Caller I.d.
Dear Support Team!
When i used the build in, credit card record Script, and i call the system then i get the caller I.D. on the call log.
but, when i call the system for the script that i have created, i don't get the caller I.D. on the call log.
Any idea, why the system acting this way?
Thanks, Amis.
Reception of Caller ID is independent of what script is used, but maybe you have set for the system to answer call too early - CallerID usually arrived between 1st and 2nd rings.. after how many rings are you answering the call? (set to 3 to be safe)
In all my 4 lines, it's set up to answer after 0 rings, incloudes the credit card script.
so, as you see it is answer "credit card" script with caller I.D. even though it's answer after 0 rings, but with my script, no caller I.D.
Thanks, Amis.
Dear Support Team!
I am still waiting for your answer, regarding above situation.
Thanks, Amis.
Dear Support team,
In all my 4 lines, it's set up to answer after 3 rings.
What should i do to get caller's I.D.
Thanks, Amis.
Could you please post a copy of VoiceGuide's Debug Printout which captures an incoming call when each of the scripts is selected as the one to run after the call is answered, this will allow us to see what is happening on the system.
As mentioned before, reception of CallerID is something that happens before the call is answered, and the starting of the script is something that happens after the call is answered - so selection of one script or another should not be affecting whether or not you receive the CallerID...
Dear Support Team!
Yes, i know that's why it doesn't make sense to me that with one script i get the caller i.d an not with the other one.
Here is the call log for the script that doesn't get the caller i.d.
Dialogic 4dpci and answer after 3 rings.
130702.51 0 dial start any summary:|7:idx=0|8:dok=0|9:idx=0|10:idx=0|
130703.55 0 dial start any summary:|7:idx=0|8:dok=0|9:idx=0|10:idx=0|
130704.59 0 dial start any summary:|7:idx=0|8:dok=0|9:idx=0|10:idx=0|
130704.96 8 linedevstate 2048 0 0
130705.04 8 callstate OFFERING 65772 0 4
130705.09 8 callinfo CALLEDID
130705.13 8 callinfo ORIGIN
130705.20 8 ring 0
130710.93 8 ring 2
130716.91 8 ring 3
130716.95 8 Answer the call at 10/6/2004 1:07:16 PM
130716.99 8 lineAnswer(65772) => 65755
130717.57 8 callstate CONNECTED 65772 1 0
130717.60 8 callstate CONNECTED 65772,1,0
130717.64 8 WorkingModeTAPI@Connected=
130717.67 8 WorkingModeScript@Connected=
130717.71 8 Inband detection not enabled
130717.74 8 StartLoadedVgs at 10/6/2004 1:07:17 PM
130717.77 8 AddRVns [scriptsPath]{C:\Program Files\VoiceGuide\Scripts\Newcall\}
130717.80 8 AddRVns [scriptPath]{C:\Program Files\VoiceGuide\Scripts\Newcall}
130717.84 8 rv add [$RV_STARTTIME]{10/6/2004 1:07:17 PM}
130717.86 8 rv add [$RV_DEVICEID]{8}
130717.89 8 rv add [$RV_CIDNAME]{}
130717.91 8 AddRVns [PathApp]{C:\Program Files\VoiceGuide\}
130717.95 8 rv add [$RV_CIDNUMBER]{}
130718.02 8 tapi Reply (LineEvReply) ok 65755 0
130718.04 8 callinfo MONITORMODES
130718.09 8 timer clear
130718.11 8 [Play 1] Playing
130718.14 8 [Play 1] Playing (C:\Documents and Settings\Roni\Desktop\tst123.wav)
130718.16 8 play set playid=242713
130718.98 8 PlaySoundStart ok [C:\Documents and Settings\Roni\Desktop\tst123.wav]
130719.05 8 timer clear
130719.07 8 RunModule PLAY end
130719.13 8 wa(12020,24271300)
130719.16 8 callinfo MONITORMODES
130731.19 8 play end current play (playid=242713)
130731.23 8 ScriptEventCode 8001 iLineState=1100
130731.28 8 LsPlayMsg EV_PLAY_FINISHED
130731.30 8 timer set 5 EV_TIMEOUT_REPLAYMSG
130733.39 8 callstate DISCONNECTED 65772 0 0
130733.41 8 ScriptEventCode 9250 iLineState=1101
130733.44 8 LsPlayMsgFinished EV_REMOTEPARTY_DISCONNECT
130733.46 8 rv add [Hangup Time]{10/6/2004 1:07:33 PM}
130733.48 8 Hanging up call...
130733.53 8 RecSoundStop ok
130733.57 8 PlaySoundStop err=0
130733.59 8 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
130733.66 8 fnHangupCall end
130733.70 8 linedevstate 2048 0 0
130733.73 8 callstate IDLE 65772 0 0
130733.76 8 WorkingMode@Idle=
130733.79 8 timer clear
130733.90 8 timer set 1 EV_TIMEOUT_TIMETOREINITLINE
130733.98 8 tapi Reply (LineEvReply) ok 65738 0
130734.90 8 timer fired EV_TIMEOUT_TIMETOREINITLINE
130734.92 8 ScriptEventCode 9008 iLineState=900
130734.95 8 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
130734.97 8 ReinitTelephony due to IDLE
130735.01 8 tapic lineDeallocateCall(MainCall:65772) 0
130735.32 8 lineOpen(8)=>
130735.34 8 Waiting for a call...
130735.37 8 LineHandle=65721
130735.40 8 timer set 3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
130736.06 0 dial start any summary:|7:idx=0|8:rdy=0|9:idx=0|10:idx=0|
130737.10 0 dial start any summary:|7:idx=0|8:rdy=0|9:idx=0|10:idx=0|
130738.14 0 dial start any summary:|7:idx=0|8:rdy=0|9:idx=0|10:idx=0|
130738.43 8 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
130738.46 8 ScriptEventCode 9013 iLineState=900
130739.20 0 dial start any summary:|7:idx=0|8:dok=0|9:idx=0|10:idx=0|
130740.25 0 dial start any summary:|7:idx=0|8:dok=0|9:idx=0|10:idx=0|
Can you please post the trace when the credit card payment script is selected to answer the call... please ensure call is made from the same phone as before - when the trace already posted was captured....
Dear Support Team,
Per your request, here is the call that capture the caller I.D. (the same line used, only different script, the "credit card payment" script).
190702.89 7 linedevstate 2048 0 0
190702.91 7 callstate OFFERING 66161 0 4
190702.92 7 Answer the call at 10/9/2004 7:07:02 PM
190702.94 7 lineAnswer(66161) => 66144
190702.97 7 Lev_CallerID [7023026215,COHEN RONI,0000]
190702.98 7 rv add [DNIS]{0000}
190703.02 7 Lev_CallerID [7023026215,COHEN RONI,0000]
190703.04 7 callinfo CALLEDID
190703.06 7 callinfo ORIGIN
190703.08 7 ring 0
190703.52 7 callstate CONNECTED 66161 1 0
190703.53 7 callstate CONNECTED 66161,1,0
190703.55 7 WorkingModeTAPI@Connected=
190703.57 7 WorkingModeScript@Connected=
190703.59 7 Inband detection not enabled
190703.60 7 StartLoadedVgs at 10/9/2004 7:07:03 PM
190703.62 7 AddRVns [scriptsPath]{C:\Program Files\VoiceGuide\Scripts\Credit Card Payment\}
190703.64 7 AddRVns [scriptPath]{C:\Program Files\VoiceGuide\Scripts\Credit Card Payment}
190703.67 7 rv add [$RV_STARTTIME]{10/9/2004 7:07:03 PM}
190703.70 7 rv add [$RV_DEVICEID]{7}
190703.73 7 rv add [$RV_CIDNAME]{COHEN RONI}
190703.75 7 AddRVns [PathApp]{C:\Program Files\VoiceGuide\}
190703.78 7 rv add [$RV_CIDNUMBER]{7023206215}
190703.81 7 tapi Reply (LineEvReply) ok 66144 0
190703.85 7 callinfo MONITORMODES
190703.88 7 timer clear
190703.90 7 [Get Client ID] Number Input
190703.93 7 [Get Client ID] Playing (PayGetId.wav)
190703.96 7 play set playid=528509
190704.42 7 PlaySoundStart ok [PayGetId.wav]
190704.45 7 timer clear
190704.49 7 wa(8358,52850900)
190704.52 7 callinfo MONITORMODES
190712.91 7 play end current play (playid=528509)
190712.94 7 ScriptEventCode 8001 iLineState=1300
190712.95 7 LsGetNbrsPlayWelcMsg EV_PLAY_FINISHED
190712.98 7 timer set 10 EV_TIMEOUT_HANGUP
190713.02 7 timer set 6 EV_TIMEOUT_ENTERDATA
190718.71 7 callstate DISCONNECTED 66161 0 0
190718.74 7 ScriptEventCode 9250 iLineState=1301
190718.77 7 LsGetNbrsRxDigits EV_REMOTEPARTY_DISCONNECT
190718.79 7 rv add [Get Client ID]{}
190718.82 7 rv add [Hangup Time]{10/9/2004 7:07:18 PM}
190718.85 7 Hanging up call...
190718.89 7 RecSoundStop ok
190718.93 7 PlaySoundStop err=0
190718.95 7 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
190719.02 7 fnHangupCall end
190719.06 7 linedevstate 2048 0 0
190719.09 7 callstate IDLE 66161 0 0
190719.13 7 WorkingMode@Idle=
190719.16 7 timer clear
190719.30 7 timer set 1 EV_TIMEOUT_TIMETOREINITLINE
190719.32 7 tapi Reply (LineEvReply) ok 66143 0
190720.24 7 timer fired EV_TIMEOUT_TIMETOREINITLINE
190720.27 7 ScriptEventCode 9008 iLineState=900
190720.30 7 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
190720.32 7 ReinitTelephony due to IDLE
190720.35 7 tapic lineDeallocateCall(MainCall:66161) 0
190720.67 7 lineOpen(7)=>
190720.70 7 Waiting for a call...
190720.73 7 LineHandle=66126
190720.76 7 timer set 3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
190721.41 0 dial start any summary:|7:rdy=0|8:idx=0|9:idx=0|10:idx=0|
190722.44 0 dial start any summary:|7:rdy=0|8:idx=0|9:idx=0|10:idx=0|
190723.48 0 dial start any summary:|7:rdy=0|8:idx=0|9:idx=0|10:idx=0|
190723.81 7 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
190723.83 7 ScriptEventCode 9013 iLineState=900
I also added here "trace Log" calling to the line from the same line, but here with my script, no I.D. number
191350.90 8 linedevstate 2048 0 0
191350.91 8 callstate OFFERING 65973 0 4
191350.94 8 callinfo CALLEDID
191350.95 8 callinfo ORIGIN
191350.97 8 ring 0
191356.91 8 ring 2
191402.95 8 ring 3
191402.95 8 Answer the call at 10/9/2004 7:14:02 PM
191402.98 8 lineAnswer(65973) => 65956
191403.55 8 callstate CONNECTED 65973 1 0
191403.56 8 callstate CONNECTED 65973,1,0
191403.57 8 WorkingModeTAPI@Connected=
191403.59 8 WorkingModeScript@Connected=
191403.60 8 Inband detection not enabled
191403.63 8 StartLoadedVgs at 10/9/2004 7:14:03 PM
191403.64 8 AddRVns [scriptsPath]{C:\Program Files\VoiceGuide\Scripts\Newcall\}
191403.66 8 AddRVns [scriptPath]{C:\Program Files\VoiceGuide\Scripts\Newcall}
191403.69 8 rv add [$RV_STARTTIME]{10/9/2004 7:14:03 PM}
191403.70 8 rv add [$RV_DEVICEID]{8}
191403.73 8 rv add [$RV_CIDNAME]{}
191403.76 8 AddRVns [PathApp]{C:\Program Files\VoiceGuide\}
191403.78 8 rv add [$RV_CIDNUMBER]{}
191403.81 8 tapi Reply (LineEvReply) ok 65956 0
191403.84 8 callinfo MONITORMODES
191403.88 8 timer clear
191403.90 8 [Play 1] Playing
191403.92 8 [Play 1] Playing (C:\Documents and Settings\Roni\Desktop\tst123.wav)
191403.95 8 play set playid=948503
191404.10 8 PlaySoundStart ok [C:\Documents and Settings\Roni\Desktop\tst123.wav]
191404.13 8 timer clear
191404.16 8 RunModule PLAY end
191404.20 8 wa(12020,94850300)
191404.23 8 callinfo MONITORMODES
191416.24 8 play end current play (playid=948503)
191416.27 8 ScriptEventCode 8001 iLineState=1100
191416.29 8 LsPlayMsg EV_PLAY_FINISHED
191416.32 8 timer set 5 EV_TIMEOUT_REPLAYMSG
191421.25 8 timer fired EV_TIMEOUT_REPLAYMSG
191421.27 8 ScriptEventCode 9005 iLineState=1101
191421.30 8 LsPlayMsgFinished EV_TIMEOUT_REPLAYMSG
191421.32 8 [Play 1] Playing (C:\Documents and Settings\Roni\Desktop\tst123.wav)
191421.35 8 play set playid=965898
191421.47 8 PlaySoundStart ok [C:\Documents and Settings\Roni\Desktop\tst123.wav]
191421.50 8 timer clear
191421.53 8 wa(12020,96589800)
191421.56 8 callinfo MONITORMODES
191421.59 8 callstate DISCONNECTED 65973 0 0
191421.62 8 ScriptEventCode 9250 iLineState=1100
191421.65 8 LsPlayMsg EV_REMOTEPARTY_DISCONNECT
191421.67 8 rv add [Hangup Time]{10/9/2004 7:14:21 PM}
191421.70 8 Hanging up call...
191421.74 8 RecSoundStop ok
191421.85 8 PlaySoundStop err=0
191421.87 8 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
191421.93 8 fnHangupCall end
191422.02 8 linedevstate 2048 0 0
191422.05 8 callstate IDLE 65973 0 0
191422.07 8 WorkingMode@Idle=
191422.10 8 timer clear
191422.13 8 timer set 1 EV_TIMEOUT_TIMETOREINITLINE
191422.16 8 tapi Reply (LineEvReply) ok 65939 0
191423.08 8 timer fired EV_TIMEOUT_TIMETOREINITLINE
191423.10 8 ScriptEventCode 9008 iLineState=900
191423.13 8 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
191423.15 8 ReinitTelephony due to IDLE
191423.18 8 tapic lineDeallocateCall(MainCall:65973) 0
191423.52 8 lineOpen(8)=>
191423.53 8 Waiting for a call...
191423.56 8 LineHandle=65905
191423.59 8 timer set 3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
191424.24 0 dial start any summary:|7:idx=0|8:rdy=0|9:idx=0|10:idx=0|
191425.28 0 dial start any summary:|7:idx=0|8:rdy=0|9:idx=0|10:idx=0|
191426.33 0 dial start any summary:|7:idx=0|8:rdy=0|9:idx=0|10:idx=0|
191426.63 8 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
191426.66 8 ScriptEventCode 9013 iLineState=900
Please let me know, Amis
Traces show first call arrived on line ID '7', and the second call arrived on a different line - ID '8'...
Can you post a trace when call arrives on line ID '7' and your script is used...
At this stage I'd suspect that you have one line enabled for CallerID and the other line is not enabled to deliver CallerID...
Thanks for your quick response,
I don't understand, i called from my phone to one line in the system (dxxxB1c2)
and heared the "Credit Card Payment" play script and caller i.d. showed.
Then i change the script to "my script", and called from the same telephone to the system to the same "box" (dxxxB1c2), i heared my script, but when i checked for the caller i.d. it wasn't there, the only thing that was there is the date and the time.
Dear support person, i don't want to ask too meny questions, i know you are buissy with other client, but please let me know what it meanes line id 7 & id 8
also, how could it be different lines when i used the same exact telephone called to the same box.
Thanks, Amis
Traces show first call came in on one line, and second call came in a different line...
How many lines do you have plugged into the computer?
I have 4 lines, now what i found out is that from 3 lines iget caller i.d.
and 1 line no caller i.d.
before it was exactly different, i would get caller i.d. from 1 line and not from the other 3 caller i.d.,
it acts strange!
what i am going to do is call my phone company on monday and ask them to make sure that all the 4 lines are caller i.d. abale.
if there is something to do with VG please let me know, otherwise i'll take care of it my self.
Any way THANKS ALLOT, I know you have try heard.
Thank again, Amis.
There is nothing that you need to do with VG - just make sure that the phone company enables the sending of CallerID on all 4 lines.
