Guest Pat Report post Posted 04/28/2003 10:50 PM Question 1 ) Can I somehow " input " data into an Excel document using the RUN PROGRAM module ?? If so, can it be done using version 2.9 ?? Question 2 ) Is there a way to JOIN 2 or more recordings together automatically so that there may be 2 or more different persons who made the recordings ? Is it called " CONCATENATION " ?? Thanks Share this post Link to post
SupportTeam Report post Posted 04/28/2003 10:56 PM From VoiceGuide help file (Run VB Script module section): Quote Example 6: The VB Script below retrieves information from an Excel spreadsheet. Dim xlApp 'Excel.Application Dim xlBook 'Excel.Workbook dim xlSht Dim filename, value1, value2, value3, value4 filename = "c:\Warehouse.xls" Set xlApp = CreateObject("Excel.Application") set xlBook = xlApp.WorkBooks.Open(filename) set xlSht = xlApp.activesheet value1 = xlSht.Cells(2, 1) value2 = xlSht.Cells(2, 2) msgbox "Values are: " & value1 & ", " & value2 xlBook.Close False xlApp.Quit Set xlBook = Nothing Set xlApp = Nothing Example 7: The VB Script below saves information to an Excel spreadsheet. Dim xlApp 'Excel.Application Dim xlBook 'Excel.Workbook dim xlSht Dim filename, value1, value2, value3, value4 on error resume next filename = "c:\warehouse.xls" Set xlApp = CreateObject("Excel.Application") set xlBook = xlApp.WorkBooks.Open(filename) set xlSht = xlApp.activesheet xlApp.DisplayAlerts = False 'write data into the spreadsheet xlSht.Cells(2, 2) = "New Data" xlBook.Save xlBook.Close SaveChanges=True xlApp.Close xlApp.Quit set xlSht = Nothing Set xlBook = Nothing Set xlApp = Nothing you cannot do this from v2.9 - that version does not have a "Run VB Script" module. To join two sound files: Quote Multiple sound files can be selected to be played by separating the successive files by commas. eg: prompts\1.wav, prompts\2.wav would result in two files from the prompts subdirectory being played (1.wav and 2.wav) one after another. This again only works in v4 Share this post Link to post
