to next post fix this issue - if you are using v4.9.0 please download the ZIP attachment at the bottom of this post and unzip the contents in your VoiceGuide directory, letting new files overwrite the old.
BTW, your script is a good demonstration of how to use VoiceGuide to retrieve info from internet/www ASP pages.
Hi!! thanks we have a registered copy of the software..
We encounter the following problem while we test on the script i posted above..
42411 7 tapie linedevstate 2048 0 0
42451 7 tapie callstate OFFERING 65776 0 4
42752 7 Answer the call
42762 7 lineAnswer(65776) => 65793
42762 7 tapie callinfo CALLEDID
42762 7 tapie callinfo ORIGIN
42762 7 tapie ring 0
43292 7 tapie callstate CONNECTED 65776,1,0
43292 7 WorkingModeTAPI=
43302 7 WorkingModeScript=
43312 7 tapi Reply 65793 0
43312 7 [introduction] Playing
43312 7 [introduction] Playing (D:\auto\intro.wav)
43322 7 PlaySoundStart ok [D:\auto\intro.wav]
43322 7 RunModule PLAY end
46888 7 wb(4331200)
46958 7 Play End line[7] (id=43312)
47078 7 LsPlayMsg EV_PLAY_FINISHED
47088 7 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE
47118 7 [Get PIN] Number Input
47118 7 [Get PIN] Playing (D:\auto\getpin.wav)
47178 7 PlaySoundStart ok [D:\auto\getpin.wav]
49622 7 Play End line[7] (id=47118)
49622 7 LsGetNbrsPlayWelcMsg EV_PLAY_FINISHED
51294 7 tapie monitordigits 57 2
51294 7 LsGetNbrsRxDigits [9]
51294 7 [Get PIN] Number Input 9
52025 7 tapie monitordigits 57 2
52035 7 LsGetNbrsRxDigits [9]
52035 7 [Get PIN] Number Input 99
52736 7 tapie monitordigits 57 2
52736 7 LsGetNbrsRxDigits [9]
52746 7 [Get PIN] Number Input 994
54008 7 tapie monitordigits 49 2
54088 7 LsGetNbrsRxDigits [1]
54088 7 [Get PIN] Number Input 9943
54489 7 tapie monitordigits 50 2
54499 7 LsGetNbrsRxDigits [2]
54499 7 [Get PIN] Number Input 99435
54989 7 tapie monitordigits 51 2
55009 7 LsGetNbrsRxDigits [3]
55019 7 [Get PIN] Number Input 994356
55340 7 tapie monitordigits 52 2
55450 7 LsGetNbrsRxDigits [4]
55450 7 [Get PIN] Number Input 9943564
55851 7 tapie monitordigits 53 2
55851 7 LsGetNbrsRxDigits [5]
55851 7 [Get PIN] Number Input 99435645
55871 7 [Verify PIN] Running VB Script...
56241 7 VBScript Run waiting...
60477 7 Found result file: VGRUNRESULT_7.TXT
60477 7 Run Results
>>>[PINResult]{1}[website]{x2003}[lang]{uk}[filetype]{ram}<<<
60527 7 [Check Result] Evaluate $RV[PINResult]
60647 7 RVreplace start: [$RV[PINResult]]
60647 7 RVreplace end: [1]
60657 7 .Eval(1)
60657 7 Eval Expr result:[1]
60667 7 [select Website] Evaluate $RV[website]
60667 7 RVreplace start: [$RV[website]]
60667 7 RVreplace end: [x2003]
60677 7 .Eval(x2003)
60677 7 Eval Expr result:[x2003]
60697 7 [Get GP] Number Input
60697 7 [Get GP] Playing (D:\auto\getgp.wav)
60738 7 PlaySoundStart ok [D:\auto\getgp.wav]
66796 7 Play End line[7] (id=60697)
66796 7 LsGetNbrsPlayWelcMsg EV_PLAY_FINISHED
67307 7 tapie monitordigits 49 2
67317 7 LsGetNbrsRxDigits [1]
67317 7 [Get GP] Number Input 1
68879 7 tapie monitordigits 54 2
68879 7 LsGetNbrsRxDigits [6]
68889 7 [Get GP] Number Input 16
68929 7 [Verify GPID] Running VB Script...
69650 7 VBScript Run waiting...
73886 7 Found result file: VGRUNRESULT_7.TXT
73886 7 Run Results >>>[x]{wev}<<<
73937 7 [Check GPID] Evaluate $RV[gp] = "0"
74067 7 RVreplace start: [$RV[gp] = "0"]
74077 7 RVreplace end: [web = "0"]
74077 7 .Eval(web = "0")
74087 7 Eval Expr result:[Faux]
74107 7 [Get GP] Number Input
74257 7 [Get GP] Playing (D:\auto\getgp.wav)
74287 7 PlaySoundStart ok [D:\auto\getgp.wav]
80256 7 Play End line[7] (id=74267)
80396 7 LsGetNbrsPlayWelcMsg EV_PLAY_FINISHED
11040 7 LsGetNbrsRxDigits EV_TIMEOUT_GOTOMODULE
11080 7 HangupCall called from [Run module 3098]
11220 7 Hanging up call...
11220 7 PlaySoundStop ok
11230 7 fnHangupCall end
11350 7 tapie linedevstate 2048 0 0
11390 7 tapie callstate IDLE 65776 0 0
11390 7 WorkingMode@Idle=
11400 7 set EV_TIMEOUT_TIMETOREINITLINE 2
11410 7 tapi Reply 65639 0
12342 7 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
12342 7 ReinitTelephony due to IDLE start
12402 7 tapic lineDeallocateCall(MainCall:65776) 0
13293 7 lineOpen(7) => 0
13293 7 Waiting for a call...
13303 7 lineOpen(7)LineHandle=65622
On the bold section it should have load the [Get GPDay] module but it load back [Get GP]
I have no idea what is wrong
Hello? How come nobody response to my query? I have posted this query since early morning...
OK, this is a different issue to the one that this thread was initially about - I take it that the initial issue is now resolved?
Did you resolve it by registering your copy of the software?
In whose name/company is your registration license?
As far as this new problem - are you using version 4.9 of VoiceGuide, or some other version?
Are you using a Voice modem or a Dialogic card?
Is D:\auto\getgp.wav the correct format for the modem/card that you are using?
From VoiceGuide Help file:
Windows Voice Modem Wave driver can only support sound files in the following format PCM 8000Hz, 16bit, Mono. When using Voice modems all sound files must be recorded in the above format.
Dialogic Wave driver prefers sound files in the following format PCM 11025Hz, 8bit, Mono. When using a Dialogic card, all sound files should be recorded in the above format.
