kemcmanus Report post Posted 10/10/2004 08:01 PM Our auto dialer stoped working. We a Dialogic 4 line board using 1 line (the first one) all other lines are disconnected. When I load the phone number list (about 5000) everything looks ok except the voiceguide program is orange on the taskbar when it opens. Then it just sits there. Answering scripts seem to work fine. I even tried it with two phone number only, same problem. The numbers just sit in the database (I looked). It worked two weeks ago... Here's the event trace: 155334.89 0 init saving dialer settings 155334.93 0 db database opened 155334.93 0 info Do Not Call List Loading... 155334.94 0 dnc Do No Call List file not specified 155334.94 0 info Do Not Call List Load Finished 0 155334.94 0 info Loading File Reading... 155334.94 0 load dial list file [D:\Backup\46000 Independents - 10K 15K.csv] read start 155334.98 0 load dial list file [5202] read end 155334.99 0 load dial list array save to db start 155334.99 0 info Loading File Database Insert 155335.35 0 info Loading File queued:100 rejected:0 155335.35 0 load dial list array db insert progress: ok: 100 rejected: 0 155335.71 0 info Loading File queued:200 rejected:0 155335.72 0 load dial list array db insert progress: ok: 200 rejected: 0 155336.07 0 info Loading File queued:300 rejected:0 155336.07 0 load dial list array db insert progress: ok: 300 rejected: 0 155336.43 0 info Loading File queued:400 rejected:0 155336.43 0 load dial list array db insert progress: ok: 400 rejected: 0 155336.79 0 info Loading File queued:500 rejected:0 155336.79 0 load dial list array db insert progress: ok: 500 rejected: 0 155337.15 0 info Loading File queued:600 rejected:0 155337.15 0 load dial list array db insert progress: ok: 600 rejected: 0 155337.52 0 info Loading File queued:700 rejected:0 155337.52 0 load dial list array db insert progress: ok: 700 rejected: 0 155337.88 0 info Loading File queued:800 rejected:0 155337.88 0 load dial list array db insert progress: ok: 800 rejected: 0 155338.23 0 info Loading File queued:900 rejected:0 155338.25 0 load dial list array db insert progress: ok: 900 rejected: 0 155338.61 0 info Loading File queued:1000 rejected:0 155338.61 0 load dial list array db insert progress: ok: 1000 rejected: 0 155338.96 0 info Loading File queued:1100 rejected:0 155338.96 0 load dial list array db insert progress: ok: 1100 rejected: 0 155339.33 0 info Loading File queued:1200 rejected:0 155339.33 0 load dial list array db insert progress: ok: 1200 rejected: 0 155339.70 0 info Loading File queued:1300 rejected:0 155339.70 0 load dial list array db insert progress: ok: 1300 rejected: 0 155340.06 0 info Loading File queued:1400 rejected:0 155340.07 0 load dial list array db insert progress: ok: 1400 rejected: 0 155340.43 0 info Loading File queued:1500 rejected:0 155340.43 0 load dial list array db insert progress: ok: 1500 rejected: 0 155340.79 0 info Loading File queued:1600 rejected:0 155340.79 0 load dial list array db insert progress: ok: 1600 rejected: 0 155341.16 0 info Loading File queued:1700 rejected:0 155341.16 0 load dial list array db insert progress: ok: 1700 rejected: 0 155341.52 0 info Loading File queued:1800 rejected:0 155341.53 0 load dial list array db insert progress: ok: 1800 rejected: 0 155341.94 0 info Loading File queued:1900 rejected:0 155341.94 0 load dial list array db insert progress: ok: 1900 rejected: 0 155342.36 0 info Loading File queued:2000 rejected:0 155342.36 0 load dial list array db insert progress: ok: 2000 rejected: 0 155342.78 0 info Loading File queued:2100 rejected:0 155342.78 0 load dial list array db insert progress: ok: 2100 rejected: 0 155343.20 0 info Loading File queued:2200 rejected:0 155343.20 0 load dial list array db insert progress: ok: 2200 rejected: 0 155343.62 0 info Loading File queued:2300 rejected:0 155343.62 0 load dial list array db insert progress: ok: 2300 rejected: 0 155344.04 0 info Loading File queued:2400 rejected:0 155344.04 0 load dial list array db insert progress: ok: 2400 rejected: 0 155344.45 0 info Loading File queued:2500 rejected:0 155344.45 0 load dial list array db insert progress: ok: 2500 rejected: 0 155344.88 0 info Loading File queued:2600 rejected:0 155344.88 0 load dial list array db insert progress: ok: 2600 rejected: 0 155345.29 0 info Loading File queued:2700 rejected:0 155345.30 0 load dial list array db insert progress: ok: 2700 rejected: 0 155345.71 0 info Loading File queued:2800 rejected:0 155345.71 0 load dial list array db insert progress: ok: 2800 rejected: 0 155346.14 0 info Loading File queued:2900 rejected:0 155346.14 0 load dial list array db insert progress: ok: 2900 rejected: 0 155346.55 0 info Loading File queued:3000 rejected:0 155346.56 0 load dial list array db insert progress: ok: 3000 rejected: 0 155346.97 0 info Loading File queued:3100 rejected:0 155346.97 0 load dial list array db insert progress: ok: 3100 rejected: 0 155347.40 0 info Loading File queued:3200 rejected:0 155347.41 0 load dial list array db insert progress: ok: 3200 rejected: 0 155347.83 0 info Loading File queued:3300 rejected:0 155347.84 0 load dial list array db insert progress: ok: 3300 rejected: 0 155348.27 0 info Loading File queued:3400 rejected:0 155348.27 0 load dial list array db insert progress: ok: 3400 rejected: 0 155348.70 0 info Loading File queued:3500 rejected:0 155348.71 0 load dial list array db insert progress: ok: 3500 rejected: 0 155349.16 0 info Loading File queued:3600 rejected:0 155349.17 0 load dial list array db insert progress: ok: 3600 rejected: 0 155349.60 0 info Loading File queued:3700 rejected:0 155350.60 0 load dial list array db insert progress: ok: 3700 rejected: 0 155351.02 0 info Loading File queued:3800 rejected:0 155351.02 0 load dial list array db insert progress: ok: 3800 rejected: 0 155351.46 0 info Loading File queued:3900 rejected:0 155351.46 0 load dial list array db insert progress: ok: 3900 rejected: 0 155351.89 0 info Loading File queued:4000 rejected:0 155351.91 0 load dial list array db insert progress: ok: 4000 rejected: 0 155352.32 0 info Loading File queued:4100 rejected:0 155352.32 0 load dial list array db insert progress: ok: 4100 rejected: 0 155352.75 0 info Loading File queued:4200 rejected:0 155352.77 0 load dial list array db insert progress: ok: 4200 rejected: 0 155353.20 0 info Loading File queued:4300 rejected:0 155353.20 0 load dial list array db insert progress: ok: 4300 rejected: 0 155353.63 0 info Loading File queued:4400 rejected:0 155353.63 0 load dial list array db insert progress: ok: 4400 rejected: 0 155354.06 0 info Loading File queued:4500 rejected:0 155354.06 0 load dial list array db insert progress: ok: 4500 rejected: 0 155354.48 0 info Loading File queued:4600 rejected:0 155354.48 0 load dial list array db insert progress: ok: 4600 rejected: 0 155354.90 0 info Loading File queued:4700 rejected:0 155354.91 0 load dial list array db insert progress: ok: 4700 rejected: 0 155355.33 0 info Loading File queued:4800 rejected:0 155355.34 0 load dial list array db insert progress: ok: 4800 rejected: 0 155355.76 0 info Loading File queued:4900 rejected:0 155355.76 0 load dial list array db insert progress: ok: 4900 rejected: 0 155356.18 0 info Loading File queued:5000 rejected:0 155356.19 0 load dial list array db insert progress: ok: 5000 rejected: 0 155356.61 0 info Loading File queued:5100 rejected:0 155356.61 0 load dial list array db insert progress: ok: 5100 rejected: 0 155357.03 0 info Loading File queued:5200 rejected:0 155357.04 0 load dial list array db insert progress: ok: 5200 rejected: 0 155357.05 0 load dial list array save to db end 155357.06 0 load text box numbers start 155357.06 0 info Text Box Numbers Loading... 155357.09 0 load text box numbers end 155357.09 0 db database closed 155357.10 0 info Finished queued:5202 rejected:0 155357.36 0 info file : 5202 explicittly listed loaded OK 155357.36 0 info file : 0 explicittly listed rejected (Do Not Call List) 155357.37 0 info file : 0 explicittly listed rejected (Other) 155357.37 0 info file : 0 expanded from template loaded OK 155357.37 0 info file : 0 expanded from template rejected (Do Not Call List) 155357.38 0 info file : 0 expanded from template rejected (Other) 155357.38 0 info text : 0 explicittly listed loaded OK 155357.39 0 info text : 0 explicittly listed rejected (Do Not Call List) 155357.39 0 info text : 0 explicittly listed rejected (Other) 155357.40 0 info text : 0 expanded from template loaded OK 155357.40 0 info text : 0 expanded from template rejected (Do Not Call List) 155357.42 0 info text : 0 expanded from template rejected (Other) 155357.43 0 info TOTAL : 5202 loaded OK 155357.43 0 info TOTAL : 0 rejected 150740.44 0 ApiMode=[TAPI] 150740.55 0 Tapi device 10 is: Analog Line 4(dxxxB1C4) 150740.56 0 Tapi device 9 is: Analog Line 3(dxxxB1C3) 150740.56 0 Tapi device 8 is: Analog Line 2(dxxxB1C2) 150740.56 0 Tapi device 7 is: Analog Line 1(dxxxB1C1) 150740.56 0 Tapi device 6 is: H323 Line 150740.56 0 Tapi device 5 is: IPCONF LINE 150740.56 0 Tapi device 4 is: LPT1T 150740.56 0 Tapi device 3 is: WAN Miniport (L2TP) 150740.57 0 Tapi device 2 is: RAS VPN Line 0 150740.57 0 Tapi device 1 is: RAS PPPoE Line0000 150740.57 0 Tapi device 0 is: Creative DI5630 Data Fax Modem 150740.86 0 init vgmulti ver 5.2.3018 150740.91 0 Inband Signaling Config file not specified 150740.93 0 Loading VMB data begin 150740.98 0 Loading VMB data - about to delete old entries 150741.13 0 Loading VMB data - sorting/ordering 150741.13 0 Loading VMB data end 150741.37 0 init clear settings on 1 devices. 150741.42 7 Initialising... 150741.42 0 init attach vgs on 1 devices. 150741.43 0 Script Load C:\Program Files\VoiceGuide\Scripts\Floyd\Standard.vgs 150741.44 0 init lineopen on 1 devices. 150741.44 0 Calling .lineOpen on device 1 150742.64 7 lineOpen(7)=> 150742.64 0 Calling .GetLineHandle on LineId 7 150742.64 7 hLine=66525 150742.68 0 Calling .GetProviderInfo on LineId 7 150742.73 7 tapi ProviderInfo: D41MT.TSP: Dialogic D41 Service Provider 150742.74 7 set provider type: PROVTYPE_DIALOGIC 150742.74 0 Calling lineSetNumRings on lLineHandle 66525 150742.75 7 Waiting for a call... 150742.76 7 dlgc bus switching not supported 150836.36 0 sys cleanup Start 150836.36 0 sys cleanup End 151439.14 0 ERROR 5.2.3018 dial FindDueCall CreateQueryDef [3420:Object invalid or no longer set.] 151439.14 0 Unloading Main Window 151853.85 0 ApiMode=[TAPI] 151853.96 0 Tapi device 10 is: Analog Line 4(dxxxB1C4) 151853.96 0 Tapi device 9 is: Analog Line 3(dxxxB1C3) 151853.97 0 Tapi device 8 is: Analog Line 2(dxxxB1C2) 151853.97 0 Tapi device 7 is: Analog Line 1(dxxxB1C1) 151853.97 0 Tapi device 6 is: H323 Line 151853.97 0 Tapi device 5 is: IPCONF LINE 151853.97 0 Tapi device 4 is: LPT1T 151853.97 0 Tapi device 3 is: WAN Miniport (L2TP) 151853.98 0 Tapi device 2 is: RAS VPN Line 0 151853.98 0 Tapi device 1 is: RAS PPPoE Line0000 151853.98 0 Tapi device 0 is: Creative DI5630 Data Fax Modem 151854.25 0 init vgmulti ver 5.2.3018 151854.30 0 Inband Signaling Config file not specified 151854.33 0 Loading VMB data begin 151854.37 0 Loading VMB data - about to delete old entries 151854.52 0 Loading VMB data - sorting/ordering 151854.53 0 Loading VMB data end 151854.74 0 init clear settings on 1 devices. 151854.79 7 Initialising... 151854.79 0 init attach vgs on 1 devices. 151854.79 0 Script Load C:\Program Files\VoiceGuide\Scripts\Floyd\Standard.vgs 151854.81 0 init lineopen on 1 devices. 151854.81 0 Calling .lineOpen on device 1 151855.92 7 lineOpen(7)=> 151855.92 0 Calling .GetLineHandle on LineId 7 151855.92 7 hLine=66525 151855.95 0 Calling .GetProviderInfo on LineId 7 151855.98 7 tapi ProviderInfo: D41MT.TSP: Dialogic D41 Service Provider 151855.98 7 set provider type: PROVTYPE_DIALOGIC 151855.98 0 Calling lineSetNumRings on lLineHandle 66525 151855.99 7 Waiting for a call... 151856.00 7 dlgc bus switching not supported 151949.23 0 sys cleanup Start 151949.23 0 sys cleanup End 152159.91 0 ERROR 5.2.3018 dial FindDueCall CreateQueryDef [3420:Object invalid or no longer set.] 152159.91 0 Unloading Main Window 152207.65 0 ApiMode=[TAPI] 152207.69 0 Tapi device 10 is: Analog Line 4(dxxxB1C4) 152207.69 0 Tapi device 9 is: Analog Line 3(dxxxB1C3) 152207.69 0 Tapi device 8 is: Analog Line 2(dxxxB1C2) 152207.69 0 Tapi device 7 is: Analog Line 1(dxxxB1C1) 152207.69 0 Tapi device 6 is: H323 Line 152207.70 0 Tapi device 5 is: IPCONF LINE 152207.70 0 Tapi device 4 is: LPT1T 152207.70 0 Tapi device 3 is: WAN Miniport (L2TP) 152207.70 0 Tapi device 2 is: RAS VPN Line 0 152207.70 0 Tapi device 1 is: RAS PPPoE Line0000 152207.70 0 Tapi device 0 is: Creative DI5630 Data Fax Modem 152207.92 0 init vgmulti ver 5.2.3018 152207.95 0 Inband Signaling Config file not specified 152207.96 0 Loading VMB data begin 152207.97 0 Loading VMB data - about to delete old entries 152208.09 0 Loading VMB data - sorting/ordering 152208.09 0 Loading VMB data end 152208.16 0 init clear settings on 1 devices. 152208.16 7 Initialising... 152208.17 0 init attach vgs on 1 devices. 152208.17 0 Script Load C:\Program Files\VoiceGuide\Scripts\Floyd\Standard.vgs 152208.17 0 init lineopen on 1 devices. 152208.17 0 Calling .lineOpen on device 1 152208.46 7 lineOpen(7)=> 152208.46 0 Calling .GetLineHandle on LineId 7 152208.46 7 hLine=66457 152208.47 0 Calling .GetProviderInfo on LineId 7 152208.50 7 tapi ProviderInfo: D41MT.TSP: Dialogic D41 Service Provider 152208.50 7 set provider type: PROVTYPE_DIALOGIC 152208.50 0 Calling lineSetNumRings on lLineHandle 66457 152208.50 7 Waiting for a call... 152208.51 7 dlgc bus switching not supported 152305.63 0 sys cleanup Start 152305.63 0 sys cleanup End 152341.54 0 ERROR 5.2.3018 dial FindDueCall CreateQueryDef [3420:Object invalid or no longer set.] 152341.55 0 Unloading Main Window 152610.11 0 ApiMode=[TAPI] 152610.16 0 Tapi device 10 is: Analog Line 4(dxxxB1C4) 152610.16 0 Tapi device 9 is: Analog Line 3(dxxxB1C3) 152610.18 0 Tapi device 8 is: Analog Line 2(dxxxB1C2) 152610.18 0 Tapi device 7 is: Analog Line 1(dxxxB1C1) 152610.18 0 Tapi device 6 is: H323 Line 152610.18 0 Tapi device 5 is: IPCONF LINE 152610.18 0 Tapi device 4 is: LPT1T 152610.18 0 Tapi device 3 is: WAN Miniport (L2TP) 152610.19 0 Tapi device 2 is: RAS VPN Line 0 152610.19 0 Tapi device 1 is: RAS PPPoE Line0000 152610.19 0 Tapi device 0 is: Creative DI5630 Data Fax Modem 152610.41 0 init vgmulti ver 5.2.3018 152610.44 0 Inband Signaling Config file not specified 152610.45 0 Loading VMB data begin 152610.46 0 Loading VMB data - about to delete old entries 152610.59 0 Loading VMB data - sorting/ordering 152610.59 0 Loading VMB data end 152610.66 0 init clear settings on 1 devices. 152610.66 7 Initialising... 152610.66 0 init attach vgs on 1 devices. 152610.66 0 Script Load C:\Program Files\VoiceGuide\Scripts\Floyd\Standard.vgs 152610.66 0 init lineopen on 1 devices. 152610.66 0 Calling .lineOpen on device 1 152610.96 7 lineOpen(7)=> 152610.96 0 Calling .GetLineHandle on LineId 7 152610.97 7 hLine=66525 152610.97 0 Calling .GetProviderInfo on LineId 7 152610.99 7 tapi ProviderInfo: D41MT.TSP: Dialogic D41 Service Provider 152610.99 7 set provider type: PROVTYPE_DIALOGIC 152610.99 0 Calling lineSetNumRings on lLineHandle 66525 152610.99 7 Waiting for a call... 152610.00 7 dlgc bus switching not supported 152707.05 0 sys cleanup Start 152707.05 0 sys cleanup End 152858.38 0 ERROR 5.2.3018 dial FindDueCall CreateQueryDef [3420:Object invalid or no longer set.] 152858.39 0 Unloading Main Window 153037.50 0 ApiMode=[TAPI] 153037.54 0 Tapi device 10 is: Analog Line 4(dxxxB1C4) 153037.56 0 Tapi device 9 is: Analog Line 3(dxxxB1C3) 153037.56 0 Tapi device 8 is: Analog Line 2(dxxxB1C2) 153037.57 0 Tapi device 7 is: Analog Line 1(dxxxB1C1) 153037.57 0 Tapi device 6 is: H323 Line 153037.57 0 Tapi device 5 is: IPCONF LINE 153037.57 0 Tapi device 4 is: LPT1T 153037.57 0 Tapi device 3 is: WAN Miniport (L2TP) 153037.57 0 Tapi device 2 is: RAS VPN Line 0 153037.58 0 Tapi device 1 is: RAS PPPoE Line0000 153037.58 0 Tapi device 0 is: Creative DI5630 Data Fax Modem 153037.99 0 init vgmulti ver 5.2.3018 153038.02 0 Inband Signaling Config file not specified 153038.03 0 Loading VMB data begin 153038.07 0 Loading VMB data - about to delete old entries 153038.30 0 Loading VMB data - sorting/ordering 153038.31 0 Loading VMB data end 153038.44 0 init clear settings on 1 devices. 153038.44 7 Initialising... 153038.44 0 init attach vgs on 1 devices. 153038.44 0 Script Load C:\Program Files\VoiceGuide\Scripts\Floyd\Standard.vgs 153038.44 0 init lineopen on 1 devices. 153038.44 0 Calling .lineOpen on device 1 153038.75 7 lineOpen(7)=> 153038.75 0 Calling .GetLineHandle on LineId 7 153038.75 7 hLine=66457 153038.75 0 Calling .GetProviderInfo on LineId 7 153038.78 7 tapi ProviderInfo: D41MT.TSP: Dialogic D41 Service Provider 153038.78 7 set provider type: PROVTYPE_DIALOGIC 153038.78 0 Calling lineSetNumRings on lLineHandle 66457 153038.78 7 Waiting for a call... 153038.79 7 dlgc bus switching not supported 153136.61 0 sys cleanup Start 153136.61 0 sys cleanup End 154728.79 0 Unloading Main Window 155359.93 0 ApiMode=[TAPI] 155359.97 0 Tapi device 10 is: Analog Line 4(dxxxB1C4) 155359.97 0 Tapi device 9 is: Analog Line 3(dxxxB1C3) 155359.97 0 Tapi device 8 is: Analog Line 2(dxxxB1C2) 155359.97 0 Tapi device 7 is: Analog Line 1(dxxxB1C1) 155359.97 0 Tapi device 6 is: H323 Line 155359.98 0 Tapi device 5 is: IPCONF LINE 155359.98 0 Tapi device 4 is: LPT1T 155359.98 0 Tapi device 3 is: WAN Miniport (L2TP) 155359.98 0 Tapi device 2 is: RAS VPN Line 0 155359.98 0 Tapi device 1 is: RAS PPPoE Line0000 155359.98 0 Tapi device 0 is: Creative DI5630 Data Fax Modem 155400.20 0 init vgmulti ver 5.2.3018 155400.23 0 Inband Signaling Config file not specified 155400.23 0 Loading VMB data begin 155400.25 0 Loading VMB data - about to delete old entries 155400.41 0 Loading VMB data - sorting/ordering 155400.41 0 Loading VMB data end 155400.50 0 init clear settings on 1 devices. 155400.50 7 Initialising... 155400.50 0 init attach vgs on 1 devices. 155400.50 0 Script Load C:\Program Files\VoiceGuide\Scripts\Floyd\Standard.vgs 155400.51 0 init lineopen on 1 devices. 155400.51 0 Calling .lineOpen on device 1 155400.83 7 lineOpen(7)=> 155400.83 0 Calling .GetLineHandle on LineId 7 155400.83 7 hLine=66525 155400.83 0 Calling .GetProviderInfo on LineId 7 155400.86 7 tapi ProviderInfo: D41MT.TSP: Dialogic D41 Service Provider 155400.86 7 set provider type: PROVTYPE_DIALOGIC 155400.86 0 Calling lineSetNumRings on lLineHandle 66525 155400.86 7 Waiting for a call... 155400.87 7 dlgc bus switching not supported 155458.48 0 sys cleanup Start 155458.48 0 sys cleanup End 150737.004 ocxfn LogLevels 10,C:\Program Files\VoiceGuide\log\,tw.txt,,(null) 150737.004 ------------------------------------------------------------------------------ 150737.004 TAPIWrap OCX v1.84.0, May 20 2004 14:56:36 [For Dialogic Analog] 150737.004 Started at 1010 150737.004 150737.004 ------------------------------------------------------------------------------ 150740.329 linec lineInitialize(0x3130690, 0x2ce0000, 0x2ce9b40, TapiWrap, 0x3130694) => 0x0 150740.329 tapic lineNegotiateAPIVersion(0x800003ff, 0, 0x10003, 0x20001, 0x197570, 0x12c6e0) 150740.329 tapic lineGetDevCaps(0x800003ff, 0, 0x10004, 0, 0x1a4768) call 150740.349 tapic lineGetDevCaps(0x800003ff, 0, 0x10004, 0, 0x1a4768) => NO_ERROR (0) 150740.349 tapic lineGetIcon(0, 0, 0x197578) 150740.389 tapic lineNegotiateAPIVersion(0x800003ff, 1, 0x10003, 0x20001, 0x1a8470, 0x12c6e0) 150740.389 tapic lineGetDevCaps(0x800003ff, 1, 0x10003, 0, 0x1b5668) call 150740.389 tapic lineGetDevCaps(0x800003ff, 1, 0x10003, 0, 0x1b5668) => NO_ERROR (0) 150740.389 tapic lineGetIcon(1, 0, 0x1a8478) 150740.389 tapic lineNegotiateAPIVersion(0x800003ff, 2, 0x10003, 0x20001, 0x1b6938, 0x12c6e0) 150740.389 tapic lineGetDevCaps(0x800003ff, 2, 0x10003, 0, 0x1b5668) call 150740.389 tapic lineGetDevCaps(0x800003ff, 2, 0x10003, 0, 0x1b5668) => NO_ERROR (0) 150740.389 tapic lineGetIcon(2, 0, 0x1b6940) 150740.389 tapic lineNegotiateAPIVersion(0x800003ff, 3, 0x10003, 0x20001, 0x1c3b40, 0x12c6e0) 150740.389 tapic lineGetDevCaps(0x800003ff, 3, 0x10004, 0, 0x1b5668) call 150740.389 tapic lineGetDevCaps(0x800003ff, 3, 0x10004, 0, 0x1b5668) => NO_ERROR (0) 150740.389 tapic lineGetIcon(3, 0, 0x1c3b48) 150740.389 tapic lineNegotiateAPIVersion(0x800003ff, 4, 0x10003, 0x20001, 0x1d0d48, 0x12c6e0) 150740.389 tapic lineGetDevCaps(0x800003ff, 4, 0x10004, 0, 0x1b5668) call 150740.389 tapic lineGetDevCaps(0x800003ff, 4, 0x10004, 0, 0x1b5668) => NO_ERROR (0) 150740.389 tapic lineGetIcon(4, 0, 0x1d0d50) 150740.389 tapic lineNegotiateAPIVersion(0x800003ff, 5, 0x10003, 0x20001, 0x1ddf50, 0x12c6e0) 150740.389 tapic lineGetDevCaps(0x800003ff, 5, 0x10004, 0, 0x1b5668) call 150740.389 tapic lineGetDevCaps(0x800003ff, 5, 0x10004, 0, 0x1b5668) => NO_ERROR (0) 150740.389 tapic lineGetIcon(5, 0, 0x1ddf58) 150740.389 fn TAPI_ERR:LINEERR_OPERATIONUNAVAIL 150740.389 tapic lineNegotiateAPIVersion(0x800003ff, 6, 0x10003, 0x20001, 0x1eb158, 0x12c6e0) 150740.399 tapic lineGetDevCaps(0x800003ff, 6, 0x10004, 0, 0x1b5668) call 150740.399 tapic lineGetDevCaps(0x800003ff, 6, 0x10004, 0, 0x1b5668) => NO_ERROR (0) 150740.399 tapic lineGetIcon(6, 0, 0x1eb160) 150740.399 tapic lineNegotiateAPIVersion(0x800003ff, 7, 0x10003, 0x20001, 0x1f8360, 0x12c6e0) 150740.399 tapic lineGetDevCaps(0x800003ff, 7, 0x10004, 0, 0x1b5668) call 150740.399 tapic lineGetDevCaps(0x800003ff, 7, 0x10004, 0, 0x1b5668) => NO_ERROR (0) 150740.399 tapic lineGetIcon(7, 0, 0x1f8368) 150740.399 tapic lineNegotiateAPIVersion(0x800003ff, 8, 0x10003, 0x20001, 0x205568, 0x12c6e0) 150740.399 tapic lineGetDevCaps(0x800003ff, 8, 0x10004, 0, 0x1b5668) call 150740.399 tapic lineGetDevCaps(0x800003ff, 8, 0x10004, 0, 0x1b5668) => NO_ERROR (0) 150740.399 tapic lineGetIcon(8, 0, 0x205570) 150740.399 tapic lineNegotiateAPIVersion(0x800003ff, 9, 0x10003, 0x20001, 0x212770, 0x12c6e0) 150740.399 tapic lineGetDevCaps(0x800003ff, 9, 0x10004, 0, 0x1b5668) call 150740.399 tapic lineGetDevCaps(0x800003ff, 9, 0x10004, 0, 0x1b5668) => NO_ERROR (0) 150740.399 tapic lineGetIcon(9, 0, 0x212778) 150740.399 tapic lineNegotiateAPIVersion(0x800003ff, 10, 0x10003, 0x20001, 0x21f978, 0x12c6e0) 150740.399 tapic lineGetDevCaps(0x800003ff, 10, 0x10004, 0, 0x1b5668) call 150740.409 tapic lineGetDevCaps(0x800003ff, 10, 0x10004, 0, 0x1b5668) => NO_ERROR (0) 150740.409 tapic lineGetIcon(10, 0, 0x21f980) 150740.549 ocxfn GetLineCount() 150740.549 ocxfn GetLineName(sLineId=10) 150740.549 tapic lineGetDevCaps(0x800003ff, 10, 0x10004, 0, 0x231c20) call 150740.549 tapic lineGetDevCaps(0x800003ff, 10, 0x10004, 0, 0x231c20) => NO_ERROR (0) 150740.549 ocxfn GetLineName(sLineId=9) 150740.549 tapic lineGetDevCaps(0x800003ff, 9, 0x10004, 0, 0x231d48) call 150740.549 tapic lineGetDevCaps(0x800003ff, 9, 0x10004, 0, 0x231d48) => NO_ERROR (0) 150740.559 ocxfn GetLineName(sLineId=8) 150740.559 tapic lineGetDevCaps(0x800003ff, 8, 0x10004, 0, 0x231d70) call 150740.559 tapic lineGetDevCaps(0x800003ff, 8, 0x10004, 0, 0x231d70) => NO_ERROR (0) 150740.559 ocxfn GetLineName(sLineId=7) 150740.559 tapic lineGetDevCaps(0x800003ff, 7, 0x10004, 0, 0x231d70) call 150740.559 tapic lineGetDevCaps(0x800003ff, 7, 0x10004, 0, 0x231d70) => NO_ERROR (0) 150740.559 ocxfn GetLineName(sLineId=6) 150740.559 tapic lineGetDevCaps(0x800003ff, 6, 0x10004, 0, 0x231d70) call 150740.559 tapic lineGetDevCaps(0x800003ff, 6, 0x10004, 0, 0x231d70) => NO_ERROR (0) 150740.559 ocxfn GetLineName(sLineId=5) 150740.559 tapic lineGetDevCaps(0x800003ff, 5, 0x10004, 0, 0x231d98) call 150740.559 tapic lineGetDevCaps(0x800003ff, 5, 0x10004, 0, 0x231d98) => NO_ERROR (0) 150740.559 ocxfn GetLineName(sLineId=4) 150740.559 tapic lineGetDevCaps(0x800003ff, 4, 0x10004, 0, 0x231d98) call 150740.559 tapic lineGetDevCaps(0x800003ff, 4, 0x10004, 0, 0x231d98) => NO_ERROR (0) 150740.559 ocxfn GetLineName(sLineId=3) 150740.559 tapic lineGetDevCaps(0x800003ff, 3, 0x10004, 0, 0x231d98) call 150740.559 tapic lineGetDevCaps(0x800003ff, 3, 0x10004, 0, 0x231d98) => NO_ERROR (0) 150740.569 ocxfn GetLineName(sLineId=2) 150740.569 tapic lineGetDevCaps(0x800003ff, 2, 0x10003, 0, 0x231d98) call 150740.569 tapic lineGetDevCaps(0x800003ff, 2, 0x10003, 0, 0x231d98) => NO_ERROR (0) 150740.569 ocxfn GetLineName(sLineId=1) 150740.569 tapic lineGetDevCaps(0x800003ff, 1, 0x10003, 0, 0x231d98) call 150740.569 tapic lineGetDevCaps(0x800003ff, 1, 0x10003, 0, 0x231d98) => NO_ERROR (0) 150740.569 ocxfn GetLineName(sLineId=0) 150740.569 tapic lineGetDevCaps(0x800003ff, 0, 0x10004, 0, 0x231d98) call 150740.569 tapic lineGetDevCaps(0x800003ff, 0, 0x10004, 0, 0x231d98) => NO_ERROR (0) 150741.440 ocxfn LineOpen(sLineId=7) 150741.450 tapic lineNegotiateAPIVersion(0x800003ff, 7, 0x10003, 0x20001, 0x1f8360, 0x12dfec) 150741.450 tapic lineGetDevCaps(0x800003ff, 7, 0x10004, 0, 0x2497d8) call 150741.450 tapic lineGetDevCaps(0x800003ff, 7, 0x10004, 0, 0x2497d8) => NO_ERROR (0) 150741.450 tapic lineGetIcon(7, 0, 0x1f8368) 150741.450 tapic lineGetDevCaps(0x800003ff, 7, 0x10004, 0, 0x2497d8) call 150741.450 tapic lineGetDevCaps(0x800003ff, 7, 0x10004, 0, 0x2497d8) => NO_ERROR (0) 150741.450 tapic lineOpen(0x800003ff, 7, 0x1f835c, 0x10004, 0, 0x1f8350, 0x4, LINEMEDIAMODE_INTERACTIVEVOICE | LINEMEDIAMODE_AUTOMATEDVOICE, 0) 150741.561 tapic lineGetID(0x103dd, 0, 0, 0x1, 0x55b0008, wave/in) LINECALLSELECT_LINE hLineInfo 150742.562 tapic lineGetID(0x103dd, 0, 0, 0x1, 0x55b0008, wave/in) => 0x0 150742.562 tapic lineGetID => 1 150742.562 tapic lineGetID(0x103dd, 0, 0, 0x1, 0x55b0008, wave/out) LINECALLSELECT_LINE hLineInfo 150742.582 tapic lineGetID(0x103dd, 0, 0, 0x1, 0x55b0008, wave/out) => 0x0 150742.582 tapic lineGetID => 1 150742.582 ocxfn GetLineName(sLineId=7) 150742.582 tapic lineGetDevCaps(0x800003ff, 7, 0x10004, 0, 0x5595a48) call 150742.612 tapic lineGetDevCaps(0x800003ff, 7, 0x10004, 0, 0x5595a48) => NO_ERROR (0) 150742.632 wavec waveInGetDevCaps(0x1, 0x12e050, 0x30) => 0 150742.632 wavec waveOutGetDevCaps(0x1, 0x12e01c, 0x34) => 0 150742.632 wave IN:[Dialogic Wave[dxxxB1C1] v16.0 format=0x1, channels=0x1] OUT:[Dialogic Wave[dxxxB1C1] v16.0 format=0x1, channels=0x1, support=0x4] 150742.632 ocxfn LineOpen(7, 0, 0, , ) 150742.632 tapic lineGetID(0x103dd, 0, 0, 0x1, 0x55b0240, wave/in) LINECALLSELECT_LINE hLineInfo 150742.632 tapic lineGetID(0x103dd, 0, 0, 0x1, 0x55b0240, wave/in) => 0x0 150742.632 tapic lineGetID => 1 150742.632 tapic lineGetID(0x103dd, 0, 0, 0x1, 0x55b0240, wave/out) LINECALLSELECT_LINE hLineInfo 150742.632 tapic lineGetID(0x103dd, 0, 0, 0x1, 0x55b0240, wave/out) => 0x0 150742.632 tapic lineGetID => 1 150742.632 ocxfn GetLineName(sLineId=7) 150742.632 tapic lineGetDevCaps(0x800003ff, 7, 0x10004, 0, 0x5595a48) call 150742.642 tapic lineGetDevCaps(0x800003ff, 7, 0x10004, 0, 0x5595a48) => NO_ERROR (0) 150742.642 wavec waveInGetDevCaps(0x1, 0x12dfb4, 0x30) => 0 150742.642 wavec waveOutGetDevCaps(0x1, 0x12df80, 0x34) => 0 150742.642 wave IN:[Dialogic Wave[dxxxB1C1] v16.0 format=0x1, channels=0x1] OUT:[Dialogic Wave[dxxxB1C1] v16.0 format=0x1, channels=0x1, support=0x4] 150742.682 ocxfn GetProviderInfo(sLineId=7) 150742.682 tapic lineGetDevCaps(0x800003ff, 7, 0x10004, 0, 0x5595dd8) call 150742.692 tapic lineGetDevCaps(0x800003ff, 7, 0x10004, 0, 0x5595dd8) => NO_ERROR (0) 150742.732 fn GetProviderInfo => Dialogic 150742.742 ocxfn SilenceDetectSet(sLineId=7, sTimeLen=0, sVolumeLevel=0) 150742.752 ocxfn DialogicScUnroute dxxxB1C1 150742.752 dlgc scbus set DevType1 = LSI, sDlgcDevName=dxxxB1C1 150742.752 dlgc scbus opened dxxxB1C1 as devh=1 150742.752 dlgc scbus dx_getxmitslot() failed dxxxB1C1(1): Error message = Invalid Switching Handler Bus Mode 151437.889 tapic lineNegotiateAPIVersion(0x800003ff, 7, 0x10003, 0x20001, 0x1f8360, 0x12ee28) 151437.889 tapic lineGetDevCaps(0x800003ff, 7, 0x10004, 0, 0x559d008) call 151437.889 tapic lineGetDevCaps(0x800003ff, 7, 0x10004, 0, 0x559d008) => NO_ERROR (0) 151437.889 tapic lineGetIcon(7, 0, 0x1f8368) 151439.031 linec lineShutdown(0x800003ff) => 0x0 151850.383 ocxfn LogLevels 10,C:\Program Files\VoiceGuide\log\,tw.txt,,(null) 151850.393 ------------------------------------------------------------------------------ 151850.393 TAPIWrap OCX v1.84.0, May 20 2004 14:56:36 [For Dialogic Analog] 151850.393 Started at 1010 151850.393 151850.393 ------------------------------------------------------------------------------ 151853.738 linec lineInitialize(0x3130690, 0x2ce0000, 0x2ce9b40, TapiWrap, 0x3130694) => 0x0 151853.738 tapic lineNegotiateAPIVersion(0x800003ff, 0, 0x10003, 0x20001, 0x197570, 0x12c6e0) 151853.738 tapic lineGetDevCaps(0x800003ff, 0, 0x10004, 0, 0x1a4768) call 151853.758 tapic lineGetDevCaps(0x800003ff, 0, 0x10004, 0, 0x1a4768) => NO_ERROR (0) 151853.758 tapic lineGetIcon(0, 0, 0x197578) 151853.788 tapic lineNegotiateAPIVersion(0x800003ff, 1, 0x10003, 0x20001, 0x1a8470, 0x12c6e0) 151853.788 tapic lineGetDevCaps(0x800003ff, 1, 0x10003, 0, 0x1b5668) call 151853.798 tapic lineGetDevCaps(0x800003ff, 1, 0x10003, 0, 0x1b5668) => NO_ERROR (0) 151853.798 tapic lineGetIcon(1, 0, 0x1a8478) 151853.798 tapic lineNegotiateAPIVersion(0x800003ff, 2, 0x10003, 0x20001, 0x1b6938, 0x12c6e0) 151853.798 tapic lineGetDevCaps(0x800003ff, 2, 0x10003, 0, 0x1b5668) call 151853.798 tapic lineGetDevCaps(0x800003ff, 2, 0x10003, 0, 0x1b5668) => NO_ERROR (0) 151853.798 tapic lineGetIcon(2, 0, 0x1b6940) 151853.798 tapic lineNegotiateAPIVersion(0x800003ff, 3, 0x10003, 0x20001, 0x1c3b40, 0x12c6e0) 151853.798 tapic lineGetDevCaps(0x800003ff, 3, 0x10004, 0, 0x1b5668) call 151853.798 tapic lineGetDevCaps(0x800003ff, 3, 0x10004, 0, 0x1b5668) => NO_ERROR (0) 151853.798 tapic lineGetIcon(3, 0, 0x1c3b48) 151853.798 tapic lineNegotiateAPIVersion(0x800003ff, 4, 0x10003, 0x20001, 0x1d0d48, 0x12c6e0) 151853.798 tapic lineGetDevCaps(0x800003ff, 4, 0x10004, 0, 0x1b5668) call 151853.798 tapic lineGetDevCaps(0x800003ff, 4, 0x10004, 0, 0x1b5668) => NO_ERROR (0) 151853.798 tapic lineGetIcon(4, 0, 0x1d0d50) 151853.798 tapic lineNegotiateAPIVersion(0x800003ff, 5, 0x10003, 0x20001, 0x1ddf50, 0x12c6e0) 151853.798 tapic lineGetDevCaps(0x800003ff, 5, 0x10004, 0, 0x1b5668) call 151853.798 tapic lineGetDevCaps(0x800003ff, 5, 0x10004, 0, 0x1b5668) => NO_ERROR (0) 151853.798 tapic lineGetIcon(5, 0, 0x1ddf58) 151853.798 fn TAPI_ERR:LINEERR_OPERATIONUNAVAIL 151853.798 tapic lineNegotiateAPIVersion(0x800003ff, 6, 0x10003, 0x20001, 0x1eb158, 0x12c6e0) 151853.798 tapic lineGetDevCaps(0x800003ff, 6, 0x10004, 0, 0x1b5668) call 151853.798 tapic lineGetDevCaps(0x800003ff, 6, 0x10004, 0, 0x1b5668) => NO_ERROR (0) 151853.798 tapic lineGetIcon(6, 0, 0x1eb160) 151853.798 tapic lineNegotiateAPIVersion(0x800003ff, 7, 0x10003, 0x20001, 0x1f8360, 0x12c6e0) 151853.808 tapic lineGetDevCaps(0x800003ff, 7, 0x10004, 0, 0x1b5668) call 151853.808 tapic lineGetDevCaps(0x800003ff, 7, 0x10004, 0, 0x1b5668) => NO_ERROR (0) 151853.808 tapic lineGetIcon(7, 0, 0x1f8368) 151853.808 tapic lineNegotiateAPIVersion(0x800003ff, 8, 0x10003, 0x20001, 0x205568, 0x12c6e0) 151853.808 tapic lineGetDevCaps(0x800003ff, 8, 0x10004, 0, 0x1b5668) call 151853.808 tapic lineGetDevCaps(0x800003ff, 8, 0x10004, 0, 0x1b5668) => NO_ERROR (0) 151853.808 tapic lineGetIcon(8, 0, 0x205570) 151853.808 tapic lineNegotiateAPIVersion(0x800003ff, 9, 0x10003, 0x20001, 0x212770, 0x12c6e0) 151853.808 tapic lineGetDevCaps(0x800003ff, 9, 0x10004, 0, 0x1b5668) call 151853.808 tapic lineGetDevCaps(0x800003ff, 9, 0x10004, 0, 0x1b5668) => NO_ERROR (0) 151853.808 tapic lineGetIcon(9, 0, 0x212778) 151853.808 tapic lineNegotiateAPIVersion(0x800003ff, 10, 0x10003, 0x20001, 0x21f978, 0x12c6e0) 151853.808 tapic lineGetDevCaps(0x800003ff, 10, 0x10004, 0, 0x1b5668) call 151853.808 tapic lineGetDevCaps(0x800003ff, 10, 0x10004, 0, 0x1b5668) => NO_ERROR (0) 151853.808 tapic lineGetIcon(10, 0, 0x21f980) 151853.958 ocxfn GetLineCount() 151853.958 ocxfn GetLineName(sLineId=10) 151853.958 tapic lineGetDevCaps(0x800003ff, 10, 0x10004, 0, 0x231c20) call 151853.958 tapic lineGetDevCaps(0x800003ff, 10, 0x10004, 0, 0x231c20) => NO_ERROR (0) 151853.958 ocxfn GetLineName(sLineId=9) 151853.958 tapic lineGetDevCaps(0x800003ff, 9, 0x10004, 0, 0x231d48) call 151853.958 tapic lineGetDevCaps(0x800003ff, 9, 0x10004, 0, 0x231d48) => NO_ERROR (0) 151853.958 ocxfn GetLineName(sLineId=8) 151853.958 tapic lineGetDevCaps(0x800003ff, 8, 0x10004, 0, 0x231d70) call 151853.968 tapic lineGetDevCaps(0x800003ff, 8, 0x10004, 0, 0x231d70) => NO_ERROR (0) 151853.968 ocxfn GetLineName(sLineId=7) 151853.968 tapic lineGetDevCaps(0x800003ff, 7, 0x10004, 0, 0x231d70) call 151853.968 tapic lineGetDevCaps(0x800003ff, 7, 0x10004, 0, 0x231d70) => NO_ERROR (0) 151853.968 ocxfn GetLineName(sLineId=6) 151853.968 tapic lineGetDevCaps(0x800003ff, 6, 0x10004, 0, 0x231d70) call 151853.968 tapic lineGetDevCaps(0x800003ff, 6, 0x10004, 0, 0x231d70) => NO_ERROR (0) 151853.968 ocxfn GetLineName(sLineId=5) 151853.968 tapic lineGetDevCaps(0x800003ff, 5, 0x10004, 0, 0x231d98) call 151853.968 tapic lineGetDevCaps(0x800003ff, 5, 0x10004, 0, 0x231d98) => NO_ERROR (0) 151853.968 ocxfn GetLineName(sLineId=4) 151853.968 tapic lineGetDevCaps(0x800003ff, 4, 0x10004, 0, 0x231d98) call 151853.968 tapic lineGetDevCaps(0x800003ff, 4, 0x10004, 0, 0x231d98) => NO_ERROR (0) 151853.968 ocxfn GetLineName(sLineId=3) 151853.968 tapic lineGetDevCaps(0x800003ff, 3, 0x10004, 0, 0x231d98) call 151853.968 tapic lineGetDevCaps(0x800003ff, 3, 0x10004, 0, 0x231d98) => NO_ERROR (0) 151853.968 ocxfn GetLineName(sLineId=2) 151853.968 tapic lineGetDevCaps(0x800003ff, 2, 0x10003, 0, 0x231d98) call 151853.968 tapic lineGetDevCaps(0x800003ff, 2, 0x10003, 0, 0x231d98) => NO_ERROR (0) 151853.978 ocxfn GetLineName(sLineId=1) 151853.978 tapic lineGetDevCaps(0x800003ff, 1, 0x10003, 0, 0x231d98) call 151853.978 tapic lineGetDevCaps(0x800003ff, 1, 0x10003, 0, 0x231d98) => NO_ERROR (0) 151853.978 ocxfn GetLineName(sLineId=0) 151853.978 tapic lineGetDevCaps(0x800003ff, 0, 0x10004, 0, 0x231d98) call 151853.978 tapic lineGetDevCaps(0x800003ff, 0, 0x10004, 0, 0x231d98) => NO_ERROR (0) 151854.810 ocxfn LineOpen(sLineId=7) 151854.810 tapic lineNegotiateAPIVersion(0x800003ff, 7, 0x10003, 0x20001, 0x1f8360, 0x12dfec) 151854.810 tapic lineGetDevCaps(0x800003ff, 7, 0x10004, 0, 0x2497d8) call 151854.810 tapic lineGetDevCaps(0x800003ff, 7, 0x10004, 0, 0x2497d8) => NO_ERROR (0) 151854.810 tapic lineGetIcon(7, 0, 0x1f8368) 151854.810 tapic lineGetDevCaps(0x800003ff, 7, 0x10004, 0, 0x2497d8) call 151854.820 tapic lineGetDevCaps(0x800003ff, 7, 0x10004, 0, 0x2497d8) => NO_ERROR (0) 151854.820 tapic lineOpen(0x800003ff, 7, 0x1f835c, 0x10004, 0, 0x1f8350, 0x4, LINEMEDIAMODE_INTERACTIVEVOICE | LINEMEDIAMODE_AUTOMATEDVOICE, 0) 151854.930 tapic lineGetID(0x103dd, 0, 0, 0x1, 0x55b0008, wave/in) LINECALLSELECT_LINE hLineInfo 151855.821 tapic lineGetID(0x103dd, 0, 0, 0x1, 0x55b0008, wave/in) => 0x0 151855.821 tapic lineGetID => 1 151855.821 tapic lineGetID(0x103dd, 0, 0, 0x1, 0x55b0008, wave/out) LINECALLSELECT_LINE hLineInfo 151855.821 tapic lineGetID(0x103dd, 0, 0, 0x1, 0x55b0008, wave/out) => 0x0 151855.821 tapic lineGetID => 1 151855.821 ocxfn GetLineName(sLineId=7) 151855.821 tapic lineGetDevCaps(0x800003ff, 7, 0x10004, 0, 0x5595a48) call 151855.891 tapic lineGetDevCaps(0x800003ff, 7, 0x10004, 0, 0x5595a48) => NO_ERROR (0) 151855.901 wavec waveInGetDevCaps(0x1, 0x12e050, 0x30) => 0 151855.911 wavec waveOutGetDevCaps(0x1, 0x12e01c, 0x34) => 0 151855.911 wave IN:[Dialogic Wave[dxxxB1C1] v16.0 format=0x1, channels=0x1] OUT:[Dialogic Wave[dxxxB1C1] v16.0 format=0x1, channels=0x1, support=0x4] 151855.911 ocxfn LineOpen(7, 0, 0, , ) 151855.911 tapic lineGetID(0x103dd, 0, 0, 0x1, 0x55b0240, wave/in) LINECALLSELECT_LINE hLineInfo 151855.911 tapic lineGetID(0x103dd, 0, 0, 0x1, 0x55b0240, wave/in) => 0x0 151855.911 tapic lineGetID => 1 151855.911 tapic lineGetID(0x103dd, 0, 0, 0x1, 0x55b0240, wave/out) LINECALLSELECT_LINE hLineInfo 151855.911 tapic lineGetID(0x103dd, 0, 0, 0x1, 0x55b0240, wave/out) => 0x0 151855.911 tapic lineGetID => 1 151855.911 ocxfn GetLineName(sLineId=7) 151855.911 tapic lineGetDevCaps(0x800003ff, 7, 0x10004, 0, 0x5595a48) call 151855.921 tapic lineGetDevCaps(0x800003ff, 7, 0x10004, 0, 0x5595a48) => NO_ERROR (0) 151855.921 wavec waveInGetDevCaps(0x1, 0x12dfb4, 0x30) => 0 151855.921 wavec waveOutGetDevCaps(0x1, 0x12df80, 0x34) => 0 151855.921 wave IN:[Dialogic Wave[dxxxB1C1] v16.0 format=0x1, channels=0x1] OUT:[Dialogic Wave[dxxxB1C1] v16.0 format=0x1, channels=0x1, support=0x4] 151855.951 ocxfn GetProviderInfo(sLineId=7) 151855.951 tapic lineGetDevCaps(0x800003ff, 7, 0x10004, 0, 0x5595dd8) call 151855.971 tapic lineGetDevCaps(0x800003ff, 7, 0x10004, 0, 0x5595dd8) => NO_ERROR (0) 151855.981 fn GetProviderInfo => Dialogic 151855.981 ocxfn SilenceDetectSet(sLineId=7, sTimeLen=0, sVolumeLevel=0) 151855.991 ocxfn DialogicScUnroute dxxxB1C1 151855.991 dlgc scbus set DevType1 = LSI, sDlgcDevName=dxxxB1C1 151855.991 dlgc scbus opened dxxxB1C1 as devh=1 151856.001 dlgc scbus dx_getxmitslot() failed dxxxB1C1(1): Error message = Invalid Switching Handler Bus Mode 152158.674 tapic lineNegotiateAPIVersion(0x800003ff, 7, 0x10003, 0x20001, 0x1f8360, 0x12ee28) 152158.674 tapic lineGetDevCaps(0x800003ff, 7, 0x10004, 0, 0x559d008) call 152158.684 tapic lineGetDevCaps(0x800003ff, 7, 0x10004, 0, 0x559d008) => NO_ERROR (0) 152158.684 tapic lineGetIcon(7, 0, 0x1f8368) 152159.796 linec lineShutdown(0x800003ff) => 0x0 152206.886 ocxfn LogLevels 10,C:\Program Files\VoiceGuide\log\,tw.txt,,(null) 152206.886 ------------------------------------------------------------------------------ 152206.886 TAPIWrap OCX v1.84.0, May 20 2004 14:56:36 [For Dialogic Analog] 152206.886 Started at 1010 152206.886 152206.886 ------------------------------------------------------------------------------ 152207.617 linec lineInitialize(0x3130690, 0x2ce0000, 0x2ce9b40, TapiWrap, 0x3130694) => 0x0 152207.617 tapic lineNegotiateAPIVersion(0x800003ff, 0, 0x10003, 0x20001, 0x1975a0, 0x12c6e0) 152207.617 tapic lineGetDevCaps(0x800003ff, 0, 0x10004, 0, 0x1a4fb0) call 152207.617 tapic lineGetDevCaps(0x800003ff, 0, 0x10004, 0, 0x1a4fb0) => NO_ERROR (0) 152207.617 tapic lineGetIcon(0, 0, 0x1975a8) 152207.617 tapic lineNegotiateAPIVersion(0x800003ff, 1, 0x10003, 0x20001, 0x1a84a0, 0x12c6e0) 152207.617 tapic lineGetDevCaps(0x800003ff, 1, 0x10003, 0, 0x1b5698) call 152207.617 tapic lineGetDevCaps(0x800003ff, 1, 0x10003, 0, 0x1b5698) => NO_ERROR (0) 152207.617 tapic lineGetIcon(1, 0, 0x1a84a8) 152207.617 tapic lineNegotiateAPIVersion(0x800003ff, 2, 0x10003, 0x20001, 0x1b56a8, 0x12c6e0) 152207.617 tapic lineGetDevCaps(0x800003ff, 2, 0x10003, 0, 0x1c28a0) call 152207.617 tapic lineGetDevCaps(0x800003ff, 2, 0x10003, 0, 0x1c28a0) => NO_ERROR (0) 152207.617 tapic lineGetIcon(2, 0, 0x1b56b0) 152207.617 tapic lineNegotiateAPIVersion(0x800003ff, 3, 0x10003, 0x20001, 0x1c28b0, 0x12c6e0) 152207.627 tapic lineGetDevCaps(0x800003ff, 3, 0x10004, 0, 0x1cfaa8) call 152207.627 tapic lineGetDevCaps(0x800003ff, 3, 0x10004, 0, 0x1cfaa8) => NO_ERROR (0) 152207.627 tapic lineGetIcon(3, 0, 0x1c28b8) 152207.627 tapic lineNegotiateAPIVersion(0x800003ff, 4, 0x10003, 0x20001, 0x1cfab8, 0x12c6e0) 152207.627 tapic lineGetDevCaps(0x800003ff, 4, 0x10004, 0, 0x1dccb0) call 152207.627 tapic lineGetDevCaps(0x800003ff, 4, 0x10004, 0, 0x1dccb0) => NO_ERROR (0) 152207.627 tapic lineGetIcon(4, 0, 0x1cfac0) 152207.627 tapic lineNegotiateAPIVersion(0x800003ff, 5, 0x10003, 0x20001, 0x1dccc0, 0x12c6e0) 152207.627 tapic lineGetDevCaps(0x800003ff, 5, 0x10004, 0, 0x1e9eb8) call 152207.627 tapic lineGetDevCaps(0x800003ff, 5, 0x10004, 0, 0x1e9eb8) => NO_ERROR (0) 152207.627 tapic lineGetIcon(5, 0, 0x1dccc8) 152207.627 fn TAPI_ERR:LINEERR_OPERATIONUNAVAIL 152207.627 tapic lineNegotiateAPIVersion(0x800003ff, 6, 0x10003, 0x20001, 0x1e9ec8, 0x12c6e0) 152207.627 tapic lineGetDevCaps(0x800003ff, 6, 0x10004, 0, 0x1f70c0) call 152207.627 tapic lineGetDevCaps(0x800003ff, 6, 0x10004, 0, 0x1f70c0) => NO_ERROR (0) 152207.627 tapic lineGetIcon(6, 0, 0x1e9ed0) 152207.627 tapic lineNegotiateAPIVersion(0x800003ff, 7, 0x10003, 0x20001, 0x1f70d0, 0x12c6e0) 152207.627 tapic lineGetDevCaps(0x800003ff, 7, 0x10004, 0, 0x2042c8) call 152207.627 tapic lineGetDevCaps(0x800003ff, 7, 0x10004, 0, 0x2042c8) => NO_ERROR (0) 152207.627 tapic lineGetIcon(7, 0, 0x1f70d8) 152207.627 tapic lineNegotiateAPIVersion(0x800003ff, 8, 0x10003, 0x20001, 0x2042d8, 0x12c6e0) 152207.627 tapic lineGetDevCaps(0x800003ff, 8, 0x10004, 0, 0x2114d0) call 152207.637 tapic lineGetDevCaps(0x800003ff, 8, 0x10004, 0, 0x2114d0) => NO_ERROR (0) 152207.637 tapic lineGetIcon(8, 0, 0x2042e0) 152207.637 tapic lineNegotiateAPIVersion(0x800003ff, 9, 0x10003, 0x20001, 0x2114e0, 0x12c6e0) 152207.637 tapic lineGetDevCaps(0x800003ff, 9, 0x10004, 0, 0x21e6d8) call 152207.637 tapic lineGetDevCaps(0x800003ff, 9, 0x10004, 0, 0x21e6d8) => NO_ERROR (0) 152207.637 tapic lineGetIcon(9, 0, 0x2114e8) 152207.637 tapic lineNegotiateAPIVersion(0x800003ff, 10, 0x10003, 0x20001, 0x21e6e8, 0x12c6e0) 152207.637 tapic lineGetDevCaps(0x800003ff, 10, 0x10004, 0, 0x22b8e0) call 152207.637 tapic lineGetDevCaps(0x800003ff, 10, 0x10004, 0, 0x22b8e0) => NO_ERROR (0) 152207.637 tapic lineGetIcon(10, 0, 0x21e6f0) 152207.677 ocxfn GetLineCount() 152207.677 ocxfn GetLineName(sLineId=10) 152207.677 tapic lineGetDevCaps(0x800003ff, 10, 0x10004, 0, 0x231418) call 152207.687 tapic lineGetDevCaps(0x800003ff, 10, 0x10004, 0, 0x231418) => NO_ERROR (0) 152207.687 ocxfn GetLineName(sLineId=9) 152207.687 tapic lineGetDevCaps(0x800003ff, 9, 0x10004, 0, 0x232d60) call 152207.687 tapic lineGetDevCaps(0x800003ff, 9, 0x10004, 0, 0x232d60) => NO_ERROR (0) 152207.687 ocxfn GetLineName(sLineId=8) 152207.687 tapic lineGetDevCaps(0x800003ff, 8, 0x10004, 0, 0x232d60) call 152207.687 tapic lineGetDevCaps(0x800003ff, 8, 0x10004, 0, 0x232d60) => NO_ERROR (0) 152207.687 ocxfn GetLineName(sLineId=7) 152207.687 tapic lineGetDevCaps(0x800003ff, 7, 0x10004, 0, 0x232d60) call 152207.687 tapic lineGetDevCaps(0x800003ff, 7, 0x10004, 0, 0x232d60) => NO_ERROR (0) 152207.687 ocxfn GetLineName(sLineId=6) 152207.687 tapic lineGetDevCaps(0x800003ff, 6, 0x10004, 0, 0x232d60) call 152207.687 tapic lineGetDevCaps(0x800003ff, 6, 0x10004, 0, 0x232d60) => NO_ERROR (0) 152207.697 ocxfn GetLineName(sLineId=5) 152207.697 tapic lineGetDevCaps(0x800003ff, 5, 0x10004, 0, 0x232d60) call 152207.697 tapic lineGetDevCaps(0x800003ff, 5, 0x10004, 0, 0x232d60) => NO_ERROR (0) 152207.697 ocxfn GetLineName(sLineId=4) 152207.697 tapic lineGetDevCaps(0x800003ff, 4, 0x10004, 0, 0x232d60) call 152207.697 tapic lineGetDevCaps(0x800003ff, 4, 0x10004, 0, 0x232d60) => NO_ERROR (0) 152207.697 ocxfn GetLineName(sLineId=3) 152207.697 tapic lineGetDevCaps(0x800003ff, 3, 0x10004, 0, 0x232d60) call 152207.697 tapic lineGetDevCaps(0x800003ff, 3, 0x10004, 0, 0x232d60) => NO_ERROR (0) 152207.697 ocxfn GetLineName(sLineId=2) 152207.697 tapic lineGetDevCaps(0x800003ff, 2, 0x10003, 0, 0x232d60) call 152207.697 tapic lineGetDevCaps(0x800003ff, 2, 0x10003, 0, 0x232d60) => NO_ERROR (0) 152207.697 ocxfn GetLineName(sLineId=1) 152207.697 tapic lineGetDevCaps(0x800003ff, 1, 0x10003, 0, 0x232d60) call 152207.697 tapic lineGetDevCaps(0x800003ff, 1, 0x10003, 0, 0x232d60) => NO_ERROR (0) 152207.697 ocxfn GetLineName(sLineId=0) 152207.697 tapic lineGetDevCaps(0x800003ff, 0, 0x10004, 0, 0x232d60) call 152207.697 tapic lineGetDevCaps(0x800003ff, 0, 0x10004, 0, 0x232d60) => NO_ERROR (0) 152208.168 ocxfn LineOpen(sLineId=7) 152208.168 tapic lineNegotiateAPIVersion(0x800003ff, 7, 0x10003, 0x20001, 0x1f70d0, 0x12dfec) 152208.168 tapic lineGetDevCaps(0x800003ff, 7, 0x10004, 0, 0x249c18) call 152208.168 tapic lineGetDevCaps(0x800003ff, 7, 0x10004, 0, 0x249c18) => NO_ERROR (0) 152208.168 tapic lineGetIcon(7, 0, 0x1f70d8) 152208.168 tapic lineGetDevCaps(0x800003ff, 7, 0x10004, 0, 0x249c18) call 152208.178 tapic lineGetDevCaps(0x800003ff, 7, 0x10004, 0, 0x249c18) => NO_ERROR (0) 152208.178 tapic lineOpen(0x800003ff, 7, 0x1f70cc, 0x10004, 0, 0x1f70c0, 0x4, LINEMEDIAMODE_INTERACTIVEVOICE | LINEMEDIAMODE_AUTOMATEDVOICE, 0) 152208.268 tapic lineGetID(0x10399, 0, 0, 0x1, 0x55b0040, wave/in) LINECALLSELECT_LINE hLineInfo 152208.438 tapic lineGetID(0x10399, 0, 0, 0x1, 0x55b0040, wave/in) => 0x0 152208.438 tapic lineGetID => 1 152208.438 tapic lineGetID(0x10399, 0, 0, 0x1, 0x55b0040, wave/out) LINECALLSELECT_LINE hLineInfo 152208.438 tapic lineGetID(0x10399, 0, 0, 0x1, 0x55b0040, wave/out) => 0x0 152208.438 tapic lineGetID => 1 152208.438 ocxfn GetLineName(sLineId=7) 152208.438 tapic lineGetDevCaps(0x800003ff, 7, 0x10004, 0, 0x55936a8) call 152208.448 tapic lineGetDevCaps(0x800003ff, 7, 0x10004, 0, 0x55936a8) => NO_ERROR (0) 152208.448 wavec waveInGetDevCaps(0x1, 0x12e050, 0x30) => 0 152208.448 wavec waveOutGetDevCaps(0x1, 0x12e01c, 0x34) => 0 152208.448 wave IN:[Dialogic Wave[dxxxB1C1] v16.0 format=0x1, channels=0x1] OUT:[Dialogic Wave[dxxxB1C1] v16.0 format=0x1, channels=0x1, support=0x4] 152208.448 ocxfn LineOpen(7, 0, 0, , ) 152208.448 tapic lineGetID(0x10399, 0, 0, 0x1, 0x55b0278, wave/in) LINECALLSELECT_LINE hLineInfo 152208.448 tapic lineGetID(0x10399, 0, 0, 0x1, 0x55b0278, wave/in) => 0x0 152208.448 tapic lineGetID => 1 152208.448 tapic lineGetID(0x10399, 0, 0, 0x1, 0x55b0278, wave/out) LINECALLSELECT_LINE hLineInfo 152208.448 tapic lineGetID(0x10399, 0, 0, 0x1, 0x55b0278, wave/out) => 0x0 152208.448 tapic lineGetID => 1 152208.448 ocxfn GetLineName(sLineId=7) 152208.448 tapic lineGetDevCaps(0x800003ff, 7, 0x10004, 0, 0x55936a8) call 152208.458 tapic lineGetDevCaps(0x800003ff, 7, 0x10004, 0, 0x55936a8) => NO_ERROR (0) 152208.458 wavec waveInGetDevCaps(0x1, 0x12dfb4, 0x30) => 0 152208.458 wavec waveOutGetDevCaps(0x1, 0x12df80, 0x34) => 0 152208.458 wave IN:[Dialogic Wave[dxxxB1C1] v16.0 format=0x1, channels=0x1] OUT:[Dialogic Wave[dxxxB1C1] v16.0 format=0x1, channels=0x1, support=0x4] 152208.468 ocxfn GetProviderInfo(sLineId=7) 152208.468 tapic lineGetDevCaps(0x800003ff, 7, 0x10004, 0, 0x55936a8) call 152208.498 tapic lineGetDevCaps(0x800003ff, 7, 0x10004, 0, 0x55936a8) => NO_ERROR (0) 152208.498 fn GetProviderInfo => Dialogic 152208.498 ocxfn SilenceDetectSet(sLineId=7, sTimeLen=0, sVolumeLevel=0) 152208.498 ocxfn DialogicScUnroute dxxxB1C1 152208.498 dlgc scbus set DevType1 = LSI, sDlgcDevName=dxxxB1C1 152208.498 dlgc scbus opened dxxxB1C1 as devh=1 152208.498 dlgc scbus dx_getxmitslot() failed dxxxB1C1(1): Error message = Invalid Switching Handler Bus Mode 152340.360 tapic lineNegotiateAPIVersion(0x800003ff, 7, 0x10003, 0x20001, 0x1f70d0, 0x12ee28) 152340.360 tapic lineGetDevCaps(0x800003ff, 7, 0x10004, 0, 0x559b9f8) call 152340.370 tapic lineGetDevCaps(0x800003ff, 7, 0x10004, 0, 0x559b9f8) => NO_ERROR (0) 152340.370 tapic lineGetIcon(7, 0, 0x1f70d8) 152341.432 linec lineShutdown(0x800003ff) => 0x0 152608.333 ocxfn LogLevels 10,C:\Program Files\VoiceGuide\log\,tw.txt,,(null) 152608.343 ------------------------------------------------------------------------------ 152608.343 TAPIWrap OCX v1.84.0, May 20 2004 14:56:36 [For Dialogic Analog] 152608.343 Started at 1010 152608.343 152608.343 ------------------------------------------------------------------------------ 152610.065 linec lineInitialize(0x3130690, 0x2ce0000, 0x2ce9b40, TapiWrap, 0x3130694) => 0x0 152610.076 tapic lineNegotiateAPIVersion(0x800003ff, 0, 0x10003, 0x20001, 0x197570, 0x12c6e0) 152610.076 tapic lineGetDevCaps(0x800003ff, 0, 0x10004, 0, 0x1a4f80) call 152610.076 tapic lineGetDevCaps(0x800003ff, 0, 0x10004, 0, 0x1a4f80) => NO_ERROR (0) 152610.076 tapic lineGetIcon(0, 0, 0x197578) 152610.076 tapic lineNegotiateAPIVersion(0x800003ff, 1, 0x10003, 0x20001, 0x1a8470, 0x12c6e0) 152610.076 tapic lineGetDevCaps(0x800003ff, 1, 0x10003, 0, 0x1b5668) call 152610.076 tapic lineGetDevCaps(0x800003ff, 1, 0x10003, 0, 0x1b5668) => NO_ERROR (0) 152610.076 tapic lineGetIcon(1, 0, 0x1a8478) 152610.076 tapic lineNegotiateAPIVersion(0x800003ff, 2, 0x10003, 0x20001, 0x1b5678, 0x12c6e0) 152610.076 tapic lineGetDevCaps(0x800003ff, 2, 0x10003, 0, 0x1c2870) call 152610.076 tapic lineGetDevCaps(0x800003ff, 2, 0x10003, 0, 0x1c2870) => NO_ERROR (0) 152610.076 tapic lineGetIcon(2, 0, 0x1b5680) 152610.076 tapic lineNegotiateAPIVersion(0x800003ff, 3, 0x10003, 0x20001, 0x1c2880, 0x12c6e0) 152610.076 tapic lineGetDevCaps(0x800003ff, 3, 0x10004, 0, 0x1cfa78) call 152610.076 tapic lineGetDevCaps(0x800003ff, 3, 0x10004, 0, 0x1cfa78) => NO_ERROR (0) 152610.076 tapic lineGetIcon(3, 0, 0x1c2888) 152610.076 tapic lineNegotiateAPIVersion(0x800003ff, 4, 0x10003, 0x20001, 0x1cfa88, 0x12c6e0) 152610.086 tapic lineGetDevCaps(0x800003ff, 4, 0x10004, 0, 0x1dcc80) call 152610.086 tapic lineGetDevCaps(0x800003ff, 4, 0x10004, 0, 0x1dcc80) => NO_ERROR (0) 152610.086 tapic lineGetIcon(4, 0, 0x1cfa90) 152610.086 tapic lineNegotiateAPIVersion(0x800003ff, 5, 0x10003, 0x20001, 0x1dcc90, 0x12c6e0) 152610.086 tapic lineGetDevCaps(0x800003ff, 5, 0x10004, 0, 0x1e9e88) call 152610.086 tapic lineGetDevCaps(0x800003ff, 5, 0x10004, 0, 0x1e9e88) => NO_ERROR (0) 152610.086 tapic lineGetIcon(5, 0, 0x1dcc98) 152610.086 fn TAPI_ERR:LINEERR_OPERATIONUNAVAIL 152610.086 tapic lineNegotiateAPIVersion(0x800003ff, 6, 0x10003, 0x20001, 0x1e9e98, 0x12c6e0) 152610.086 tapic lineGetDevCaps(0x800003ff, 6, 0x10004, 0, 0x1f7090) call 152610.086 tapic lineGetDevCaps(0x800003ff, 6, 0x10004, 0, 0x1f7090) => NO_ERROR (0) 152610.086 tapic lineGetIcon(6, 0, 0x1e9ea0) 152610.086 tapic lineNegotiateAPIVersion(0x800003ff, 7, 0x10003, 0x20001, 0x1f70a0, 0x12c6e0) 152610.086 tapic lineGetDevCaps(0x800003ff, 7, 0x10004, 0, 0x204298) call 152610.086 tapic lineGetDevCaps(0x800003ff, 7, 0x10004, 0, 0x204298) => NO_ERROR (0) 152610.086 tapic lineGetIcon(7, 0, 0x1f70a8) 152610.086 tapic lineNegotiateAPIVersion(0x800003ff, 8, 0x10003, 0x20001, 0x2042a8, 0x12c6e0) 152610.086 tapic lineGetDevCaps(0x800003ff, 8, 0x10004, 0, 0x2114a0) call 152610.086 tapic lineGetDevCaps(0x800003ff, 8, 0x10004, 0, 0x2114a0) => NO_ERROR (0) 152610.086 tapic lineGetIcon(8, 0, 0x2042b0) 152610.086 tapic lineNegotiateAPIVersion(0x800003ff, 9, 0x10003, 0x20001, 0x2114b0, 0x12c6e0) 152610.096 tapic lineGetDevCaps(0x800003ff, 9, 0x10004, 0, 0x21e6a8) call 152610.096 tapic lineGetDevCaps(0x800003ff, 9, 0x10004, 0, 0x21e6a8) => NO_ERROR (0) 152610.096 tapic lineGetIcon(9, 0, 0x2114b8) 152610.096 tapic lineNegotiateAPIVersion(0x800003ff, 10, 0x10003, 0x20001, 0x21e6b8, 0x12c6e0) 152610.096 tapic lineGetDevCaps(0x800003ff, 10, 0x10004, 0, 0x22b8b0) call 152610.096 tapic lineGetDevCaps(0x800003ff, 10, 0x10004, 0, 0x22b8b0) => NO_ERROR (0) 152610.096 tapic lineGetIcon(10, 0, 0x21e6c0) 152610.166 ocxfn GetLineCount() 152610.166 ocxfn GetLineName(sLineId=10) 152610.166 tapic lineGetDevCaps(0x800003ff, 10, 0x10004, 0, 0x2313e8) call 152610.166 tapic lineGetDevCaps(0x800003ff, 10, 0x10004, 0, 0x2313e8) => NO_ERROR (0) 152610.166 ocxfn GetLineName(sLineId=9) 152610.166 tapic lineGetDevCaps(0x800003ff, 9, 0x10004, 0, 0x232d30) call 152610.166 tapic lineGetDevCaps(0x800003ff, 9, 0x10004, 0, 0x232d30) => NO_ERROR (0) 152610.166 ocxfn GetLineName(sLineId=8) 152610.176 tapic lineGetDevCaps(0x800003ff, 8, 0x10004, 0, 0x232d30) call 152610.176 tapic lineGetDevCaps(0x800003ff, 8, 0x10004, 0, 0x232d30) => NO_ERROR (0) 152610.176 ocxfn GetLineName(sLineId=7) 152610.176 tapic lineGetDevCaps(0x800003ff, 7, 0x10004, 0, 0x232d30) call 152610.176 tapic lineGetDevCaps(0x800003ff, 7, 0x10004, 0, 0x232d30) => NO_ERROR (0) 152610.176 ocxfn GetLineName(sLineId=6) 152610.176 tapic lineGetDevCaps(0x800003ff, 6, 0x10004, 0, 0x232d30) call 152610.176 tapic lineGetDevCaps(0x800003ff, 6, 0x10004, 0, 0x232d30) => NO_ERROR (0) 152610.176 ocxfn GetLineName(sLineId=5) 152610.176 tapic lineGetDevCaps(0x800003ff, 5, 0x10004, 0, 0x232d30) call 152610.176 tapic lineGetDevCaps(0x800003ff, 5, 0x10004, 0, 0x232d30) => NO_ERROR (0) 152610.176 ocxfn GetLineName(sLineId=4) 152610.176 tapic lineGetDevCaps(0x800003ff, 4, 0x10004, 0, 0x232d30) call 152610.176 tapic lineGetDevCaps(0x800003ff, 4, 0x10004, 0, 0x232d30) => NO_ERROR (0) 152610.176 ocxfn GetLineName(sLineId=3) 152610.176 tapic lineGetDevCaps(0x800003ff, 3, 0x10004, 0, 0x232d30) call 152610.176 tapic lineGetDevCaps(0x800003ff, 3, 0x10004, 0, 0x232d30) => NO_ERROR (0) 152610.176 ocxfn GetLineName(sLineId=2) 152610.186 tapic lineGetDevCaps(0x800003ff, 2, 0x10003, 0, 0x232d30) call 152610.186 tapic lineGetDevCaps(0x800003ff, 2, 0x10003, 0, 0x232d30) => NO_ERROR (0) 152610.186 ocxfn GetLineName(sLineId=1) 152610.186 tapic lineGetDevCaps(0x800003ff, 1, 0x10003, 0, 0x232d30) call 152610.186 tapic lineGetDevCaps(0x800003ff, 1, 0x10003, 0, 0x232d30) => NO_ERROR (0) 152610.186 ocxfn GetLineName(sLineId=0) 152610.186 tapic lineGetDevCaps(0x800003ff, 0, 0x10004, 0, 0x232d30) call 152610.186 tapic lineGetDevCaps(0x800003ff, 0, 0x10004, 0, 0x232d30) => NO_ERROR (0) 152610.666 ocxfn LineOpen(sLineId=7) 152610.666 tapic lineNegotiateAPIVersion(0x800003ff, 7, 0x10003, 0x20001, 0x1f70a0, 0x12dfec) 152610.666 tapic lineGetDevCaps(0x800003ff, 7, 0x10004, 0, 0x249bf8) call 152610.666 tapic lineGetDevCaps(0x800003ff, 7, 0x10004, 0, 0x249bf8) => NO_ERROR (0) 152610.676 tapic lineGetIcon(7, 0, 0x1f70a8) 152610.676 tapic lineGetDevCaps(0x800003ff, 7, 0x10004, 0, 0x249bf8) call 152610.676 tapic lineGetDevCaps(0x800003ff, 7, 0x10004, 0, 0x249bf8) => NO_ERROR (0) 152610.676 tapic lineOpen(0x800003ff, 7, 0x1f709c, 0x10004, 0, 0x1f7090, 0x4, LINEMEDIAMODE_INTERACTIVEVOICE | LINEMEDIAMODE_AUTOMATEDVOICE, 0) 152610.777 tapic lineGetID(0x103dd, 0, 0, 0x1, 0x55b0040, wave/in) LINECALLSELECT_LINE hLineInfo 152610.937 tapic lineGetID(0x103dd, 0, 0, 0x1, 0x55b0040, wave/in) => 0x0 152610.937 tapic lineGetID => 1 152610.937 tapic lineGetID(0x103dd, 0, 0, 0x1, 0x55b0040, wave/out) LINECALLSELECT_LINE hLineInfo 152610.937 tapic lineGetID(0x103dd, 0, 0, 0x1, 0x55b0040, wave/out) => 0x0 152610.937 tapic lineGetID => 1 152610.937 ocxfn GetLineName(sLineId=7) 152610.937 tapic lineGetDevCaps(0x800003ff, 7, 0x10004, 0, 0x5593668) call 152610.947 tapic lineGetDevCaps(0x800003ff, 7, 0x10004, 0, 0x5593668) => NO_ERROR (0) 152610.947 wavec waveInGetDevCaps(0x1, 0x12e050, 0x30) => 0 152610.947 wavec waveOutGetDevCaps(0x1, 0x12e01c, 0x34) => 0 152610.947 wave IN:[Dialogic Wave[dxxxB1C1] v16.0 format=0x1, channels=0x1] OUT:[Dialogic Wave[dxxxB1C1] v16.0 format=0x1, channels=0x1, support=0x4] 152610.947 ocxfn LineOpen(7, 0, 0, , ) 152610.947 tapic lineGetID(0x103dd, 0, 0, 0x1, 0x55b0278, wave/in) LINECALLSELECT_LINE hLineInfo 152610.947 tapic lineGetID(0x103dd, 0, 0, 0x1, 0x55b0278, wave/in) => 0x0 152610.947 tapic lineGetID => 1 152610.947 tapic lineGetID(0x103dd, 0, 0, 0x1, 0x55b0278, wave/out) LINECALLSELECT_LINE hLineInfo 152610.947 tapic lineGetID(0x103dd, 0, 0, 0x1, 0x55b0278, wave/out) => 0x0 152610.947 tapic lineGetID => 1 152610.947 ocxfn GetLineName(sLineId=7) 152610.947 tapic lineGetDevCaps(0x800003ff, 7, 0x10004, 0, 0x5593668) call 152610.957 tapic lineGetDevCaps(0x800003ff, 7, 0x10004, 0, 0x5593668) => NO_ERROR (0) 152610.957 wavec waveInGetDevCaps(0x1, 0x12dfb4, 0x30) => 0 152610.957 wavec waveOutGetDevCaps(0x1, 0x12df80, 0x34) => 0 152610.957 wave IN:[Dialogic Wave[dxxxB1C1] v16.0 format=0x1, channels=0x1] OUT:[Dialogic Wave[dxxxB1C1] v16.0 format=0x1, channels=0x1, support=0x4] 152610.967 ocxfn GetProviderInfo(sLineId=7) 152610.967 tapic lineGetDevCaps(0x800003ff, 7, 0x10004, 0, 0x5593668) call 152610.987 tapic lineGetDevCaps(0x800003ff, 7, 0x10004, 0, 0x5593668) => NO_ERROR (0) 152610.987 fn GetProviderInfo => Dialogic 152610.987 ocxfn SilenceDetectSet(sLineId=7, sTimeLen=0, sVolumeLevel=0) 152610.987 ocxfn DialogicScUnroute dxxxB1C1 152610.987 dlgc scbus set DevType1 = LSI, sDlgcDevName=dxxxB1C1 152610.997 dlgc scbus opened dxxxB1C1 as devh=1 152610.997 dlgc scbus dx_getxmitslot() failed dxxxB1C1(1): Error message = Invalid Switching Handler Bus Mode 152857.206 tapic lineNegotiateAPIVersion(0x800003ff, 7, 0x10003, 0x20001, 0x1f70a0, 0x12ee28) 152857.206 tapic lineGetDevCaps(0x800003ff, 7, 0x10004, 0, 0x559a218) call 152857.206 tapic lineGetDevCaps(0x800003ff, 7, 0x10004, 0, 0x559a218) => NO_ERROR (0) 152857.206 tapic lineGetIcon(7, 0, 0x1f70a8) 152858.277 linec lineShutdown(0x800003ff) => 0x0 153036.028 ocxfn LogLevels 10,C:\Program Files\VoiceGuide\log\,tw.txt,,(null) 153036.028 ------------------------------------------------------------------------------ 153036.028 TAPIWrap OCX v1.84.0, May 20 2004 14:56:36 [For Dialogic Analog] 153036.028 Started at 1010 153036.028 153036.028 ------------------------------------------------------------------------------ 153037.390 linec lineInitialize(0x3130690, 0x2ce0000, 0x2ce9b40, TapiWrap, 0x3130694) => 0x0 153037.390 tapic lineNegotiateAPIVersion(0x800003ff, 0, 0x10003, 0x20001, 0x1973a0, 0x12c6e0) 153037.390 tapic lineGetDevCaps(0x800003ff, 0, 0x10004, 0, 0x1a4598) call 153037.410 tapic lineGetDevCaps(0x800003ff, 0, 0x10004, 0, 0x1a4598) => NO_ERROR (0) 153037.410 tapic lineGetIcon(0, 0, 0x1973a8) 153037.430 tapic lineNegotiateAPIVersion(0x800003ff, 1, 0x10003, 0x20001, 0x1a82a0, 0x12c6e0) 153037.430 tapic lineGetDevCaps(0x800003ff, 1, 0x10003, 0, 0x1a4598) call 153037.440 tapic lineGetDevCaps(0x800003ff, 1, 0x10003, 0, 0x1a4598) => NO_ERROR (0) 153037.440 tapic lineGetIcon(1, 0, 0x1a82a8) 153037.440 tapic lineNegotiateAPIVersion(0x800003ff, 2, 0x10003, 0x20001, 0x1b5660, 0x12c6e0) 153037.450 tapic lineGetDevCaps(0x800003ff, 2, 0x10003, 0, 0x1c2858) call 153037.460 tapic lineGetDevCaps(0x800003ff, 2, 0x10003, 0, 0x1c2858) => NO_ERROR (0) 153037.460 tapic lineGetIcon(2, 0, 0x1b5668) 153037.470 tapic lineNegotiateAPIVersion(0x800003ff, 3, 0x10003, 0x20001, 0x1c2868, 0x12c6e0) 153037.470 tapic lineGetDevCaps(0x800003ff, 3, 0x10004, 0, 0x1cfa60) call 153037.470 tapic lineGetDevCaps(0x800003ff, 3, 0x10004, 0, 0x1cfa60) => NO_ERROR (0) 153037.470 tapic lineGetIcon(3, 0, 0x1c2870) 153037.470 tapic lineNegotiateAPIVersion(0x800003ff, 4, 0x10003, 0x20001, 0x1cfa70, 0x12c6e0) 153037.470 tapic lineGetDevCaps(0x800003ff, 4, 0x10004, 0, 0x1dcc68) call 153037.470 tapic lineGetDevCaps(0x800003ff, 4, 0x10004, 0, 0x1dcc68) => NO_ERROR (0) 153037.470 tapic lineGetIcon(4, 0, 0x1cfa78) 153037.470 tapic lineNegotiateAPIVersion(0x800003ff, 5, 0x10003, 0x20001, 0x1dcc78, 0x12c6e0) 153037.470 tapic lineGetDevCaps(0x800003ff, 5, 0x10004, 0, 0x1e9e70) call 153037.470 tapic lineGetDevCaps(0x800003ff, 5, 0x10004, 0, 0x1e9e70) => NO_ERROR (0) 153037.470 tapic lineGetIcon(5, 0, 0x1dcc80) 153037.470 fn TAPI_ERR:LINEERR_OPERATIONUNAVAIL 153037.470 tapic lineNegotiateAPIVersion(0x800003ff, 6, 0x10003, 0x20001, 0x1e9e80, 0x12c6e0) 153037.470 tapic lineGetDevCaps(0x800003ff, 6, 0x10004, 0, 0x1f7078) call 153037.470 tapic lineGetDevCaps(0x800003ff, 6, 0x10004, 0, 0x1f7078) => NO_ERROR (0) 153037.480 tapic lineGetIcon(6, 0, 0x1e9e88) 153037.480 tapic lineNegotiateAPIVersion(0x800003ff, 7, 0x10003, 0x20001, 0x1f7088, 0x12c6e0) 153037.480 tapic lineGetDevCaps(0x800003ff, 7, 0x10004, 0, 0x204280) call 153037.490 tapic lineGetDevCaps(0x800003ff, 7, 0x10004, 0, 0x204280) => NO_ERROR (0) 153037.490 tapic lineGetIcon(7, 0, 0x1f7090) 153037.490 tapic lineNegotiateAPIVersion(0x800003ff, 8, 0x10003, 0x20001, 0x204290, 0x12c6e0) 153037.490 tapic lineGetDevCaps(0x800003ff, 8, 0x10004, 0, 0x211488) call 153037.490 tapic lineGetDevCaps(0x800003ff, 8, 0x10004, 0, 0x211488) => NO_ERROR (0) 153037.490 tapic lineGetIcon(8, 0, 0x204298) 153037.490 tapic lineNegotiateAPIVersion(0x800003ff, 9, 0x10003, 0x20001, 0x211498, 0x12c6e0) 153037.490 tapic lineGetDevCaps(0x800003ff, 9, 0x10004, 0, 0x21e690) call 153037.490 tapic lineGetDevCaps(0x800003ff, 9, 0x10004, 0, 0x21e690) => NO_ERROR (0) 153037.490 tapic lineGetIcon(9, 0, 0x2114a0) 153037.490 tapic lineNegotiateAPIVersion(0x800003ff, 10, 0x10003, 0x20001, 0x21e6a0, 0x12c6e0) 153037.490 tapic lineGetDevCaps(0x800003ff, 10, 0x10004, 0, 0x22b898) call 153037.490 tapic lineGetDevCaps(0x800003ff, 10, 0x10004, 0, 0x22b898) => NO_ERROR (0) 153037.490 tapic lineGetIcon(10, 0, 0x21e6a8) 153037.540 ocxfn GetLineCount() 153037.540 ocxfn GetLineName(sLineId=10) 153037.540 tapic lineGetDevCaps(0x800003ff, 10, 0x10004, 0, 0x231000) call 153037.540 tapic lineGetDevCaps(0x800003ff, 10, 0x10004, 0, 0x231000) => NO_ERROR (0) 153037.550 ocxfn GetLineName(sLineId=9) 153037.550 tapic lineGetDevCaps(0x800003ff, 9, 0x10004, 0, 0x231940) call 153037.560 tapic lineGetDevCaps(0x800003ff, 9, 0x10004, 0, 0x231940) => NO_ERROR (0) 153037.560 ocxfn GetLineName(sLineId=8) 153037.560 tapic lineGetDevCaps(0x800003ff, 8, 0x10004, 0, 0x2319b8) call 153037.560 tapic lineGetDevCaps(0x800003ff, 8, 0x10004, 0, 0x2319b8) => NO_ERROR (0) 153037.560 ocxfn GetLineName(sLineId=7) 153037.560 tapic lineGetDevCaps(0x800003ff, 7, 0x10004, 0, 0x2319b8) call 153037.570 tapic lineGetDevCaps(0x800003ff, 7, 0x10004, 0, 0x2319b8) => NO_ERROR (0) 153037.570 ocxfn GetLineName(sLineId=6) 153037.570 tapic lineGetDevCaps(0x800003ff, 6, 0x10004, 0, 0x2319b8) call 153037.570 tapic lineGetDevCaps(0x800003ff, 6, 0x10004, 0, 0x2319b8) => NO_ERROR (0) 153037.570 ocxfn GetLineName(sLineId=5) 153037.57 Share this post Link to post
SupportTeam Report post Posted 10/10/2004 08:31 PM Traces show the numbers to be called are loaded into the OutDialQue.mdb database with no problems. If it was all working for you beforehand then I'd be checking the dialing times settings (see Dialing Times tab in the Telephone Numbers Loader app) and whether the lines are allowed to dial out (see the View->Line Device Config menu). Share this post Link to post
kemcmanus Report post Posted 10/11/2004 10:40 PM Here's the first record in the database (phone numbers X'd out by me) ID PhoneNumber ActivateTime DayTimeStart DayTimeStop DaysCallAllowed LineSelection Priority AnnounceMessage Script OnAnswerMachine RV AnswerTimeout CallRetriesLeft DelayBetweenRetries OnNotConnected EscalationCalls 1 301XXXXXXX 410111821 900 2100 MoTuWeThFrSaSu ,301XXXXXXX, 1 NONE D:\Backup\IndependentVoiceOver2.wav D:\Backup\IndependentVoiceOver2.wav none 30 1 2 none Still only works for incomming calls, not outgoing. The times look ok 9am to 9pm. I've attached the dial out menu as a gif to this email. Would it be easier just to reinstall? How would I do that? Thanks. Share this post Link to post
SupportTeam Report post Posted 10/12/2004 07:56 AM Have you looked at the "View"->"Line Device Config" menu - are the "Allow Dialout on this Line" boxes ticked? Share this post Link to post
kemcmanus Report post Posted 10/12/2004 01:17 PM Yes, only one line is active and the box is ticked. Share this post Link to post
SupportTeam Report post Posted 10/13/2004 07:17 AM No idea why it's not dialing then... One thing that I've noticed is that although you are using a Dialogic card you have selected to install VoiceGuide in the "voice modem" mode - I'd try reinstalling VG in the "Dialogic analog" mode... Share this post Link to post
kemcmanus Report post Posted 10/13/2004 05:41 PM How do I reinstall and keep the registration, or do I need to call in for a new registration number or is it tied to the CPU? Share this post Link to post
SupportTeam Report post Posted 10/14/2004 05:46 AM Registration Unique ID will not change. (It's tied to either the Dialogic card or to the Network Card). Share this post Link to post
kemcmanus Report post Posted 10/17/2004 08:12 PM I reinstalled. It worked. Then I put in the registration number and rebooted. Now it does the same thing as before. Voice Guide just sits there and displays "hanging up". Share this post Link to post
SupportTeam Report post Posted 10/17/2004 09:01 PM displays "hanging up". So this is after a call is made? Could you please post a copy of VoiceGuide's Debug Printout which captures the problem, this will allow us to see what is going wrong. (When running the script click on VoiceGuide's View menu and select 'Event Trace Log' option - any log information will then appear in this window. You must open the trace window before making the call.) Share this post Link to post
kemcmanus Report post Posted 10/18/2004 01:29 AM I think I found the problem. Office 2000 Pro. Specifically the database drivers (my guess). It seems to work fine now that I erased everything and reinstalled without Office using the drivers your website suggests instead. Luckly I'd seen something like this before, data goes into an Access database fine but won't come back out. Share this post Link to post
