Guest Brian Report post Posted 10/01/2004 12:46 AM After we connect a DTMF T-1 to the dialogic card, (D/240SC-1T), the signal light at the backend of the dialogic card did not turn green at all. The other side of the connection is the patch pannel and it is lead to a lucent Excel EXS switch. We've downloaded the latest dialogic softward of 5.11 from your website. Your help manu doesn't provide any senarios for the T1 connection. Please advise. Thanks Share this post Link to post
SupportTeam Report post Posted 10/01/2004 07:20 AM You should speak with the Lucent technicians to confirm that the line is set up correctly. Dialogic lights would go to at least Orange if there is a signal on the line. (what each status light means is covered in the Dialogic card's installation guide) Share this post Link to post
