Guest Andrew Smith Report post Posted 10/15/2004 06:34 PM I moved a modem from one computer to another and installed the trial voiceguide software on the new computer. The software detects when a new call is coming in and shows caller id info but won't pick it up. Additionally, it won't dial out. Any suggestions? Share this post Link to post
SupportTeam Report post Posted 10/16/2004 03:29 AM Could you please post a copy of VoiceGuide's Debug Printout which captures the problem, this will allow us to see what is going wrong. (When running the script click on VoiceGuide's View menu and select 'Event Trace Log' option - any log information will then appear in this window. You must open the trace window before making the call.) Share this post Link to post
Guest Guest Report post Posted 10/18/2004 02:25 PM This was in the vgm file: 072436.15 0 tapi Reply (LineEvReply) err 65928 LINEERR_OPERATIONFAILED [80000048] 072436.15 0 callstate DISCONNECTED 65945 16384 0 072436.16 0 ScriptEventCode 9250 iLineState=900 072436.18 0 LsAwaitingCalls EV_REMOTEPARTY_DISCONNECT 072436.20 0 rv add [Hangup Time]{10/18/2004 7:24:36 AM} 072436.22 0 Hanging up call... 072436.24 0 RecSoundStop ok 072436.24 0 PlaySoundStop err=0 072436.24 0 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP 072436.25 0 Waiting for a call... 072436.25 0 fnHangupCall end 072436.26 0 callstate IDLE 65945 0 0 072436.26 0 WorkingMode@Idle= 072436.26 0 timer clear 072436.26 0 LineState(iLineId).iVgsIdx = 0 072436.26 0 timer set 1 EV_TIMEOUT_TIMETOREINITLINE 072436.26 0 tapi Reply (LineEvReply) ok 65911 0 072437.23 0 timer fired EV_TIMEOUT_TIMETOREINITLINE 072437.23 0 ScriptEventCode 9008 iLineState=900 072437.23 0 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE 072437.23 0 ReinitTelephony due to IDLE 072437.24 0 tapic lineDeallocateCall(MainCall:65945) 0 072438.10 0 lineOpen(0)=> 072438.10 0 Waiting for a call... 072438.11 0 LineHandle=65894 072438.11 0 timer set 3 EV_TIMEOUT_ATERIDLE_ALLOWOUT 072438.11 0 dial start any summary:|0:rdy=0| 072439.11 0 dial start any summary:|0:rdy=0| 072440.11 0 dial start any summary:|0:rdy=0| 072441.11 0 dial start any summary:|0:rdy=0| 072441.14 0 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT 072441.14 0 ScriptEventCode 9013 iLineState=900 072442.96 0 callstate OFFERING 65843 0 4 072442.96 0 ring 1 072442.96 0 Answer the call at 10/18/2004 7:24:42 AM 072442.96 0 lineAnswer(65843) => 65826 072442.96 0 callstate ACCEPTED 65843 0 0 and this was the tw file: 072410.206 ocxfn LogLevels 10,C:\Program Files\VoiceGuide\log\,tw.txt,,(null) 072436.154 tapie LINE_REPLY(0, 0x0, 0x10188, 0x80000048) 072436.154 tapie LINE_CALLSTATE(0, 0x10199, 0x4000, 0x4000, 0x0) 072436.224 ocxfn RecStop(sLineId:0) 072436.244 wavec waveInReset(0x0) => 5 072436.244 linec lineMonitorTones(0x10199, 0x0, 1) => 0x8000003c (disabling monitoring for silence/tones) 072436.244 ocxfn PlayStop(sLineId=0) 072436.244 fn PlaySoundStop start 072436.244 fn PlaySoundStop line not playing a sound file. 0x0 072436.244 ocxfn LineDrop(sLineId=0, sOpt=0) 072436.244 tapic lineDrop(0x10199, , 0) call in ocxfn_LineDrop 072436.244 tapic lineDrop(0x10199, , 0) => async:65911 (65911) 072436.264 tapie LINE_CALLSTATE(0, 0x10199, 0x1, 0x0, 0x0) 072436.264 tapie LINE_REPLY(0, 0x0, 0x10177, 0x0) 072437.245 ocxfn LineClose(sLineId:0) 072437.376 tapic lineNegotiateAPIVersion(0x800003ff, 0, 0x10003, 0x20001, 0x1705d0, 0x12f158) 072437.376 tapic lineGetDevCaps(0x800003ff, 0, 0x10004, 0, 0x215c98) call 072437.376 tapic lineGetDevCaps(0x800003ff, 0, 0x10004, 0, 0x215c98) => NO_ERROR (0) 072437.376 tapic lineGetIcon(0, 0, 0x1705d8) 072437.376 ocxfn LineOpen(0, 0, 0, , ) 072437.376 tapic lineNegotiateAPIVersion(0x800003ff, 0, 0x10003, 0x20001, 0x1705d0, 0x12e498) 072437.376 tapic lineGetDevCaps(0x800003ff, 0, 0x10004, 0, 0x215c98) call 072437.376 tapic lineGetDevCaps(0x800003ff, 0, 0x10004, 0, 0x215c98) => NO_ERROR (0) 072437.376 tapic lineGetIcon(0, 0, 0x1705d8) 072437.376 tapic lineGetDevCaps(0x800003ff, 0, 0x10004, 0, 0x215c98) call 072437.376 tapic lineGetDevCaps(0x800003ff, 0, 0x10004, 0, 0x215c98) => NO_ERROR (0) 072437.376 tapic lineOpen(0x800003ff, 0, 0x1705cc, 0x10004, 0, 0x1705c0, 0x4, LINEMEDIAMODE_INTERACTIVEVOICE | LINEMEDIAMODE_AUTOMATEDVOICE, 0) 072438.097 tapic lineGetID(0x10166, 0, 0, 0x1, 0x221598, wave/in) LINECALLSELECT_LINE hLineInfo 072438.097 tapic lineGetID(0x10166, 0, 0, 0x1, 0x221598, wave/in) => 0x0 072438.097 tapic lineGetID => 0 072438.097 tapic lineGetID(0x10166, 0, 0, 0x1, 0x221598, wave/out) LINECALLSELECT_LINE hLineInfo 072438.097 tapic lineGetID(0x10166, 0, 0, 0x1, 0x221598, wave/out) => 0x0 072438.097 tapic lineGetID => 0 072438.097 ocxfn GetLineName(sLineId=0) 072438.097 tapic lineGetDevCaps(0x800003ff, 0, 0x10004, 0, 0x215c98) call 072438.097 tapic lineGetDevCaps(0x800003ff, 0, 0x10004, 0, 0x215c98) => NO_ERROR (0) 072438.097 wavec waveInGetDevCaps(0x0, 0x12e500, 0x30) => 0 072438.097 wavec waveOutGetDevCaps(0x0, 0x12e4cc, 0x34) => 0 072438.097 wave IN:[Modem #0 Line Record v80.0 format=0x0, channels=0x1] OUT:[Modem #0 Line Playback v80.0 format=0x0, channels=0x1, support=0x0] 072438.107 ocxfn SilenceDetectSet(sLineId=0, sTimeLen=30, sVolumeLevel=10) 072442.954 tapie LINE_CALLSTATE(0, 0x10133, 0x2, 0x0, 0x4) 072442.954 tapic lineMonitorDigits(0x10133, 0x2) => 0x0 072442.954 tapic lineMonitorMedia(0x10133, 0xfc) => -2147483601 072442.964 fn TAPI_ERR:LINEERR_INVALMEDIAMODE 072442.964 tapic lineGetCallInfo(0x10133, 0x2162c8) 072442.964 eng No CallerId info available at this time 072442.964 tapie LINE_LINEDEVSTATE(0, 0x10166, 0x2, 0x1, 0x1) 072442.964 tapie LINE_CALLSTATE(0, 0x10133, 0x4, 0x0, 0x0) 072546.565 tapie LINE_REPLY(0, 0x0, 0x10122, 0x80000048) 072546.585 tapie LINE_CALLSTATE(0, 0x10133, 0x4000, 0x4000, 0x0) 072546.585 ocxfn RecStop(sLineId:0) 072546.585 wavec waveInReset(0x0) => 5 072546.585 linec lineMonitorTones(0x10133, 0x0, 1) => 0x8000003c (disabling monitoring for silence/tones) 072546.595 ocxfn PlayStop(sLineId=0) 072546.595 fn PlaySoundStop start 072546.595 fn PlaySoundStop line not playing a sound file. 0x0 072546.595 ocxfn LineDrop(sLineId=0, sOpt=0) 072546.595 tapic lineDrop(0x10133, , 0) call in ocxfn_LineDrop 072546.595 tapic lineDrop(0x10133, , 0) => async:65809 (65809) 072546.595 tapie LINE_CALLSTATE(0, 0x10133, 0x1, 0x0, 0x0) 072546.595 tapie LINE_REPLY(0, 0x0, 0x10111, 0x0) 072547.506 ocxfn LineClose(sLineId:0) 072547.506 tapic lineNegotiateAPIVersion(0x800003ff, 0, 0x10003, 0x20001, 0x1705d0, 0x12f158) 072547.506 tapic lineGetDevCaps(0x800003ff, 0, 0x10004, 0, 0x217418) call 072547.506 tapic lineGetDevCaps(0x800003ff, 0, 0x10004, 0, 0x217418) => NO_ERROR (0) 072547.506 tapic lineGetIcon(0, 0, 0x1705d8) 072547.506 ocxfn LineOpen(0, 0, 0, , ) 072547.506 tapic lineNegotiateAPIVersion(0x800003ff, 0, 0x10003, 0x20001, 0x1705d0, 0x12e498) 072547.506 tapic lineGetDevCaps(0x800003ff, 0, 0x10004, 0, 0x217418) call 072547.506 tapic lineGetDevCaps(0x800003ff, 0, 0x10004, 0, 0x217418) => NO_ERROR (0) 072547.506 tapic lineGetIcon(0, 0, 0x1705d8) 072547.506 tapic lineGetDevCaps(0x800003ff, 0, 0x10004, 0, 0x217418) call 072547.516 tapic lineGetDevCaps(0x800003ff, 0, 0x10004, 0, 0x217418) => NO_ERROR (0) 072547.516 tapic lineOpen(0x800003ff, 0, 0x1705cc, 0x10004, 0, 0x1705c0, 0x4, LINEMEDIAMODE_INTERACTIVEVOICE | LINEMEDIAMODE_AUTOMATEDVOICE, 0) 072548.237 tapic lineGetID(0x10100, 0, 0, 0x1, 0x221158, wave/in) LINECALLSELECT_LINE hLineInfo 072548.237 tapic lineGetID(0x10100, 0, 0, 0x1, 0x221158, wave/in) => 0x0 072548.237 tapic lineGetID => 0 072548.237 tapic lineGetID(0x10100, 0, 0, 0x1, 0x221158, wave/out) LINECALLSELECT_LINE hLineInfo 072548.237 tapic lineGetID(0x10100, 0, 0, 0x1, 0x221158, wave/out) => 0x0 072548.237 tapic lineGetID => 0 072548.237 ocxfn GetLineName(sLineId=0) 072548.237 tapic lineGetDevCaps(0x800003ff, 0, 0x10004, 0, 0x217418) call 072548.237 tapic lineGetDevCaps(0x800003ff, 0, 0x10004, 0, 0x217418) => NO_ERROR (0) 072548.237 wavec waveInGetDevCaps(0x0, 0x12e500, 0x30) => 0 072548.237 wavec waveOutGetDevCaps(0x0, 0x12e4cc, 0x34) => 0 072548.237 wave IN:[Modem #0 Line Record v80.0 format=0x0, channels=0x1] OUT:[Modem #0 Line Playback v80.0 format=0x0, channels=0x1, support=0x0] 072548.237 ocxfn SilenceDetectSet(sLineId=0, sTimeLen=30, sVolumeLevel=10) Thanks! Share this post Link to post
SupportTeam Report post Posted 10/19/2004 01:31 AM If this is where the modem stops: 072442.96 0 lineAnswer(65843) => 65826 072442.96 0 callstate ACCEPTED 65843 0 0 then there is something wrong with it's drivers or the drivers were not correctly installed. If this modem worked for you before then I'd recommend re-installing the modem, making sure that you are using same drivers. Share this post Link to post
