Guest Guest Report post Posted 10/20/2004 12:10 AM Hello All, Has anyone created a screen pop with your application, if so please explain how it was done. Thanks for your help. Share this post Link to post
SupportTeam Report post Posted 10/20/2004 12:18 AM From: http://www.voiceguide.com/vghelp/html/modR...dRunProgram.htm : Example 4: Send a message to another computer, alerting a particular user of an event. eg. when the caller on the VoiceGuide system is about to be transferred to their extension. Windows NT/2000/XP : Can use the NET SEND command (type "net help send" for full command syntax) : net send someusername "VG call from $RV_CIDNUMBER" Windows 95/98/ME : need to use a 3rd party message product like Vypress Messenger or RealPopup. Is this what you want or did you have something else in mind? Share this post Link to post
Guest Guest Report post Posted 10/20/2004 12:31 AM Thanks for your quick response, but what I had in mind was for the caller's information to appear on my agent's computer. Something like a CTI interface. Share this post Link to post
SupportTeam Report post Posted 10/20/2004 07:22 AM Would this callers information be retrieved from your database using the incoming call's CallerID number? If yes then you should be retrieving this info from a database before sending the message containing the required info to the agents computer... Share this post Link to post
Guest Guest Report post Posted 10/20/2004 02:38 PM The answer is yes, after that information has been retrieved from the database how do I dispaly that information on the agent's screen? Please help. Share this post Link to post
SupportTeam Report post Posted 10/20/2004 08:21 PM The simplest was to display information on agents screen is as mentioned in the first response - use the NET SEND command or Vypress Messenger or RealPopup etc... You can also get a programmer to write your own popup application... Share this post Link to post
Guest Guest Report post Posted 10/21/2004 12:47 AM If I want to write my own popup application, do you know where to start or do you know of a book I could read to show me how it is done? Thanks. Share this post Link to post
SupportTeam Report post Posted 10/21/2004 06:00 AM Popup is just a simple instant messaging application - sending a message from one computer (VG) to another (Agent). Don't know of any particular book - but you should probably read up on TCP/IP sockets. Share this post Link to post
