Active Lines
is there a why to VG show what lines are avaiable?
example: I have 10 lines... I want my customers to see what lines are currently avaiable from my website, so that way they dont dial a busy line... Can this be done?
David
Just ask your phone company to set up a 'rotary' system across the lines - so customers all a single number and call gets put through to an available line...
If you wnat to externally keep track of which line is used just use a 'DB Query' module in your script to update a database entry at the beginning of call to indicate a line is used and also use a 'DB Query' module on a "On Hangup" script to indicate the line is now free. (see: http://www.voiceguide.com/vghelp/html/Call...l%20Finish.htm)
