Guest Tan Chee Leng Report post Posted 04/28/2003 03:13 AM To whom it may concern, I would like to enquire if I have buy the license from your party, is that license is only applicable in the particular PC only and I am not able to uninstall and install the license on a brand new pc. thanks. Yours sincerely, Tan Chee Leng Share this post Link to post
SupportTeam Report post Posted 04/28/2003 10:53 PM The Unique ID (to which the Registration is linked) is linked to the network card installed in your computer. This allows you to transfer the VoiceGuide installation to another machine in the future by moving the network card to the new machine. If you want to be able to move the license and your PC has an built-in on-board network card then you should get a PCI based network card which you can easily move in the future, and plug that card into your PC - and disable the built-in on-board network card. The Unique ID will then be linked to the easily movable PCI network card. The licenses for the Standard/Personal version of VoiceGuide are not be linked to a Unique ID (this starts with v4.9) - so you can move them to another PC easily. Share this post Link to post
