Dialogic D/600sc-2e1 Install Problems Over Win2000
I just got a D/600SC-2E1 already installed on an IBM Netfinity Server running Windows 2000 SP-3, and somehow, only recognizes 1 port (30 channels). I am just getting started working with E1's so I am kind of lost on this. Does anybody have any tips for me regarding this issue?
Thanks.
JM
Thank you for your response. As you'll be able to see on the screen shots included, altough I phisically have a D/600SC, the system initially recognizes it as a D/300SC. When I run tests with the UDD, in runs it on both a mother and "slave" cards (each with 30 channels). In says something about "interrupt" (and so far I think it refers to the IRQ's in the server. I've already gone trough the system administration and there are no IRQ conflicts with local devices; according to the card's configuration, IRQ 7 is been used (without any other device using this IRQ).
Thank you so much for your help.
Juan Aguirre
You should be speaking with Dialogic/Intel as to why the drivers fail to detect the board correctly on this system...
I already tryed that, but they no longer offer support for this model from Dialogic, only the new boards produced by them.
Any other ideas (configuration on the board, switches or something?)
Thank you,
JM
Can you try a different computer?
You may also want to start playing around with computer’s BIOS - you may be able to change how interrupts are assigned and controlled at that level...
To give us a better idea of how your system is currently configured please run this command from a Command prompt:
regedit /A c:\reg.txt HKEY_LOCAL_MACHINE\SOFTWARE\Dialogic
and then post the file reg.txt which will be created in "C:\"
Have you tried using the other interupts which can be selected in the DCM?
Hi...sorry it took me so long to post a reply. So far, I´ve tried looking at how IRQ and resources are assigned on the BIOS, but didn't get lucky. I've even tried reformating the server, doing a clean install, and installed the latest version from Dialogic's system release (v.5.1.1) including it's service pack...no luck. It "autodetects" a D/300sc-1e1. The following is the output from the command you asked me to run...could you please give it a look. Thanks.....
REGEDIT4
[HKEY_LOCAL_MACHINE\SOFTWARE\Dialogic]
"ActiveSystemReleaseName"="native"
"Release"="SR5.1.1"
"build"="30"
[HKEY_LOCAL_MACHINE\SOFTWARE\Dialogic\Application Notification]
"ANM_MAX_LOGFILE_SIZE"=dword:000f4240
"ANM_MAX_TRACEFILE_SIZE"=dword:000f4240
"ANM_ENABLE_TRACING"=dword:00000001
"ANM_THREAD_MAX_POOLSIZE"=dword:00000003
"ANM_ENABLE_LOGGING"=dword:00000000
"ANM_ENABLE_EVENT_GENERATION"=dword:00000000
[HKEY_LOCAL_MACHINE\SOFTWARE\Dialogic\Cheetah]
"EmptyMMBsPerBoard"=dword:0000012c
"EmptyMsgTimeout"=dword:0000ffff
"WorkerThreadPriority"=dword:0000000f
"ApcThreadPriority"=dword:00000002
[HKEY_LOCAL_MACHINE\SOFTWARE\Dialogic\Cheetah\Logger]
"Channels"="-DEBG-INFO-WARN-APPL+EXCE+ERR1+ERR2"
"LineLength"=dword:00000096
"MaxLines"=dword:000186a0
"UseDbgView"=dword:00000000
[HKEY_LOCAL_MACHINE\SOFTWARE\Dialogic\Configuration]
"DLLOGPATH"="D:\\WINNT\\System32"
"DIALOGICDIR"="D:\\PROGRA~1\\Dialogic"
"DLCFGPATH"="D:\\PROGRA~1\\Dialogic\\cfg"
"DLFWLPATH"="D:\\PROGRA~1\\Dialogic\\data"
"DNASDKDIR"="D:\\PROGRA~1\\Dialogic\\bin"
"DLINFPATH"="D:\\PROGRA~1\\Dialogic\\inf"
"MRFDir"="D:\\PROGRA~1\\Dialogic\\mrf"
"Board Information Source"="Installed Boards"
"BLTInterrupt"=dword:00000007
[HKEY_LOCAL_MACHINE\SOFTWARE\Dialogic\Configuration\Debug]
[HKEY_LOCAL_MACHINE\SOFTWARE\Dialogic\Configuration\Debug\NCMdata]
[HKEY_LOCAL_MACHINE\SOFTWARE\Dialogic\Configuration\NDI Information]
[HKEY_LOCAL_MACHINE\SOFTWARE\Dialogic\Configuration\NDI Information\BRI]
[HKEY_LOCAL_MACHINE\SOFTWARE\Dialogic\Configuration\NDI Information\BRI\DlgcSram]
"Formatter Name"="BRIntf.dll"
"Formatter Status"="Enabled"
[HKEY_LOCAL_MACHINE\SOFTWARE\Dialogic\Configuration\NDI Information\D42]
[HKEY_LOCAL_MACHINE\SOFTWARE\Dialogic\Configuration\NDI Information\D42\DlgcSram]
"Formatter Name"="d42ntf.dll"
[HKEY_LOCAL_MACHINE\SOFTWARE\Dialogic\Configuration\NDI Information\DTI]
[HKEY_LOCAL_MACHINE\SOFTWARE\Dialogic\Configuration\NDI Information\DTI\DlgcSram]
"Formatter Name"="dtintf.dll"
"TechFormatter1"="MSI"
"TechFormatter3"="BRI"
"VendorName1"="DlgcSram"
"VendorName3"="DlgcSram"
"TechFormatter2"="ISDN"
"VendorName2"="DlgcSram"
[HKEY_LOCAL_MACHINE\SOFTWARE\Dialogic\Configuration\NDI Information\FAX]
[HKEY_LOCAL_MACHINE\SOFTWARE\Dialogic\Configuration\NDI Information\FAX\DlgcSram]
"Formatter Name"="vfxntf.dll"
[HKEY_LOCAL_MACHINE\SOFTWARE\Dialogic\Configuration\NDI Information\ISDN]
[HKEY_LOCAL_MACHINE\SOFTWARE\Dialogic\Configuration\NDI Information\ISDN\DlgcSram]
"Formatter Name"="isdnspan.dll"
[HKEY_LOCAL_MACHINE\SOFTWARE\Dialogic\Configuration\NDI Information\MSI]
[HKEY_LOCAL_MACHINE\SOFTWARE\Dialogic\Configuration\NDI Information\MSI\DlgcSram]
"Formatter Name"="MSIntf.dll"
[HKEY_LOCAL_MACHINE\SOFTWARE\Dialogic\Configuration\NDI Information\Voice]
[HKEY_LOCAL_MACHINE\SOFTWARE\Dialogic\Configuration\NDI Information\Voice\DlgcSram]
"Formatter Name"="VoxSpan.dll"
"TechFormatter2"="FAX"
"TechFormatter1"="D42"
[HKEY_LOCAL_MACHINE\SOFTWARE\Dialogic\Configuration\Protocol Drivers]
"Number of Protocol Drivers"=dword:00000002
"ProtocolDriver1"="DlgcSram"
"ProtocolDriver2"="DLGCDK"
"Standard Wait Hint"=dword:00000bb8
"Default Wait For Process"=dword:000493e0
[HKEY_LOCAL_MACHINE\SOFTWARE\Dialogic\Configuration\Protocol Drivers\DLGCDK]
"StartStatus"="enabled"
[HKEY_LOCAL_MACHINE\SOFTWARE\Dialogic\Configuration\Protocol Drivers\DLGCDK\Start]
"ImagePath01"="StartS7.exe -LStartS7.log"
[HKEY_LOCAL_MACHINE\SOFTWARE\Dialogic\Configuration\Protocol Drivers\DLGCDK\Stop]
"ImagePath01"="StopS7.exe -LStopS7.log"
[HKEY_LOCAL_MACHINE\SOFTWARE\Dialogic\Configuration\Protocol Drivers\DlgcSram]
[HKEY_LOCAL_MACHINE\SOFTWARE\Dialogic\Configuration\Protocol Drivers\DlgcSram\Devices]
[HKEY_LOCAL_MACHINE\SOFTWARE\Dialogic\Configuration\Protocol Drivers\DlgcSram\DownLoader]
[HKEY_LOCAL_MACHINE\SOFTWARE\Dialogic\Configuration\Protocol Drivers\DlgcSram\Properties]
"PCI_IDS"=hex:
"NUM_PCI_CARDS_TYPE"=dword:00000000
[HKEY_LOCAL_MACHINE\SOFTWARE\Dialogic\Configuration\Protocol Drivers\DlgcSram\Start]
"ImagePath01"="CTBBAPI.exe -Lctbbapi.log -apiCTBB_AddToTDMBus -clientDLGCSRAM"
"ImagePath02"="GenLoad.exe -LGenLoad.log"
"ImagePath03"="RegVox.exe"
"ImagePath04"="nfascfg.exe"
"ImagePath05"="StartDrv.exe -LStartDrv.log"
"ImagePath06"="RegVox.exe -LRegVox.log -c"
"ImagePath07"="nfascfg.exe -Lnfascfg.log -c"
"ImagePath08"="StartDti.exe"
"ImagePath09"="genstart.exe"
"ImagePath10"="SctsAssi.exe -LSctsassi.log"
[HKEY_LOCAL_MACHINE\SOFTWARE\Dialogic\Configuration\Protocol Drivers\DlgcSram\Stop]
"ImagePath01"="StopDrv.exe -Lstopdrv.log"
"ImagePath02"="RegVox.exe -e"
"ImagePath03"="GenStop.exe"
"ImagePath04"="Sctsunas.exe"
"ImagePath05"="CTBBAPI.exe -Lctbbapi.log -apiCTBB_RemoveFromTDMBus -clientDLGCSRAM"
"ImagePath06"="GenLoad.exe -gd"
[HKEY_LOCAL_MACHINE\SOFTWARE\Dialogic\CT Bus Broker]
"Transaction Completion Time Out (ms)"=dword:00000000
"Service Report Status Period (ms)"=dword:00002710
[HKEY_LOCAL_MACHINE\SOFTWARE\Dialogic\CT Bus Broker\0]
[HKEY_LOCAL_MACHINE\SOFTWARE\Dialogic\CT Bus Broker\Technologies]
[HKEY_LOCAL_MACHINE\SOFTWARE\Dialogic\CT Bus Broker\Technologies\DLGCSRAM]
"Version"=dword:00010032
"DCM Family"="DIALOG/HD-PCI"
"BSP DLL"="r4bsp.dll"
[HKEY_LOCAL_MACHINE\SOFTWARE\Dialogic\DCM]
"NoThreads"="5"
[HKEY_LOCAL_MACHINE\SOFTWARE\Dialogic\Dialogic System Software]
[HKEY_LOCAL_MACHINE\SOFTWARE\Dialogic\Dialogic System Software\DNA]
"RegisteredOwner"="TELEPROMOS"
"RegisteredOrganization"="TELEPROMOS"
[HKEY_LOCAL_MACHINE\SOFTWARE\Dialogic\Installation]
[HKEY_LOCAL_MACHINE\SOFTWARE\Dialogic\Installation\System]
"version"="DNA5"
"ProgramGroup"="Intel Dialogic System Software"
"Service Pack"="1"
[HKEY_LOCAL_MACHINE\SOFTWARE\Dialogic\Installation\System\COMPONENTS]
[HKEY_LOCAL_MACHINE\SOFTWARE\Dialogic\Installation\System\COMPONENTS\perfmon]
"version"="DNA3"
[HKEY_LOCAL_MACHINE\SOFTWARE\Dialogic\Installation\System\COMPONENTS\progdrv]
"version"="DNA3"
[HKEY_LOCAL_MACHINE\SOFTWARE\Dialogic\Installed Boards]
"BLTInterrupt"=dword:0000000e
"InstalledBoards"=dword:00000002
"BusType"=""
"BLTAddress"=dword:000c0000
"BLTInterruptUsage"=dword:00000001
"BLTAddressUsage"=dword:00000001
"IRQResource"=hex:02,01,00,0e,00,01,00
"MEMResource"=hex:04,01,00,00,00,0c,00,00,80,00,00,01,00
"ISABusWidth"="16-bit"
"PCMEncoding"="Automatic"
"ISDNProtocol"="None"
"ParameterFile"=""
"TSFFileSupport"="Yes"
"DisconnectTone"="No"
"SelectiveStartMode"="Disable"
"Country"=""
"Features"=""
"TSFFileName"=""
"IgnoreMissingBoards"="Yes"
"ParameterFile2"=""
"FrontEnd"=""
[HKEY_LOCAL_MACHINE\SOFTWARE\Dialogic\Installed Boards\Dialog/HD]
"InstalledBoards"=dword:00000001
"IRQResource"=hex:02,00,00
"MEMResource"=hex:04,00,00
"TechnologyName"="DlgcSram"
"IPAddress"=""
"SubnetMask"=""
"TargetName"=""
"HostIPAddress"=""
"HostName"=""
"UserName"=""
"GatewayIPAddress"=""
[HKEY_LOCAL_MACHINE\SOFTWARE\Dialogic\Installed Boards\Dialog/HD\D/300SC-E1 at ID 10]
"DllName"=""
"GenericName"="D/300SC-E1"
"BLTAddressLength"=dword:00008000
"BLTId"="0x10"
"BoardEnabled"="Yes"
"BoardPresent"="Yes"
"FirmwareFile"=""
"EC_Resource"="OFF"
"CanBeDeleted"="No"
"SerialNumber"="FQ006584"
"Single Start/Stop Operation capable"="False"
"Fault Detector DLL"=""
"Administrative Status"="Stopped"
"Operational Status"="Initial"
"Physical State"="In_System_Locked"
"BoardCondition"="Good"
"TDM Bus Type"="c"
"SCbus Clock Rate"="4"
"Media Type"="3"
"Netref 1 Clock Rate Provide"="0"
"Netref 1 Clock Rate Derive"="0"
"Netref 2 Clock Rate Provide"="0"
"Netref 2 Clock Rate Derive"="0"
"Number of Network Interfaces"="1"
"Can Silence Compatibility Clocks"="False"
"Config Delta capable"="False"
"Telephony Bus capable"="True"
"Local Reference Capable"="Yes"
"Attached to TDM Buses"="0"
"TDM Bus Type (Resolved)"="SCbus"
"SCbus Clock Rate (Resolved)"="4MHz"
"Media Type (Resolved)"="MuLaw"
"Group One Clock Rate (Resolved)"="NotApplicable"
"Group Two Clock Rate (Resolved)"="NotApplicable"
"Group Three Clock Rate (Resolved)"="NotApplicable"
"Group Four Clock Rate (Resolved)"="NotApplicable"
"Using Compatibility Clocks (Resolved)"="NotApplicable"
"Master Status (Resolved)"="PrimaryMaster"
"Derive Clock From (Resolved)"="FrontEnd_1"
"Primary Lines (Resolved)"="NotApplicable"
"Provide NETREF One (Resolved)"="No"
"Provide NETREF One From (Resolved)"="NotApplicable"
"NETREF One Clock Rate (Resolved)"="NotApplicable"
"Provide NETREF Two (Resolved)"="NotApplicable"
"Provide NETREF Two From (Resolved)"="NotApplicable"
"NETREF Two Clock Rate (Resolved)"="NotApplicable"
[HKEY_LOCAL_MACHINE\SOFTWARE\Dialogic\Installed Boards\TDM Bus]
"TechnologyName"=""
[HKEY_LOCAL_MACHINE\SOFTWARE\Dialogic\Installed Boards\TDM Bus\Bus-0]
"DllName"=""
"GenericName"="Bus"
"TDM Bus Type (User Defined)"="Default"
"SCbus Clock Rate (User Defined)"="Default"
"Media Type (User Defined)"="Default"
"Group One Clock Rate (User Defined)"="Default"
"Group Two Clock Rate (User Defined)"="Default"
"Group Three Clock Rate (User Defined)"="Default"
"Group Four Clock Rate (User Defined)"="Default"
"Using Compatibility Clocks (User Defined)"="Default"
"Primary Lines (User Defined)"="Default"
"Using Primary Master (User Defined)"="Default"
"Using Primary Master (Resolved)"="Yes"
"Using Secondary Master (User Defined)"="Default"
"Using Secondary Master (Resolved)"="NotApplicable"
"Using NETREF One (User Defined)"="Default"
"Using NETREF One (Resolved)"="NotApplicable"
"Using NETREF Two (User Defined)"="Default"
"Using NETREF Two (Resolved)"="NotApplicable"
"Primary Master FRU (User Defined)"="Default"
"Primary Master FRU (Resolved)"="D/300SC-E1 at ID 10"
"Derive Primary Clock From (User Defined)"="Default"
"Derive Primary Clock From (Resolved)"="FrontEnd_1"
"Secondary Master FRU (User Defined)"="Default"
"Secondary Master FRU (Resolved)"="NotApplicable"
"Derive Secondary Clock From (User Defined)"="Default"
"Derive Secondary Clock From (Resolved)"="NotApplicable"
"NETREF One FRU (User Defined)"="Default"
"NETREF One FRU (Resolved)"="NotApplicable"
"Derive NETREF One From (User Defined)"="Default"
"Derive NETREF One From (Resolved)"="NotApplicable"
"NETREF One Clock Rate (User Defined)"="Default"
"NETREF Two FRU (User Defined)"="Default"
"NETREF Two FRU (Resolved)"="NotApplicable"
"Derive NETREF Two From (User Defined)"="Default"
"Derive NETREF Two From (Resolved)"="NotApplicable"
"NETREF Two Clock Rate (User Defined)"="Default"
"CanBeDeleted"="No"
"Administrative Status"="Initial"
"IPAddress"=""
"SubnetMask"=""
"TargetName"=""
"HostIPAddress"=""
"HostName"=""
"UserName"=""
[HKEY_LOCAL_MACHINE\SOFTWARE\Dialogic\SERVICE PACKS]
[HKEY_LOCAL_MACHINE\SOFTWARE\Dialogic\SERVICE PACKS\SERVICE PACK]
[HKEY_LOCAL_MACHINE\SOFTWARE\Dialogic\SERVICE PACKS\SERVICE PACK\System Release 5.1.1 Service Pack 1]
"RESTORE_DIR"="D:\\PROGRA~1\\Dialogic\\Save\\System Release 5.1.1 Service Pack 1"
"Installed_Sequence"="1"
[HKEY_LOCAL_MACHINE\SOFTWARE\Dialogic\SERVICE PACKS\System Release 5.1.1 Service Pack 1]
"Date"="12-16-2004"
[HKEY_LOCAL_MACHINE\SOFTWARE\Dialogic\SystemRelease 4.x]
[HKEY_LOCAL_MACHINE\SOFTWARE\Dialogic\SystemRelease 4.x\ConfigInfo]
"DIALOGICDIR"="D:\\PROGRA~1"
"DIALOGICDRV"="D:"
"TSTDIR"="D:\\WINNT\\System32"
"DLGCDESTDIR"="D:"
"R4 BOARD COUNTS"=hex:00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\
00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00
"Voice Boards"=dword:00000000
"DTI Boards"=dword:00000000
"MSI Boards"=dword:00000000
"Recognition Boards"=dword:00000000
"SCX Boards"=dword:00000000
"DCB Boards"=dword:00000000
"DCP Boards"=dword:00000000
"IPT Boards"=dword:00000000
"IPM Boards"=dword:00000000
"AI Boards"=dword:00000000
[HKEY_LOCAL_MACHINE\SOFTWARE\Dialogic\SystemRelease 4.x\ConfigInfo\TAPI]
[HKEY_LOCAL_MACHINE\SOFTWARE\Dialogic\SystemRelease 4.x\ConfigInfo\TAPI\Global data]
"Storage"=hex:c4,03,00,00,00,00,00,00,54,00,00,00,05,00,00,00,00,00,00,00,03,\
00,00,00,05,00,00,00,50,00,00,00,32,00,00,00,02,00,00,00,00,00,00,00,bc,02,\
00,00,01,00,00,00,0a,00,00,00,03,00,00,00,05,00,00,00,50,00,00,00,32,00,00,\
00,02,00,00,00,00,00,00,00,64,00,00,00,01,00,00,00,0a,00,00,00,54,00,00,00,\
07,00,00,00,00,00,00,00,6c,02,00,00,c8,00,00,00,e0,01,00,00,c8,00,00,00,1e,\
00,00,00,0a,00,00,00,14,00,00,00,0a,00,00,00,03,00,00,00,6c,02,00,00,c8,00,\
00,00,e0,01,00,00,c8,00,00,00,1e,00,00,00,0a,00,00,00,14,00,00,00,0a,00,00,\
00,05,00,00,00,54,00,00,00,08,00,00,00,00,00,00,00,26,02,00,00,c8,00,00,00,\
00,00,00,00,00,00,00,00,1e,00,00,00,0a,00,00,00,14,00,00,00,0a,00,00,00,03,\
00,00,00,6c,02,00,00,c8,00,00,00,e0,01,00,00,c8,00,00,00,1e,00,00,00,0a,00,\
00,00,14,00,00,00,0a,00,00,00,05,00,00,00,54,00,00,00,0b,00,00,00,00,00,00,\
00,4c,04,00,00,28,00,00,00,00,00,00,00,00,00,00,00,32,00,00,00,0a,00,00,00,\
2c,01,00,00,0a,00,00,00,01,00,00,00,4c,04,00,00,28,00,00,00,00,00,00,00,00,\
00,00,00,32,00,00,00,0a,00,00,00,2c,01,00,00,0a,00,00,00,01,00,00,00,24,00,\
00,00,03,00,00,00,00,00,00,00,00,00,f4,01,00,00,00,00,00,00,14,00,00,00,d0,\
07,00,00,00,00,00,00,00,00,fc,00,00,00,04,00,00,00,00,00,00,00,0a,00,00,00,\
32,00,00,00,c8,00,00,00,04,00,00,00,06,00,00,00,64,00,00,00,05,00,00,00,00,\
00,00,00,00,00,00,00,00,00,00,00,ff,ff,ff,ff,ff,ff,ff,ff,01,00,00,00,90,01,\
00,00,c8,00,00,00,00,00,00,00,01,00,00,00,02,00,00,00,03,00,00,00,04,00,00,\
00,09,00,00,00,00,00,00,00,2a,2a,39,00,00,00,00,00,00,00,00,00,00,00,00,00,\
23,23,39,00,00,00,00,00,00,00,00,00,00,00,00,00,0a,00,00,00,32,00,00,00,c8,\
00,00,00,04,00,00,00,06,00,00,00,64,00,00,00,05,00,00,00,00,00,00,00,00,00,\
00,00,00,00,00,00,ff,ff,ff,ff,ff,ff,ff,ff,01,00,00,00,90,01,00,00,c8,00,00,\
00,00,00,00,00,01,00,00,00,02,00,00,00,03,00,00,00,04,00,00,00,09,00,00,00,\
00,00,00,00,2a,2a,39,00,00,00,00,00,00,00,00,00,00,00,00,00,23,23,39,00,00,\
00,00,00,00,00,00,00,00,00,00,00,4c,01,00,00,06,00,00,00,00,00,00,00,4e,45,\
43,20,50,42,58,2f,4b,54,53,00,cd,cd,cd,cd,cd,cd,cd,cd,cd,cd,cd,cd,cd,cd,cd,\
cd,cd,cd,cd,cd,58,00,cd,cd,cd,cd,cd,cd,cd,cd,cd,cd,cd,cd,cd,cd,58,00,cd,cd,\
cd,cd,cd,cd,cd,cd,cd,cd,cd,cd,cd,cd,58,00,cd,cd,cd,cd,cd,cd,cd,cd,cd,cd,cd,\
cd,cd,cd,58,00,cd,cd,cd,cd,cd,cd,cd,cd,cd,cd,cd,cd,cd,cd,00,cd,cd,cd,cd,cd,\
cd,cd,cd,cd,cd,cd,cd,cd,cd,cd,00,cd,cd,cd,cd,cd,cd,cd,cd,cd,cd,cd,cd,cd,cd,\
cd,58,00,cd,cd,cd,cd,cd,cd,cd,cd,cd,cd,cd,cd,cd,cd,58,00,cd,cd,cd,cd,cd,cd,\
cd,cd,cd,cd,cd,cd,cd,cd,58,00,cd,cd,cd,cd,cd,cd,cd,cd,cd,cd,cd,cd,cd,cd,00,\
cd,cd,cd,cd,cd,cd,cd,cd,cd,cd,cd,cd,cd,cd,cd,26,00,cd,cd,cd,cd,cd,cd,cd,cd,\
cd,cd,cd,cd,cd,cd,00,cd,cd,cd,cd,cd,cd,cd,cd,cd,cd,cd,cd,cd,cd,cd,00,cd,cd,\
cd,cd,cd,cd,cd,cd,cd,cd,cd,cd,cd,cd,cd,00,cd,cd,cd,cd,cd,cd,cd,cd,cd,cd,cd,\
cd,cd,cd,cd,00,cd,cd,cd,cd,cd,cd,cd,cd,cd,cd,cd,cd,cd,cd,cd,00,cd,cd,cd,cd,\
cd,cd,cd,cd,cd,cd,cd,cd,cd,cd,cd,00,cd,cd,cd,cd,cd,cd,cd,cd,cd,cd,cd,cd,cd,\
[HKEY_LOCAL_MACHINE\SOFTWARE\Dialogic\SystemRelease 4.x\ConfigInfo\TAPI\PbxDB]
"Main list"=hex:01,00,00,00,50,61,6e,61,73,6f,6e,69,63,20,4b,58,54,2d,36,31,36,\
30,00,00,00,00,00,00,00,00,00,00,00,00,00,00,37,31,78,23,00,00,00,00,00,00,\
00,00,00,00,00,00,37,30,23,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\
00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\
00,00,37,34,31,23,00,00,00,00,00,00,00,00,00,00,00,00,21,00,00,00,00,00,00,\
00,00,00,00,00,00,00,00,00,21,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\
00,00,00,00,00,00,00,00,00,00,00,00,36,31,38,2c,30,00,00,00,00,00,00,00,00,\
00,00,00,01,00,00,00,4e,45,43,20,50,42,58,2f,4b,54,53,00,00,00,00,00,00,00,\
00,00,00,00,00,00,00,00,00,00,00,00,00,00,2a,2a,35,00,00,00,00,00,00,00,00,\
00,00,00,00,00,23,23,35,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\
00,00,00,34,33,00,00,00,00,00,00,00,00,00,00,00,00,00,00,34,34,00,00,00,00,\
00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,21,00,00,00,00,00,00,00,\
00,00,00,00,00,00,00,00,21,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\
00,00
"Defaults"=hex:01,00,00,00,58,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\
00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,58,00,00,00,00,00,00,00,00,00,\
00,00,00,00,00,00,58,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,58,00,00,\
00,00,00,00,00,00,00,00,00,00,00,00,00,58,00,00,00,00,00,00,00,00,00,00,00,\
00,00,00,00,58,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,58,00,00,00,00,\
00,00,00,00,00,00,00,00,00,00,00,58,00,00,00,00,00,00,00,00,00,00,00,00,00,\
00,00,58,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\
00,00,00,00,00,00,00,00,00,00,00,00,00,00,58,00,00,00,00,00,00,00,00,00,00,\
00,00,00,00,00,02,00,00,00,50,61,6e,61,73,6f,6e,69,63,20,4b,58,54,2d,36,31,\
36,30,00,00,00,00,00,00,00,00,00,00,00,00,00,00,37,31,78,23,00,00,00,00,00,\
00,00,00,00,00,00,00,37,30,23,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\
00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,21,33,2c,00,\
00,00,00,00,00,00,00,00,00,00,00,00,37,34,31,23,00,00,00,00,00,00,00,00,00,\
00,00,00,21,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,21,00,00,00,00,00,\
00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,36,31,38,2c,30,00,00,00,00,00,\
00,00,00,00,00,00
[HKEY_LOCAL_MACHINE\SOFTWARE\Dialogic\SystemRelease 4.x\PBXpert]
"Disconnect Tone"=""
"TSF Download File"=""
"TSF File Support"=""
Looked through the list and the only thing that is a bit different from standard Registry shows that switch is set to an ID of '10' instead of the usual 0 or 1 that most people set their 'Card ID' selector switched on the spine of the card to, not that this should be the cause of any problems...
I'd probably recommend speaking to the Dialogic supplier who sold you this card...
Thank you for all of your help. I'll try to get in touch with the seller, although not even Intel/Dialogic provide support for this OLD model (market 1997 on the plate). Just one more thing; I can't seem to find schematics for this card over the internet, and am not so sure about some switches on the board, could you please help me? Particularly, I need help for the jumpers located at the base of each "female" conector (pic 04), the "switch" located on one end of the card (Pic 05), and two switches located beside the "female" conectors, right beside some leds (pic 06). Pics 01 thru 03 are just for reference, so you can see the card I have, although on a sticker located on the "side" of the card (pic 03) it reads "Dialogic D/600SC 2E1 75".
Thanks for all of your help.
JM
I’d say these would be used to change the resistance of the terminations of the coax connectors - but am not sure as we’ve never really worked with the ‘Coaxial’ versions of the cards…
If these are the termination switches then these would not affect how the board is detected by the DCM.
The grey rotating switch is used to set the board ID. Just set it to 0 or 1 (each board in system should have it’s rotating board ID switch set to a different value)
and two switches located beside the "female" connectors, right beside some leds (pic 06).
I’d say these would be used to place lines into ‘loopback’ mode – these would not affect how the board is detected by the DCM.
Just more on pic04 - given that each coax connector seems to have it’s own switch I'd say it's a safe bet these switches would not affect how the board is detected by the DCM.
Edited by SupportTeam
Thank you so much for all of your help....you've been more helpful than Intel/dialogic to this point.
Best regards, and a great new year.
JM
