Initialize Variable
uninitialize variable can cause a problem.Should i always initialize every variable with Zero?
If you feel that the way you designed your script requires this then yes, you can do this if you want...
Uninitialized RV's get replaced with a blank otherwise, which can cause problems if the script is not designed to handle this correctly...
