Email Forwarding
I tried to use the email forwarding feature of VG 4.9 and install the patch VGMGR but still have this error below. The error is the same whether you select the simple mapi or smtp server. From the VmailManager, I configure one mailbox to forward the message to an email. Note from this PC I can send/receive mail using outlook express. The smtp server was tested with an ip address or host name but still same problem.
80237 5 RVreplace start: [Voicemail received from $RV_CIDNAME, $RV_CIDNUMBER at $RV_HOUR:$RV_MINUTE $RV_DATE/$RV_MONTH]
80297 5 RVreplace end: [Voicemail received from , at 18:31 29/4]
80307 5 Queue Voicemail=>Email forward: rico@yahoo.com
80317 5 HangupCall called from [srvm]
80327 5 Hanging up call...
80327 5 PlaySoundStop ok
80357 5 fnHangupCall end
80397 5 tapie linedevstate 2048 0 0
80407 5 tapie callstate IDLE 66034 0 0
80407 5 WorkingMode@Idle=
80417 5 set EV_TIMEOUT_TIMETOREINITLINE 2
80427 5 tapi Reply 65948 0
81399 5 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
81399 5 ReinitTelephony due to IDLE start
81409 5 tapic lineDeallocateCall(MainCall:66034) 0
81649 5 lineOpen(5) => 0
81649 5 Waiting for a call...
81659 5 lineOpen(5)LineHandle=65931
85375 0 SendEmailMapi 2
85385 0 SendEmailMapi msm about to call
85395 0 SendEmailMapi msm returned
85395 5 Send Email Error: -2147467259 [unknown Error]
To use the MAPI method you need to have Outlook or Exchange running at the same time (Outlook Express will not work - you need Outlook itself).
Can you post a trace of what happens on your system when you try to send email using SMTP?
Okay I understand I need a full outlook product.
For the use of SMTP server option, I got the problem were. You need to specify the port number, i.e. 192.168.0.1:25
I'm not sure if current version supports specifying a special port number - I think it will work only with a default port number (do you have any problems when using the default SMTP port number?)
I'll request that v4.9.1 supports the specifying of an alternative SMTP port using the ":" notation as per your example.
It works also without specifying the port number but I need to restart VG.
I also notice that when the smtp connection is not successful, VG does not retry the connection to forward the email again. Sometimes when smtp fails it says "host not found" but the connectivity is okay. If I issue continous ping to the smtp server, the smtp connection is 100% successful so far in my testing for around 10 messages.
I suggest that in the next version you include in the smtp parameters that are configurable the port number, retry count and timeout.
In addition, the vmemailforwardbody template is being truncated even though you edit this text file template. It limits the text to 64 bytes
In 4.9.1 the email sender is completely re-written. I think that pretty much all the issues you raise have been raised over here and will be addressed in that new version.
