Tts Problem
I have installed VoiceGuide Enterprise and the SPeech SDK from Microsoft
The Speech SDK samples work well for me
I get the following trace log when trying to play a text file:
180919.08 15 callstate OFFERING 65758 0 4
180919.09 15 Dont answer yet, wait for CallerID information.
180919.09 15 callinfo DEVSPECIFIC
180919.09 15 ring 0
180919.09 15 Answer the call at 10/10/2004 18:09:19
180919.10 15 lineAnswer(65758) => 65741
180919.10 15 tapi Reply (LineEvReply) ok 65741 0
180919.18 15 callstate CONNECTED 65758,1,0
180919.18 15 WorkingModeTAPI@Connected=
180919.18 15 WorkingModeScript@Connected=
180919.18 15 Inband detection not enabled
180919.18 15 StartLoadedVgs at 10/10/2004 18:09:19
180919.19 15 AddRVns [scriptsPath]{C:\Program Files\VoiceGuide\Scripts\Lewyn\}
180919.20 15 rv add [$RV_STARTTIME]{10/10/2004 18:09:19}
180919.20 15 rv add [$RV_DEVICEID]{15}
180919.20 15 rv add [$RV_CIDNAME]{}
180919.20 15 AddRVns [PathApp]{C:\Program Files\VoiceGuide\}
180919.20 15 rv add [$RV_CIDNUMBER]{}
180919.20 15 TimeoutClear
180919.21 15 [Play 4] Playing
180919.21 15 callinfo TERMINAL
180919.22 15 tts generate start[Hello ]
180919.22 15 tts generate wait
180919.22 15 RunModule PLAY end
180919.40 15 tts generate finish
180919.40 15 [Play 4] Playing (C:\Program Files\VoiceGuide\data\tts15.wav)
180919.41 15 PlaySoundStart err=[0 play PlaySoundStart ResetWavOutAndContinuePlay=>7,play pss EnsureWaveOutIsOpenAndReady=>play FileMmioOpenAndAscend failed in Play_EnsureWaveOutIsOpenAndReady] [C:\Program Files\VoiceGuide\data\tts15.wav]
180919.41 15 err wav file not ready to play. Header incomplete. Lets wait a little while and try again.
180919.41 15 TimeoutSet 0.2 EV_TIMEOUT_REPLAYMSG
180919.41 15 tapie PlayEnd old line=15 0 6877
180919.52 15 Timer fired EV_TIMEOUT_REPLAYMSG
180919.52 15 ScriptEventCode 9005 iLineState=1100
180919.53 15 LsPlayMsg EV_TIMEOUT_REPLAYMSG
180919.53 15 tts generate reuse
180919.53 15 [Play 4] Playing (C:\Program Files\VoiceGuide\data\tts15.wav)
180919.54 15 PlaySoundStart err=[0 play PlaySoundStart ResetWavOutAndContinuePlay=>7,play pss EnsureWaveOutIsOpenAndReady=>play FileMmioOpenAndAscend failed in Play_EnsureWaveOutIsOpenAndReady] [C:\Program Files\VoiceGuide\data\tts15.wav]
180919.54 15 err wav file not ready to play. Header incomplete. Lets wait a little while and try again.
180919.54 15 TimeoutSet 0.2 EV_TIMEOUT_REPLAYMSG
180919.55 15 tapie PlayEnd old line=15 0 7007
180919.75 15 Timer fired EV_TIMEOUT_REPLAYMSG
180919.75 15 ScriptEventCode 9005 iLineState=1100
180919.75 15 LsPlayMsg EV_TIMEOUT_REPLAYMSG
180919.75 15 tts generate reuse
180919.76 15 [Play 4] Playing (C:\Program Files\VoiceGuide\data\tts15.wav)
180919.76 15 PlaySoundStart err=[0 play PlaySoundStart ResetWavOutAndContinuePlay=>7,play pss EnsureWaveOutIsOpenAndReady=>play FileMmioOpenAndAscend failed in Play_EnsureWaveOutIsOpenAndReady] [C:\Program Files\VoiceGuide\data\tts15.wav]
180919.77 15 err wav file not ready to play. Header incomplete. Lets wait a little while and try again.
180919.77 15 TimeoutSet 0.2 EV_TIMEOUT_REPLAYMSG
180919.77 15 tapie PlayEnd old line=15 0 7237
180919.97 15 Timer fired EV_TIMEOUT_REPLAYMSG
180919.97 15 ScriptEventCode 9005 iLineState=1100
180919.97 15 LsPlayMsg EV_TIMEOUT_REPLAYMSG
180919.98 15 tts generate reuse
180919.98 15 [Play 4] Playing (C:\Program Files\VoiceGuide\data\tts15.wav)
180919.99 15 PlaySoundStart err=[0 play PlaySoundStart ResetWavOutAndContinuePlay=>7,play pss EnsureWaveOutIsOpenAndReady=>play FileMmioOpenAndAscend failed in Play_EnsureWaveOutIsOpenAndReady] [C:\Program Files\VoiceGuide\data\tts15.wav]
180919.99 15 err wav file not ready to play. Header incomplete. Lets wait a little while and try again.
180919.99 15 TimeoutSet 0.2 EV_TIMEOUT_REPLAYMSG
180919.99 15 tapie PlayEnd old line=15 0 7457
180920.19 15 Timer fired EV_TIMEOUT_REPLAYMSG
180920.19 15 ScriptEventCode 9005 iLineState=1100
180920.19 15 LsPlayMsg EV_TIMEOUT_REPLAYMSG
180920.20 15 tts generate reuse
180920.20 15 [Play 4] Playing (C:\Program Files\VoiceGuide\data\tts15.wav)
180920.21 15 PlaySoundStart err=[0 play PlaySoundStart ResetWavOutAndContinuePlay=>7,play pss EnsureWaveOutIsOpenAndReady=>play FileMmioOpenAndAscend failed in Play_EnsureWaveOutIsOpenAndReady] [C:\Program Files\VoiceGuide\data\tts15.wav]
180920.21 15 err wav file not ready to play. Header incomplete. Lets wait a little while and try again.
180920.21 15 TimeoutSet 0.2 EV_TIMEOUT_REPLAYMSG
180920.22 15 tapie PlayEnd old line=15 0 7678
180920.41 15 Timer fired EV_TIMEOUT_REPLAYMSG
180920.41 15 ScriptEventCode 9005 iLineState=1100
180920.41 15 LsPlayMsg EV_TIMEOUT_REPLAYMSG
180920.41 15 tts generate reuse
180920.42 15 [Play 4] Playing (C:\Program Files\VoiceGuide\data\tts15.wav)
180920.42 15 PlaySoundStart err=[0 play PlaySoundStart ResetWavOutAndContinuePlay=>7,play pss EnsureWaveOutIsOpenAndReady=>play FileMmioOpenAndAscend failed in Play_EnsureWaveOutIsOpenAndReady] [C:\Program Files\VoiceGuide\data\tts15.wav]
180920.44 15 TimeoutClear
180920.45 15 tapie PlayEnd old line=15 0 7898
180920.45 15 wa(4425,789800)
180924.81 15 Play End line[15] (id=7898)
180924.81 15 ScriptEventCode 8001 iLineState=1100
180924.81 15 LsPlayMsg EV_PLAY_FINISHED
180924.82 15 TimeoutSet 5 EV_TIMEOUT_REPLAYMSG
180927.36 15 callinfo DEVSPECIFIC
180927.37 15 callinfo DEVSPECIFIC
180927.47 15 callinfo TERMINAL
180927.47 15 callstate DISCONNECTED 65758,1,0
180927.48 15 ScriptEventCode 9250 iLineState=1101
180927.48 15 LsPlayMsgFinished EV_REMOTEPARTY_DISCONNECT
180927.48 15 rv add [Hangup Time]{10/10/2004 18:09:27}
180927.48 15 Hanging up call...
180927.49 15 RecSoundStop ok
180927.49 15 PlaySoundStop err=0
180927.49 15 TimeoutSet 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
180927.49 15 fnHangupCall end
180927.50 15 callstate IDLE 65758 0 0
180927.50 15 WorkingMode@Idle=
180927.50 15 TimeoutClear
180927.50 15 TimeoutSet 1 EV_TIMEOUT_TIMETOREINITLINE
180927.51 15 tapi Reply (LineEvReply) err 65724 LINEERR_INVALCALLSTATE [8000001C]
180928.46 15 Timer fired EV_TIMEOUT_TIMETOREINITLINE
180928.46 15 ScriptEventCode 9008 iLineState=900
180928.46 15 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
180928.46 15 ReinitTelephony due to IDLE
180928.48 15 tapic lineDeallocateCall(MainCall:65758) 0
180928.48 15 lineOpen(15)=>
180928.48 15 Waiting for a call...
180928.50 15 LineHandle=65707
180928.50 15 TimeoutSet 3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
180931.85 15 Timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
180931.85 15 ScriptEventCode 9013 iLineState=900
180956.89 0 sys cleanup Start
180956.89 0 sys cleanup End
